- Today
looks like i have to open my steering column next winter, i think i have play on lower splines, upper bearing might have also something going on. anyone has good link for that kind of operation on fresh memory?
Seppi72? what power window stuff / kit did you use?
That is an interesting master cylinder set-up. I haven't seen that before. I assume that you will be running all new brake lines. -
Cut out the indented areas & fabricate new sheetmetal to fill the holes. Personally I like the smooth look. 😎
- Yesterday
It's not uncommon. I added a terminal post near the battery for a few things. If I had a bunch I'd probably just install an auxiliary fuse box. Otherwise you have a bunch of inline fuses to take care of. There are many out there but a trip to the salvage yard would probably find one that is weatherproof and high quality. Depends on where you want it mounted. Looks like I'm on the same page as jhm, who replied as I was writing.
It can be confusing when talking about technical areas vs car model areas, but we do have the "Ignition and Electrical" sub-forum here: https://forums.hybridz.org/forum/16-ignition-and-electrical/. Yes, I think it's fairly common to add new circuits/etc to these old cars. I've done it to the last couple of my cars to simplify/improve the electrical capabilities over the stock harness. I've always used off-the-shelf breakers, relays, fuse panels, switches; but there are a bunch of pre-built kits that are available through numerous vendors. I like to use marine hardware if I can find it; as it's typically extra beefy and durable. Good luck with it; and please be sure to post your results once completed!!
There doesn't seem to be an electrical forum on HybridZ so I thought I'd put this in the model-specific one. I am in the process of adding several updated accessories to my original-owner S30. In particular: power windows, Vintage Air A/C system and RetroSound Motor 4 radio with quad speakers. I've already installed Dave Irwin's headlight relay system to take that load off the combo switch. I have a rebuilt 280ZX alternator from MSA to supply power once the Optima red top kicks things off. With all these new accessories, it occurs to me that perhaps I don't want to be chopping into the existing dash harness wires to provide them with power. So I'm thinking about installing positive and negative busbars on the interior firewall that I can hook up to as needed. Is this a wise idea? Has anyone ever done this mod and, if so, what parts did you use and where did you locate them?
Got the front coilovers and the dual master cylinder assembly on today. Still too hot out for working on the car here, I can’t wait until it cools down. A few challenges with each, but got it on right. Was hoping to start tearing down the rear, but I’ll give that a go next weekend. -
Nice, I could see building a dart block sometime down the road. Just a cam and twisted wedge heads on the 302 for this build for now. -
Just some quick updates, after finishing chassis preparations and dropping off the shell for restoration last month I've been organizing my garage and have finally got things in a reasonable enough state to continue work. For the turbo build, the plan is to refabricate all fluid lines as SS hardlines so I've set the engine/transmission to ensure I get all of the angles for drainage and thermal siphon correct. It's really nice to be doing all of this work fully accessible, but I'm going to attempt to ensure the routing I fabricate can be serviced back in the car as well. Also for the driveline, I saw on IG someone had used the same CD bellhousing from Derek which locked up on their clutch when assembled. So I've put in the OSG twin plate and will check if the bellhousing needs any clearancing for the rotating assembly.
New to forum - potentially a Z owner soon!
jhm replied to Zappingbaby's topic in S30 Series - 240z, 260z, 280z
First off, welcome to the forum and good luck in your search for a Z car. In our "FAQ" section, you'll find hundreds of excellent discussions on common issues, modifications and repairs on the Datsun/Nissan Z cars. Without knowing the asking price, your mechanical abilities, and your ultimate plans for the car....here are a couple of things to look for: - Inspect the floor pans topside and underside, the frame rails, the rocker panels, and the inner fenders for rust/damage/shoddy repairs/fiberglass/bondo. These are some of the areas most often rotted out and/or poorly repaired. If the car really has "all new metal", it should be apparent via inspection. - Are you comfortable buying a built engine just based on listening to it run for a few minutes? If it smokes heavily, has significant clatter and/or rattle in the valvetrain; those are just a couple of signs that the internals are suffering. Visually inspect the oil, trans fluid, coolant, and brake fluid to ensure they all look clean, fresh, and uncontaminated. The car looks neat from those couple of photos; but unfortunately, people often buy someone else's unused "toy" only to find that it doesn't live up to their expectations for one reason or another. Do as much research on old Z cars as possible before buying anything, to ensure that you don't fall into this trap. Looking forward to you joining us as another proud and happy Z owner! -
The dyno chart for that was from my old 331 stroker: Stock Roller Block (4.030" bore) Eagle 3.25" stroker crank and rods Mahle 4.030 Pistons Custom Hydraulic roller cam (.571" lift) AFR 185 heads 1.75 Long Tube headers 30# injectors I scattered that engine at Daytona My new engine is a 347. Dart SHP Block (4.125 bore) Scat 3.25" stroke forged crank and H-Beam rods Custom Hydraulic roller cam (.625" lift) AFR 185 heads Long Tube headers 42# injectors I use Megasquirt MSPNP 2 to tune both engines. -
I will do this -eventually. I did pull the center ITB and tested the flow past the butterfly using a vacuum cleaner . Not sure thats an appropriate testing method but the sync tool showed same flow between the two ports. So maybe my issue with 4 is a porting of that intake runner at low flow. At this point I did another valve adjustment -cold- and I did end up finding small adjustments needed, so we will see if that changes anything. Meanwhile I am going to use injector trim to even things up the best I can before Zcon.
I have had a lot of problems with the throttle cable and related parts. a late night job came up with an extremely basic solution for cable hookup at the carb....I made a bracket and got a brass cable stop at Auto Zone, and the gas pedal bottom edge hitting the floor keeping full range from happening were the culprits. FIXED.
