Michael
    9
Everything posted by Michael
  1. Like all tools, CFD can be very useful in the right context, but otherwise becomes just another hammer. That context is a “tuned†setup where various configurations have been gridded and run through the code, with validation relative to experiment. Once such a setup is in place, it is straightforward and productive to make configuration changes (add spoilers, lower the ride height, block off the radiator grill) and so forth. The incremental effect of replacing air dam A with air dam B becomes believable. But until all that infrastructure is in place, all CFD answers will be clouded with doubt. The “ballpark†figure will probably be correct, but the increment between air dam A and air dam B will be smaller than the uncertainty in either of the answers. But as I’ve been mentioning elsewhere, car aerodynamics is actually harder than airplane aerodynamics. Much of the car aerodynamics business remains in the wind tunnels, while today perhaps the majority of airplane applied aerodynamics is done computationally. Computations are generally cheaper, so wherever the industry can get away with doing stuff on the computer, they will. There are many reasons for why the automotive world still largely relies on wind tunnels, but I think that the main reason is that numerical methods are so tough to “tune†to work for cars. So the bottom line is: CFD is not necessarily intractable for our Datsuns, but odds are that it will be easier, cheaper and more productive to stick with the wind tunnel. I still believe that we should consider option #3: testing scale models in a university wind tunnel. I don’t mean Franklin Mint 1:18 models, but 1:5 clay/wood models that we would custom-make ourselves. Here’s another thought: the Henry Ford Museum in Dearborn, Michigan has a beautiful display model of the 240Z, at around 1:5 scale. While that won’t work for a wind tunnel model, wouldn’t it be nice if we could make molds from that model?
  2. This is something that I would love to one day do with my 1992 325is. Stock it had around 180 hp, and in present condition probably makes less. Off the line it’s slower than my 1990 Honda (2.2L 4-cylinder), and the Honda is in dire beater condition. In many regards it is a very satisfying car to drive - good handling, reasonable creature-comforts without lavish ostentation, pleasing aesthetics and compact external dimensions. In many regards it’s superior to present-generation coupes. It just lacks power. The engine bay is relatively roomy, as is the case for most L6-equipped cars. It’s just begging for a LS3 swap! But to me the complexity of such a swap would be overwhelming. It’s a 15 year old car, but when I open the hood, any enthusiasm to work on it becomes instantly drained. Recently I did manage to replace the thermostat - took several hours, amidst much cursing. The clutch throwout bearing gave out over the summer - I didn’t even consider doing the job myself. It seems that everything in the European-car aftermarket is a ripoff, but if I were to act on doing the BMW V8 swap, at this point I’d just pay a shop to do it.
  3. On my first attempt playing with this software, it gave hp/torque curves very similar to Desktop Dyno’s predictions - except that it’s less optimistic than DD on low-end torque, and the torque curve doesn’t fall as steeply as DD predicts; DD really penalizes high-rpm torque rolloff for advancing the cam. For camshaft recommendations, the intake lobe that’s their #1 choice is almost identical with what I ended up at - lift is exactly the same, duration is 3 deg less; can’t exactly compare area under the curve due to insufficient information. On the exhaust side, their recommended lobe again has the exact same lift, but about 10 deg less duration. (disclaimer: being in a hurry, I picked head flow numbers from the supplied library, which was closed to what I have, but not “exactâ€). For the cam that I ended up buying, I intentionally picked higher exhaust duration as a crutch for poor E/I on the heads (Brodix Race-Rite) and a weak exhaust system. Also, I went with 112 lobe separation - as mentioned already in this thread, Comp has a fixation on 110. So, bottom line: the approximation is sound, given the sparse input deck and necessarily coarse assumptions. But if you already know what you’re doing (OK, sort-of ), all that this software will do for you is provide a warm-fuzzy.
