9
Everything posted by Michael
Anyone use a Corvette "transaxle" in their Z?
Michael replied to Jerminator96's topic in Gen I & II Chevy V8 Tech Board
To sum up, the Z rear suspension swap is NOT pointless, but it is complicated, expensive and labor-intensive. When contemplating any such swap, one ought to balance the benefits vs. the costs/efforts. The consensus seems to be that for a surprisingly broad range of applications and power levels, the stock Z rear suspension and drivetrain are good enough – perhaps with minor upgrades such as CV halfshafts. At some point I would like to design and build my own unequal-length double A-arm suspension, with a Ford 9†center-section IRS and inboard disk brakes. But at this point that would be silly, considering that I have many yeoman-grade upgrades and maintenance items to address. Changing the topic… the look of the C6 Corvette coupe is really starting to grow on me. As the typical new performance car’s weight is staring to exceed 4000 lbs, the Corvette’s 3200 is starting to sound lithe and trim. If could only justify as slightly accelerated midlife crisis! -
Big block temp question for Grumpyvette
Michael replied to a topic in Gen I & II Chevy V8 Tech Board
The 454 in my Z (1978 Mark IV block, Brodix Race-Rite aluminum heads) briefly hit 235-240 degrees water temperature when the water pump threw its drive belt, and there was no possibility of pulling over. There were no discernable cracks in block or head, or cylinder bore wear, though possibly the rod bearings received some ill treatment. But my impression is that even occasional spikes of such high water temperature are very very bad!!! When my 454 was stock (pulled from a Suburban), it made around 150 psi of cranking pressure in most cylinders. This was with a static compression ratio of around 7.8:1 and peanut-port heads. Your best option is probably to pull the heads. If the bores are OK, consider having the heads rebuilt. -
Happy birthday, Pete!! Just think - in a few more years we'll start the jokes about getting that AARP card in the mail!
Deja is right. 300hp in a reliable, fully streetable package is nothing to sneeze at! Too often there’s the temptation to go for 500, 600hp – only to end up with a garage queen. If the engine does not start, the car is only making about 1/3hp – when I push it! As I keep saying, often the hardest part of the swap isn’t the swap itself, but getting the engine to work! If you have a complete donor car in reasonable running condition, not only will the “odds and ends†(sensors, wiring, accessories) be complete and cost-effective to acquire, but the engine itself will be a low-risk proposition. The problem is finding a good candidate. Locally there’s a ’98 Pontiac Trans Am for sale – LS1, 6-speed, with around 100K miles. Price: $9000 or so. The car looks to be in good shape – no rust, no cracks, no obvious sign of abuse. Not a bad candidate for a dail driver in its own right, but it’s a hideous body style (the red paint makes it even more gaudy and ostentatious), and I could not bring myself to spend $9000 on a donor just for the drivetrain. Nor is there much prospect for selling a “roller†once I’ve stripped it of the useful parts. Nevertheless, $9K on a crate engine, transmission, clutch/flywheel, accessories and so forth, seems to be the going retail rate for the individual parts. We readily spend $9K on an incomplete and untested collection of parts, but not $9K on a used albeit complete and proven set of parts (with the rest of the car for free). So perhaps the greatest obstacle is defeating the conundrums of one’s own psychology?
The trouble with hobby cars is that the budget has so many uncertainties! When you buy a new performance car, you take the huge hit in depreciation up front, but thereafter the costs level off, unless it is a lemon. With hobby cars, you pay for performance parts – but then the parts break, or don’t fit, or are installed incorrectly, or do not perform synergistically together. So you end up paying for the same thing over and over again. I mean, why should I spend $50 on yet another set of gaskets, when for all that I know, replacing the gaskets will only reveal another $300 problem, followed by a $800 problem, and so forth? It’s dumb to throw good money after bad, even if the amount involved is small! What keeps me glued to my Z, and avoiding purchases like a Z06 or GTR or whatnot, is the large weight and overbearing complexity of modern cars. I don’t care if the thing has 600 hp off the showroom floor; if it weighs 3800 lbs, I don’t want it! A performance car should weigh well under 3000 lbs and should have an electrical system with no more than a dozen fuses. Probably the best way to go is to buy other people’s completed projects at a discount. Right now the “fastest street car in America†(7-second Camaro) is for sale for $90K on racingjunk.com. Now that’s a deal! If I weren’t smarting from all those stock market losses in the past 6 months, I’d seriously consider spending the cash.
