9
Everything posted by Michael
Who swaps their engines by themselves?
Michael replied to Plague_oc's topic in Gen I & II Chevy V8 Tech Board
Returning to the original question in this thread.... The choice comes down to this: doing your own engine swap belongs to a particular lifestyle. Does that sound like your sort of lifestyle? If so, then any alternative to doing it yourself will be unsatisfying and will leave the proverbial poor taste in your mouth. If not, then by doing it yourself, you’re setting yourself up for frustration - or worse. So the satisfaction of building your own car is not to be denied, but be wary of the flip side: many years of toil with no completion in sight --> dejection and self-doubt. And ask me how it feels when you’ve been working on an engine for 7 years, then drive the car for 40 miles, open it up for minor tuning and find significant internal damage… There are so many disparate yet related aspects to this hobby - the craftsmanship, the engineering, the sport, the camaraderie. Achievements in many of these is possible even if you never finish your car. Still, it’s hard to be proud of a project with recurring setbacks, like blown engines or broken suspension parts. And it’s hard to maintain motivation when seemingly even the simple things backfire (such as the carburetor ). But hanging out with knowledgeable people is a rewarding experience in its own right - whether in the car hobby or essentially anything else. In hindsight my own project has many regrettable aspects. Strictly in the practical terms of owning a fast car, I would have done far better by either buying an OEM sports car and leaving it stock, or performing minor bolt-ons on such a car, or buying some one else’s complete or nearly-complete project car. Going your own way as an engineer/hobbyist has an ineluctable romantic pull. I couldn’t resist, to my detriment in practical terms. But only in practical terms! The emotional and intellectual rewards defy quantification. They will remain even if the engine’s oil pan doesn’t get reinstalled for 20 years. Welding, cutting and measuring, fabbing parts etc. are often regarded as the tough part of a hybrid engine swap. This is not necessarily true, depending on one’s mix of skills and one’s experience. The tough part can be the “routine†auto mechanics - keeping a high-performance engine together. -
Building a scale windtunnel
Michael replied to rudypoochris's topic in Windtunnel Test Results and Analysis
For you guys currently in ME undergrad programs - this stuff should all gel by the time that you're halfway through your junior year. That is when you get the coursework with some real-world examples. To get a head start, consult the books.... An easy but useful book - intended for airplanes, but just as applicable for cars - is "Introduction to Flight", by John Anderson. Ignore the stuff on compressible flow, but concentrate on the first 4-5 chapters. Once you have read that, have a look at "Low-speed Wind Tunnel Testing", by Barlow, Rae and Pope; http://www.amazon.com/Low-Speed-Tunnel-Testing-Jewel-Barlow/dp/0471557749 -
Why don't you guys contact the Mechanical or Aerospace Engineering department at your local university? They probably already have the facilties that you would like to use, and can answer your questions in detail. -
Some more philosophy to add to the pile.... Engine swaps are big projects. They might appear to be comparatively small to folks already well-versed in automotive craftsmanship, but especially for the fellow just starting out with tinkering in the garage, it's a big undertaking. As some testaments above have already noted, you CAN be successful with the V8 Z swap with little or no prior experience, but the key is having the right mindset - the combination of self-confidence that gets you through the rough spots, with the humilty of knowing when to ask for help and to admit making mistakes. The creativity of finding your own answers, and the studiousness of researching answers already out there. It certainly helps to have a mentor, to be part of a club or other support organization where the proverbial greybeards look out for the proverbial cubs; it helps to have a shop full of high-end tools, and the experience to use them. But mostly it's a matter of personality, of mindset. From personal experience I can attest that even if you have most of the tools and some hot-rodding experience, you will be frustrated with the engine swap if you're not the do-it-yourselfer type. Me - I'm more of the armchair theoretician. I kept getting stymied by "simple" problems that a more even hand would have detected early. Why not buy an older V8 car - not necessarily high-performance - and just spend a few months wrenching on that? Play with the timing, the fuel delivery, etc. Swap intake manifolds, and later swap cams. Get to know the engine. And then, once the "basic" mechanical stuff is under your belt, start on the swap itself. To a large extent what's hard about the V8 Z engine swap is not making the mounts or fitting the driveshaft or splicing wiring harnesses; it's the care and feeding of a high-performance engine. -
