- Past hour
- Today
Part 19-More Detailed Work on the Gull Wing Door More Detailed work continues on the Gull Wing Door- Drain Channels and Gapping the Door in preparation for weather stripping. -
Nice Nate, keep it up! I know how family stuff goes, we have three now so totally feel you on that. I've finally primed my side mirror today to repaint it in the original grey. Getting to painting a side mirror has taken me upwards of many months so you're doing way better than me!
07-19-2026 ATLAS Z UPDATE: I started by color sanding and buffing the tops of the fenders and the sail panels with 2000 grit, 3000 grit and 5000 grit and then used Meguires Premium Polish with my foam pad on the buffer at medium speed. Then I re-installed the side view mirrors, and re-installed the emblems and plug for the antenna hole. Then I finished the door panels by putting the latch surround trim under the door release latches on both sides. Then I took some rope and measured out the length for the serpentine belt and the remaining brake lines, which will also be PTFE braided line form "Finishing Lines". All of this took longer than it sounds. PICS:
TomoHawk started following Bushing for emergency brake control lever.
TomoHawk replied to LooseRocks's topic in Brakes, Wheels, Suspension and Chassis
You really need the hard ring to make it work. The rubber cover holds it in place, but the plastic or metal ring is the pivot, so the geometry is right, and the cable can pull the brakes and hold the car. - Yesterday
07-18-2026 ATLAS Z UPDATE: Today was Doors Day. I put this off for a long time, because it is just no fun. I deleted the windows for the car to lighten it up and keep it in the mindset of being basically a 4 wheeled motorcycle. I gutted the doors out except for the door handle mechanisms, leaving the locks in....and then vacuuming the bottoms of the doors out and then taping the holes off, and then I installed my repro door "cards" I got from Hung Vu. the Arm rests I got from Ebay and the holes left for window crank and door lock I filled with some push in plastic plugs I got off of eBay as well. I then started on the layout for the rear window. I am replacing the glass with Clear Polycarbonate from a company in England called Plastics4Performance (.com). I am getting the rear window in clear, with the special hardened coating, and making it a custom order, having slots cut into it like they do for the Ferrari 488 cars (see pic). The weight will be easily half of what the heavy glass weights, and I will lay down a layer of rubber int he window well, drop the glass in, and then with holes already drilled, bolt the window down into the hatch itself. It should look great! I also installed the door weatherstripping and the threshold plates. Seems to have made a big difference looking at it after I was done today. PICS:
- Last week
I'm not dead. 2025 was a pretty big bust though. Just way too much going on being a family man. But I've recently made some progress. Engine is back out for hopefully the final time. Finished welding up the chassis side of the engine mounts and engine bay is painted. Still need to do some finish welding in the transmission tunnel. Also fabricated a mounting bracket for the brake master (booster delete). Still to be done off the top of my head: Cut down and weld the brake master pushrod Fab new brake lines Mount clutch master Fab clutch line Install flywheel Install adapter plate for final time with loctite and such Install clutch Drain and replace fluid in transmission Clean up transmission shifter hole (rusty from standing water in it (before me)) Install transmission Install new thermostat housing Install rear coolant adapter (with gasket, was just set on for test fitting) Install intake coolant adapter Fab and install engine to engine coolant lines Finish last bits of engine harness wiring Weigh final engine/transmission combo Install engine/trans for (hopefully) last time Fabricate radiator mount and ducting Mount and plumb radiator Plumb fuel line That's starting to get down into the last bits before first fire up. I'll also need to fabricate exhaust at some point, but it'll survive running an open header for just getting it back on the ground. With any luck I hope to have it close to first start by end of August. Will depend on how many side quests I have to also complete.
