Michael
    9
Everything posted by Michael
  1. Have we completely ruled out that it's a 1st-generation 260? Sure, the bumpers are second-generation, but what about the indentation in the front valence panel, which seems a natural fit to receive the old-style bumpers? Check underneath the car; do the frame rails terminate shortly behind the firewall, or do they extend quite a ways back? If the former, then it should be a 1st-generation 260, like a 240. And are the VIN numbers the same on the firewall (near the brake cylinder booster), the dash and the riveted plate on the driver's-side door jamb? In any case, sounds like a good find!
  2. Hybrid swaps just aren’t cheap, period. Anything requiring custom engineering will be expensive, even if you find attractive deals on individual components. As mentioned before, what causes costs to escalate isn’t the parts installed in your car, but the wrong parts, the broken parts, the worn parts, the parts that don’t work together and the parts that never should have been installed in the first place - in other words, it’s the mistakes that are costly. I’m becoming convinced that the “right” way to build a hybrid is to first own a nearly stock muscle car AND an improved-touring-type Z (or Mazda, or BMW, or whatever). Work on those for years - I mean, years and years. Learn the quirks of each. And only then attempt a hybrid.
  3. Unfortunately even thorough research, a detailed plan and a steady approach can still result in an unworkable combo or a vehicle that isn’t compatible with your expectations or preferences. The first problem is that a person often doesn’t know what he wants until he actually attains it - which presents an ineluctable catch-22. The second problem is that “minor” -yet potentially devastating setbacks can crop up despite the best planning. Example: take the “dream engine” that Grumpy discussed several months ago (all-aluminum BBC, ~540 cubic inches, symmetric-port heads, 700+ hp at 6000 rpm). Plan it out, conduct tradeoffs and paper design exercises, order parts, perform machining, and assemble it. But guess what - it’s entirely possible to get a spun rod bearing, or improper ring seating, or any other seemingly “minor” problem! Suddenly you have a potentially $5000 problem on your hands! It’s enough to make a guy want to throw that engine into the nearest river. In the end there is the universal element of luck. You can be thorough, you can be patient, you can be realistic, you can be skilled - but I’d rather just be lucky, even if it means foregoing everything else.
  4. The teardrop-type nose as pictured in Olderthanme’s second post in this thread has always been my desired cosmetic modification to the S30 Z’s nose; the sugarscoop headlights, the sharp hood lip, the fishmouth look resulting from a stock hood and airdam - all seem incongruous with the otherwise gently flowing curves of the Z; not to mention contributing to poor aerodynamics! On my car I deleted the sugarscoops, moved the headlights inboard, and replaced the sharp hood lip with a sloping nose. It remains to revise the air dam to purge the fishmouth look. Pictures are in my album. The execution is admittedly poor.
  5. It seems to me that in actuality there are very few HybridZ people in Ohio! This is a heavily-populated state with a large automotive/machining industry and a vibrant do-it-yourselfer tradition, so one would expect car hobbyists at every corner. But between the declining economy and the preponderance of interest exclusive to American cars, interest in Z’s - hybrid or otherwise - is very narrow. Also consider what we mean by “local”: the distance from Cincinnati to Toledo is about the same as from Northern Virginia to New York City - yet VA and NYC guys would not consider themselves to be from the same area! Anyway, I still say that we should have a southwest Ohio HybridZ meet - conceivably at my house. Any interest?
  6. Some years ago I got a great deal on a Lincoln Weldpack at a Home Depot (it was a returned item, which I bought for less than half price). Wire feed speed was continuously adjustable, and power was adjusted by a 5-position clicker. I tried welding sheet metal (a Z hood) and some moderate-gauge (probably 12-gauge or so) mild-steel tubes. Both were a disaster - splatter everywhere, burnt-through holes, and very little actual established metal to metal contact. By the time the splatter was ground off, metal-to-metal contact was nearly zero. I was so frustrated that I ended up giving the rig away to a local acquaintance. But on the “bright side”, I gave up trying to modify my stock hood, and instead built a fiberglass one.
  7. I’ve been looking for a decent metal-cutting band saw for along time. Jet, Delta, and other “consumer” brands all seem to be ONLY for wood or plastic. The speeds are just too high for metal, except possibly thin aluminum. So how did you guys manage to be successful cutting steel on a $300 bandsaw with 3000 fpm blade speed? The best way to go seems to be a Do-All metal-cutting band saw; see http://www.doallsawing.com/band_saws_cat.aspx?cat_id=6 . But those things cost some serious money, and I have NEVER seen one for sale in a consumer-accessible retail store.
  8. Impressive, but nuclear marine powerplants are considerably more powerful. And gas turbines, while nowhere near as torquey, have much higher power density, and could probably be combined to spin the same propeller. Of course, there's much to be said for the efficiency and durability of an inline-Diesel.
