- Past hour
08-07-2025. DYNO morning. Found out a couple of things. 7 psi in 3rd gear WOT at 5500 RPM, 9 psi in 4th gear WOT 5500 RPM. She is RICH....rich to the point of fuel popping, 10.0 to 1, A/F rich, and didn't want to go past 5500 RPM (strange since on the road she will but nevermind). So, there is probably 40 horsepower left in her in the DYNO guys mind. We made 4 runs, and in 4th gear without using any Water/Methanol injection, it pulled 196.8 hp at the rear wheel, at 5500 RPM and at 18% drive train loss that is 232 hp at the crank@5500 RPM. Torque was 268.3 at the rear wheel, 316.59 at the crank@ 5500 RPM. Boost was 9 psi at 5500 when he had to let out because it was so rich. We did a run in 3rd gear WITH water/Methanol and it pulled 226.7 hp at 5500 RPM at the rear wheel, so 267 HP at the crank@5500 RPM and 260 torque, which is 306.8 TQ@5500 RPM, boost was 7 psi. So, as I thought when building it, the stroker and the stock cam made it into a torque monster. well over 300 ft lbs. torque, 232-267 horsepower.....but it is PIG RICH. So, power is limited by being rich. I have dyno charts, but the RPM range at the bottom is all wrong. we weren't able to get to 6000 RPM because of the rich condition. He said it was basically 10 to 1 A/F on the runs, which is WOT, so the main jet is just too big. I can step it down one. As expected, the carb is the limiting factor. At any rate, this is where this engine setup is at now. As predicted, it is a torque monster.
08-07-2025. DYNO morning. Found out a couple of things. 7 psi in 3rd gear WOT at 5500 RPM, 9 psi in 4th gear WOT 5500 RPM. She is RICH....rich to the point of fuel popping, 10.0 to 1, A/F rich, and didn't want to go past 5500 RPM (strange since on the road she will but nevermind). So, there is probably 40 horsepower left in her in the DYNO guys mind. We made 4 runs, and in 4th gear without using any Water/Methanol injection, it pulled 196.8 hp at the rear wheel, at 5500 RPM and at 18% drive train loss that is 232 hp at the crank@5500 RPM. Torque was 268.3 at the rear wheel, 316.59 at the crank@ 5500 RPM. Boost was 9 psi at 5500 when he had to let out because it was so rich. We did a run in 3rd gear WITH water/Methanol and it pulled 226.7 hp at 5500 RPM at the rear wheel, so 267 HP at the crank@5500 RPM and 260 torque, which is 306.8 TQ@5500 RPM, boost was 7 psi. So, as I thought when building it, the stroker and the stock cam made it into a torque monster. well over 300 ft lbs. torque, 232-267 horsepower.....but it is PIG RICH. So, power is limited by being rich. I have dyno charts, but the RPM range at the bottom is all wrong. we weren't able to get to 6000 RPM because of the rich condition. He said it was basically 10 to 1 A/F on the runs, which is WOT, so the main jet is just too big. I can step it down one. As expected, the carb is the limiting factor. I will post the dyno sheets, but as I said the RPM range at the bottom is wrong. he let off at 5500, I wanted 6000 RPM but he said it just wouldn't do it., when he let off the throttle the unburned fuel was popping and banging. Pics follow (video at the end). V1.MOV - Today
Found this on Grassroots Motorsport web page. Seems Legit Garage is adapting some interesting modern trannys to other platforms. Think $2k for a fully sequential used 8sp box, any HP needs you have. The ZF-8HP from BMWs, Dodge and others can be fully reprogrammed for sequential operation and even add a dbw pedal to simulate a clutch launch. Might be a good project for someone that could adapt this to an L6 easily....Derek? Transmission Solutions | "Seems Legit" Garage https://share.google/HyOxohcae82yQu0Th
In doing a V8 swap, are you able to hook up the factory speedo cable to a GM trans? I guess there is a box you can install to get the factory tach to work. Can't think of the name right now. Thanks.
- Yesterday
jeffer949 started following 280ZX Cruise Control Limit.
Wy wouldn't you want cruise to set faster than 75? Interstates are 75mph and traffic goes 80. Turnpike speeds are 85.
After priming the engine oil and starting/warming up the car, there is a small leak around the rear main seal. It is either my side seals or the rear main. Considering how easy it is to bump the seal while installing the rear cap, I wouldn't be surprised. I guess it is time for a tranny drop operation. I will check with my endoscope.
Hi CalZ, It is https://www.amayama.com/en
Cool stuff Clark! I dig the ARB. Cary
If i still had cruise on mine, i'd be happy to find out for you. But i don't have it no more. Props to you for thinking you need a cruise control unit that goes higher than 75. Good luck. Hope someone can help.
I'd take them off and have a close look. If the bleeder screws have holes through and the screws seal, then they MUST have an effect. If you can't measure a difference with the synchrometer, then there must already be an overwhelming amount of air going past the butterfly. Either they're already open, or they're poorly centered.
What is the name of the company selling brand new timing covers?
Back to synchronizing itbs . #4 reads less than #3 port . Bleeder screws do nothing on any ITB - are they just there for looks ? No blockage I can see anywhere . I can pull the needle completely out and it does nothing to change air flow . I thought previously it was #3 was hanging on the linkage but that turned out to not be the issue . If I got any adjustment out of the bleeder screws I think I could get it dead nuts . I’m at a loss . Been searching on line but with no luck . Maybe cheap Chinese stuff .