1972 240Z Fuel Level Sender Wiring Terminals / Connectors
darom replied to jmendez72's topic in S30 Series - 240z, 260z, 280z
@senna21 I would advise you (if you still have a chance now) to remove your brand new sending unit and apply some JB Water Weld or Tank Weld (or whichever preferred fuel resistant epoxy) to the inside/outside of those terminal posts. My brand new sending unit from ZCar Depot leaked. I filled up my brand new tank (also from the s30.world) and went to a car show. I had a big embarrassing fuel leak. They are sending me a replacement unit. I won't be taking any chances again and will JB weld stuff. Both posts leaked. -
Stock Hood Release Cable Replacement with Lokar Hood Release Cable kit
calZ replied to Miles's topic in Miscellaneous Tech
Good post! I love the annotated pictures.- 1 reply
- 1
calZ replied to jmendez72's topic in S30 Series - 240z, 260z, 280z
I agree. Are you sure the Prothane bushings don't use that outer sleeve? Most poly kits I've seen are like Mitchel said. You might want to see if the bushing slips in as it sits. -
Replacement Door Mirrors for a 1972 240z Nissan The old MSA door mirrors fell apart and I wanted to find a better replacement. After doing some research I found that GM part #987460 refers to the classic chrome outside rearview door mirror used on 1955, 1956, and 1957 Chevrolet passenger cars would be a good fit. I found a kit that provides both left and right mirrors at United Pacific: Item No.110745 Exterior Mirror Bundle for 1955-1957 Chevy Passenger Car (Pair) which includes: · Polished stainless steel mirror head & chrome plated arm with identical design as original. · Convex mirror with wide angle optics for R/H side. https://classic.upauto.com/exterior-mirror-bundle-for-1955-1957-chevy-passenger-car-pair-110745 I purchased the mirror kit at Amazon for $57.69 https://www.amazon.com/United-Pacific-110745-Exterior-Passenger/dp/B07CSM82R6/ref=sr_1_5?crid=3D4VKZQDPPL45&dib=eyJ2IjoiMSJ9.Ji_ewCdOZDHJk5NTl-hJJNFlKNsQBt5lpAOLKHcRoK31x-GRce_gxezK_VKJFo0J9IkZHkDcZBC1uO-yqa9wAikFa3d3ppFs1Z_e9oMH7GHS0hSYXVCL3mPH2KdHlNipyinC19rlSI2bJ2OSt4dOu31VkbQgttxV3F9sjOnvlwdEzUBrH0x35XHZypqXaZKhHaGVoA8HQfe6yph6tpYjD9i1U7980UgA3v1My4M_ZeA.60nOt1lFZGTfNCnWtHJyTgcmFLSL1-4Gz3NCXbznMr0&dib_tag=se&keywords=car+side+mirrors+chrome+metal&qid=1783662323&sprefix=car+side+mirrors+chrome+metal%2Caps%2C189&sr=8-5&ufe=app_do%3Aamzn1.fos.9fe8cbfa-bf43-43d1-a707-3f4e65a4b666 See pictures.
Note that this applies to my 1972 V8 240z which uses a Motor Sports Auto (MSA) / Jags That Run (JTR) style hood release bracket. The stock hood release cable tends to fail with age. If the cable breaks you will be very sad. So I decided to replace my failing hood release cable with a Lokar Hood Release Cable kit. I installed the hood release handle where the driver’s side vent control was mounted. The vent control mounting bracket is rigid and lines up the hood release cable with the stock hole in the firewall. The vent control was moved to the left of the Lokar hood release lever and bolted to the underside of the dash. Installation required making two brackets from 2” x 2” x 1/8” aluminum angle one for each end of the cable. The release arm on the stock hood latch release mechanism required modification because the Lokar cable stop would not fit into the stock cable connection. I removed the stock cable connector on the release arm and replaced it with a spare Lokar throttle cable end and ball pivot. This allows the attachment point on the lever arm to swivel as the release arm moves to release the hood latch. Summit p/n: Lokar Hood Release Cable Kits HR-1100U $129.95 https://www.summitracing.com/parts/lok-hr1100u Summit p/n: Lokar Cable Fittings WCA-1034 $33.95 https://www.summitracing.com/parts/lok-wca-1034
- 1 reply
- 1
07-15-2026 ATLAS Z UPDATE: Today I finished sanding the first coat of gloss clear and then prepped and applied a second coat of poppy's patina. Now 48-72 hours of cure time before color sand and buff. I also finished the work on converting the hatch lock pushbutton to a hood pin setup. PICS:
- Earlier
I finally had some time this weekend to work on the Z again and finish off some of the little things that where nagging me. I finished my DIY door card project and got them installed in the car. I must say that they turned out pretty good. The only finishing piece would be to add the wood trim back in but I would have to make one myself. A few weeks ago I managed to pic up a set of Euro taillights from an original Dutch 260z that where in excellent condition. So with the remaining time I had that day I quickly switched them out. Yesterday there was a small all Nissan/Datsun meet I attended which gave me the opportunity to compare my Z with others and do up some inspiration for future modifications. Afterwards I finally had the time to take some proper pictures of the car (with the car not half apart) and cruise along the dikes. WhatsApp Video 2026-07-13 at 09.15.40.mp4 -