  9. Big block all the way!!! Rodeck or Donovan tall-deck aluminum block, 4.5" bore Billet 4.75" crank ~0.800" mechanical roller cam 14-71 Rootes blower Powerglide (with some mods to handle the power) Aftermarket 9"-type rear hung on a 4-link Chromoly tube chassis with lift-off fiberglass shell Wheelbase, track and engine position altered as required
  10. All-aluminum small block with the displacement of a big block - awesome! BTW my Brodix Race-Rite aluminum heads (big block) weighed about 90 pounds for the pair, fully assembled. Cast iron heads are supposed to be 70-80 lbs heavier!
  11. Curiously, as circumstances now appear to stand, if the car's owner is somehow too frightened to sue, or just does not know how to get the process going, he's out of luck. And even if he does sue, after lawyer's fees and the strain of legal proceedings take their toll, perhaps he would end up losing more than what he paid for the car. Gotta love "the system"!
  12. Externally that Nissan SE-R resembles the 1992 1.6L Sentra that I bought recently... only mine would be lucky to run the 1/4 mile in under 20 seconds. With the air conditioning running, it is unable to exceed 90 mph on a straight level road.
  13. Some one replied to my post from 6 years ago? Wow! - I don't quite know what to say....
  14. Experience shows that the swap contains too challenges: getting the engine and transmission to work, and doing the swap itself. I mean, mounting the engine, doing the cooling and exhaust, connecting the driveshaft, wiring the electricals and fuel pump, etc., is “the swap”. But if your engine is wounded then you’ll be doing engine work quite unrelated to the swap per se - and this could be considerably more frustrating and time consuming that the swap itself! So the best option, as reiterated in the JTR book, is to score a well-running donor car. It really doesn’t matter if it’s a 70’s Caprice with a old-school carb’d 350, or a mid 90’s Z28 Camaro with a LT1 - as long as the thing runs. If the donor car is relatively quick, the Z will be very quick. But if the donor car pukes smoke, burns oil and runs 19’s in the quarter mile, the Z will run maybe 15’s - which defeats the point of doing a swap. I would have to differ from some of the above posts, in that there’s something emotionally unfulfilling in using a 305 instead of a 350. Unfortunately 350’s have become much more scarce since the JTR manual first hit the market, around 8 years ago. So perhaps a worthwhile option is a 80’s-90’s Chevy or GMC pickup truck with a 350. Often these come with a 700R4 transmission, and they may be relatively easy to find at auctions - for example, retired city maintenance vehicles. A manual transmission with a Gen I 350 seems to be quite rare. Most manual-transmission Camaros and Firebirds had 305s; the 1989 Firebird that you found is almost certainly a 305. Personally I dislike automatics, but I would rather get a 350 with a slushbox than a 305 with a T5 manual, and would look for an early 1990’s Chevy pickup with a TBI 350 and 700R4.
  15. 0.712” lift in a SBC is HUGE! I have to wonder - if they went with a shaft rocker system and a commensurately race-oriented valvetrain, why did they not use aluminum heads, and why did they limit themselves to 385 cubic inches? This engine could evidently get decent volumetric efficiency even approaching 7000 rpm - but at that point, would the bottom end still be reliable?
  16. I had a 1987 MKIII Supra. Some people swear by these cars, but it wasn’t my type at all: heavy, ponderous, and with obnoxiously annoying turbo lag. Oh yeah, and the head gasket blew twice. They are, however, quite comfortable and very stable in high-speed cruising, but that’s not my driving style. The car that I really miss is my 1983 Celica - it was the first generation to have reliable fuel injection, and the last generation still with RWD. It was a bit boxy, but reasonably light (about 2600 lbs, if I’m not mistaken) despite being quite roomy. A really cool swap would have been some sort of V8 (such as 302 Ford) into the 1983-1985 Celica. Some pictures of a similarly-equipped drag Celica were floating around a few years ago.
  17. Agreed that this heat is miserable, especially when air conditioning at the office breaks down! But also agreed that it’s nowhere near as unpleasant as the winter freeze. Last year right before Christmas we got >12” of snow, followed by sub-zero nights and 10-deg days. It’s almost 400’ from my garage to the road, and digging that by hand took me most of one night, the entire following day, and the next evening. We ran out of clean drinking water (it is unsafe to drink our tap water, as it comes from a questionable well), and quite literally had to gather snow in buckets and boil it. Summer might be especially hot in the city, but winter is especially miserable in the countryside! Every time I catch myself cursing the heat, I shudder to contemplate the coming snows.
  18. I seem to have lost motivation right after the car was “done”; drove it a total of 2.0 miles (as registered by the odometer) in three segments, mostly up and down my driveway. It’s really hard to shift, the engine smokes profusely, and who knows what sorts of horrors await me at the dyno shop, where I intend to take the car for diagnosis. Eventually I realized that it is simply impractical to drive this car on the street; I need a tow rig and trailer. Besides, I would rather have a “running” car sitting in my garage, than banging on it, only to render it into a pile of broken parts.
