Michael
    9
Everything posted by Michael
  1. Thanks guys!!!! Now here's a question... Last night I finally mustered the courage to look at the oil dipstick. Well, the oil is more or less clear (after a total of about 1/2 hour of engine operation), but has a slight tinge of gray. No metal particles - at least not yet, and not on the dipstick - but definitely something like a fine gray powder. Is this normal? Is this the result of rings lapping themselves into the cylinders? Should I change the oil immediately, or follow the 500-mile rule? Years ago, when I was into R/C model airplanes (2-cycle single-cylinder engines with aluminum head and case, bronze cylinder sleeve and aluminum piston with some form of chrome coating), such gray mist in the oil was indicative of mechanical wear.
  2. Well, sort-of first drive – the first since the summer of 2000. The engine needs tuning, the chassis needs tuning, the suspension needs tuning, and the driver needs tuning, but somehow the whole combination held together – at least for a lap around the block. The horror of a potential cam wipe has not entirely dissipated, yet something I feel a tinge of optimism. First impressions… 460 cubic inches pushing a 2600-lb overgeared sheet-metal box really can not be described as driving a car. But I can say – with my usual hedges, disclaimers and qualifiers, that the sensation is not without its satisfactions. It is entirely different from Mike Kelly’s Corvette, or Pete Paraska’s Z, or any other roadgoing vehicle in which I’ve been driver or passenger – which, in a sense, was the original goal… 8 years ago. Now off to the dyno tuning shop – probably via tow truck; one should not push luck too far.
  3. In my opinion the whole point of a V8 hybrid is to build a stout engine from a bare-block, with good aftermarket components, custom machining, component matching and porting. The Z becomes a carrying case for the engine. If the engine moves a 3700 lb muscle, it should really move a 2600 lb Z. Use the skills and philosophy that you've developed in your L6 builds - except that now you would have >2X the displacement! A junkyard engine with a swap-meet intake manifold may turn out to be a disappointment, compared to your turbo L6.
  4. It sounds like this car would be your daily driver. If so, do please think twice before tackling an engine swap! A hobby-car could be built at your leisure, and with enough deal-making acumen and technical skill, you might indeed be able to meet your goals for price and performance – either with a small block Chevy, or turbo L6, or some other variation. But please, ask yourself again if you wish to encumber yourself with the risk, the hassle and uncertainty of relying on a custom hybrid as your only transportation!
  5. One trend that seems to be happening is that that once folks get into the 8’s or even 9’s, a compact “street car†loses its attraction. Further progress becomes increasingly difficult – as either the car becomes unrecognizably different from its origin, or becomes too temperamental and unsafe. In either case, the trend is to move to a dedicated dragster. The formula of light compact street car + huge hi-po engine works great up to a point – but evidently only up to a point. Ron Jones probably reached that point, and chose to go elsewhere to make further progress. Now here’s a question for the cognoscenti: why do so many drag Z’s on racingjunk have Dana 60’s? I would have thought that a 9†or 12-bolt would be the more natural choice.
  6. I’m wondering about the distinction between tuning a modern, fuel-injected, computer-controlled car vs. 1960’s/1970’s-type “technology†(vacuum-secondary carburetor, naturally aspirated, no nitrous, HEI distributor, mechanical fuel pump). Assuming reasonable initial choices for spark plug gap, ignition timing, distributor rotor weights and springs, and fuel jets, what are some of the options available for tuning with the dynamometer? Would a probe with an oxygen sensor be inserted up the exhaust pipe, closing the loop via external diagnostic equipment, where onboard equipment is insufficient? Would a fuel flow-rate gauge be plumbed into the line between the fuel pump and the carb? What about some sort of intake air flow sensor?
  7. As a point of reference, I just returned from a business trip to England. Over there the gasoline is about 1.0 GBP (British Pound) per liter. At the current exchange rate, that works out to over $7 per gallon! However, in 2003 their gas prices were around $5 per gallon, while ours were at around $1.40. Evidently prices in the US and in Europe went up by nearly the same absolute amount – which means a relatively slight proportional increase for them, but a huge increase for us!
  8. Not a bad idea…. We did have a mini-meet at Denny’s house in Wapakoneta around two years ago. My car is in its “final†stage of construction – currently at Denny’s, in fact. Conceivably it would be finished by the end of the summer – at which point I’d be delighted to host a Z meet at my house (southeast of Dayton).
  9. Another alternative is to do some work yourself, but farm out the “hard stuff” to a professional. For example, have a pro do the exhaust, structural reinforcements (as required/desired), etc. In some jobs, such as the driveshaft, appealing to a shop is almost unavoidable. If literally following the JTR book, a pro could do the radiator installation and the grinding of the exhaust manifolds. Again if following the JTR book, buy the mounts, speedometer cable, differential yoke, etc. from JTR. The main challenge for a “straightforward” swap is having enough garage space. Buying the tools is a secondary consideration – unless, of course, you’re really into custom fabrication. But as others have said, the cheapest route is to buy an already converted car. BTW for a 1977 you shouldn’t have to worry about smog check if you wait until 2007.
