Brad-ManQ45
    9
  1. I've soaked mine w/Kroil and hit it with a dead-blow hammer and it doesn't want to move. Now thinking about heating the housing w/MAPP torch and trying it... Any tips from the gurus? Thanks
  2. I agree with TonyD. I would also like to point out that before I joined, I read almost every post in the forum - admittedly a LOT easier in 2000. What we should not be tolerant of is people - and by people I mean newbies - that don't search, don't capitalize, don't spell, use bad grammar and basically treat their posts on this site like they are texting their LCD friends. The purpose and yes, JOY of this site is the ability to learn a lot from the shared knowledge - IF you are willing to read (and search). Anyone that makes it hard to be understood should not be a continuing part of this site. No one here gets paid to nursemaid/teach, we're here to learn and share. The newbie's that blatantly ignore the simple common courtesies we request of them and they accepted by checking the appropriate box upon sign up SHOULD get the ruler across their knuckles (sadly only metaphorically). If they cop an attitude about being slapped down, we definitely don't need them - I doubt seriously that they are our kind of people. I think that the first 5 posts should be in a special forum, and see that before turned loose on the general membership that they are willing to capitalize, spell, use proper grammar and basically COMMUNICATE according to our rules. If they can do that, then they have no excuse when out in the regular forums. Then all we have to complain about is not searching before asking questions that have been covered numerous times. Note: The spelling requirement is probably the most important - no search will come up right if they can't spell.
  3. No spoon feeding here - do a search of this site and learn.
  4. I would also like to mention that bottom taps are available and should be used on all blind holes that have needed tapping.
  5. Your math IS good - been there and done that already.
  6. I THOUGHT you might like the 3076 once you really looked at it - you'll get a bit better response from the slightly smaller impeller wheel just to start. You may want to consider the 1.06 turbine housing for top end - it's ~= to the .82 GT35R turbine housing, but I think I'd start with the .82 and see if it's holding you back any up top - for sure it'll be better getting to the top end. Except for pure drag racing, I'd trade a small bit off the top for better response across the range any day. Sometimes having a choice of gears lets me be a bit smoother and work a bit less. I'd do a search of this site and look for the GT35 threads and check out what those that have swapped turbine housings have to say.
  7. The GT35R is already more than enough for either engine, provided you have the right turbine housing, which you allude to not having but don't specify which one you have. In point of fact, for road racing, I would consider the 3076 w/a .82 exhaust housing (~same flow as the .63 GT35R housing). Area under the curve is far more critical for road racing and I think the lower end response would really help more than later top end power... You haven't mentioned how much boost you want to run either, so until we know more specifics you're just gonna get pot shots/guessing at what would be appropriate. Not sure what you mean by later technology, the 6262 that you refer to seems to be a Precision turbo, and there is no "later technology" there.
  8. Scottie: Please accept my condolences, and let your family know that I am thinking of ya'll. I am very glad that you do everything the RIGHT way, and are alive to prove it.
  9. Black soot on ground = RICH White smoke is water vapor. What does it SMELL like (other than exhaust). Slightly sweet = water w/antifreeze. If so, you may have a crack in your head allowing water into combustion chamber. Bluish smoke = oil and will smell like burnt oil. If it IS bluish, then valve guides or seals. You may have a crack in your head allowing water into combustion chamber.
  10. Do the Seafoam treatment. Put in 20w50 oil. What is the compression on the cylinders? Black is usually fuel. Bluish/white is oil. At what point do you notice the smoke - just idling, on acceleration or decelleration? Idling/acceleration = rings Decelleration = valve guides This is of course assuming that it IS burning oil, which the black smoke doesn't suggest.
  11. Big difference in simply putting DynaMat in the door panels. Did that when I did custom speaker pods for the front doors. Nothing elsre done and much quieter - and this is on an '83ZXT... A S30 should benefit even more...
  12. On my '83ZXT, I had custom "pods" made that bolt onto the door panel to house the 5.25" ADS speakers. I personally don't want the midbass speaker more than 6" away from the tweeters.
  13. All 280ZXT's had 3.54 R200s.
  14. T3/T4E 50 Trim compressor, .63 AR standard turbine. Go w/3" downpipe.
  15. Since he has Megasquirt he can program more advance when under light load - why screw w/vacuum advance?
  16. There is no way that you can get any better than white light for vision. By going to any other color, you lose illumination PERIOD. This isn't rocket science - but it IS simple physics. I won't argue with you - you haven't taken the time to research as I have. What you have stated is subjective opinion with nothing to back it up. I just want to make sure that people looking for information get GOOD information - a goal we should all share on this site.
  17. At the power range you are looking at, I believe that you are doing yourself a disservice in getting a thicker head gasket. You would have 10.5:1 with the 44.6cc N42 head. With the larger combustion chamber of the P90/P79 head (53.6cc), your compression will be considerably lower. You will have at most 9:1 compression ratio with flat tops and the P90 head. Even at 9.5:1 you should be ok. There are plenty of people that have run this combo with good fueling and ignition maps and made over 300 hp. You say you only want 240-275 - problem solved. Lowering compression will compromise much needed off boost torque that the people who use flat tops instead of the dished Turbo pistons enjoy. You'll even get better gas mileage with the higher compression. Buy an intercooler and piping to keep the intake charge cool and cap boost at 12-15 psi and you're gold. Now if you were gonna run HIGH boost, that is another story, but that would be in the 20+ psi range...
  18. You can't go to carbs - won't pass visual. Low compression=low vacuum. My '83ZXT didn't pass emissions 1 year, so I replaced the O2 sensor and it passed. I had just put in a 3" exhaust from stock downpipe back w/3" cat, new plugs, wires, rotor and cap and was surprised that it didn't pass. I found out later, after it had passed, that the EGR was not working at all - there was a plate made out of the top of a tin can between 2 gaskets holding the EGR valve to the intake manifold - effectively blocking off any gasses being passed. All by way of saying that you don't need EGR to pass - fix your other problems.
  19. Are you asking for the measurement from the front of the bellhousing (engine plate side to the face that bolts to the transmission itself? If so I would say that you would be looking for the length the bellhousing adds to the overall length of the tranny and not the width... I have a T5 ffrom my '83 ZXT in the garage, but I have no idea from your request what you want...
  20. Do a search...this has been covered many times.
  21. It's not the sensor - it simply senses if there is continuity through both low beam filaments...
  22. 6000k bulbs? You're losing some illumination there - ~4500 is best for illumination - the higher the bluer and the less you can see at night.