Mitchel0407 replied to flatout's topic in S30 Series - 240z, 260z, 280z
Your engine bay looks very clean, nicely done! You really are flying true this project, keep up the good work! -
Those sleeves are really had to take out, that’s why they sell inserts that reuse the old outer sleeve. Because of this I went with polyurethane bushings in my 280z and I must say they are pretty comfortable. People always complain that they cause massive vibrations and are undrivable on the street but I really don’t know what they are talking about, they feel fine to me.
I can’t wait how she looks out in the sun!
07-12-20206 ATLAS Z UPDATE: Well I started today by wiping down all the sections to be cleared with the Poppy's Patina Wax and Grease Remover. Then I went ahead, got my mrespirator ready and glove for my wiping hand and mixed the gloss clear and started wiping. It goes surprisingly quick...and I found that I was sicking the applicator into the paint and then then I LIGHTLY squeezed it out so that I had a lot of the applicator, but not dripping as much. As expected, there is a learning curve. After I was done and the hours went by, I could see spots I had missed. Normally you want until it is completely dry, at least 24 hours, but since I know I am sanding and adding a second coat, I mixed up, a small amount and went over the spots that were missed. Sure enough, it changed the appearance......so don't do it unless YOU KNOW you are adding another coat, which means sanding or at least using the grey scratch pads they send you to rough up the surface a hair before laying on a second coat. I wanted to get a coat of the stuff on there so the second coat later will be a true second coat everywhere. But, I am impressed. It is my intention to get a second good coat on, let it sit 24 hours, and any spots missed to then add where needed and let it sit for awhile....maybe a full week, before I sand it with 2000, 3000, 5000 grit sandpaper, and then use my buffer with the foam pad and some compound to bring it up to a smooth shine......then a good coat of wax. PICS:
Thanks jhm, I've ordered and installed them. I couldn't find rubber boots so I just used the sheaths they came with and covered them in a lot of electrical tape. A new gas take from S30 world went in as did new fuel sender from ZCar Depot and vapor hoses from Resurrected Classics. On another note, I'm trying to install new front prothane bushings, ball joints, shocks, springs etc.. and of course it's fighting me every step of the way. Everything seems like it's been tightened down with an impact hammer. But I've gotten the driver's side apart and when I went to press out the bushing I mistakenly only pressed out the rubber and inner sleeve. It appears this (see photo of C-Arm) is the outer part of the bushing. Am I correct? I've tried pressing it out with a 24mm impact socket, from the front end of the arm, same side as in the pic. Should I be trying it from the other? It didn't move a millimeter and it actually bent the top of my press. I could take a saw to the inside and cut through it but that's always dicey. The other thing that's fighting me is the nut securing the shock to the strut. It also won't move. I've done over half a dozen cars in my life and I've never had something like this happen. PB blaster hasn't had any effect. I'm not sure the Special Service Tools are available anymore. So, any help on that front would be appreciate. Thanks jhm, I've ordered and installed them. I couldn't find rubber boots so I just used the sheaths they came with and covered them in a lot of electrical tape. A new gas take from S30 world went in as did new fuel sender from ZCar Depot and vapor hoses from Resurrected Classics. On another note, I'm trying to install new front prothane bushings, ball joints, shocks, springs etc.. and of course it's fighting me every step of the way. Everything seems like it's been tightened down with an impact hammer. But I've gotten the driver's side apart and when I went to press out the bushing I mistakenly only pressed out the rubber and inner sleeve. It appears this (see photo of C-Arm) is the outer part of the bushing. Am I correct? I've tried pressing it out with a 24mm impact socket, from the front end of the arm, same side as in the pic. Should I be trying it from the other? It didn't move a millimeter and it actually bent the top of my press. I could take a saw to the inside and cut through it but that's always dicey. The other thing that's fighting me is the nut securing the shock to the strut. It also won't move. I've done over half a dozen cars in my life and I've never had something like this happen. PB blaster hasn't had any effect. I'm not sure the Special Service Tools are available anymore. So, any help on that front would be appreciate.