  19. In my view there is much to be said for the achievement value and camaraderie of working together on a group HybridZ car. The more experienced folks would help the younger ones. The theoreticians and the practitioners would find some happy medium. The road racers would dip into drag racing, and vice versa. But what is the justification for “promoting the Z car experience”? What do we gain from popularizing Z-cars, Hybrid or otherwise? Do we need expanded endorsement and attention to feel better about our cars? Would we like to get more “respect” at car shows and race tracks? Do we wish to reverse the condescending treatment in Hot Rod Magazine? Would we hope to get discounts on parts, or more model-specific aftermarket support? I’m very interested in participating in a group build, but the objective is to meet more fellow enthusiasts in person and to learn from their experience - and maybe to share a bit of my own “experience” - and NOT to somehow increase visibility or engage in an advertising campaign. This is why it makes sense to have several HybridZ cars under construction concurrently, in different parts of the country; one in NorCal, one in SoCal, one in Texas, one in Florida, one in the Mid-Atlantic region, one in the Midwest, and so forth. I would like to be with a few hours’ drive of the build site; and in fact, the build site could rotate amongst several different garages. Such cars would NOT be built over a few months, then raced and retired. They would evolve over many years, chronicling lessons-learned and building a real-life FAQ list.
  20. For a rotational system, power is torque times angular speed. The power dissipated in spinning a transmission comes from two parts: that necessary to change the rpm (when accelerating), and that needed to maintain a steady rpm. The former goes as moment of inertia times rate of angular acceleration times angular speed. This is where spinning “big stuff” takes more power. The latter goes as force (as in friction) “times” (actually cross product) a moment arm times angular speed. A transmission with lots of big, heavy parts (technical terms here!) does not necessarily absorb lots of power when maintaining a constant rpm, but it will absorb lots of power to spool-up. Whereas a transmission with "light" parts might nevertheless absorb lots of power in cruise, if it has a lot of internal friction acting between surfaces at high relative rotational rates.
  21. This is one of those open-ended questions that tend to rile people, as (1) it has been asked frequently before, and (2) the answer depends completely on the scope of your project, the initial condition of your car, and the extent of your hot-rodding experience. An experienced mechanic starting with solid, rust-“free” car and a complete set of parts could complete the swap over a weekend. An inexperienced non-mechanic with a worn-out car and an incomplete/mismatched set of parts won’t complete the swap even in one year. Some people are now into their second decade.
  22. If you used the JTR mounts, which offset the engine towards the passenger side, header/frame rail interference is almost certainly unavoidable; be prepared to notch the frame rail and weld in a patch.
  23. This reminds me of the thread about whether people work on their Z alone or in the company of friends/advisors. There the preponderance of comments were in the “alone” column. And in this thread, most folks are posting that they are the ones providing the tools and being the neighborhood automotive resource. Whereas I tend to be the guy who appeals to acquaintances to borrow tools, to weld something for me, to come clean my gutters, etc. Maybe this is why it took so long to get my Z built, and why it’s still no really finished? Then it dawned on me… at work, I tell graduate students, technicians and the like to wire such-and-such device, to calibrate so-and-so instrument, to run various tests, do different derivations, plot this and that - but I don’t do any of that myself! Instead, I go to meetings, review proposals, chair sessions at conferences and write research topic descriptions. In other words, I’ve become a manager! I am now officially incompetent and obnoxious!
  24. This brings up an excellent point: not all of us are comfortable with E-bay or other internet-based long distance purchases. There is something to be said for visiting a junkyard within driving distance and finding a usable engine - if only a core. This shouldn’t be hard for something as common as the 350 SBC! For a number of reasons this option is in decline. Junkyards are closing down, while internet "commerce" is pulling the rug out from traditional in-person sales. When I lived in the Los Angeles area I relied on the “Recycler” newspaper, or its web site; the latter combined internet reach and immediacy, with local convenience. Anyway, back to the original question… consider buying a 1970’s-1980’s Chevy truck with a 350; these remain relatively plentiful, while full-size automobiles of similar vintage are becoming rare, and in the vast majority have 305’s instead of 350’s. Or, if you plan on a complete rebuild with heavy reliance on aftermarket parts, perhaps local machine shops already have bare blocks.
  25. Project_BBZ, congratulations on the resumption of work on your Z! But why the 049 heads? Didn’t you sink plenty of labor into cleaning-up those Pro Toplines? It is highly unlikely that even professionally ported 049’s would flow comparably to the Pro Toplines. But perhaps your new combo is more conservative and the aftermarket heads would be of minor additional benefit… My big block Z now runs - well, to some extent. First oil change revealed no cause for alarm regarding possible bearing/rod/cam lobe problems, but I’m still worried. In fact, I’m so petrified that I would rather have a functional car sit forlorn in my garage, than risk damaging it by driving it - which, I suppose, negates the whole point of building the car… Anyway, be patient at this stage of the build; it would be most disconcerting to rush through the final details, only to discover a $4000 mistake upon break-in.
