madkaw
    24
Everything posted by madkaw
  1. Well when I started my resto-mod I thought I spent a lot of time on here, then as I come too a close on my project I realized that I didn't nearly spend enough ,or I would have done things differently in the first place. I spend a lot of time when I am laying over in the hotels, but at home I am catching up on lost time from being gone, so it's a quick glance at the recent posts.
  2. Frame rails are solid-no apparent damage anywhere. Drivetrain is removed but tranny brace installed and tight. Car is solidly jacked on a level concrete floor. This car is pretty solid all around with no prior collision work apparent. Both floor pans fit in the same manor, so difference side to side.
  3. This thread would be for those that have installed these type floor pans only. I know Charlie makes these for other vendors, but I seeking feedback from you guys that have installed his pans. I wrote charlie an email soliciting his response and I also wanted to hear how your install went too. In general I am happy with the pans, but it seems to me that they were made too deep. Lining up the pan along it's original attaching point along the rocker the panel sits deeper then stock. This isn't a problem until you try and line up with the tension box and you end up with the front of the floor pan higher in the middle. Not much of a way to rememdy this unless i'm missing something . I have an original untouched Z in the garage to compare with and take measurements from, and they tell me that the pans sit a little low. This issue is not very noticeable, but makes the fit tougher and I think it could be made a little better---- and that is the ONLY reason for this thread-NOT to bash Zedd Findings. I also suggested to Charlie to increase the length on the frame rail so one can replace the bottom of the tension box at the same time you are installing the rail. Of course the other issue is the lack of pan material up front to tie in with the firewall. That little piece is a PITA to fabricate because of tying it in with the curves of the floor pan. Disclaimer: I am not a professional bodyman, but have done quite a bit of sheetmetal work. These are the first floor pans I have done-but might not be the last-thus the questions:) The pics attached are mostly the passenger side which came out nice, but if you look at the drivers side(not welded yet) you can see what I am talking about in that certain view looking down the length of the panel from underneath.
  4. These cars are for a DD, so no v8 conversions for me. It would be a guess to say whether or not the head suffered any damage. We took a took a 5 mile ride half of that showing the temp in the hot range and it was 15 degrees out. My concern is that if it overheated because things froze up enough that the thermostat didn't work, did it do any other damage???? I also have to have an automatic, so no tranny swaps either. I appreciate your insight BRAAP. I love cars-but shopping for one can be a bitch. You come across so many losers and liars it isn't funny-especially in the price range I'm shopping in. If I was really nuts I would buy the 87 325e that was on ebay the other day. It had 87,000 original miles and was super clean and he wanted 4500$ for it. It might actually be the best deal and the easiest to work on of the bunch. It was on craiglist, but he pulled the listing. I am waiting on vin#s from the sellers of these other cars so I can do a carfax.
  5. Any major do's or don'ts or stay away from models. I know there is a lot more info needed, but it is a used car. 1994 325is 155K some service records, but car overheated on test drive and it was 15 degres out. It was a flordia car and the glycol solution was weak and the thermostat froze up!!??? 2600$ new tires and service records showing timing belt and ater pump done 2007 1998 328i,no service records, pretty clean 165kmiles. Trans slipped a little under hard acceleration. 4200$-probably take less 1995 540i(beast) no service records,new tires, a little rust here and there, 169k miles, drove good-weird tranny. I say weird because 6 speed auto seems sluggish-but heard that's normal. Did not slip under hard acceleration. Got to love those factory SS headers .3000$ may take less
  6. I've done it, but it's not running yet-maybe in a few months
  7. Make sure you get the pedal box from a 73 and not an earlier because things won't line(holes for brake and clutch MC)
  8. ....because it could have been ugly! My daughter was home for the holidays and I try and take the oppurtunity to check on her 81 280zxt and make sure it's okay. I put some new speakers in the car for her Christmas present and I also had some maintenance items I wanted to take care of. Due to the extreme cold here in Indianapolis the 30 year old oil seals were starting to give out. The Crank pulley or front main seal started leaking and the power steering pump started spewing too. I happened to have an extra crank seal and I was actually able to order a shaft seal for the pump from Napa(6$). I never had messed with the PS pump before but thought it couldn't be too bad. I was actually guessing the seal was bad on the shaft since I hadn't taken it apart yet. Both jobs went pretty well and I was bale to replace the crank seal without disconnecting my condenser and moving it. The hardest part was getting the keyway to line up when reinstalling the pulley-I couldn'y really see it and had to feel my way around. I was really nervous about dropping it into the timing cover. The PS pump was a learning curve but not too bad, but I did booger up the first seal when i tapped it into place, so I had to order another one from Napa(last one they had). I was doing this job without removing the PS pump, because I didn't have a wrench big enough to hold the HP line nut to get the line off. I got in a hurry the first time installing the seal but came up with a better paln of attack the second time. Since I had to wait another day for the new PS pump seal I was putting my schedule in a bind. I told my daughter I would get the car to her that day that the seal came in, so I had to move effeciently to get everything done and checked out. The second seal went on great and I finished putting the car back together and test drove it-no noises, no leaks-i'm cool Well I hop in the car and drive it 50 miles to her school and drop it off and everyone is happy A busy day and I was done Z-ing and I would clean up the garage tomorrow. Tomorrow came and I cleaned up the aftermath on my work bench of the pile of tools rags and stuff. Then suddenly I locked up looking at my bench--------there sat a C-clip-a C-clip to hold the PS shaft in place--OH Sh%t, I said about a million times. I called my daughter right then and told her to not drive the car until I get down there. Then I had this scary image of being on the highway at 70mph when the shaft came out of the PS pump and how much damage that would have done I really got lucky this time-thankyou Z Gods __________________
  9. Cool, at least I know a couple of things to look for. It keeps getting busier for her and she's starting to complain about not having her ZXT to drive around. I'm fixing an oil leak and will be taking it down there Saturday.