The 572 need not necessarily be high-compression or unsuitable for the street, but it will be expensive! At a minimum you're looking at a $2500 aftermarket block (tall deck - 10.2"), $1500 crank, $1000 rods, $500 pistons, $2500 heads, $400 cam, $500 lifters, $200 oil pan, $200 pushrods, $600 carb, and so forth. Big blocks are expensive, and all-aftermarket big blocks are even more expensive. Also, note that the 572 will be considerably harder to fit in the Z's engine bay than would the LSx, which after all is a small block (at least in terms of exterior dimensions). And to answer your original question, the 572 will weigh on the order of 200 lbs more than the LSx - unless you get an aluminum big block... for which, add another $2000 premium.
The big question is, is this finally going to be the V8 Z that beats Johnc in roadracing???
Congratulations! 10 years is a long time, but then again, that depends on one's perspective. The key thing is to not give up on what seems like a perpetual work-in-progress. My one data point (1978 S30) suggests that the speedometer is optimistic by about 10-12%. So, indicated 85 mph is closer to 75.
electric cooling fans - brands and theory
Michael replied to Michael's topic in Gen I & II Chevy V8 Tech Board
Wow, this thread certainly brings back the memories! 8 years ago I was less humble, though on balance at present I have far more cause for humility. For what it’s worth, I too have a Flex-a-lite “Black Magicâ€, model 150. By now this has become a standard solution. It works tolerably well, even in hot weather, provided that the water pump is spinning (which it occasionally fails to do, for example upon throwing the fan belt; once in a rather awkward heavy-traffic scenario such an incident caused a temperature spike to 240 degrees). By now the front end of my Z is considerably revised from stock; the stock hood-lip problem has been solved – functionally, if not cosmetically. What has not been solved is the thorny problem of lack of basic mechanic’s acumen for engine maintenance and tuning. A fellow on this board, whose car budget is less than the roundoff error of my budget, and whose Z now accompanies mine in the garage, went from headless shortblock to fully-running car in a matter of a few wrenching sessions over two weeks, and then proceeded to drive 1200 miles round trip to a drag race without major qualm or incident. 8 years ago I would have thought that I could have accomplished a similar thing. Today I know better than to even attempt it! Sorry to hijack this thread (my own thread???) with sappy reminiscences, but it truly is disconcerting how little actual progress has been made in 8 years! -
My 1990 Corolla made it to 228,000 miles before I killed it. It got stuck in my driveway during a snowstorm, and I literally beat it to death (with a sledgehammer). En route to 228K, the only repair was replacing the starter. Oh, and cheap tires would blow out regularly. Its last oil change was at around 190,000 miles. The point, I think, is that a light car with a lazy engine (even if revved to red line) will live an unstressed life, despite flogging and abuse. This makes it more reliable. A “high performance†engine is a lot more finicky, and is liable to fail much more readily, even if it’s built with better components. It is remarkable how much worse was the reliability on my 1987 Toyota Supra turbo! On the other hand, my other Toyotas – 1983 Celica, and before that, 1977 Corona – were very solid, and weren’t retired until collision damage or excessive rust.
What Distributor/Ignition setup are YOU running?
