    33122
    5167
    MichaelAMcDaniel
    MichaelAMcDaniel
  1. Today
  2. It's not a straight forward plug and play for any car. You have to set your TDC offset angle before it will start up. It's easy to do and there's a write up on how to do it on Haltech's site. https://support.haltech.com/portal/en/kb/articles/calibrating-ignition-timing-7-4-2020
  3. Yesterday
  4. By "tightened up" do you mean you just cranked down on the nut? If your front bearings need to be replaced that's one thing, but you should definitely not just tighten them down. Did you follow the FSM procedures for proper torque on the front hubs? It's way less than you would expect. The nut gets torqued to 20ft lbs then *backed off by 60 degrees. I had a front wheel bearing fail pretty catastrophically last summer and the race bored out the hub. Most likely cause was that it was just too tight. initially and failed prematurely then seized suddenly and basically friction welded itself.
  5. The reason for replacing them is not for quality, its for fitment. I'm pretty sure Viking offers a coilover long enough to fit with my SLA design but I know the Penske one will work. I just need to check for interference in the UCA throughout travel. Lol well if you wanna save a few pennies on the front kit from AE let me know, I'm going to get rid of mine. That last part is probably true, but more tie rod ends means more maintenance and more failure modes. Dirt and debris entering the ball joint and load fatigue both contribute to this. I've spoke to Viking and they were very helpful. A little confused on the choice to use the C203 shock with the motion ratios given to me by Apex. From their reaction and the assessments from Rob Fuller and Mike Maier I'm standing by my opinion that 3.2" of shock travel is simply not enough.
  6. Their overall suspension including the front to me is good. It has evolved to the current version which has been updated at least a couple of times. Instead of trying to design your own you might consider just upgrading the Viking to the quad adjustable which is what I am doing. The Viking with their front can work great but you just have to be sure to know roughly what height you want, the tire/wheel height, etc. To me it is not a limitation on travel but they just have a limitation on the range of changing the ride height but once you know the desired midpoint that is a mute issue. I am getting their current Track Attack but am ordering them with the upgraded Viking 4 way adjustable Berserker coil overs so that I can get the ability to please my wife when not racing and high speed settings when needed with their independent high and low speed rebound and compression system. Once you know your desired midpoint then the Viking will give you around 3 to 3.5" up and down height adjustment which is plenty and your not likely going to change once you find your ideal level. Many big HP Corvettes, and other street/track cars are very happy with the Viking Quad coil overs. The Apex extra settings to me do not make it weaker but rather just complicate it for owners as those settings would never ever be used so you are just creating more chances for DIY people to get frustrated. Also as Ben280 suggested Viking tech support is very knowledgeable and can help you choose the right version. Again I do not believe there is any issue of bottoming or travel limits. It is just that the Viking gives you plenty of adjustability but the design is not a standard nono tube coil over so you just need to know the mid point of the height you want the car to be and order the right length to match. It is all of their adjustability which creates this difference compare to a mono tube where you do not have all of those knobs to adjust things.
  7. Last week
  8. I see, it seems AE just sent me 4 identical C203 shocks from Viking and said have at it. I won't be using them anyway, the entire front suspension kit is pretty much a wash for me at this point. Going to just resell it for cheap once I finish my own design. I'll be either using JRi modular shocks that are 21.7" extended or Penske 24.7" extended. I agree, there's too much usage of many tie rod ends, from an engineering perspective it just adds more and more failure modes, more and more maintenance. I'll edit this post and link my front SLA thread.
  9. I was asking because on the front of the Track Attack the Viking coil over set up needs to be ordered based on the wheel/tire height and how you want it to sit as the front setup due to the Viking design has limited travel for adjusting the height. The Viking is not like a standard coil over where you have all of the adjustability to change the perch height; it is a good design but you need to get the right option. Apex does not tell you that. The rear is fine as there is adjustability with the cantilever ability to have adjustment for height. Also be careful as that suspension has way too many unnecessary adjustments that would never be used so you can get into trouble easily on the setup...
  10. Hi @Mike280zx, if you don't get answers on this forum, i'd advise to post on https://www.msextra.com/forums/index.php Regards and good luck with your project.
  11. These are pullers and I will have them set up to come on with AC . Megasquirt 3X just came out with firmware to control with PW . I think the only option is fans at full speed with AC . I have a buddy that said he can make a controller that will do a better job . I have no idea what CFM these fans are except they are 300 watts and they are SPAL fans OEM
  12. I'm in Florida and I use 2 smaller fans in puller config an a single larger fan in front of the condenser in pusher mode that comes on with the AC clutch. Sitting still you really need air passing through that condenser. I have the radiator fans controlled by my Megasquirt.
  13. While waiting for my stacks to get printed I jumped on this other project . I ordered AC but my cooling system wasn’t up for the task. My 15” Mishimoto with no should struggles to keep up in traffic . Watched a couple of YouTube videos and decided to step up to some brushless fans from a Chevy Volt . I went with them because they look like they would fit the radiator . It’s TIGHT -even after carving on it for a day . It’s been a learning curve on how I was going to power and control them . Hope this works !
