Michael
    7
Everything posted by Michael
  1. That does sound intriguing! I have a 280Z which might perhaps be back on the road by the time that your autumn semester starts. Its condition is approximately of the type that you desribe (some rust in rocker panels, covered by POR-15 years ago, but otherwise generally rust-free). Where in Kentucky are you? I'm about 50 miles north of Cincinnati, Ohio.
  2. I removed the reinforcements and related sheet metal from the doors of my 1978 280Z; net weight savings: 10 lbs. Certainly something to consider in the all-out effort for your specific purposes, but not a huge weight savings. Cutting out the front bumper supports and the associated bracing forward of the radiator support should be worth another 10 lbs or so. If you have enough time, consider cutting out the entire radiator support, including the transverse crossmember forming the power portion of the radiator support and connecting the frame rails. Replace with round or square tubes. What about replacing the radiator itself, with an aluminum universal-fit unit, such as Griffin?
  3. While we’re on the subject of deep pockets…. For some one with the resources, the engineering know-how and the gumption to make such an ambitious purchase, wouldn’t it be wonderful to take the additional leap to build a complete car from scratch – to build something truly light-weight and modular, with a chassis designed around the drivetrain, and thus avoid the compromises inherent in any hybrid? If I had the experience and the time, I’d begin quite literally with a clean sheet of paper. Begin with the conceptual design; wheelbase, suspension architecture, rough layout of main components. In aircraft design, once a notional mission is defined, we conduct performance trades, to determine minimal thresholds of things such as thrust to weight ratio, wing loading, fuel fraction, and so forth. Well, apply similar thinking to cars. Then proceed to chassis design and external lines. Some day I’d like to build a car with size and weight comparable to the Anglia or Fiat Topolino, but with better aerodynamics and better chassis design, stuffed with an all-aluminum ~600 cubic inch BBC, with a chromoly frame and fiberglass lift-off body panels. But until then – there’s the Z.
  4. Peak torque and hp figures are very impressive, especially considering the 2.4L displacement. But I can’t help asking… at 2500 rpm, which is already pretty high in my book, this thing isn’t even making 35% of peak torque! Is such a radical torque curve considered to be an acceptable price to pay, to obtain those peak numbers?
  5. I wouldn’t be surprised of that weight figure is optimistic. With aluminum heads, Doug Nash 5-speed, R200, mild-steel roll cage and very liberal slicing of the unibody, I’m hoping to get my 280Z under 2600 lbs. It weighed in at 2725 with cast-iron 236 heads, full-size starter (figure 10 lbs savings), stock hood (new hood weighs 7 lbs). And about 30 lbs have been saved from gutting the doors, hood mounting area, “baggage compartment†behind the seats, etc. Anyway, my original thought was that $24K is pretty cheap for a pro-built car running in the 9’s. But then I realized that even if this car is exactly as advertised, it’s too specialized for my tastes. I’d waste $1000’s undoing what’s been done, just to get it the way I want it. Nevertheless, the next time that I’m in the D.C. area, I’ll pay a visit to see the car. Something tells me that it won’t sell anytime soon. Unfortunately for the seller, the Z community just won’t support a $24,000 car – and the sort of folks willing to drop that kind of money on a dragster would be looking at Chevelles, not Datsuns.
  6. All well and good, but it seems to me that the ultimate arbiter of “what’s the correct valvetrain geometry†– assuming that the various clearances between the various components are within spec, and nothing binds – is how the rocker tip sweeps across the valve stem. Every cam manufacturer’s web site has a drawing akin to “diagram A†in Grumpy’s posting, but I have yet to find any consensus on what is the ideal displacement which is swept by the rocker tip across the valve stem. This is the distance between arrows “1†and “3†in the above diagram. Or to put it another way, if for a given pushrod length the rocker tip goes across the valve stem by, say, 0.070†as the respective valve goes through its lift cycle, is that displacement too much? If so, then the pushrod is too short or too long. If not, then the pushrod length is close enough to optimal, and there’s no point fuddling with pushrod length any further. Use of that plastic “toolâ€, by the way, does not guarantee accurate pushrod length, unless the relation between the base of the rocker studs and the installed-height of the valve springs on your engine happens to be exactly as what the tool’s manufacturer intended. BTW those beehive springs are pretty cool, but unfortunately they’re not (yet) available in spring rates suitable for mechanical roller cams.
  7. The seller's reply was that the car ran mid-low 9's with a 427, and is now "probably" running mid 8's with the 469 - but didn't offer hard numbers. It has Merlin cast-iron rectangular-port heads, a Powerglide and a Dana-60 rear. My personal preferences would be a lighter rear, a stick-shift and oval-port aluminum heads. With the Dana and the cast-iron heads, however, the 2200 lb weight is very impressive!