  4. My one experience (which is for a big block) is Brodix, from their Race-Rite series. Comparing what I have with anecdotal evidence on the others, I’d say that quality is above-average, but not exceptional. The CNC’d combustion chambers have a definite “staircase†pattern, the rocker studs protrude into the intake ports and the deck has ~1/4â€-deep marks from a 1/2" drill, evidently used to secure the heads when doing the CNCing. However, the casting quality is very good and there are no fitment problems. The stock exhaust port and spark plug locations are a definite plus. I went with Brodix because AFR simply refused to make oval-port BBC heads. Brodix flow numbers are great on the intake side (especially given their 271cc port volume), but mediocre on the exhaust side. This led me to a cam with strong exhaust bias - which is hopefully going to work out well.
  5. Katz’s book is a good start, and his reference list is an excellent one-stop-shop intro to more specialized material. That said, his book has some drawbacks from the viewpoint of explaining the theory and from practical tips on what does and does not work. As a second reference I recommend: "Aerodynamics of Road Vehicles" by Wolf-Heinrich Hucho, Editor. It is published by SAE International. Knowing that blocking off the radiator grill area had such an effect in the first wind tunnel campaign, we can infer that front-end mods are a useful area for concentration; replace the stock hood with something more “swoopy†and with a smaller fishmouth, improve the airdam and seal the area underneath the car between the airdam’s lip and the steering crossmember. I believe that this will yield max bang for the buck. Smoothing the underbody, recessing the exhaust, adding diffusers etc. is hypothetically cool and is great for bench racing, but is impractical because there are too many variables and too much fabrication is required to get it “rightâ€. My own wish-list would be to explore front-end modifications that take advantage of the space freed up by V8 installations, lowered radiators, etc.
  6. A lot of folks, including some very accomplished racers and mechanics, seem obsessed with the notion that a L6 is "naturally balanced" - that it has a sort of mechanical purity that no other configuration has attained. And the forced-induction crowd often prefers inline engines for what is probably a simpler exhaust system, and hence an easier turbo installation. Personally I applaud the trend away from L6 to V6 (for example, in Mercedes). Maybe someday the BMW 3-series will be V6, too.
  7. The swap is easy if you know your way around cars, if you have the tools and a suitable environment to work, if you have the time to do the job, and if you stick to a reasonable plan. Otherwise the swap won't be easy. A '72 Z and a carbureted 350 V8 are about the easiest choice for a swap. In fact the biggest challenges may not be in the swap itself, but getting the engine to run right - the usual stuff in any hotrod project.
  8. Slightly off topic, but I'm reminded of an episode of the British car show "Top Gear" from a couple of years ago, featuring a review of a special-edition (but still factory, at least in the UK) Evo with 400 hp. First, the Evo was driven all-out on a road-racing track, and posted a time comparable to a Lamborghini something or other. Next, the host drag-raced the Evo against an economy rental car with a ~90 hp 4-banger. Both cars started in their highest gear, at 50 mph - and both drivers floored the gas. The result was remarkable - the rental car actually pulled ahead! It walked away from the Evo, while the latter was hopelessly out of its power band, and unable to build boost.
  9. V6, L6, V8, whatever.... what perturbs me is that this thing is supposed to weigh >3800 lbs in Japanese trip - perhaps even more for U.S. spec. That's about the same as a Shelby Mustang on the proposed 2009 (?) Camaro. How's that for progress/technology/innovation?
  10. It seems that in the car hobby, as in most hobbies, there are two peaks of activity: folks aged <25, and >45. In between those pesky career and family obligations invariably detract from time, money, and motivation.
  11. I went the exact opposite route from starting my own business - got an undergraduate engineering degree (aerospace), then got a government job and the gov't paid for my grad school degrees (also in aerospace) - piled higher and deeper. Now my job consists of a mix of in-house research, program management and administrative stuff. The job isn't bad, but the location is very contrary to my preference. And being a very narrow and deep specialist, relocation is not an option; you become married to your lab! From my experience, there is very little difference between school and the "real world". Nearly every day I open at least one of my old textbooks. A large part of my job is running experiments, taking notes, reading and reviewing technical literature, and writing papers. If I were to change jobs, the logical alternative would be academia.
