- Last week
Looking at your pictures make sure that the oil pickup is parallel to the oil pan bottom. With it angled like that its going to be a ways away from the bottom of the pan.
Im using the stock maxima oil pan. The diesel maxima pan should work also. It actually has more volume i believe and has a place to drain your turbo into also!!!
If your extending your oil pickup you can not drill the front dipstick tube hole. it goes straight through the oil galley. I was able to do it as i plugged mine first. You will have to make a dip stick tube holder in your oil pan. I drilled my block as Im way better at machining than i am at welding. What are you working on that you are front sump?
Something is not right if your getting knock out of boost. Have you verified timing with a timing light and not just gone off what the computer says it is? or your running way lean.
I believe the offset is zero.
03-25-2026 ATLAS Z UPDATE: I got some of the fittings in I need for my crankcase pressure to catch can to intake setup. Also tall of my carbon fiber panels have been cut, final polishing on roof section then ready to ship to me and bond them on! Then make the borders shiny!
Damian_GTX joined the community
You caught my screw up. Unfortunately that oil pan doesn’t work, gonna have to replace it 😤. I ordered, basically the same thing, but a rear sump. Hopefully I’ll get it on this weekend. I went with a moroso baffled oil pan. I should be able to make this one clear the subframe. -
What oil pan are you using? You'll have to set the motor back really far to get a front sump pan behind the front crossmember. I'm using an Aviaid Mangusta pan on mine and I needed a custom crossmember to get the front sump to clear. -
PART 9- ROLL BAR WELDED IN AND FABRICATING SQUARE TUBING INTERMEDIATE FRAME Thing are really moving along now. The Roll BAR is welded in and a frame connecting the existing front and rear frame rails is being fabricated. Excellent metal fabrication is demonstrated. i can for see that the original Transmission Tunnel will have to be removed to provide clearance for the Mercedes transmission. e Firewall probably have to be widen also. -
My efforts to get this other Z back running have expanded quite a bit beyond the rebuild of the 3.0 stroker motor. At the moment, I am working on repairing some rust in the floor panels. I have been watching a number of "Make It Kustom" videos on Youtube by Carl Fisher. In one of them, he creates some forms out of 3/8" plate to create a "hammer formed" part. Additionally, he uses a hydraulic press to "stamp" a recess into the battery tray he is making in the video. The rust in my floors on this car is not extensive. It is generally in the area of the large oval depression in the floor panel (on both sides of the car). Yesterday, I spent a few hours cutting out and grinding/filing on part of the form I plan to use to replicate the depression. On the right side floor, I only need a small portion of it. On the left side, I will attempt to make a full piece to replace the depression. I've never done anything with forms likes this, so we'll see how it goes. I will be using my 12 ton press because it is what I have to attempt to make the replacement part. But, I have been watching facebook for a suitable upgrade, perhaps a 30 to 45 ton press.
03-21-2026 ATLAS Z UPDATE: After painting the intercooler piping silver yesterday, I didn't think it had enough "pop" to it, so today I I put a couple of coats of chrome spray over the top....I like it much better. I was able to get all the intercooling pipes installed. Then I went ahead and vacuumed out the car, and installed the carpets from Newark Auto I got on eBay. some carpeted pieces I am not installing, as I will leave the vinyl 260Z pieces that the car has from the factory. I dropped in my heel plates from Skillard and then mounted my dashboard and then set the console in to see what modifications would be necessary. The pics of the shift knob on the steel show that I am ready to hold it to the shifter, mark it and then cut out a shifter so that the shift knob is right where I want it. PICS!
- Earlier
02-20-2026 ATLAS Z UPDATE: Today I got my intercooled pipes back from being welded up, and I decided to see how they would look painted. I used the Duplicolor silver engine block paint. I also was able to finally get the right length of hose for the lower radiator hookup. When time comes, I will tighten it up and assemble the intercooler piping! PICS.
Progress on my insane VQ35HR 240Z project
calZ replied to markrolston@mac.com's topic in Nissan V6 Forum
One of the best builds ever on the site. I'll be sad if this is the final update, but I have a feeling it won't be. There's always something to fix or change! -
It's been one of the busiest years of my life but the turbo build continues in the background. Since the last update, the circuitry has been mapped out so I visited the chassis to start installing the mil-spec bulkhead and radlok connectors. Generally, the plan is to run Haltech for ignition control, knock detection, etc. and ditch all piggyback systems which I'll probably recycle on another ongoing turbo project. Only the best for the Z 😉. The resto shop is doing a fantastic job with great attention to the details. They've installed the sweet Capital Metal Works full length framerails and started massaging bent OEM sheetmetal back into shape, along with continuing to metalwork other detailed aspects of the chassis.