  8. Awesome! I contacted the seller and asked for time slips.
  9. Short-style valve covers won’t clear the Comp Magnum roller rockers on my BBC, but conventional tall-style valve covers can not be used because their installation or removal would be impeded by the proximity of the “Monte Carlo†bars (diagonals from the front strut towers passing through the firewall and connecting at the dash bar). In other words, those bars pass too closely to the engine, and that makes the choice of valvecovers problematic. Tall valve covers would physically rest in place without interference - they just couldn't be routed over the rockers and under the Monte Carlo bars. Hopefully that wasn’t a too verbose explanation for a pretty simple problem. Anyway, other than custom-machined valve covers, which I am becoming inclined to attempt, the only solution seems to be 2-piece valve covers. These are available for marine engines, for example here: than custom-machined valve covers, which I am becoming inclined to attempt, the only solution seems to be 2-piece valve covers. These are available for marine engines, for example here: http://www.offshoreonly.com/esvon/page-4338.html http://www.hardin-marine.com/detail~ID~818.aspx http://www.zoops.com/newstalgia-products.asp But those cost around $400! Does anyone have leads on “reasonably priced†(< $150) two-piece valve covers for the Mark IV big block Chevy?
  10. Pete, good observation! I was also surprised to find that passage in Hot Rod, considering that they spent the past half dozen issues lashing themselves for their "imports might not be so bad, after all" phase a couple of years ago. The Toyota Carina build-up in the previous month's issue was also an interesting exception. But the same article went on to mention that the post-swap weight of the Solistice would likely be over 3000 lbs - perhaps well over 3000 lbs. Most our HybridZ's are under 3000 lbs, even with all-cast-iron engines and full amenities.
  11. Just an observation on the meaning of “high cost of livingâ€â€¦. High taxes – sure, that’s a high cost of living. But high housing prices? Bubbles aside, if you move to a place where houses are inexpensive, that’s probably because they have not been appreciating in recent years – and they probably won’t be appreciating in the near future. So the net difference between what you get out of the house when you sell it, vs. what you paid for the house when you moved in, would be lower in areas where the housing costs are lower. If you can afford larger monthly payments, the true cost of living is actually LOWER where the housing is more expensive! Example: my house in semi-rural Southwest Ohio now costs a little over $200K. That’s what it cost about 5 years ago, when I bought it. The net appreciation is zero. The same house in a “working class†neighborhood in Los Angeles would have cost around $500K in 2001. And today it would be worth - $1M? Also keep in mind that wealthier areas have a better tax base. If you earn $100K/yr in Ohio, you’re the local aristocrat, and will be taxed accordingly. If you earn $100K in Northern Virginia, you’re just an average Joe – and again, will be taxed accordingly. If there are lots of affluent people in a given area, then the burden of funding the schools, the firehouse, the police department, and so forth, is spread collectively. So, my point is, that if you’re going to settle in a new place for quite some time, it might make more financial sense to seek a more “expensive†area.
  12. Back to the original question.... Early 1990's Camry/Accord are good choices, but would be tough to find in decent shape at under $2000. A Corolla or its GM twin, the Prism, might be a better price/condition compromise. I found a $1200 1990 Honda Accord last year, but it was in really rough condition. And the fuel mileage isn't that great - around 25 mpg in mixed city/highway driving. My 1991 Corolla (bought for $1800 in 2001) would get around 32 mpg. V8 Mustangs, on the other hand, command quote a premium. Finding one below $2000 from any year, in any condition, would be quite a challenge!
  13. So that’s how that BMW mpg gauge works! That explains why it swings wildly between full-throttle blips going uphill, and shifting into neutral. It’s so annoying on my 1992 325 that seriously considering masking it with tape.
  14. First I sawed through the spindle pin to remove the control arm. Then I used a 75-ton press – and bent the fixture that I used to apply loading to the spindle pin, but didn’t budge the spindle pin! Then I drilled through the spindle pin with a 3/8†drill bit from both ends, and tried again with the hydraulic press – no luck. Finally I took the strut casting to a machine shop, which used a mill and boring-bar to remove the remnants of the spindle pin. $200 later the job was done. Next time I do this, I’ll take the whole strut/control arm assembly to a machine shop.
  15. Refreshing messed-up threads with a die can be problematic. I tried this on a particularly bad example (did not grind off the stakes on the retaining nut; unscrewed it with brute force, consequently destroying all threads at the stake location and further outboard), but could not get the die to cut into the same helix as the remaining, good threads. The "solution" was to first grid off the half dozen or so of the most outboard threads, then resume rethreading with the die. I ended up installing the 280ZX-style nuts, torqued to 240 ft-lbs. Car hasn't hit the road yet, so durability has not been verified.
  16. If the preponderance of your concerns is with cost and reliability, then wouldn't it be cheaper to keep your Neon and - if necessary - pay out-of-pocket to get the transmission fixed, than to take a guaranteed loss on a replacement vehicle, only to potentially be disappointed with its performance?