  14. About 800 miles later. Running smooth. Temps with the new e fans were steady all the way. Only time they climbed a *little* was on very long uphill stretches. But it's to be expected when the turbo is getting loaded more and the return coolant line from the turbo goes straight to the thermostat. Overall very smooth, and as usual the long trip gave me a variety of small things to start looking at. Definitely want to update the mounting on the exhaust, just a bit too much movement and occasionally tapping the back and making some noise. New mounting method and the bigger muffler will make it downright comfortable on long drives.
  15. Nice, cool to see you didn’t waste your time making that video. Probably running 325s on the rear, and maybe even all around (still a lot of time before I need to decide on that), I’ll need those wide fenders to fit all that rubber.
  16. I just received the kit on Friday, the front kit will likely stay uninstalled. Not sure what you mean by "asking hypothetically", I'm designing a new front SLA suspension that will allow a full length coilover to mount to the LCA.
  17. Hi all, hoping for some clarification on a couple items regarding upgrading from fuel only to fuel & spark (apologies if they seem to be basic/simple questions) Currently I am using MS2 V3.0 with NA Distributor and coil negative tach input. I have installed a turbo distributor with the DIY Optical Trigger Wheel and am following the instructions DIY has online: https://www.diyautotune.com/support/technical-articles/install/nissan-datsun/megasquirt-your-280zx-turbo/ https://www.diyautotune.com/support/technical-articles/hardware/nissan-trigger-disc/ I am making all the necessary changes in the ECU as per the Trigger Wheel document (like cutting out some caps/resistors) as well will add the 1k resistor to S12 & TachSelect in the ECU versus under the hood or at the distributor harness pin 24 (I believe this would eliminate the need for the 1k resistor connecting 12v to the Pin 24 wire noted in the diagram) Currently I have the shielded wire from Pin 24 going to the coil negative. With the upgrade Pin 24 wire should move to the distributor as the MS Trigger and pin 36 wire needs to be added as the ignition trigger to the coil negative. My questions.. - should the Pin 24 wire remain as the heavy shielded wire? ...spidey sense tells me the negative coil wire should be shielded not the one to the distributor. If not, what gauge wire is recommended for Pin 36 to coil negative? - should the 12v feed to the distributor be on a separate fuse/circuit or can I tap off the coil positive for this (seems like that is the way the NA Distributor module gets its 12v feed). -finally the last sentence in Optical Wheel "Wiring" section says "The primary trigger always wires to pin 24 on the main board DB37. For MS2, the second trigger wires to pin 3 on the main board DB37, or pin 7 on the DB15 if using the optional V3.57 DB15 input".....what the hell does this mean regarding pin3??? (that is a ground I believe) Thanks in advance to anyone helping me with this upgrade.
  18. Just randomly reading through some build threads on here and see my video linked lol Those are some massively wide rear quarters you're using @FastFloridian. Crazy stuff.
  19. pulled from heat soak to almost midrange in under 10 minutes, sitting still, no additional airflow. SPAL fans are #1. Yes, it is a 3 core aluminum radiator, and a 160 thermostat, but it got heat soaked, and my twin 10" SPAL fans pulled it back down.
  20. Final update before road tripping tomorrow. I was so bothered by the vibrations last night come back home from my niece's birthday that I decided to pull off the front diff mount and inspect. It looks like the bolt through the bushing was either loose or the upper piece of the mount was warped and didn't let the side squeeze right on the bushing. Bottom was rattling back and forth when I moved it after taking off the cross member. 3 hours worth of work later and putting the RT top mount on instead I tested and the vibrations are gone! I had to grind part of the bolt going through the bushing to pull it out because I couldn't get any leverage on the bolts going through the diff and they block each other. For a moment I thought it was placebo, so I kept finding multiple loads and speeds that it would vibrate the most at last night and got nothing. The biggest difference is the lock mechanism on the seatbelts is never rattling anymore which was a huge annoyance. TL;DR - the T3 diff mount (not the cross member itself) is probably needlessly complicated and is just too many parts stuffed into a tiny space.
  21. It's going to be good! I had to wait months for it, but it once it was ready to go shopping was very fast. Even with tariffs on entry it cost me much less than it would have from a vendor here in the US
  22. Might help your conversation to distinguish between "no signal" and "no signal showing in Tunerstudio". The first is a problem at or with the hall sensor itself, the second could be anywhere in between or at the computer.
  23. Really jealous of that diff. I probably need to do a similar thing shortly out here!
  24. I tried Poll Level and cranking and still no signal.
  25. Have you actually finished the installation of the track attack, or are just asking these questions hypothetically? I am somewhat familiar with this set and based on what I read it sounds like you have not installed it yet, is this correct?
  26. The hairlines weren't that bad, it was the handful that were going through the edge of the rotor that I was worried about. Friday marked my first return to the track in almost 2 years. Knocked off a bunch of rust, the car worked the whole time, and I made a couple changes that were impactful and improved the car. I went pretty slow, so y'all could enjoy some v8 sounds for longer than normal
  27. 07-26-2025. Okay....radiator and fans installed and working. Waiting on the Thermostat sensor probe that is on it's way. 1 bottle of Water Wetter added. click below for video: fans work.MOV
  • Who's Online   0 Members, 0 Anonymous, 595 Guests (See full list)
