- Yesterday
Is there any pictures showing the 1979 to 1986 Jeep CJ7 master cylinder with swapped pushrod from the Datsun 240Z clutch master cylinder installed in a Datsun 240Z? https://x.com/i/grok/share/CZVSqy9yUiQEwFV9TZpEACANa
Ford trucks with the 400 engine would be a good source also.
My turbo header from Forever Fabrication for my 4200 build came in today. Top notch craftsmanship as expected:
09-27-2025 More 4200 stuff. I stripped off all the unnecessary junk and was able to get one side of the engine cleaned up. I didn't worry about the oil pan as it is going to junk pile soon. Progress....sometime slow but moving forward. Pics show the cleaning in stages on that side. I got the springs into the external wastegate, and it shows a crack pressure of 8 psi and wide open at 12 psi. Not too bad.
- Last week
Yet another LS 260z swap :)
christianmoller replied to christianmoller's topic in Gen III & IV Chevy V8Z Tech Board
Good evening Picked up my shaft Wednesday. Out of the garage for the first time in two years. First test run was very gentle as there are a lot of things to keep track of, not only engine. Today i have driven the car and made some log with HPTuners and it is a bit rich. Cheers Christian -
So I went ahead and bought one off of eBay and it showed up the other day. It is a 2006, which is the 2nd of 3 variants. It has larger ports and larger valves than the 2002-2005 models. I have ordered a few of the high dollar pieces needed so far, my T shaped oil pan made by Forever Fabrication has arrived and I have it in silver engine enamel, within a few days my turbo header from the same shop will be here and I am awaiting the intake flange, runners from DMZ and plenum from eBay I will use to put together and have welded, then have the welds sanded smooth and either polished or powder coated. I picked up another S30 engine crossmember which I will use, strapped tot eh bottom of the engine and measured from my Z car to fashion the motor mounts. An Aisin AR5 5 speed is also on the way, and my Turbo is here, I ordered a T76 with T4 flange off of eBay, along with a Tial knockoff external wastegate. A chromoly 17.1 lbs flywheel from Atlas Industries is on order. Cool stuff!
3bola joined the community
IMSA GTU vintage racer build
43Connor joined the community
Yes, still working on then, just have not posted anything. Bought some expensive components that take time to recover from. A blank PAMS head, that I then designed and has DelWest make me titanium intake valves, Inconel mnemonic stainless steel exhaust valves, also MoldStar 90 seats and guides. Had it assembled, and ports cleaned up for some nice flow numbers. Also purchased a Nismo 6 Speed Trans that was also strengthened and modified by HPI in Japan. I take some progress pics soon.
Turbo oil feed line, block adapter, turbo drain. I really have no clue how much for this. I know they dont come up for sale much especially with the block adapter. It may be slightly tweaked but its really close to original shape. Will package on a bog enough box. $150 plus shipping?
Oil cooler assembly. Includes everything from the block adapte, all four oil lines and the oil cooler and banjo bolts. $250 obo plus shipping. I flushed it out in my parts washer. Hoses and adapter where dirty but i cleaned them up. Does not appear to have any leaks.
It's been a busy few weeks, but I've recently started back in on the fuel system. Still waiting on some AN fittings to arrive but I think I'll do a -10 SS hardline with a 45 or 90 degree bend directed into the side of the surge tank for the return. The fuel sender arrangement should also work well, having been integrated as part of the surge tank mounting and also top hat connectors. Also, one thing I was not expecting is how expensive submersible fuel safe nylon line is and I suspect it will still need to be replaced every few years. Most of the turbo/wastegate SS fittings and hardline stock have also arrived so I'll be starting back in on that over the fall/winter along with completing the external oil pickup conversion.
ScarlettVibe joined the community
So after doing a valve adjustment my ITBS did sync up better . I guess I will have to keep an eye on that. I took out most of the injector trims and my afrs between the banks paired up better -especially at light cruise . I also worked out linkage issues I was having. You get no instructions with this kit and there was adjustments that I could have done better like the main rod-the only rod-to bellcrank. I didnt have it pulling the linkage in a straight line. Also found the linkage on the side of the ITB loose . This caused the linkage to rub against the body of the ITB. I got all this sorted right before ZCON . It was 4.5 hours to Nashville on smooth highway. 80 mph is where she likes to cruise . AFR's were around 15 on flat ground. No issues on the round trip. Got some great compliments from Peter Brock on my airbox . Cold idle is still 650rpm and about 800rpm when hot . AFRs at idle are normally around 13.1 Now to move on to IAC . I gave up on it right before I left .