  17. Basically, the totality of my race is 0-20 mph. Mike, let me know if you find any Festivas! Maybe if we swap in a Honda 4-cylinder and install stiffer springs... No joke – I actually like my lawn tractor. It’s got a Briggs and Stratton rated for 20 hp. It tops out at around walking speed, but it really lunges (I can’t bring myself to say “launchesâ€) hard from a start. I am, however, thinking of test-driving a GTO. Then I’ll complain to the salesman, and take note of his reaction.
  18. On matters where I’m reasonably competent, I prefer to work alone. But whenever I have doubts, especially in installing expensive parts where casual stupidity could cost me dearly, I would much rather seek the help of some one more experienced. I’ve found that the more I learn about engine theory, the more I doubt my capacity to execute engine practice. It’s almost as if ignorance really were strength. This is one reason why my engine sat abandoned and forlorn for three years. Then I found Denny, (Denny411 on Hybridz), who lives “nearby†(~90 miles). It’ll take many more weekends of joint work for my engine to finally run – but perhaps now it’s a matter of months, not decades. Pete Paraska and Mike Kelly have also been very helpful over the years. Like many people my age (30’s) I’m finding that time is more precious than it used to be, but a combination of luck and planning has somewhat lightened the financial burden. Often it strikes me that it would be more productive – and cheaper in the long run – to pay shop-rates for a professional to finish the job. But like many have said, can we really trust a “professional†with a unique custom car? And what happens to the achievement value, if you replace your hands and tools with a checkbook and credit card? I would much rather be in a friend’s shop and “helping outâ€, even if all that I’m doing is watching him work, than to completely farm out the work to a stranger. But the issue of working on cars alone vs. working with friends is much deeper than just the car hobby. Unfortunately as people move into the “family formation†stage of life, social interaction between acquaintances and even between friends becomes sporadic and strained. My wife and I made the decision not to have children, and this has done wonders for ensuring leisure time and leisure money, but few people in our demographic cohort have a comparable approach. It’s hard to find social interaction even to play bridge or go shooting, let alone to work on cars. My wife complains the she doesn’t have any friends – and women are supposed to be more social than men!
  19. Mike – don’t interpret my disillusionment as a criticism of your car or your endeavors in car building. Bartman – in short, I have no background. My “racing†experience consists of exactly one 1/4-mile pass at the Pomona drag strip (Los Angeles), around 1998, in a 1987 Toyota Supra turbo. It ran 15.9 @86. But by then, the turbo wouldn’t boost past around 3 psi. So I have zero practical appreciation for what makes a race car fast, in any venue. All that I can draw upon, is what I personally find pleasurable in casual driving, in my hamfisted ways. And that comes down to on-demand throttle response at any rpm. Mike Kelly’s Corvette and Pete Paraska’s 327Z deserve full appreciation for what they were intended to be, but that appreciation is just not consistent with my juvenile fascination with meekly tapping the gas pedal and having the car violently lunge forward. Maybe I never properly learned to drive a manual transmission; 17 years and some 200,000 miles might not mean much, if I started with bad habits and never had occasion to improve them.
  20. In the end, it all goes to heat, so why bother?
  21. In the spring of 2000 I also “saw it comingâ€, and reduced my exposure to the market considerably. So far, so good. But in late 2000, when companies such as Dell, Lucent, Worldcom, AT&T, Cisco, Intel, and so forth, had lost >50% of their value from where they stood when the NASDAQ peaked, I came to think that the market has found the bottom, and bought very heavily into large-cap tech stocks. Of course, the rest was history! My Worldcom and Global Crossings “investments†went to zero, Dell eventually broke even, and the rest are somewhere in between. I did sell most of my tech mutual funds, and took the capital gains tax hit. And speaking of taxes, losses will bring many “happy†years of $3000 annual capital gains write-offs. “Buy, hold and diversify†should not be taken as a mantra. It is indeed far superior to many alternatives, but is by no means foolproof, and by no means necessarily the route to affluence, even over the proverbial long term. If there’s one thing that I learned, it’s that it is better to invest in index funds (several at once – S&P 500, overseas markets, etc.) than in actively-managed mutual funds. But even better than that, is getting the insider deal.