  10. Thanks Bob. So a weak transmission and what's up with the wiring? How's school going?
  11. All I know is that I worked at a F.B.O.(airport fixed base operator) for 12 years and ran 100ll in my 71 and it was the cure for my sticking valves and the car ran beautiful on it. Lead contact is very high even though it is called low-lead. The manager at my place wouldn't sell it it to anyone that didn't have a plane-maybe things are looser where your at.
  12. Okay, so maybe the 93 190e I have been looking at might be looking a little better here. It has a few more miles, but it's also cheaper. Plus I have heard good things from you guys about these cars. Anything I should look for on the 190e? I think the owner said it had 175k miles.
  13. Looking for a used car and have noticed some decent pricing on late 90's Audi's. Looking at a 98 Quattro A-8, but don't know much about them except for the fact they have really depreciated from original sticker-ouch! Going to look at one with 125k miles for 4000$. Looks really nice and is loaded. Are these garage queens or do they make a decent DD.
  14. http://forums.hybridz.org/showthread.php?t=89111&highlight=toe+adjuster
  15. Where do you find one?????????? I've been calling all morning and can't find anyone that carries them..
  16. The cheapest thing to do is replace all your vaccuum lines associated with the heater. You will probably stumble across on ehtat is cracked that you didn't see before. About 5$ worht of hose is pretty cheap and easy. I am speaking from experience:mrgreen:
  17. Well I know the gears are all there and working-albeit they work much better for speed if you manually regulate shift points. First gear shifts way to early. The car just doen't have any snap at all off the line-but don't have any other zx's to compare it too. Still, I would like to play with the timing a bit with this car if I can find an easy way to do it.
  18. I wish it was that easy Mat, but it is down below. Makes me want to convert to that style.
  19. I have searched on this site and a couple of others about adjusting the timing on a stock 81zxt. I do have the FSM downloaded and have read about checking the position of the CAS. The FSM talked about a bolt or screw that you turn to adjust the position of the pick-up-thus changing the timing. Well I have A/C and I can't even see it. I am asking for any pointers for doing this task(adjusting timing). I checked timing before and it was at 20BTC I believe, which is stock. The car seems sluggish of line(automatic), don't know if a couple of degrees advance would help that or just the nature of the beast. I hear no audible pinging and I always run premium(93). I believe the car is in tune, but have yet to put a wide band on the engine to see what's going on there. Also, It looks like the front main seal is leaking ,so it looks like I might be getting up to my elbows in this anyway. Again, any helpful hints would be appreciated.
  20. I've been wanting one of those laser temperature guages just for this reason. I think it could be an excellent troubleshooting tool , especially in this scenerio. Can you explain the big difference in the #6 cylinder temperature compared to the others. Are you zeroing in the laser on the head where you would tap for the coolant on 5& 6 ?
  21. The frame rails will come out with whatever section of floor you take out. They are welded to the floor, so if the floor is bad-more likely the rails are bad-so rip them out any way you want, sawzall, cut-off wheel. Now if you are talking about the SEAT RAILS, then you need to get a spot weld cutter, or just cut the floor around them and methodically remove the floor metal from them so you can reinstall later.
  22. Yeh those clecos can be a lifesaver on abig job like this. You can order them from any on line speed shop(jegs) and they are cheap. You can mock up the hole job with these to test fit and remove them as you weld around them. Then like he said, weld the holes shot. The small ones are only 1/8" holes.
  23. Hey guys I am wanting to get my daughter some replacement speakers for her 81zxt, but don't know what size they are and she has the car. Can someone tell me what size round speaker will fit in there so I can do some christmas shopping. Thanks
