- Past hour
Thanks guys. Making me feel confident in my set up. @74_5.0L_Z good info and impressive dyno on old engine, I’m hoping for something close when I’m done. What is your new engine, still a ford 302? Slight change to my diff setup. Didn’t do enough homework, but I think it’s actually going to come out better, just by dumb luck. I didn’t realize auto vs manual was a different sized pumkin on the 370Z. I bought an auto diff, and the wavetrac doesn’t fit an auto. Good news is I really wanted the 3.3 gearing and that only fits in the auto pumpkin (dumb luck). An OS Giken diff fits with the 3.3 gearing in an auto diff, so it looks like I’m going that route. A little more money, but the OS Giken is better for a track car anyway. - Yesterday
With a good 5th gear, overdrive is wonderful... I have the mythical R200 with 3.36 rear gear. The transmission is a T5 with the G-Force Shafts and gears 1 through 4. I run short tires Avon 23 /10.5-15 on all four corners. When I first installed the G-Force gears I was only auto crossing the car, and really only used 2nd gear. When I started doing track days (Daytona and Sebring), I quickly discovered that 5th gear was horrible. With the stock gears, 5th wasn't optimal but wasn't too terrible (3.35, 1.94, 1.44, 1.0, .67). When I changed to the G-Force Gears, 1st gear was improved but 5th gear sucked (2.95, 1.95, 1.33, 1.0, .58) First time at Daytona, I was redlining 4th gear by the time I came off the banking onto the front and rear straights, and the .58 5th gear would drop my rpms and torque too much to be useful. The .58 5th gear was horrible, so I pulled the transmission and took it to Astro Performance in Tavares, Fl and had them install the A5 5th gear (0.81). The difference was night and day. Overdrive went from a total buzz kill to being my Warp Drive... If you get a transmission with a good 5th gear (TKX with .81 5th), then you'll be fine. This is what the gear spread (speed versus rpm) looks like: Here is what a full acceleration run looks like if you assume 0.25 second shifts: The above uses numbers from my old dyno chart and the following inputs: Dyno graph from my old engine (my new engine makes more power and torque): -
clarkspeed replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
The tranny/rear is a trade off. You really dont want to shift to 5th at 120+mph. The wind resistance will drop you 10+ mph and if you are not in power band you will not accelerate much after that. Not good for Daytona. Rule of thumb is the more peaky your engine is, the closer tranny ratios you need to keep it in power band. The other rule is select gearing to be well into power band or just over in top gear, top speed. Depending on engine you may need a different rear/and or tire ratio to run Daytona, it is different than other tracks. Many club racers run the final 1000-2000 ft at redline, but that can be risky. -
ideas on how to get this rusty bolt out
NewZed replied to adsdsasdasdasda's topic in S130 Series - 280ZX
Seems like you might need a better wrench. A six point box end would be best. 12 mm I believe. p.s. forgot to mention the original impact wrench. Tighten up the wrench on the nut. Then hit it with a hammer. p.s. 2 - it will take a lot of heat to get the flange hot enough to hurt the seal. A torch on the nut should help. Doesn't have to be red hot. https://www.lowes.com/pd/Capri-Tools-12mm-WaveDrive-Pro-Combination-Wrench-for-Regular-and-Rounded-Bolts/5001577325 - Last week
tube80z replied to adsdsasdasdasda's topic in S130 Series - 280ZX
I have a set of extractor wrenches that come in handy for things like this. Here's a link https://olsatools.com/products/7pc-offset-extractor-wrench-set?variant=41307851161651&country=US¤cy=USD. Cary -
I really think you should move to an overhead bar.