Aussie Speed has a dual SU intake for draw through turbo setups. This intake would also allow for dual Mikuni HSR bike carbs as well!
Lunar Loox joined the community
- Last week
So after much searching and an upgrade to 1.6 firmware I was able to control these fans very well . They must have some built in controller that can decipher the low PW signal from MS . Testing at 87hz -which is what MS3 offers - they worked smoothly with no humming or any strange behavior . My GOD they move some air . Still wish I knew how much CFM they really are . The 1.6 firmware allows for a low/partial speed and full speed . Haven’t tried any AC controls since I don’t have AC yet .
Does some one know how fast you can set the cruise on 280zx or a z31 300zx? by that I mean is there a limit to the speed it will allow you to engage cruise control? I have a 1984 maxima wagon and my cruise works fine except that by design it wont allow me to set cruise past 75mph. Is this limitation the same on the 280zx and the 300zx? I'm looking to swap in a cruise control module from the same era of car that doesn't limit the speed. Ive already looked at the wiring and the 280zx looks to be plug in. and a 300zx will have to be reworked but doable. Thanks in advance.
WOW!! That is slick!! The car's coming along nicely! 👍👍
IMSA GTU vintage racer build
DuffyMahoney replied to clarkspeed's topic in S30 Series - 240z, 260z, 280z
man, how cool is that! -
Got on the wire wheel and went to town on the engine bay and front fender wells, prepping for paint. Need to wash it down and go over it one more time. Test painted a few spots. Also got the fender braces on, but not fully welded. Started getting a hole in the body panel, so decided to tac it and fully welded it later after some more practice, probably start practicing tig, need some gas first. -
Going with a holley digital dash, this offered a blank canvas. -
I have been dealing with some consistent oil leaks around tranny/engine block, and front RH lower part of the timing cover. The worst leaks would happen when the car was parked at an incline. I replaced my original TC with a new unit (there is a company selling them from Japan), total shipped was around $100. My original cover had some stripped threads. The water pump's long 80mm M6 bolt (at 10 o'clock) was broken inside the block. I had to weld a washer with a nut to remove it. The oil pan gasket that I sealed 10 years before, with permatex gray/gasket sandwich started leaking on the RH side. The removal of it was a major pain. I decided to get an aluminum pan from AZC since I am considering a turbo upgrade in the future and that pan already has provisions for the oil temp sensor and turbo oil return fitting (I went with the 8AN fitting). The pan is solid and straight. I 'glued' the cork oil pan gasket with the permatex black to the pan to prevent the gasket movement while I was installing the pan. My hope is the fact the pan is a solid aluminum piece, there is not going to be much flexing/worrying about dimpled surfaces etc. While the pan was off, I also replaced the rear main side seals. Mine looked old/brittle when I removed the rear main cap and inspected them. I tried pulling the metal inserts with a pair of needle nose pliers, but they were stuck really good. The rear cap was removed using an improvised slide hammer (the taped part is a bunch of heavy washers): It took about 10 minutes to remove the cap: I didn't see any sealant in the corners in my engine. I am hoping this might explain the oil leaks. Per FSM: Before the cap installation, I put a bead of gray ultra in the corners on each side. The side seals got a coat of gray as well when I inserted them. The rear main cap was in a freezer. Its installation went smoothly. I haven't filled the engine with oil/coolant yet. If I see more of oil leaks around the rear part of the engine/tranny, I would probably pull the transmission and replace the rear main seal along with the transmission's gasket/seals.
A to Z replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
sure is a different looking dash! -
08-02-2025. My thermostat probe arrived, and after a bit of thread sealer I installed it and crimped on the end to finish that job. then I FINALLY got my new speedo cable screwed on to the back of the speedo. IT WORKS! In testing out my fan, I took 3 pictures of my gauge you see below. The first one is where the fans turned on, between the "M" and "P" on the word "TEMP". The second is what the fans pulled it down to , and the third page is where the fans turned off when I had turned the engine off and the fans were running....when they stopped I ran and took this pic, so don't fret about the oil psi looking low as the engine was off! I also have 3 videos at the end of the pics, just walk around type pics. So I can really say it's done. I did the car twice before this, and then the turbo install which turned into a MAJOR undertaking. Was it worth it? Yeah, but I didn't know how deep the rabbit hole was going to be when I started.....if I had I may not have done it, but what is done is done. With a draw through turbo setup like this, you have to have an "educated" foot, gradual on the adding power and removing power unless you are over 3000 RPM. That is the way these are, or at least the way mine turned out. I know the instances where it will go lean for about 1-2 seconds in certain accelerating situations, and hitting the Water/Meth injection right then smoothes that out. I think a small block Chevy (with dual 4 barrels & a nice cam) would have been way easier than all this, but maybe keeping this an L series makes the car more "neat", I don't know. Anyway this my Z car, version 2.5 V1.MOV V2.MOV V3.MOV -
I found this You Tube Video that shows the use of Laser Technology to strip down a Fairlady in Japan. Although the video doe not have English Subtitles, the Laser Machines utilized provided a different method of removing paint, rust, corrosion,etc. The major drawback is it is too labor intensive. Using Total Chemical Vehicle Dip (previously shown) would be much faster and still be able to remove internal corrosion (in boxed areas). But in certain case such as surface corrosion, this method would work well. I found the video interesting as it provide a new option in corrosion and paint removal in the restoration process.
Who's Online 2 Members, 0 Anonymous, 197 Guests (See full list)