  12. Back during my graduate student days in the Los Angeles area in the late 1990’s, an acquaintance of mine had 3 or 4 Opel GT’s - all stored in a Caltech parking garage. Two were parts cars, but one was spotless. The rotating headlights and lack of rear hatch were rather quirky, but the exterior aesthetics were very attractive. I’ve heard of Opel GT’s as drag cars, with everything from 426 Hemis to turbo 4-cylinders. Personally I think that the best swap option would be a Mustang 5.0 V8, built mildly to around 250 hp. This would probably be the threshold at which chassis reinforcement or major suspension mods would not yet be necessary.
  13. It seems strange to have a BBC vs. SBC debate on a Datsun site! That said, let’s clear up some misnomers… - all pushrod engine families are having problems these days wiping lobes on flat-tappet cams. There is anecdotal evidence that big blocks are more prone to this than small blocks. My single data point is a 1978 Mark IV BBC into which I installed a Comp 262 Xtreme (or whatever it was called) hydraulic flat-tappet cam, together with their matching springs - back in 2000. Wiped the cam after 20 miles, despite by-the-book break-in. Now I run a mechanical roller. - It is true that the BBC valvetrain is heavier than that of the SBC, but a matched set of lifters-cam-pushrods-valves-springs-retainers, set up with correct clearances and installed-height, will even the playing field. - If you do buy good aftermarket valvetrain parts, prices for SBC vs. BBC are not much different. The notable exception is heads: BBC heads are around $2000 assembled, while comparable SBC heads run $1000-$1200. - The BBC family has no equivalent to the LSx; a more proper BBC vs. SBC comparison would be Mark IV BBC vs. Gen I SBC. - 500 hp is about the break-even point, beyond which a BBC build becomes comparable in cost to a SBC build. Head north from that, and the BBC becomes cheaper. - There is no JTR-type kit for BBC installation in a S30 Z. Some people have however successfully used a very similar approach, while others have used firewall setback (me) and still others have gone the full tube chassis route (Ron Jones, Brad Barkley) - The BBC remains an engine for specialists, who grew up using them or who just prefer their layout over the LSx engines. As I’ve been saying for many years, the “best†engine to swap is the engine with which you personally happen to be most familiar. That may not be the most elegant, or most economical, or most advanced engine - but if that’s the engine with which you have the most experience, that is the best swap candidate for you.
  14. Business savvy is a great trait to nurture and ultimately to use to get out of the proverbial rat race. Our society assigns a special prestige to business owners. And don’t forget the tax breaks; $300K/yr of business profit is taxed much more leniently than $300K of salary! But not all of us are risk takers, and many would be wiser to take stock of their strengths and weaknesses, and to remain employees. In science, engineering, finance, medicine etc. there are many worthwhile institutional employment opportunities whose remuneration potential rivals what you’d pay yourself as sole proprietor. I mean, if you’re a carpenter then almost certainly you would do better by owning a carpentry business than by working for one, but if you’re a physicist you may think twice before quitting your university job. That said, lots of guys on this board are natural do-it-yourselfers, who started out not knowing a crescent wrench from a tire iron, but who went on to craft gorgeous cars from rusted-out barnyard specials. I can’t imagine how you can make a living reselling parts on E-bay or running a mail-order business from your basement or running your own chassis fabrication shop, but some guys do precisely that, and very successfully. So maybe more people on this board should be exploring self-employment, especially before family responsibilities curb one’s risk tolerance. For myself, the plan is salaried employment and defined-benefit pension. I’ll explore the wild-side after I’m 50…. As for "live for today, because who knows what tomorrow might bring": I beg to differ! I'd rather live miserly and die wealthy, never enjoying a single cent of my net worth, than risk running out of money before I'm dead.