Understanding the numbers on the data sheets
Michael replied to Carl Beck's topic in Windtunnel Test Results and Analysis
In any actual wind tunnel test there will be variations from run to run; repeatability is never perfect, especially if the schedule is tight and the fan rpm control system is ... well, not the best that money can buy. So in every run, the wind speed in the test section will be slightly different, despite the desire for the same nominal conditions. Sometimes it will be 80.7 mph, other times 78.9 mph, and so forth. But each time, the value is recorded, converted to dynamic pressure, and saved for future reference. Then, the physical forces for each run are normalized by the corresponding dynamic pressure for that run, to be reduced into coefficient form. If you want the actual lift and drag at 120 mph instead of at 80 mph, multiply the numbers for 80 mph by (12/8)^2. At 120 mph Q = 36.7 lbf/ft^2. In the end, variations during the tunnel runs are pretty small. We're trying to improve CD from 0.45 to 0.35 (for example); a 2% error here or there isn't going to make that much of a difference. Do we have any means of doing a group teleconference, where we could all go over the highlights of the data? I'm not trying to imply that somehow magically I have all of the answers, but it would be easier to explain some of the lingo verbally, so that we're all on the same page. -
Q is the dynamic pressure, 0.5*density*V^2. If the testing were at 80 mph (=117.3 ft/s), at "standard" conditions Q comes out to 16.3 Lbf/ft^2, in the usual engineering units. Cross-sectional area times Q times the drag (or lift, etc.) coefficient gives the drag (or lift, etc.) force. I really regret that I didn't participate in your wind tunnel test.... -
Need carb size and brand advice
Michael replied to pparaska's topic in Gen I & II Chevy V8 Tech Board
Pete, by way of comparison, I e-mailed the Barry Grant tech-line for advice for my application. I told them that mine was no daily driver, seeing maybe 200 miles/year on the street, that it weighs 2600 lbs (about right) and should have its torque peak at 4000 rpm (probably about right, too). The rest you already know. Well, the recommendation came back today: "750 Mighty Demon P/N 5402010GC". The recommendation is reasonable, but probably errs on the side of conservatism. The fellow said that "this carb is capable of 900 cfm..." Well, he's right - but at what pressure drop? Even a 390 CFM Holley 2-barrel can flow 900 CFM, given enough pressure drop - and consequent VE losses. What are your thoughts on downleg vs. annular boosters? -
The idea is intriguing, but the business case is difficult. Most of the people amenable to "checkbook hotrodding" would prefer a high-dollar restorod. Whereas the average guy would feel silly paying anyone for a custom job; he would rather do it himself, even if he is incompetent - because he thinks that paying some one else somehow cheapens the whole experience. And he might not trust anyone else to "do it right". And most people would rather spend pennies on the dollar by buying some one else's nearly-complete project, and then finishing it themselves. It's a much better business case to sell/install rims, spoilers and exhaust-tips.
You moved to Dayton? WHY? WHY? WHY? My life’s obsession has become moving out of Dayton! Anyway, welcome! - and perhaps now we’ll have a critical mass for a Dayton-area Z meet? I’m out in the “countrysideâ€, about halfway between Xenia and Wilmington.
I drove an automatic 6-cylinder 1991 190E for about a week (300 miles mixed city-highway) last fall. Competent car, but nothing particularly special. 1st gear would not engage unless the gas pedal were really mashed; otherwise it would leave the line in 2nd. Top gear felt unusually short for a German car; highway rpms were quite busy. Looking under the hood, its swap candidacy did not impress me; the L6 fits snugly, and distance between the strut towers looked considerably less than a Z. But the seats were comfy and the interior felt more solid than in my similar-vintage BMW 325is.