Linkage is what I am calling the small arms between throttle bodies and the shafts. You need to remove everything connecting each throttle to the overhead bar. Then sync. Then check again once hot. Also blip each throttle, see if they stick or bind once hot. You should have the cable going to a cam on the overhead bar. If that isn't what you are doing, I would highly suggest that route. Setting butterflys is extremely difficult to do perfectly. I would print the 3D file I posted for syncing, then set each off the car. Then put each in an oven to 185 and check each again. Do you have an injector company in your town? Have them checked for flow matching?
jhm replied to adsdsasdasdasda's topic in S130 Series - 280ZX
Can you fit vice grips on the nut? That may work. Otherwise, your idea of grinding/cutting the nut off with a cutting wheel should work as long as you have room to get it in there. -
Hey folks trying to take out the drive shaft so i can take out my transmission and engine. been trying to throw a wrench on the nut (at the end) and use a screwdrive to turn the shaft so the bolts can loosen up. how ever this isnt working. tried pb blaster, wd40, wd40 penetrate. next thing ill try is heat but im worried about the grease, oils from earlier and the break lines near by. alternatively im thinking about grinding off the nuts but not sure if there are any other ideas. please lmk! P.S. I started stripping the nut head. https://imgur.com/a/w9CVTiL
I’m using cable control on the linkage. So the issue with them is the cascading effect of using cable on one ITB that has direct linkage to the other two . It causes #1 ITB to open up sooner no matter how I try to adjust . I also have #4 port that doesn’t flow as much air as the rest . Maybe a butterfly issue - slightly off. I would go with rod linkage but I’m pushing it for time to make it to ZCON . I’ve tried syncing the best I can at lower TPS by just holding throttle open with cable adjustment and calibrating 3-6 . Once I’m around 12+ TPS - AFRS blend much better . As far as #4 - I will address this with injection trim . It’s just light cruise where I have to pull some fuel . I’d love to try the rod linkage but I’ll have to see how much time I have . It won’t help with the center ITB . I’ll have to take it off and see about doing something with the throttle plate . Again - it much time for that right now
How close are they synced now? Are you removing linkage to do that? Are dog bones the exact same lenght?
Any Reason to find one if you havent been running one? Asking for a friend....
I used his list plus a angled bearing plate from jegs or summit for like 10 bucks. I couldn't use the location he used. Still a work in progress so Ill post when i get it all welded up. https://forums.hybridz.org/topic/124248-steering-shaft-relocation/ -
bajajoas replied to bajajoas's topic in Gen III & IV Chevy V8Z Tech Board
Thanks for the tip..what is the steering shaft modification? -
Ordered the Apex track attack kit for the rear, and sent out my 370Z diff to be rebuilt with a wavetrac LSD. Going with the 3.3 gears. Did some more research and I was thinking about the gearing wrong. I’m sure it’s common sense to those with experience but I was including the overdrive gear in my analysis. For a track car, I learned you should gear it for redline in 4th on the longest straight, then you have overdrive if you need it. So going with the highlighted option below. Planning to work more on brakes this weekend, I unboxed my dual master cylinder set up, trying to understand how it all goes together and figure out plumbing. I have my new brake lines too, so hopefully replacing all the lines and get them plumbed to the master cylinders in the next few weeks. -
I am currently working on this same issue. I got sandersons D1 headers uncoated since I knew there would be issues, just based off the photos. On the passanger side I dented the backside to clear the mounts. It was just above the collector, I can't remember which cylinder. It was a pain since thats there the collector and primary overlaped. I also got to a point that i didnt want to dent it any more and cut a section off the motor mount. The mounts are lsbillet swap plates and jags that run chevy put together. The portion I cut off shouldnt affect the mounts, unless the engine spontaneously shifts back an inch.... The driver side I am going to modify the steering shaft based off another post. Its pretty good post. Not sure of the link, I copied it into my offline notes. Dont mind the fuel line returnin the photoes still moving things around. Ive been delayed on this project since spring. The wife to do list was piling up. -
G-Tech replied to bajajoas's topic in Gen III & IV Chevy V8Z Tech Board