  15. The “paint†and “interior†numbers are optimistic, but otherwise this reads like a reasonable cost estimate for a stock-ish swap, assuming that you already have a Z in decent condition, make no suspension mods and are content with a bolt-in “roll barâ€. Relaxing those assumptions and starting absolutely from scratch, the cost will conceivably double, or worse. The result becomes a decent-looking, decent-handling 2900 lb (if based on a 280Z) 300 hp $12K-$15K sports car, which takes a patient and moderately skilled fellow about 2 years to build. Compared to a late 90’s Z28 Camaro, it will be 600 lbs lighter, probably better-handling but slightly less reliable and much less comfortable. Still, a favorable comparison - provided that you do all of the work yourself. Farming out work to others, following dead-ends, suffering blown-up engines and other setbacks will however reverse the favorability of the comparison.
  16. Transmission choices are to some extent constrained by the bellhousing: in many applications a blowproof bellhousing is imperative, especially with engine setback. When I started my swap (1999), there was no blowproof bellhousing for the T56. I ended up with a Doug Nash 5-speed (which fit the standard Lakewood bellhousing for Chevy), on the strength of the recommendation of a hot-rodding buddy, and because I stumbled into a good deal on a used one. In hindsight this was a poor choice: shift quality is horrible, there is no overdrive and the gears are too close together. Every application is different, but for a light car with a very torquey engine, the wider the gear spacing the better. My ideal gear ratio choice would strike some folks as outright ridiculous: 3.5:1, 2:1, 1:1 and 0.5:1, with a 3.54:1 rear. 3.5:1 would be used only for drag racing with 33â€-diameter slicks (or similar). With 25â€-diameter street tires the other three ratios would be used - but that’s with an engine that is happy cruising at 1300 rpm. When I drove Pete’s car with the Tremec 5-speed, I found myself yearning for a deeper first gear (numerically higher ratio) because I’m a dweeb and don’t know how to shift; I tend to upshift at 2500 rpm.
  17. Contemplating a “quality†late-model used car purchase, I got interested in the 2002-2003 Mercedes C32 AMG, which is their souped-up C-class sedan, with the 3.2V6 topped by a positive-displacement blower. Depending on mileage and condition, these cars can be found for < $25K, which is about 50% depreciation over 4 years. Internet discussion on these cars is awash with nothing but glowing praise, but I’m concerned about reliability and cost of maintenance. Does anyone have any experience with these cars? My test-drive was very satisfying. Punch the gas pedal and seat-of-the-pants acceleration is exactly what I’ve been looking for in a daily driver. If reliability were not a problem, I would likely buy one.
  18. Mention was made of getting adequate traction, and reinforcement of the unibody to support a particular level of spirited driving (which, the racers tell us, has more to do with a stiff suspension and sticky tires, than with a high-torque engine). But what about the cost of building up the engine and driveline? There is a "knee" in the curve of hp vs. $, and it depends more on the choice of engine and skill of the builder, than on the choice of car into which the engine will go. In other words (and this will be controversial!) the cost is roughly the same in a Chevelle as in a Z. I mean, a $7000 SBC Chevy (or whatever engine) doesn't know into what chassis it was bolted into. But then there's the assertion that the Z is lighter, so less power is required for the same performance feel, relative to a muscle car. True, but does a 350 hp engine cost that much more than a 250 hp engine? What about a 450 hp engine? Again, the point is: consider the potential and the cost of the powerplant first, and don't worry (at first) about Z-specific engines. In my case the swap itself was relatively straightforward, but care and feeding (and repair and re-repair!) of the engine is interminable!
  19. I ended up with a cam from Cam Motion because Pete told me to do it. Actually, I wanted a mechanical roller cam with moderate duration and relatively aggressive profiles, with quite a bit more duration on exhaust than intake (to partially compensate for a small-diameter exhaust tract and poor e/i ratio for my heads). No such cam was available off-the-shelf from Comp, Crane, Crower or Isky. And if I were to go for a custom grind, I might as well pick a niche manufacturer. Carolyn Boone at Cam Motion says that they (Cam Motion, that is) do not have valvesprings suitable for my application. Instead, she recommended 933 springs from Comp. Meanwhile, my prefered supplier ("Wolfplace", in Northern California - he does not post here, but frequents the Chevelle Tech forum) gave the nod to Comp's 26094 springs, which have the right numbers but are quite pricey. So the quandary persists....
