- Yesterday
That's pretty much where I've ended up the last several years. I know some people prefer a staggered setup; but I really much prefer a square setup, for tire rotation and replacement. Very much enjoying this build, and the ongoing discussion in this thread! 👍👍 - Last week
Im looking for a parking brake handle & tunnel mechanism. Do you happen to have one? Ship to 46825 Pics and price please Thanks Lee
Miles started following A DETAILED REBUILD OF THE 260Z POWER BRAKE BOOSTER UNIT
Nice! Back in 2009I couldn't find a rebuilt 280z booster so I was going to buy a booster repair kit, but later figured that I might need special tools. I was able to find a rebuild shop in my city to rebuild my 280z brake booster. The shop specialized in rebuilding truck brake components.
- 1 reply
- 1
chong.sae joined the community
All the Pop up ads make me hate being here, how to stop the madness
jhm replied to MONZTER's topic in Site Support
I am about the furthest thing from a computer/IT expert, so I will leave it here for others more savvy than I to chime in with tech tips and advice for you. However, if you haven't already done so, click on the vertical row of three dots in the upper right corner of your Chrome browser window and that will open up your browser settings. There you can select your desired levels of security, privacy, etc. There's a "Settings" selection at the bottom of the pop-up menu that takes you to most of your selectable items. (Sorry if I'm telling you something you already know.) I should have also mentioned that your hardware and operating system can greatly affect web browsing speeds and response times. My wife's Apple Macbook Pro browses the web WAY faster, with fewer ads, than my Dell laptop....on which I've tried several web browsers (Chrome, Edge, Firefox, etc.) Mozilla Firefox seems to give me the best overall performance for web browsing. -
MONZTER replied to MONZTER's topic in Site Support
I figured it was necessary to keep the light on. Is it still the same as before the ads turn off with a premium membership or donation? Or are they always on no matter what? I use Chrome, so not sure what settings, do you have a page with instructions on how to set this up, membership benefits, ect? Happy to help. Thanks Jeff -
Yes, unfortunately the pop-up ads are a necessary evil. Active membership and annual donations have dropped way off, so Dan has to rely on the revenue generated by ads to keep the forum going. There are ways to control it, however, depending on which web browser you use (and the default settings you've selected within the browser.) Let me know if you'd like to merge your old account with your new account....we can usually do that fairly painlessly. PM me if you'd like to. Cheers. -
08-30-2026 ATLAS Z UPDATE: Started the day with putting some cut leather on the upholstery sections that needed to be covered. Amazing my new seat covers, have managed to have a worn spot....but it's all better now. Working in tight quarters these things happen.:) Then I went ahead and bolted the seats down in then vacuumed it all up and installed the hidden toggle switch to turn on so the car will start, my theft deterrent, and wired in the brake light switch....just running the wires over to the passenger footwell.... labeled, so I can start on that soon. I finally managed to get the last piece of the end links on the steering rack off, and then wire wheeled them down really clean, and used anti-seize and installed the Moog end links for now...I will have to adjust when I am ready to align the front wheels, but for now, a lot of progress made! The whole car is about 75% done already and it's only been a year! PICS:
I used to be a lifetime member years ago before I was away for like 10 years. Had to re-start my account since an old email was gone. So I'm no longer a life-time member, is this why I get such a ridiculous amount of pop-ups that I literally cant even read post? I hate Facebook, but its free and you can read what people post. Is there any solution, or are the ads the only thing keeping this plate alive? Thanks, I really want to be here and share content with others, but it is so frustrating. I want to do a new thread on Flow-bench testing and actual flow bench results, but its out of control. Thanks Jeff
Nope, smart idea. I’ll do that next weekend. I’ve got some shorty headers, but if I need to get a new exhaust I might go long tube. Not sure if the old exhaust clears my new fuel cell, I need to check on that. -
Have you mounted the headers to the engine while on the engine stand with the cradle in place? It will be much easier to clearance your cradle before everything is in the car. -
Made some progress on the engine cradle. I should be ready to drop the engine in and mark where to attach it to the frame. I’ll be using some angle iron to sit on the frame so the cradle will be welded to that then bolted to the frame. -
09-29-2026 ATLAS Z UPDATE: I mounted the plate I made to cover the hole on the side of the head with some stainless bolts I got, then I mounted up both front brake calipers, tied in the brake lines and zip tied the excess up. Then I went ahead and pulled the TC rods out, cleaned them up and painted them with some rustoleum gloss black, and wire wheeled up the washer plates and installed my new Urethane bushings. I normally would have gone with rubber, but the polys were half the price, so I will use them. While under there, I pulled out the cut off pieces that were the original sway bar end links, and installed the new ones I have had waiting. They are all rubber. Then I moved on to the drive shaft. Because of my trans layout, the factory e~brake tube going across the tunnel had to be cut out. This is fine, as the way I use the car I don't need it, and I can leave it in gear when parked. I suppose at a later date I could fashion up a cable to what is left on there to tie it back in.....I left a piece of the pipe about 1/2 long sticking out for just that. I then mounted up the drive shaft and got the bolts cinched down correctly. Then the problematic part of the day, the end links on the steering rack. Well they just didn't want to come off! It is obvious they haven't ever been adjusted, so I got one off and the other is soaking in PB Blaster! I have the end links I got from Z Car Depot ready to go, they are from MOOG. While under the car, I looked up and saw a world of polished piping so I took a pic! :D PICS:
- Earlier
SouthAfricanZ joined the community
Door latching mechanism issue
SouthAfricanZ replied to MikerZ's topic in S30 Series - 240z, 260z, 280z
@MikerZ I'm having the exact same issue. It seems like actuating mechanism from the door handle has jammed/bound the lock as in this video - However, even after releasing the nylon nut, pulling up on the handle mechanism with thick guage wire (besically everything to operate it manually as you did) I'm getting nowhere. What did you end up doing/destroying to release the hook? -
roadz joined the community
HustlaHeath joined the community
Mitchel0407 replied to flatout's topic in S30 Series - 240z, 260z, 280z
I got a tradition with my dad that I took over, every time we buy a new vehicle we stop at Mc Donalds on the way back and get a milkshake. This also gives us some time to look and admire our new purchase. We will probably continue this tradition this weekend as I’ll be looking at a 2015 BMW M550D touring (almost 400hp diesel station wagon) as a new daily driver. -
Solving heatsoak with a Holley 4-barrel carburetor on a stock L28
Brad-ManQ45 replied to Camaden's topic in Nissan L6 Forum
There was a discussion about wrapping exhaust vs ceramic coating vs high temp paint somewhere here. One person noted that changing from VHT Black to VHT White on a Corvair engines pushrod tubes lowered oil temps. You might try painting the bowls underneath white. You may also want to try fabricating aluminum heat shields that mount under the carb hold-down nuts instead of under the carb base. Wrapping the header or ceramic would help immensely. -
I am looking to acquire some 84-87 Z31 5 lug axle parts. I need the rear stub axles out by the wheel and inner axle flanges. I am trying to do a 5 lug conversion on my 280ZX. If anyone has these parts shoot me a message with the price! Thanks!
limezest joined the community
calZ replied to flatout's topic in S30 Series - 240z, 260z, 280z
The first ice cream trip is a great payoff for the hard work. -
08-25-2026 ATLAS Z UPDATE: I had a few minutes this morning, so I went ahead and prepped my new front brake calipers, by mounting the brake pads in and getting them ready for install. I got the calipers and pads from Z Car Depot.
I run 275/35-15 Hoosier or Avon 23x10.5-15 on all four corners. That size works pretty well and is the limit that I can run with struts and the SubtleZ body kit. If I had the SLA suspension, I would use wider wheels limited only by the body work and tire availability. I feel like 10 inch wide front wheels are perfect for these cars, but the rear could use a little more. -
There is a point of diminishing returns on tire width. It varies greatly with many factors tho so no one size fits all. Its a balance of contact patch, corner weight and suspension geometry. The double a arm front will allow for a good amount of adjustment with caster, and KPI that we can't get easily with struts. -
Good info, thanks. That’s certainly my plan, but good to know it’s the right plan and has some good reasons behind it. I just knew a positive offset was better for tracking, just not necessarily why. I may have asked before but what size tires do you run and if you could, would you go any wider? I was thinking of 305s for the tires and wheel width of 11”, maybe even wider. Still plenty of time before I’m ready for wheels, but starting think about it a little now. -
Camaden replied to Camaden's topic in Nissan L6 Forum
I'll start measuring temps. That'll give me a better idea of what the issue is. I'll try insulating the float bowls too, thanks for the tips. -
NewZed replied to Camaden's topic in Nissan L6 Forum
I would even consider shielding the float bowls. Wrap the bowls with some heat tape maybe. They're sticking out there in the convection stream, the hot air transfers its heat to them as it passes by. Lots of area to absorb heat. The way to approach is to ask how the heat gets there. Is it coming through the intake manifold metal, then the carb body, then to the bowls? Or is it coming through radiation or air flow (convection)? Conduction (metal transfer), radiation (line of sight), or convection (hot air flow). Each mode has a different solution. -
I do have a heatshield between the headers and intake manifold, but it's probably not great. Had to cobble something to gether with wire and some pieces of aluminum sheet I had laying around since I haven't seen anyone making a heatshield that fits this setup here. It's probably better than nothing, but it doesn't seem to help significantly. I havent measured intake manifold temperatures to see if it changed them at all. I'm considering wrapping or ceramic coating the headers to see if that helps a bit more. My radiator fan clutch is bypassed, so it's always on and providing a breeze through the engine bay. I could set try to set it or another fan up to run for a while when the car is off I guess. That might help
Who's Online 0 Members, 0 Anonymous, 269 Guests (See full list)