Not many take on this challenge, good for you! It is for sure a challenge. If you have rack and pinion steering, you have the worst. There is manual which is not bad and i dont exactly remember the name of the other style. Its like reciprocating, or something like that. Bottom line is, i found that a "block Hugger" style fits well on Pass side. It's the driver side that i had the most issue with. 1st thing is to pin the steering shaft (I drilled and tapped through it for a screw) so you can cut-off the clamping ear. Then get rid of the Rubber Rag joint on the steering shaft. Techno toy tuning makes a solid piece to put in place. I don't know anything about the size of it though. I made mine and made it smaller diameter for clearance. I have modified a couple different sets of headers. I 1st had a Hooker High Flow Manifold that i still had to cut a window in it and have a plate welded in from the back side. Then i didn't like that i had 2 different style headers so i bought BillyBoat headers for a C5 vette. Still had to cut a tube off and re-route a new one to avoid the steering shaft. Then i was worried thet 1-5/8" primaries were not big enough and i had someone make me a set of long tube 1-3/4" headers and found that it was not worth it. I went from 375whp to 387hp (very disappointing results for the $) Take a look at all the pics. There is a pic for everything i just explained. Worse case you can run manifolds upside down and they will point fwd. If you are turboing, this will work well. If not, you have to run the exhaust fwd and down around the front, which i'm not a fan of. -
Can anybody share what they used for exhaust headers for a ls1 5.7l motor in a 280zx? I knew this would be a challenge but coming up short or should I say shorty
IMSA GTU vintage racer build
Finished up the 17x8 wheel conversion on a turbo 280z. Got the geometry perfect. All the TTT suspension parts made it easy. https://www.facebook.com/share/p/15JMLRNJpd/ -
I do want to give a big thumbs up and shout out to "artishard" here on the HybridZ, I kept searching to find anyone whom had one of RIPS old custom oil pans and it turns out that "artishard" here on the HybridZ has that very pan and was kind enough to share several pictures. Those pictures were amazing as it looks like they are enough for Robbie at RIPS Racing to make a custom oil pan for my application! This is why HybridZ is so great to learn from others mistakes and share information so valuable in our pursuit of performance!- 1 reply
- 1
Datsun 240Z RB30 oil pan For my 1972 240Z, I wanted to create a reliable big horsepower streetcar capable of 800-1000 HP. To meet those goals I choose RIPS Racing whom has the proven track record in creating reliable high HP street cars, exactly what I was wanting. One of the issues I faced was that Robbie of RIPS had lost his template for a rear high-capacity oil pan for a 240Z swap. There does not seem to be any good oil pans for a 240Z RB swap. If you are building a big horsepower RB engine to be swapped into a 240Z PLEASE BE CAREFUL AS I PERSONALLY DO NOT THINK THERE ARE ANY GOOD PANS AVAILABLE AND YOU WILL NEED TO GO HAVE A CUSTOM OIL PAN MADE! Here is my sad experience thus far... After spending weeks online reviewing so many oil pans only to find that all of them were not adequate based on RIPS observations. I found this one JHK pan from U.P. Garage that appeared that it might work so I took a chance after they told me it would work, https://upgarageusa.com/collections/jhk-oil-pans/products/jhk-rear-sump-rb-cast-oil-pan When I received it, I shipped it straight to RIPS as I did not want to undo their professional packing. I did not open the box, as I just brought it to DHL and they put their label over where your label was. I sent it to Robbie at RIPS Racing in New Zealand. Unfortunately when it arrived to New Zealand it was damaged. I told Eric, & Doug @ UP Garage via email, The oil pan you shipped to me was damaged. I did not open the box, as just brought it to DHL and they put their label over where your label was. I sent it to Robbie at RIPS Racing in New Zealand. Additionally, Rob told me that this design would not work as there is insufficient clearance between the oil tube and also between the baffle and engine. I have attached pictures and an MP4 where Robbie shows the box damaged before fully opening it. This was an unfortunate expensive mistake as it cost me over $700 to ship it only to find out it was damaged and would not have been a good pan for my application. When I get my fully built engine towards the later part of this year Robbie will send your pan and I can return it. I would hope that I get a refund. Now we need to source a better pan that has more oil capacity, and a better design to provide the oil flow needed for my engine. On a phone call UP Garage said it was my fault for not opening the box before I shipped it to New Zealand. I told them I examined the box it was not damaged in anyway, so I reshipped it without opening it in order to not disturb their packaging, but they still denied any liability. I then sent them the following email, Eric, & Doug, I sent the pics you texted me to Robbie, and I am glad he explained the issues technically with the oil pan. Doug was telling me that your pan would work fine on a more stock