Zetsaz replied to markrolston@mac.com's topic in Nissan V6 Forum
Always an inspiration Mark! A lot of what you do is well out of my abilities, but seeing your project still being refined after so many years keeps me motivated on mine. -
churchData2015 changed their profile photo
So I had moved and left my car behind, but now that I'm back I did some more testing. I was unsure how accurate the knock sensors were as I was seing knock retard even when the motor was not in boost. Turns out they are 100% accurate. I put in some 104 octane and gave the car a spin. 99% of knock retard was gone. It is now quite obvious why people blow these motors so easily. I was getting knock retard throughout the 7psi (absolute PSI so 7 away from being "in boost") band from around the 3.6K+ RPM when using just 93 octane. I was getting up to 13 degrees timing pulled at higher boost. With the high octane it was only pulling timing at 14PSI boost, with a resulting spark advance of 20degrees. It will spin tires in 1-4th gear easily.
Thanks guys. I got the timing cover and water pump on, ordered a windage tray then I can get the oil pan on and start working on the top. Mounted the fuel regulator started making some fuel lines. Need to figure out filter placement then I can cut and finish the rest of the lines. I’m using black for fuel, red for return and blue for vent. -
FastFloridian replied to flatout's topic in S30 Series - 240z, 260z, 280z
Nice, you’ll be good. Yep, I went with same gearing, but I got a 3.3 in the rear. -
I plan on boxing it all to the grill opening as well as venting the hood just behind the radiator. direct air in and give it a place to go. I have 2.87 first and .81 5th. I have this gearing in a 2jz 240sx with a 3.73 rear and pretty happy with the ratios. so i'll see how 4.08 rear gear works with it on the local tracks. -
Looks good, what gearing did you go with the on the TKX, I got same bell housing too. I would definitely do some ducting to help get all the air you can through all of that. I have a TT 370Z I track occasionally, oil cooler/intercooler/radiator all stacked similar to you, after about 5 laps or so I need to do a cool down lap to get temps back in range. Adding some ducting is on my to do list on that car. -
Jboogsthethug replied to markrolston@mac.com's topic in Nissan V6 Forum
Interesting! I have never heard of keeping it all together like that, you'll have to update as time goes with how it holds up! I'm sure with the outer layer being glassed it will be fine though -
Cage is done. Driveshaft arrived. its comically short. i dont know if i even mentioned it in this thread. I bought the engine with a 350z six speed and tried to fit it and didn't like it so i switched to a tremec TKX 5 speed with a scatter shield. lighter, smaller, better gearing, serviceable. shifter position is great, and not 20+ years old. Mounted a 240z ebrake handle in place to help connect to the 300zx rear cables. Started getting the dash sorted. FIA bars are certainly making it extra challenging to do a clean install. Pedal box is in and throttle pedal is fitted. I don't know what the pedal is even out of but it was sitting in a box that came with the car so I made it work. feels good on the foot. Mounted the heater box to the tunnel. designed and 3d printed some ducts that go to the factory defrost ducts. i also added a small foot diverter for the wifes feet as shes always cold. Mounted the oil cooler. went thru a few ideas between laying it flat and ducting it, stacking it. putting one in the wheel well. etc. Although a 3 stack is not ideal i decided to try it. Can always move it around if its impeding flow to the coolers behind it to much. probably do some sort of screen infront of everything when its on track to keep debris from damaging it. Got my front valance quickly mocked up. I forgot the headlight buckets were a bit beat up so added that to the list of things to fix. drivetrain is basically all set so I am pretty close to pulling everything out and starting bodywork. -
markrolston@mac.com replied to markrolston@mac.com's topic in Nissan V6 Forum
Not a mold. I just left the original 3D part sandwiched between the outer layer of fiberglass, bondo, and paint used for fit-and-finish, and the inner layer of carbon fiber used to ensure the whole part is stiff enough to last. -
Who's Online 2 Members, 0 Anonymous, 357 Guests (See full list)