- Earlier
Stock Car Mafia's '78 280z LS2 Build
Stock Car Mafia replied to Stock Car Mafia's topic in S30 Series - 240z, 260z, 280z
It's been a hot minute since I have posted. Our oldest is in 7th grade and now have two additional rugrats in the family! One of my best friends and I started renting an astrophotography shed in New Mexico since 2020. We've both put a lot of time in to making that a real life long hobby. Otherwise I also spend the summer months playing in the yard with my reel mower. Since 2017, I've been just enjoying the car and logging miles. We are approaching 10,000 miles since the build. The last 2 years the car has mostly been idle as the kids and career have come first. The fuel pump had gone out again and just recently decided it was time to dig in and get a taste of what I have been missing out for a while....working on the car. I took out the passenger interior, seat, and back hatch area to get access to the fuel pump relay and wiring. Going to rerun a dedicated 10 gauge wire back to the TRE fuel pump as I believe I was getting too large or a voltage drop on the lower gauge wire, stressing the pump out. I noticed the rear differential also leaks some diff fluid, so that will have to be addressed at some point as well. I have all my "Build Book" 3 ring binders from the past that I have gone through. I am fricken blown away by how much I documented and kept an active To Do list. I think it is time to blow off the dust and put together my phase 2. Although building will a longer process now. -
Stock Car Mafia changed their profile photo
Got a little bit of time in the garage today. Got most of the front brake plumbing done, just waiting on the lines I ordered for the master cylinders. Also ordered this steering column mounted lights/turn signal switch and relay set. Will help with the wiring as I’ve tossed everything out. -
Yep. the 5 cylinder hasn't caught up yet to the six. the six cylinder 4200 is REALLY taking off now. I have one I am putting together, and possibly put into another Z at some point. It will be turbocharged, etc. you start with 291 horsepower and 270+ torque, and then go up from there. weight is 350 lbs. They are a beast.
Adding info I was given from Keas on these transmissions. I was given permission to share. In an email I was told that only a slightly stronger spring could be used in the Pressure modifier valve. This goes against what other build info I have found online. I think the info on replacing the plastic thrust bearing and modifying the planetary to be very useful. I have seen alot of people in my searching having broken thrust bearings or planetary failures. I know this is an old thread but trying to put this info in places it can be found JATCO 4N71B Rebuild Modifications.pdf
jeffer949 started following Keas Jatco 4n71b automatic transmission build info.
Hello everyone. I am building a 1984 Maxima wagon (not a Z but has the same basic drivetrain.) I have turbo'ed the stock L24e and have a L28et sitting on the stand to put in. My car is auto and has the L4n71b transmission. I am in the process of rebuilding a 1984 300zx Turbo auto transmission for the car which is a 4n71b. Firstly there is very little info on the internet about these transmissions and half of it is wrong. In my searching for info on how to build the 300zx transmission up to handle power the name KEAS from Australia keeps popping up. They seem to have done alot with the jatco transmissions in the performance world. Well I emailed them and asked for pricing on a valve body This is where I was shocked. They sent me the instructions on where to drill the separator plate and then he sent me the info on building up the transmission itself and how to address the weak points. I asked if I could share and he said yes so putting the info on here to help future builders. What is interesting is that they don't modify any of the springs per the level 10 info and the shift kit the guy from austraila sells. See details in the thread below. Little hard to follow but i think you can understand. Jeff, The only Valve that could use a slightly Stronger Spring is the Pressure Modifier Valve. Over-do the strength of the Spring and extremely late or nil WOT Shifting will occur. The Weak Areas in order of Failure are: Intermediate Shaft Input Shaft Over Drive Sprag. We have Billet Piston/ Servo Sets but your not there yet. See attached PDF for transmission upgrades. Have fun. Paul. Wow thank you so much for that info. I have the stock modulator from the turbo 300zx. And I have ATP nx-2 modulator. Thats adjustable that is listed for the turbo cars. Not sure about the diaphragm thickness. With the separator plate do I need to do anything with the valves? The info I've seen online say to shim the pressure regulating valve 2.54mm and the pressure modifier valve the same or install a stiffer spring.