Brad-ManQ45
    6
  1. I wouldn't use rattle can primer - it is porus to rain. I'd go ahead and use Zero Rust, but then sand it all off (don't know how hard this would be). I understand your desire to get 'er done, but I honestly think you're better off waiting until you can get a compressor and paint gun and do the DPLF. Part of the delay can be alleviated by just doing the undercarriage first, which won't get rain, and use ZR on it. Not all your time will be wasted. As far as a paint gun, get a relatively inexpensive one for primer. HF has a pretty good one for ~$49. I predicate this last statement on the premise that after you get through with all body work, you will be putting on a coat or two of primer/surfacer and block sanding everything smooth, then a final coat of reduced DPLF as a sealer and then the final paint stages (bc/cc or single stage). I have oe of the HF guns and bought the 3 gun set from Northern tools on sale for $89. The 3 gun set has a detail gun and two different guns, one for primer and one for paint. These are all HVLP guns and my $400 compressor from HD handles them fine in my testing - at least at the rate that I will be spraying. I will not be using any of these for the top coats, just for primer when I get around to actullay not dismantling and welding. Running a restaurant leaves little free time.... I like going to the AutoBodyShop Forum and reading the posts on painting there, since the last time I painted was 30 years ago.
  2. I have an '83 ZXT, on my V8 project car ('75) I'm going w/Ross' setup. I have lived with the ZXT's rear calipers since '92 and have no desire to multiply my problems.
  3. Use ZR for undercarriage and interior. Use EPLF for engine compartment and outside. You can scuff the epoxy and shoot another coat on at any time later, after body work, etc. I wouldn't bother with ZR as the base for epoxy. I think you may have the impression that once epoxy is out pf its' recoat window that you can't scuff and respray it - you can. What you can't do is wait 'til it's outside the window, scuff and put other primer/surfacer or paint on it. Once DPLF is outside its' recoat window, you mearly have to scuff and spray another coat on, then you're ready for primer/surfacer and paint. Sorry for the repetition, but it does bear repeating.
  4. dr_hunt: Lived in El Paso 2.5 yrsw baqck in the early 80's, would travel through Socorro on my way to Alabuquerque, where I also lived for a while, and Santa Fe. Plenty of women there.....
  5. I'm glad it wasn't any worse than that, and will keep him and our armed forces in my prayers.
  6. If your car is inside out of the rain, then spray it with PickleX and don't touch it. If you have to leave it outside, then go with a good two part primer as stated earlier. Some would say do the body work and then appl,y the primer, others say spray the primer, then doi bodywork, sealing all the bodywork between layers of primer. You may want to go ahead and put a coat of sandable primer oin after the last coat of epoxy. It's easier to sand than the epoxy, which you will have to spray again after sanding if waiting longer than its' recoat window.
  7. I would suspect that for the street (daily driver use) the 700R4 would work well for those that have the stock compression ratio turbo engines. Let's face it - they are a bit doggy down low. On a turbo engine, I don't see the wide gap between 1st and 2nd as an issue. On a stroker naturally aspirated engine, I would definitely give the nod to the R200.
  8. Congratulations! Someday I too will feel that particular thrill...
  9. That thing on the shock tower is the coil. Sounds like ignition module to me - the black box on the side of the dizzy....
  10. And why is it not in the body section? He WAS referring to sheetmetal, right?
  11. I'm biased. I have a '75 and an '83ZXT. Never cared much for the Z31's. BUT, I remember reading an article comparing an early model against a Z31 in ITS and there were certainly some points made there favoring the Z31. I personally detest the crummy rear calipers on the 280ZX's, but love the long hood. I would suspect that it would be easier finding a good condition Z31 for a certain price than the 280ZX, and you wouldn't have to fabricate engine mounts for the V6... All that said, there are definitely fewer 280ZX's on the road than the 300's, so I am in favor of keeping their presence felt...
  12. In looking at your photos, I see a car that looks like it is sitting level, just looking at the floor and rockers...
  13. Yet another car to be envious of while I am awaiting the opportunity to do some serious welding/bodywork on my project. Very nice - I want to paint mine a yellow also.
  14. Auxilary: Too bad his sucks. I will admit that the one my brother-in-law got initially had a TERRIBLE DA pull, but after a littlle 'Smithing", it's smooth as glass now. Neither of us has had any jams or FTF. Of course while I was doing the wsork on his action, I also polished the fed ramp, did a little recontouring and chamfered the chamber. Then I did both of mine. This was before we ever shot them.
  15. I have an '83 ZXT and I would not use 289ZX calipers, I'd use the MML 240SX swap kit and 240SX calipers, and will when I get mine to that point.
  16. Good question 240hoke: How big is the IC? I believe you haved an NPR? If it is any smaller than the rad, leave it be.... Most of us aren't on boost long enough for this to make a big difference. Road Racers need to pay attention to this more, IMHO.
  17. When I built my rotisserie, I used 3/4ths inch MDF for a 4X8 foot table that I could collapse by myself and lean against the wall. I have one of the magnetized grounding clamps that worked fine for me. Space was a big issue. Now I have a table that is belly button high to use anytime I need one.
  18. They are a lot easier to climb into bed with monetarily too!
  19. Glad to hear you're OK and car undamaged.
  20. Hartzpad: Is that a Witness I see? I've got a couple. 10mm FS Blue and .45 FS WF. Love 'em! I'm too busy to take a picture...In addition: 2 Ruger 22 Autos Beretta .32ACP Ruger Redhawk .44 Mag K-31 Swiss S&W 12 ga. Auto CZ-52 Bulgie Makarov Winchester Golden Spike Commemorative
  21. I have an R200 (3.54) you can have for $50 (what I paid for it). I live in Marietta. I originally got it from another member on the board, but now have decided to do an R230 swap. I also have the moustache bar and 280ZXT shafts....
  22. You arenow considered a dangerous polluter...
  23. Sounds like your front mount bolt is shot. That would definitely be the source of a clunk. Most diffs, if they are bad WHINE or ROAR at you - kind of sounds like a harmonic at speed.