Michael replied to a topic in Ignition and Electrical
Improper vacuum advance on my stock HEI caused many tuning problems and poor-startability on my 454. With the vacuum advance disconnected and plugged, the engine ran fine, but that was high torque and low weight possibly masking improper tuning. For what are hopefully the final touches of my build, I am leaning towards the Crane HI-6 ignition box (capacitive), Crane LX92 coil, and either Summit “Billet†distributor or the Crane electronic unit. Crane’s electronic distributor has the advantage of foregoing weights and springs in favor of switch-selectable ignition curves, but the selection of ignition curves is rather limited, and the cost is pretty steep. It would be nice to find a truly programmable distributor, with a plug into a laptop for tuning, but without the all-out complexity if a stand alone spark control system. Unfortunately in the world of the traditional V8, the options tend to be either modest improvements on a standard distributor + timing box, or a complete engine management system. BTW it wouldn’t be a bad idea to restart this thread. Ignitions for traditional V8s are underrepresented in this subforum, as most threads here discuss either LSx or the L6 applications. -
Can I just cut the springs??
Michael replied to hondabait's topic in Brakes, Wheels, Suspension and Chassis
I just used a hack saw with 18 teeth/inch to cut off 1 coil from each spring(1978 S30). Made no discernable difference to handling or ride quality, but the ride height decreased by approximately 3/4". -
This one: http://www.izhmash.ru/rus/product/nikon.shtml ... seems especially interesting. But I'm not expecting to find one at the local gun store!
The big question is, how much is it going to weigh? The convertible Solstice, if I'm not mistaken, is at around 3000 lbs. Fortunately interior space is the least of my concerns; in most cars I need to have the seat almost all the way forward, and even then fully depressing the clutch can be a stretch.
Thanks for the pointers - definitely something for me to think about! This engine has a stock block, crank, rods and damper. Everything else is aftermarket. I'm surprised that Moroso would put a relief valve set at 60-65 psi on what's ostensibly a racing oil pump, but oh well.... And unless memory is playing tricks with me, I recall getting 80 psi or more when revving the engine, back in 2006. Earlier in the assembly process I did the clay-check and found around 0.400" between the pickup screen and the floor of the oil sump. On the Moroso pump, the pickup tube comes pre-welded to the pump casing. Also, I'm using the original distributor's housing to locate the priming shaft, and am using the original distributor driveshaft as the priming tool. I varied how the distributor seats by stacking different numbers of gaskets on the distributor shaft. In desperation I removed several pushrods and found that in every case the pushrod end that mates with the lifter is soaked in oil, but the rocker-end is completely dry. I then methodically blew threw each pushrod with compressed air, reassembled the valvetrain and resumed priming... with the exact same result! There just isn't enough oil pressure to get flow through the pushrods. Follow-up questions: 1. Is it worth pulling the pan, disassembling the oil pump, and defeating the relief-valve mechanism? 2. Why would 60 psi not be enough to push oil through the pushrods?
It's the elementary steps that are the hardest and most disconcerting!... It has been nearly two years since I last started my engine. It had a problem with its adjustable timing chain - the rosette of bolts securing the cam sprocket periphery to the portion bolted to the cam somehow cam loose, and the bolt heads ate their way into the aluminum timing chain cover. In an effort to clean the aluminum shavings, I removed the heads, the timing cover and the oil pan (but did not disassemble the rotating assembly), cleaned what I could, convinced myself (perhaps naively) that no aluminum flakes were present in the oil passages (I did pull one of the rod caps, and it looked more or less OK),... and reassembled the engine. Now, in one of the last steps before firing it up, I'm trying to prime the oiling system. I am using a 14.4V cordless drill and an old distributer shaft. The engine is a 1978 Mark IV BBC, with basically stock rotating assembly, and the following relevant parts (PNs are from Summit): Summit oil filter mount SMU-2015 Moroso high-volume oil pump MOR-22160 Hamburger 8-quart oil pan HAM-1488 Fram generic oil filter 10W-40 oil (8 quarts) mechanical oil pressure gage plumbed at just above the oil filter boss (stock location) 3/8" pushrods (can't recall manufacturer) Cam Motion "low lash" (0.007" cold) mechanical roller cam Comp steel roller rockers Isky Red-zone roller lifters When I run the drill, oil pressure rapidly rises to around 60 psi - but does NOT rise any further! Max rpm of the drill is around 1200. This is on a 45-degree day. And, there is no oil whatsoever coming out of the lifter oiling holes!!! I spun the crankshaft by hand multiple times (turns over with maybe 30 ft-lbs torque with the spark plugs removed), maybe a half revolution at a time, before resuming running the drill. Before valvetrian assembly I checked that all pushrods were clean. Quesions: 1. Why would oil pressure peg at 60 psi, regardless of drill rpm? 2. Why would there be no oil coming out of the pushrods? 3. Would I be a fool to try starting the engine without first doing a complete priming, where oil flows out of every rocker?