(or pin it for very firm shifts. From the link below. https://www.mygen.com/users/dbruce/myz31/LevelTen_Performance_Automatic_Transmission_Install.htm At what point are the cast band pistons not viable and billet ones are needed? And yes the engine is a l28et from a 280zx turbo. Not sure if you ever got those in Australia but its the same l6 platform as the L24 from the 240zed etc. Jeff, I'll assume your Engine is Turbo Charged. The Valve Body (If it was from a Turbo Charged Vehicle) runs into Shifting issues around 13psi. And you cannot buy the Turbo Specific Modulator anymore. It contained a thicker diagram that lasted longer the NA items. I would fit a Full Manual Valve Body that has fixed Line Pressure. As a starting point- try modifying your Separator Plate as shown on the PDF Building a 1984 Maxima Wagon in the USA. Has a L28et from a 280zx turbo with a 4n71b from a 84 300zx turbo behind it. Planning on around 300 hp to the wheels Just replaced all the gaskets, seals, o-rings, clutches, steels, and bands set all clearances to factory spec. What valve body mods do you offer? Finding info in the states is hard and your name keeps popping up so I thought I would see what you offer and pricing. Thanks JATCO 4N71B Rebuild Modifications.pdf
IgnisFortis joined the community
Ahazel joined the community
No, i didn't buy them, the goal was to have them made at Volvo Power train as Penta(i'm Volvo Penta) have some of their product development there. but they are over there heads in work so no time for private stuff. I have contacted a guy that makes sequential gearboxes and other fun stuff to make them. /Christian -
They are Spinwerkes series 82. Unfortunately they are no longer available. I bought them around 2007. 15x10 and weigh 12 lbs
@74_5.0L_Z what wheels are those?
'77 280z running rich at idle
I also posted about this on the Classic Zcar forum but forgot to update this one. Here is a link to that post: https://www.classiczcars.com/forums/topic/69530-77-280z-running-rich-at-idle-afm-screw-doesnt-work/#comments In short, I tracked the problem to a faulty AFM (Air Flow Meter). The carbon track inside the AFM looks fine but when hooking it up to a battery and measuring with a multi meter there was a break in the track. Unfortunately it’s not repairable and I couldn’t find a Datsun AFM in Europe or somebody that could repair or recreate the circuit board (the carbon resistive track part that is). This has lead me into a pretty undocumented part of the Datsun / Bosch EFI system that is the AFM. It’s pretty much just a voltage divider (brings down the battery voltage) and a potentiometer. However nobody makes a potentiometer I could jerry rig inside of the AFM to recreate the original signal. However in my goal to make the car run (not rich) again I found a possible solution. Why not just use a different AFM? I mean it’s basically just a generic Bosch / Denso AFM module (5 pin) with fuel cut off (which makes it a 7 pin). The only problem is that the Datsun’s use the earlier > 5V AFM otherwise u could just grab one from a BMW or Opel. I did find an Australian forum post that mentioned a Toyota AFM that was plug and play with some spring tension adjustment with a part number that (over here) came back to one from a 90’s Ford Probe / Mazda 626. The part number was F201 13 210 (197100-3420) for the record. As this AFM was only €25 at the local wrecker I got one as well. I will be testing this AFM over the weekend to see if it actually works in the Datsun and also works well. I did notice the Mazda AFM is much bigger then the stock one. Maybe that second hand 60mm throttle body I saw online might be an good upgrade as well if this AFM works. -
Ok, well back from the EFI conversion posts, back to just regular fun stuff posts. I decided to try custom length spark plug wires again. I ordered a set of the wire "cranes" from Lonely Driver Company and then ordered a set of 8.5 wires form Amazon and installed them today. As the pics show, it made more of a difference than I thought.
Who's Online 3 Members, 0 Anonymous, 1099 Guests (See full list)