All of us are incompetent in our own little ways; if we had laws banning stupidity, most of us would be incarcerated for life. The scary part is how modern technology can both magnify the effects of our incompetence, while simltaneously shielding us from its immediate obviousness. I too get annoyed when drivers swerve, brake at the last minute, devote more attention to their phone conversations or to disciplining their children or fondling their pets than to the task of operating their vehicles. But it seems to me that being on the road is, fundamentally, a risk. By getting into my car I implicitly agree to subject myself to the flaws and failures of my fellow drivers - as they agree reciprocally to mine. It is however worthy of mention that our society is tremendously dependent on automobiles for routine transportation; no civic reengineering plan could possibly alter that. It's the fact that we live in our cars that raises the odds of horrific rarities to the point where we each know some one who has suffered catastropchically in a motor vehicle. But - callous as it may sound - perhaps this is the "disease" of our times. Centuries ago it was plague or tuberculosis; for us its car accidents.
Why not just a hydraulic throwout bearing? No clearance problems, easy installation, relatively inexpensive.
Grumpy, what were the build specs on that 496? And if you were to drop the compression ratio by one point, but keep everything else absolutely unchanged (so, think of it as shaving the piston dome but magically not affecting the flame propagation or quench, what would be the estimated drop in the torque curve? BTW I bought my heads (Brodix Race-Rite), lifters and a bunch of other parts for my 454 from Mike Lewis.
For me the purpose of the Z is to have something with which to tinker and to get creative. Bang-for-the-buck it would make more sense to buy a late-model used G35, Corvette, M3, or even Z28 Camaro. Where the Z excels is (1) much easier to modify on a fundamental level (as opposed to bolt-ons), and (2) does not depreciate just sitting in my garage. But in hindsight it would have been better to have several Z's: one "stock enough" to be a nearly daily driver, one with minor mods suitable for recreational racing at the local track, and one that's truly wild (and therefore completely unreliable, tempermental and expensive). I have been justifying my Z hobby by sticking to bottom-dollar daily drivers, such as 20 year old Accords and Sentras. Perhaps the best compromise is a $10K-$20K daily driver that's in the category of being inexpensive enough to justify driving it hard, but still new enough to be reliable and nice enough for relaxed normal driving.
Question: HP Gain in stroking to 383???
Michael replied to mamba_888's topic in Gen I & II Chevy V8 Tech Board
The best reason to do these kinds of upgrades is if you're doing a rebuild anyway. That is, if replacing the bearings, rings, etc. - and especially if upgrading to an aftermarket rotating assembly, or if pondering a rod resizing/crank grinding job - then that's a good opportunity to upgrade to a stroker crank. The justification is quite a bit more tenuous if the 350 is already running strong as-is, and you're just contemplating a stroker upgrade. -
I'm a career civil servant in the federal government. I sit on my butt all day and eat bon-bons. When that gets boring, I play tetris. Last year I got a promotion.
If a float is stuck at the pivot, then there will be a fountain of fuel gushing out of the corresponding bowl's air breather tube. This happened to me after I removed one of the bowls to replace a sight plug. My Holley sat for 5 years while the engine was being rebuilt. Over those 5 years, the only discernable damage was rotting of the rubber O-rings in the needle/seat assemblies. You might want to check those. Other than that, is is unlikely that age alone will cause the carb to misbehave. Perhaps it is worth taking to a local mechanic, just to have him turn the various screws and widgets back to stock settings - and, perhaps more importantly, to get the piece of mind that the unit is basically OK? In other words, I would not buy new parts before ascertaining the old part is defective, instead of merely out of tune.