Why Bother With The Lsx Swaps....
Michael replied to EvilC's topic in Gen I & II Chevy V8 Tech Board
Yup, that first drive is a great feeling!... unless the engine eats itself and you’re looking at a $7000 investment (in the engine) going out the proverbial tailpipe. If you went from despondency prompting desire to sell your car, to successful and reliable driving - all in 6 months - then you certainly deserve commendation! I’m hoping for a “second time around†first-drive this summer… after being down for about 2 years since the first drive of my rebuilt engine… after being down for 6 years since the first-drive of the original engine! -
Saw one at the Los Angeles auto show back around 1998 or 1999. It was restored by a shop called Pierre’s. The sticker, if I recall correctly, was $29,900. The car was locked, on a platform and cordoned-off, like a concept car. It was not possible to see the interior, and the hood was closed. But the paint job was as good as a new car's. There was also a Nissan dealership somewhere along the I-210 corridor in Pasadena or just east of Pasadena, that called itself a “Z storeâ€. Evidently there were only a handful of official “Z stores†around the country. They were taking orders for restored Z’s.
Z car aerodynamic enhancements for tomorrow
Michael replied to OlderThanMe's topic in Windtunnel Test Results and Analysis
It's important to note the difference between large accumulations of obstructions (mud, ice) and just dust-type covering on painted surfaces. For airplanes wings relying on natural laminar flow for drag reduction, even small surface contamination such as dust and dead insects can make a significant different in performance. This also happens in wind tunnel test, for example when grime dislodges from the screens in the settling chamber and makes its way onto the test article; one observes higher drag on the test article than predicted in "clean" flow. But I would be highly surprised if a similar thing happens to any but the most exotic and highly-optimized cars. -
Mechanical Engineering vs Mechanical Engineering Technology
Michael replied to Pete84's topic in Non Tech Board
Courses such as diff eqns are often “weeder courses†which are not inherently difficult, but are made difficult to winnow the field. Surviving the course means that you have the tenacity and dedication. This, some say, is useful later on in life, as a practicing engineer. The senior undergraduate courses are specializations of the freshman-sophomore core. In some regards they are actually easier. They repeat some of the freshman-sophomore material and do it in a more applied way. That makes them both more enjoyable and less frustrating. That said, as an engineer I very often use concepts from calc, diff eqns and other core courses. I rarely actually use variation of parameters or calculate Wronskians, but concepts such as linear independence, resonance and damping, linear superposition, truncation error and the like are so ingrained in my intuition that they’re almost done without thinking, like the proverbial riding a bicycle. If I need to have something drawn in Solidworks, or stress in a part calculated using finite elements, or code slammed out in Java, well, I can delegate that to some one else. But the conceptualization of an engineering system from scratch is really something that requires a mental training only possible from rigorous study. That study could perhaps be on-the-job; you don’t need a piece of paper to be a good engineer. But I’d argue that it is far easier in the long run to step over the high hurdles while a college student. Study hard when you’re 19, so that when you’re 39 you are an established expert. -
Questions of this type (and consequent answers) all seem to miss the two most critical problems in doing ANY type of swap: 1. Is there something fundamentally wrong with the recipient chassis? I mean, does your [presently] stock Z run well? What about rust? What about the condition of the suspension? Many swaps fail not because of the swap itself, but because the project morphs into a restoration along with the swap. 2. Is the donor engine itself in good shape? I don’t mean how to splice wiring harnesses or how to get the Z tachometer to work with the Chevy distributor. I mean things such as why are the cam lobes wiped, what’s that knocking sound coming from the oil sump, why is the oil pressure fluctuating, why are the carb fuel-bowl floats stuck, and so forth. The basic mechanics of my swap were done by professional; he did the roll cage, the sheet metal work, the exhaust, and so forth. But I was unlucky and ambitious with my engine - and have spent the past 8 years trying to “fix†the engine! So my point is: good donor engine + good host chassis = successful swap, even if you are unfamiliar with the LT1. But questionable engine and/or questionable chassis = nightmare, even if you’re skilled and well-funded.