build but reading Robbie’s great explanation, I doubt that would be the case on my 2 WD RB block. Regardless, the oil pan was damaged and if you feel that it can be resold to someone as Doug stated, I will send it to you after I receive my complete engine with the damaged oil pan from RIPS. You are specializing in a local RB market would be better suited to find a new home for this oil pan than me here in Northern CA. Doug claimed it should be easy to sell it as the damage was cosmetic, then it would make sense that afterward you resell the oil pan, you could reimburse me for my purchase or at least most of that cost. U.P. Garage sent this email to RIPS, We are, and have been, huge fans of your hard work to bring HP to the RB world!! So glad that the JHK pan has found it's way to your examination table. Here are the measurements we have taken on the RB25(rear drive block) screen configuration. Keep up the great work!! Feel free to call us: +1 253 565 9823 Doug/Erik Fatty Fat Cat www.upgarageusa.com From: RIPS Racing The pictures you have sent are not from a 2wd block, they are from a AWD block, possibly a RB26 with the longer AWD pickup. The measurements you have are with the pickup you have on your block and quite different to the measurements I have with the pickup and oil pan I have received. As stated, with the pickup bolted on (without a gasket) the pan will not go down all the way to the block, the pickup screen is holding the sump up a little bit meaning the screen is already touching the bottom of the sump before its even bolted down flat. There should be about 10mm clearance when the sump is bolted down meaning as it is, bolting the sump down will put load on the pickup and be squashing the screen and the tube inside the screen will be pretty much hard against the floor of the sump meaning a massive restriction in oil flow. RIPS also sent them this email, Hi, Just to add to this, with the oil pickup installed on the block (even without a gasket) the sump would not sit flat on the block, the oil pickup was ever so slightly holding it up so the screen on the pickup was hard against the bottom of the oil pan. This means if the sump was bolted up tight the pickup tube itself (inside the screen) would also be basically hard up against the bottom of the sump meaning major restriction is oil flow. There should be around 12-15mm clearance between the end of the oil pickup tube and usually around 5mm clearance between the screen and the bottom of the oil pan. As it was supplied there is no way it could have worked and would have surely led to an engine failure.
- 1 reply
- 1
I spend the last few days cleaning the electrical connections and timing the ignition again as it was out of spec. The car runs way better but the AFR gauge still shows 11,5 at idle. I'd like to bring that down (or up depending how you look at it) to 14,7 as the car stinks of gas. The previous owner mentioned that that was the reason it didn't pass inspection (auction company didn't mention that). I tried messing with the idle air mixture screw but that didn't help. When turning clockwise a bunch the car did start to run richer but when turning anti clockwise it didn't get past 11,5 AFR. I did notice the ignition coil is a 1,5 ohm unit with a total resistance of 2 ohm with the external resistor. I believe it needs to be closer to 1 ohm total so I'll probably replace the coil with a 0,5 ohm one. -
Mitchel0407 started following '77 280z running rich at idle
The Follow Up Road Test went fine. There was no CV Axle Grease leak and the Diffferential performed well. The Differential Gear Ratio was now 3:55 compared to the old r200 3:70 so my shift points were now more spread out. I think that 3:55 gear ratio for city driving by providing less gear shifting. Highway driving was better by running at less RPMs too. The Blue Angels-the Navy Stunt F16 planes were coming to participate in an Air Show at Kaneohe Marine Base. There also had a Car Show along with the Two Day Air Show. Although, the show was on the other side of my island , I decided to enter my 240z in the Car Show. The trip would take about one Hour but most of it was on freeway roads. The Freeway would take me over the mountain to the other side of my island. On the downward leg of the trip, I noticed that a lot of pedal effort was necessary to slow down, My conclusion was that a Bigger Brake Power booster would be needed. The OEM Brake Booster was 7" booster so the next size booster would be 1978 280z booster which is 8 !/2". The local auto places did not have a 280Z booster available so I ordered one from Z Depot. The Air Show was terrific but unfortunately, it create a large Traffic problem. However, The Good News is that I won the TOP TEN Trophy for Aloha Mother Fest 2025 -CAR Show that was combined with the Blue Angel Show. Next- Upgrading the 7" OEM Booster with the 78280z 8 1/2"Brake Booster Next-Upgrading the Brake Power Booster with a 78 280Z Unit
Who's Online 2 Members, 0 Anonymous, 296 Guests (See full list)