  20. I was in a similar predicament recently - needed to revise my choice of valve springs, to match my "low lash" mechanical roller cam. Unfortunately Comp does not make a beehive spring for this application - and in fact their tech line counsels that a single-spring (no damper) is risky for mechanical rollers. On the other hand, low-lash roller take surprisingly low pressure (160 seat, 450 open) relative to what's common for usual mechanical rollers, which really confuses tech line guys at the major manufacturers (the manufacturer of my cam, Cam Motion, does not sell springs). I'm probably going to end up with Comp 26094 springs - which are advertised as being for flat-tappet cams. Thought coil bind should not be an issue per se, my machinist recommends extending the 0.060" rule to 0.100" for endurance applications - a standard that the 26094's fail. Crane makes a similar spring good for 0.700" lift, which might be a better fit. Anyway, I'm mumbling here. Bottom line is that some half dozen considerations of spring pressure and valvetrain geometry have to be taken into account, and for the relatively unusual applications there is no good off-the-shelf solution.
  21. Solidworks proficiency is a very worthwhile skill to acquire, especially now that Solidworks seems to be taking over from some of the higher-end drafting packages. However, take care not to pigeonhole yourself as a draftsman or "mechanical designer". They get paid less than engineers with equivalent experience, and tend to be hired as short-term contractors.
  22. This would only be worth $1.5M to a effete billionaire trying to gain street cred with a more "real" crowd. Sold individually - if every part were cleaned and sold - the sum total might amount to $1.5M, but the labor involved would be high 6-figures. But those dogs are really awesome!
  23. Did the scales really protrude 1-1.5" above the tunnel floor, thus elevating the car by that amount? If so, then this is a pretty significant flaw in the A2 tunnel. Scales should ALWAYS be flush with the floor! One solution is to make a plywood template with cutouts for the scales, and a ramp several feet in front of the car, thus elevating the flow back up to "curb height" relative to the car. How much more expensive - and how much busier - is the larger tunnel?
  24. Looking at your data set, I think that the most important info is contained in three columns: CD, CL_front and CL_rear. The number of runs is very impressive for a one 8-hour shift, and compares favorably with what our engineers achieve for airplane-type testing in our tunnels. I would caution that every wind tunnel is a little bit different, so comparing numbers from your test with published numbers or measurements in other facilities is always a bit dicey. That said, the baseline numbers for lift and drag coefficients sound about right; drag is a bit high, but it would have been lower (I think) with a moving ground, or a least a boundary layer sucker upstream of the test section. There may also be some "blockage" effects that can not be entirely eliminated, despite what certainly appears to be commendable good sense on the part of the facility operators. I am however surprised that the various approaches at drag reduction did not yield more than they did. But not being part of the crew I can only speculate whether lift reduction, as opposed to drag reduction, was the primary objective. An anecdotal comparison - so, let's not get too worried about it - is that of the Hot Rod 2nd-generation Camaro - which evidently dropped something like 40% in Cd, with the various modifications tried during testing in A2. It still seems to me that the culprit is the Z's sharp hood lip. The G-nose doesn't help (I'm not surprised), but what "should" help is radical surgery to the hood, dropping the radiator upper crossmember by some 2" and sloping down the hood lip. This is unfortunately difficult to implement and is only practical for a V8 car with lots of engine setback (and probably firewall setback).
  25. I bought a 454 out of a Chevy Suburban with something like 130K miles. I did a cam swap, and got maybe 20 miles out of the engine before wiping the cam. Years later I rebuilt the engine with some pretty high-quality parts, but the cam sprocket bolts (not the 3 that hold the cam timing gear to the camshaft, but the rosette of 6 which hold the 2-piece adjustable timing gear together) worked loose, dug into the aluminum timing cover and scattered aluminum shavings all over the engine’s oil path - after 43 miles of driving. Engines fail early because owners are incompetent, complacent or just plain unlucky. While there are the occasional bad apples, a blanket statement that “Brand X engines fail much more readily than Brand Y engines†is, in my opinion, pointless. That said, if I kept the original L6 in my Z it might still have been running…