I would instead recommend the UC system. In your general area probably the best would be Berkeley. The word "technology" appended to any designation of engineering in my opinion means fluff and flotsam. "Mechanical engineering technology" is bending sheet metal to make HVAC ducts. Real mechanical engineering is modeling the gas flow properties to improve ducting design for minimizing pumping losses. -
Early 70s Japanese race car aero
Michael replied to HS30-H's topic in Windtunnel Test Results and Analysis
Mikelly nailed it when he noted “the sharp and abrupt edges on the S30†as being the culprit for its poor drag and lift characteristics. The “swoopiness†of the car is of course aesthetically pleasing (one of the main reasons that we like Z’s, right?) but “swoopy†to the eye is not equivalent to swoopy to the airflow. The hood front lip needs to be lowered and rounded, the airdam needs to be lowered, the grill opening reduced and the headlight buckets smoothed over (not just covered, but completely smoothed to remove creases). It really is a good question regarding what Nissan engineers were thinking regarding aerodynamics when they penned the S30 outer mold lines. I have several “historical†books with photographs of the S30 in wind tunnels, mounted to what look like force balance plates underneath the tires. Surely those engineers were not fools. But one can't help wondering where they placed their priorities. In the past 40 years, automotive aerodynamics has advanced far more than aircraft aerodynamics. That's not just a glib opinion; I mean, I do have something of an insider's perspective on this.... -
whats a good/common manual tranny to use??
Michael replied to ZQ8Dude's topic in Gen I & II Chevy V8 Tech Board
This has been discussed early and often! But to summarize, there really are no good options for manual transmissions with enough torque capacity - at least not in stock form. The T5 is considered to be too weak, unless fortified by with aftermarket parts (such as by G-Force). The T56 is heavy and its 6th gear is too high for most applications. The Doug Nash/Richmond 5-speed (what I have) handles the torque but is very unpleasant to shift and lacks overdrive. The Richmond 6-speed has overdrive and good torque capacity, but it’s heavy and expensive. You may wish to just get a T5, install it, debug the car, and drive it until it grenades. Then ponder an upgrade. -
What is your Top Speed. On or Off Track.
Michael replied to v80z's topic in Gen I & II Chevy V8 Tech Board
No real Z stories to report, but episodes of driving rental cars on Autobahns in Germany: 180 km/h (about 110 mph) in an Opel Meriva (hey, this is a micro-minivan with around 105 hp!) This was at max throttle in top gear for about an uninterrupted 20-minute stretch between Bremen and Hannover. 205 km/h (about 125 mph) in a diesel Golf, on the famous high-speed stretch between Frankfurt and Darmstadt. That was also absolute max throttle, but only for about 5 minutes. 220 km/h (about 135 mph) in an Opel Vectra GTS, between Kassel and Frankfurt. Again full throttle, but only for about a minute - the car probably had another 10-20 km/h if I were truly fearless. But my excuse is that lanes are fairly narrow, traffic is heavy and it’s rather difficult to maintain these speeds consistently, even if it’s perfectly legal and one has no cause to fear the police. In the Z (1978 280) the speedometer is about 15% optimistic. Indicated 70 mph is closer to 60 mph.