Super common with the L series engines. When setting the distributor spindle by mounting the oil pump the drive gear turns the spindle as it engages the crankshaft gear. Suggestions: - Yup, verify TDC with a piston stop - easiest way. Remember that the piston movement slows at the top of the crank arc so the crank can travel quite a few degrees with little movement shown on the piston. If you're really good you could probably ferret out TDC with a straw, pencil, screwdriver, etc. down the #1 spark plug hole, but piston stop will nail it when used correctly. Mark it correctly on the pulley if actual TDC doesn't match the indicator. - The pictures in the FSM of correct spindle alignment cause more confusion than enlightenment. Also rarely do you get a good picture at a proper angle from anyone else. I've found it easier to set the approximate spindle position (with the top angled slightly left) and then set the distributor on temporarily and see where the rotor points. You can mark the distributor cap #1 wire position on the distributor body. At TDC, the rotor should be coming in contact with that #1 cap position. Notice that there is a wide arc to the rotor contact and quite a bit of adjustment in the distributor so what you think may be "close enough" may well be the exact thing you need. I'm usually dyslectic about which way to adjust the spindle when putting up the oil pump and it generally takes me several tries so I never bolt it down with a four bolts. I use one bolt, snugged into position, until I'm pretty sure the spindle lines up correctly. There it helps to have a helper who knows how you want it to look after you've pushed it up...
can't believe its been almost a month since an update. got the exhaust done, made a tip from stainless. Got the wastegate tube recirculated, header and downpipe wrapped. Have been wiring away. Running an ecumaster emublack ecu and a hardwire electronics PDM25. Both of which are new to me. Got the engine harness done and chassis harness started. thinking thru everything has been a challenge but so far so good. Have the PDM powering all the lights and the ECU functions. Have the factory blinker stalk controlling the blinkers, and high beam functions. Factory brake pedal sensor for brake lights and Blink marine 12 button can keypad controlling some other functions. A couple days ago i did get it to start and that was a huge relief after this long process and "freshish" engine. oil pressure is great. engine is quiet. so very motivating. 20260707_210144.mp4 -
jhm replied to jmendez72's topic in S30 Series - 240z, 260z, 280z
@senna21, how about these? https://jdm-car-parts.com/products/fuel-sender-wire-connector-2-pc-set-for-datsun-240z-260z-early-510-620-720?variant=29670929727597&country=US¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&srsltid=AfmBOorswWtJKDRvuU-hfe5UDlY1phSIFSARxMWNfFZ-r4scgyYypB9VdXI When I've needed new connectors for mine, I've usually just fashioned them from standard female blade electrical connectors. Not the most elegant solution, but they haven't failed yet. -
07-09-2026 ATLAS Z UPDATE: Installed the intake piping. You can see the inspection door covers on the car from ZOCIETY, still just laying there I haven't bonded them down yet. Time to finish caulking in the carbon panels and then clear coat over the blue patina paint. PICS:
07-08-2026 ATLAS Z UPDATE. I picked up my intake pipe and MAF Meter cover plate from my polisher, J&S Polishing here in Colorado Springs today. int he pics, I just laid it in place, not installed yet. His ability to take my cobbled together crap and make it look fantastic is true magic. PICS:
Who's Online 4 Members, 0 Anonymous, 2161 Guests (See full list)