  22. Mike, Of course your car – any car – will produce more torque in the rpm band where volumetric efficiency is highest. But we both agree that the whole point of a large V8 in a “relatively†light car is to avoid peaky response. Breadth over depth, you might say. Your Vette might reach 450 ft-lbs at 4500 rpm (or whatever it happens to be), but surely it’s making an honest 60% of that at 1000 rpm – right? Right? And even that should feel pretty stout. To better explain what I want in a car, here’s an analogy…. A moderately athletic adult human produces around 1/3 – 1/2 peak hp. That ain’t much. Power to wait ratio would be around 1:400! And quarter mile performance would be – well, right around 1 minute. But if you can run the 50-yard dash in, say, 7 seconds (this was reasonably good performance in junior high physical education class), you can probably accelerate from a walking pace to a hard sprint in only a few steps. You don’t need to “plan ahead†to achieve that acceleration. Your brain says, “Hey! Start running!†- and off you go. I would like a comparable “throttle response†in a car. It’s not about the 1/4-mile time, or the skidpad numbers. It’s that instant, ferocious, all-circumstance on-demand animal lunge forward – this is what I crave.
  23. This thread reminds me of my test drive of a 1998 Z28 Camaro (the first year of the LS1). I was all excited about a reasonable (on paper) RWD stick-shift V8. The car was supposed to be a rocket. It wasn't. A couple of months ago Mike Kelly gave me a ride in his modified C5 Corvette. By all evidence his car is at the sweet spot of LSx streetable modification. But I was - underwhelmed. Whenever I come across a promising new car, invariably the euphoria fades after the first test drive, or in some cases even the first test ride. So I made the decision that it's pointless to salivate over OEM "performance" cars. I might as well drive an economy car and go for the reliability and low costs. And save aspirations of performance for the Z. Still, now that my Z is "finally" coming together, I'm worried that the acceleration will turn out to be a disappointment.
  24. Numerous people have posted numerous times regarding optimal pushrod length and the need to check this length for engines with other than completely stock components. However, the criteria for “what is the optimum length†conflict, or in any case are ambiguous. For instance, some sources emphasize minimal total travel of the rocker tip over the valve stem, while others emphasize minimal travel over the portion of cam rotation where the respective valve is half opened to fully opened, while still other sources emphasize that the rocker/valve stem contact area should be as close to the center of the valve stem as possible. In my application the block has been decked, the heads are aftermarket (though valve lengths are evidently stock), the cam base circle is probably not stock (1.18â€), and I’m using Comp Cams roller rockers. However, with the stock pushrods, the rocker tips sweep an interval of about 0.070†width, right in the center of the valve stems. This is just pure luck. I did NOT have access to checking pushrods, but merely tried checking on a whim the valvetrain geometry with the OEM pushrods. So I got lucky. Now here’s the question – should I use proper checking pushrods and go through the exercise of checking valvetrain geometry ANYWAY, trying to drive the swept interval of rocker-tip-to-valve-stem contact even lower – or, should I leave well-enough alone? Is 0.070†a reasonable number, or can one do better? Keep in mind that every adjustment of pushrod length requires making sure that the intake and exhaust pushrods are in turn on their respective base circles of the cam, and then spinning the crank for two revolutions – not easy and very time consuming. The engine won’t see >6000 rpm, and probably not > 5500. So, there’s the issue of some adjustments being more trouble than they’re worth – unless one is pathologically curious….
  25. Shouldn’t this be in the “fuel delivery†forum? Now that I’ve annoyed the original poster, here’s a related question… With electric fuel pumps typically one uses a pressure regulator and a return line, for example as in Grumpy’s diagrams in this thread, or in http://forums.hybridz.org/showthread.php?t=108825 . And most people end up with an electric pump, either because they’re adapting a stock fuel tank with an internal electric pump, or are using JTR-type engine mounts which interfere with the stock Chevy mechanical fuel pump location. In my application there is no interference between the engine mounts and the stock fuel pump. (454 BBC mounted to the frame rails). I plan on using a Carter “street†mechanical fuel pump, rated at something like 110 gph at 6 psi, going into a 4160-style 750 cfm dual-feed, single power valve, vacuum-secondary Holley. This should be plenty, because, well, let’s do the calculations… a 0.030-over 454 at 6000 rpm at 90% volumetric efficiency (optimistic) uses about 43,000 ft^3 of air per hour, which at standard sea level is about 100 slugs of air, or around 3200 lbm of air (per hour, not per minute). Assuming 12.5:1 mixture and fuel density of 6.3 lbm/gal (should be close), this gives just over 40 gph fuel flow requirement, if fuel were being burned at a steady rate. In an actual fuel flow path, the various pressure drops might be such that to maintain continuity, the requisite pressure rise across the pump at equilibrium is greater than 6 psi, in which case the actual max fuel flow rate will be less than 110 gph (there’s a nearly inverse relationship between volumetric flow rate and pressure rise). But I’m still fairly confident that the 110 gph at 6 psi pump should be sufficient. I’m using a 3/8†fuel feed line. Now here’s my question: (1) with this combo, do I need a fuel pressure regulator at all? (2) I have a fuel cell with a built-in sump, but don’t plan on using a return line. Do I need a return line, after all? This thread: http://forums.hybridz.org/showthread.php?t=106679 suggests that a return line is always a good idea, for heat-soak reasons.