Keep in mind for a 240Z it is rear wheel drive so to me the best RB swap would be an 2 WD RB 30, or a 2WD RB25. For a more demanding big HP version of those the pan must be rear sump, larger capacity, have the oil pickup designed to match the 2WD RB30 or 2WD RB25 at a minimum. I literally spent days searching the web and so did Robbie at RIPS Racing. I sent him so many links and none of them had what he knows is needed to keep the RB engine reliable, especially when it will be putting down big horsepower numbers. The JHK from UP Garage had one their website that it was for a 2WD RB20 or 25 block which is the same as a 2WD RB30 but that was not as claimed; If I had used that pan it would have severely damaged my expensive engine. Thus plan on a custom pan if you want the engine to last... - Last week
FastFloridian replied to Zappingbaby's topic in S30 Series - 240z, 260z, 280z
Looks good and sounds good. Wouldn’t buy without a test drive though, he’ll start it though right? Hopefully just fluids and new tires and you should be good to go. Good luck! -
Always liked the early Zs especially a 240z a this guy came up for sale recently - seeing it in person tomorrow so I'll have a better idea then - apparently being sold because the guy is retiring and getting rid of all his toys Pros: 1. Bodywork done - "12k, 1 year spent at body shop to cut out all rust and install new metal" 2. Modifications: Small block chev. 600 lift Roller cam, Gold roller rockers,202 aluminum heads, MSD ignition&box, H.P electric full pump, 150 shot NOS system (Not used). Purge lighting built 700R Trans&Convertor, B.M. Shifter, I.R.S. 3.9 Gears Custom built half shafts (Good for 600HP), New weather stripping/INT/Roll Bar. 3. Looks on pictures that it's done right - looks like a very clean install Con: 1. Sat for 10 years since 2015, 3000km after the build (Drove the F-type jag he got instead). Apparently just started couple of times a year to keep things "lubed". Recommends all fluids changed, brakes bled etc before driving - so I won't get to test drive it and make sure everything's working properly before I buy it. Looking for recommendations on what to look out for, and key things to prep to get it ready to get back on the road.
Thanks guys. Making me feel confident in my set up. @74_5.0L_Z good info and impressive dyno on old engine, I’m hoping for something close when I’m done. What is your new engine, still a ford 302? Slight change to my diff setup. Didn’t do enough homework, but I think it’s actually going to come out better, just by dumb luck. I didn’t realize auto vs manual was a different sized pumkin on the 370Z. I bought an auto diff, and the wavetrac doesn’t fit an auto. Good news is I really wanted the 3.3 gearing and that only fits in the auto pumpkin (dumb luck). An OS Giken diff fits with the 3.3 gearing in an auto diff, so it looks like I’m going that route. A little more money, but the OS Giken is better for a track car anyway. -
Zappingbaby joined the community
With a good 5th gear, overdrive is wonderful... I have the mythical R200 with 3.36 rear gear. The transmission is a T5 with the G-Force Shafts and gears 1 through 4. I run short tires Avon 23 /10.5-15 on all four corners. When I first installed the G-Force gears I was only auto crossing the car, and really only used 2nd gear. When I started doing track days (Daytona and Sebring), I quickly discovered that 5th gear was horrible. With the stock gears, 5th wasn't optimal but wasn't too terrible (3.35, 1.94, 1.44, 1.0, .67). When I changed to the G-Force Gears, 1st gear was improved but 5th gear sucked (2.95, 1.95, 1.33, 1.0, .58) First time at Daytona, I was redlining 4th gear by the time I came off the banking onto the front and rear straights, and the .58 5th gear would drop my rpms and torque too much to be useful. The .58 5th gear was horrible, so I pulled the transmission and took it to Astro Performance in Tavares, Fl and had them install the A5 5th gear (0.81). The difference was night and day. Overdrive went from a total buzz kill to being my Warp Drive... If you get a transmission with a good 5th gear (TKX with .81 5th), then you'll be fine. This is what the gear spread (speed versus rpm) looks like: Here is what a full acceleration run looks like if you assume 0.25 second shifts: The above uses numbers from my old dyno chart and the following inputs: Dyno graph from my old engine (my new engine makes more power and torque): -
clarkspeed replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
The tranny/rear is a trade off. You really dont want to shift to 5th at 120+mph. The wind resistance will drop you 10+ mph and if you are not in power band you will not accelerate much after that. Not good for Daytona. Rule of thumb is the more peaky your engine is, the closer tranny ratios you need to keep it in power band. The other rule is select gearing to be well into power band or just over in top gear, top speed. Depending on engine you may need a different rear/and or tire ratio to run Daytona, it is different than other tracks. Many club racers run the final 1000-2000 ft at redline, but that can be risky. -
ideas on how to get this rusty bolt out
NewZed replied to adsdsasdasdasda's topic in S130 Series - 280ZX
Seems like you might need a better wrench. A six point box end would be best. 12 mm I believe. p.s. forgot to mention the original impact wrench. Tighten up the wrench on the nut. Then hit it with a hammer. p.s. 2 - it will take a lot of heat to get the flange hot enough to hurt the seal. A torch on the nut should help. Doesn't have to be red hot. https://www.lowes.com/pd/Capri-Tools-12mm-WaveDrive-Pro-Combination-Wrench-for-Regular-and-Rounded-Bolts/5001577325 -
tube80z replied to adsdsasdasdasda's topic in S130 Series - 280ZX
I have a set of extractor wrenches that come in handy for things like this. Here's a link https://olsatools.com/products/7pc-offset-extractor-wrench-set?variant=41307851161651&country=US¤cy=USD. Cary
Who's Online 2 Members, 0 Anonymous, 368 Guests (See full list)