I’m going to disagree here; this guy’s combo isn’t that bad! Comparing the specs, it is actually not too different from the Goodwrench 260 hp "stock replacement" engine. Most of us run <9.5 compression with cast iron heads; will one point of compression make that much of a difference? For the technically minded, consider how one point of compression affects the DCR with the valve closing profile on the typical flat-tappet hydraulic cam. BTW the "torque cam" should be good for maintaining cylinder pressure with the relatively low static CR. Yes, the intake manifold is mismatched, and maybe costs 30 ft-lbs of torque at 2000 rpm; maybe more if the carb is too big; even more if the manifold’s runners match poorly with the intake ports of the heads. But it’s not like it is magically turning a 500 hp engine into a 75 hp engine. Even with “only†200 hp and perhaps 250 ft-lb at the crank (160/200 at the rear wheels, give or take) this should be a reasonably enjoyable car to drive, provided that the TUNING is right! I’d not worry about swapping parts, or second-guessing oneself about mismatched this or that, and instead would focus on good, reliable timing and fuel delivery. Make sure that the rings are holding compression, that there are no chunks of metal in the oil pan, that the carb isn’t puking fuel and that the plugs are not fouling. The rest, I think, is of secondary importance for the time being.
Sounds like the next piece in the collection should be an AK-47. I thought about getting one, just out of homage to nasha rodina, but the only ones that I could find were Romanian or Chinese!
building a dream or wasting your cash?
Michael replied to grumpyvette's topic in Gen I & II Chevy V8 Tech Board
The trick is to have no dreams. Then you can't be disappointed and won't waste your money. -
Mine had similar problems (454, stock HEI, 750 vacuum Holley on a Edelbrock Perf rpm, choke mechanism removed, moderately healthy mechanical roller cam). First it ran OK, then on successive attempts (days, weeks) it would run worse and worse. Then I realized that the distributor hold-down bolt was not completely tightened, and over time the distributor had rotated counterclockwise! Not sure about vacuum leaks in my case, butI did observe that if I blocked the carb venturis with my hands - even slightly - the engine would cough and sputter; if anything, it was starving for fuel. And when cold, it would need 1-2 minutes of ~1500-2000 rpm operation before it could settle into a stable idle. Once settled, it idled fine at 800 rpm. Fuel leaks from the venturis at idle (incorrect float level). My next step, since parts of the combo are definitely weak links, is upgrades; capacitive discharge ignition system and aftermarket distributor, 850 CFM mechanical-secondary carb (probably Barry Grant mighty-demon). I'm looking at a system that could communicate with manifold vacuum (below the throttle blades, not above) with dial-back. But this is for a fairly aggressive engine; if yours is more mainstream, then throwing money at it is probably an ill-advised solution (as, indeed, in may also be in my case...)
The light-weight, stripped-down, moderate-hp elemental sports car is an excellent idea in theory, but doomed in practice… 1. The demographic that used to buy sporty-cars is now buying trucks and SUVs. “Sports cars†today mean high-end low-volume flagships or souped-up sedans 2. There is very little market in 2-door anything these days; if it’s a car at all, people want 4-doors; otherwise they get a truck (see above). 3. Polls about muscle cars - for example those in Hot Rod Magazine - consistently show that while low-buck high-performance strippers (cars, that is) are popular in theory, when asked specifically what they wish to buy, people overwhelmingly prefer air conditioning, heated power seats, keyless remote and sun roofs. So much for low cost and light weight. 4. The aforementioned safety and environmental regulations. Look at what happened to the Pontiac Solstice; cute little car, but 2900 lbs??? That is probably more than a Datsun 810 (forerunner of the Maxima) in the 1970’s. 5. There is something in the American market that overwhelmingly leans towards large cars. Maybe small cars are viewed as wacko-lefty Euro-boxes, or maybe it’s something about romanticizing the great open plains and the giant redwoods, or maybe its just compensation. But whatever it is, European-type compact cars are viewed in America as cheap, low-rent appliances for those too poor to afford anything better. 6. While today there are more car models than ever, there are surprisingly few dedicated platforms. It may cost a manufacturer more to strip-down an existing model than to keep selling it with its luxo features. And it is absolutely cost-prohibitive to launch an entire new platform just for a single line of low-cost sporty car. 7. The OEMs and the market have pretty much decided that RWD is a luxury feature. Worldwide, compact RWD cars are essentially universally dead, except for a few niche convertibles. 8. We - the performance enthusiasts - are a very small minority. And among us, many are too cash-strapped or too frugal to buy a new car with performance in mind; if we do buy a new car, it’s reliable transportation for the wife and kids, or a comfy long-distance cruiser with a smooth ride and a punchy stereo. So, again, who would buy the stripper sports-car? The arguments are the same for related questions: in model lines with multiple engine options, why is a manual transmission only available with the wimpiest engine; why is the strongest engine often only available in an options bundle with the bling features and gadgets; why isn’t the JDM or European-domestic market model available in the U.S.; why do OEMs devote great effort towards making fuel-efficient engines and low-drag bodies, but do not place any emphasis on reducing vehicle curb weight; and so forth.
I’m looking at the Crane 6000-6400; retails for around $250. Its other advantage vs. MSD 6AL is that the Crane uses switches to change the rev limit, while the MSD uses plug-in modules. I will probably get the Crane PS92 ignition coil, http://www.cranecams.com/index.php?show=browseParts&lvl=4&prt=166 . But what to do for a distributor? I might spring for the Crane 1000-1500 “electronic†distributor; nice piece, but they certainly make a nice profit off that one! And, Crane’s manual for the 6000-6400 ignition box mentions all sorts of distributor combinations, but does NOT mention their own distributor! MSD makes something similar, but that one requires removal of the cap to change timing settings, while Crane’s has screwdriver-accessible switches on the distributor body.
First, congratulations on finding a 400 SBC! It is almost universally true that 70’s-80’s full-size trucks have disappointingly poor acceleration, even with large-displacement engines, at least in stock form. Part of the problem is the wear on the engines, part is in inefficiency of the driveline, part is the weight of the vehicle; but the worst part is the abysmally poor breathing capacity of these engines in stock form; with stock intake-heads-valvetrain-exhaust, especially for a truck, net hp ratings hovered around 150. Even the big-blocks barely made it over 200. Volumetric efficiency was poor (70%? 60%?) and peaked at something like 2000 rpm. Even if the bottom end is in decent shape - bearings are not knocking, rings are holding compression, cylinder bores are not damaged, and so forth - you will most likely find yourself replacing the pistons to get adequate compression, and replacing at least the rod bolts to get piece of mind about “high rpm†reliability (I was going to say "high = 5500", but they I noticed that dr_hunt mentioned a 4500 rpm limit!) . If you buy modern aftermarket aluminum heads, it is hard to avoid having to get new pistons. And this means a bottom-end rebuild. I started with a 454 BBC from a 1978 Suburban, and ended up with a complete bottom-end rebuild, though I did retain (after considerable machine work) the stock block, main caps, crank, rods and damper. For a first iteration it is not inconceivable to keep the engine completely stock (in hindsight I should have done the same) while you solve the systems-integration issues of the swap, and become familiar with tuning and troubleshooting the engine. Acceleration won’t live up to V8 hybrid expectations, but it is a good baseline, especially when money/time/tools/resources are tight.
Everyone seems to be ecstatic about real estate these days - or was that oh-so-2005? I might be biased, but it seems to me that here in the Midwest the economy has been lethargic since the 1990’s. The coastal/southern/urban boom in real estate left most of the Midwest (with the exception of pockets of affluence, such as Chicago) largely untouched. But the 2006 downturn has affected us in the Midwest, just as it hit Boston and D.C. and the bay area. It’s analogous to the 1990’s stock market boom: plenty of stocks remained flat in the 1990’s, but they tanked in the 2000-2002 bear market right along with the former highfliers. My point is that an investment real estate play in a small Midwestern city sounds really risky, unless you have insider connections in the real estate industry. Who are the investors behind that fabled “Vision 2025†to rejuvenate the city? Can that hypothetical urban renewal project really pan out without an influx of high-end jobs to buttress the tax base? Could an old urban neighborhood be gentrified without an influx of yuppies? Why would the yuppies, techies, wealthy retirees etc. want to move there? How is the downtown itself doing - are rents rising, occupancy rates solid and new buildings being put up, or is the place just sort-of puttering along, blipping up with the major’s latest pep talk and sinking again with the latest news of another factory closing down? What about the overall demographics of the region - how has the population changed in the past 5 or 10 years? My recommendation would be to consider selling the property.