  10. Here’s an effort at clarification… Olie’s point, I think, is what might happen during the first few seconds upon starting a cold engine. Consider an average temperature over some number of cycles – large enough to smooth over intake-compression-combustion-exhaust variation, but small enough so that the engine block is still cold to the touch. Well, if the temperature in the combustion chamber somehow happens to be similar to the temperature in the water jacket, then things in the combustion chamber are happening at maybe 70 deg F – and if that were true, then hypothetically detonation would not be a problem even for a very high SCR and low octane. However, this condition does not exist! Immediately upon starting the engine, combustion chamber temperatures climb to something like 300 deg F (probably much more, but this is just guess for illustrative purposes; and note that this number is much lower than the flame temperature itself), while the water jacket and exterior of the block are still cold to the touch. When the engine “warms upâ€, the ratio of temperatures at the combustion chamber walls to those in the water jacket approach equilibrium. So, there are two points of confusion. First, one can not correlate the water temperature to the combustion chamber temperature until the engine warms up. And second, the combustion chamber temperature is what effects detonation, BMEP, etc. – and not the water jacket or block temperatures. But we measure water temperature, and hence the rules of thumb are based on water temperature.
  11. The more important question is, what will this poor train do once it reaches the station in Los Angeles? I mean, that's going to be one harsh arrival!
  12. And here I am chiming in!!! Cygnusx1 is absolutely right. And besides taxes, consider the maintenance, the insurance, and the transaction costs. And the depreciation, if you're in the Midwest. Let me put this in perspective: I own my house outright - no mortgage, no monthly payments. But between taxes, insurance and maintenance, it costs me more to live in my house than I used to pay for rent in my apartment! Purchasing a house is making an investment. But some investments are good, some are bad, some are indifferent. It's ludicrous to claim that ANY investment is a good move, just because you're finally making an investment!
  13. I also wonder why the new Mustang is so heavy. We had a thread on this topic some months ago, actually. Probably the causes are (1) onboard gadgets that 80’s and even 90’s cars didn’t have, (2) safety equipment and safety-driven structural features that don’t improve chassis stiffness but do add weight, (3) insulation, sound-deadening equipment and other features to obtain the NVH (“noise, vibration and harshnessâ€) levels that modern consumers crave. It’s curious that today’s midsize sedans and coupes weigh as much as 19’ barges from the 1960’s. If they built a Chevelle in 2009, it would weigh 5000 lbs!
  14. The component of horsepower needed to overcome aerodynamic drag is just P = D*V, where D is the drag given by Olie05’s equation. Assuming 30 ft^2 frontal area and the given Cd of 0.44, at 70 mph this comes out to around 30 hp. As a very rough approximation, the towed trailer and car will have about the same Cd and frontal area, so the required hp basically doubles. More difficult to approximate would be the rolling resistance and the internal losses in the drivetrain and engine (cooling, pumping, exhaust); of course, it is only the latter will change when you swap engines. The Jetta, meanwhile, with an assumed frontal area of 25 ft^2 would only need around 18 hp to overcome aerodynamic drag at 70 mph – and evidently it gets 49 mpg doing this. Presumably the gearing is such that the Jetta’s engine’s rpm at 70 mph is around 1800 (seems reasonable for a diesel?) – in which case it needs to make around 52 ft-lb of torque to produce the hp to overcome aerodynamic drag. Now assume, very roughly, that100% of the horsepower goes into overcoming aerodynamic drag. Putting the Jetta’s engine into the pickup towing the trailer, to produce 70 hp at 1800 rpm is no longer possible, as it would require around 205 ft-lbs, and only 177 ft-lbs are available. But that’s not far off. 150 ft-lbs @ 2450 rpm give about 70 hp. Assuming that volumetric efficiency at 2450 rpm isn’t much worse than at 1800 (the torque peak), the fuel flow per unit time should just scale as the hp required – meaning, in our crude approximation, that the mileage of the Jetta’s engine in the truck would be a straight reciprocal of the ratio of the horsepower levels required. That is, 49 mpg * (18/70) = 12.6 mpg. The actual mileage should be better, since the rolling resistance for the two vehicles doesn’t differ nearly as much as does the aerodynamic drag; so the total power required for the pickup isn’t as large as the ratio of drags predicts. If the pickup and trailer will cruise at only 55 mph, then the hp to overcome aerodynamic drag is only around 34 hp, and the mileage (same assumptions as above) becomes 26 mpg. But I highly doubt that the truck doubles its mileage by slowing down from 70 mph to 55 mph!
  15. Good luck, Mike! May your real estate ventures turn out better than mine! (But that goes for EVERYONE on HybridZ!). Is this place in the Fredericksburg area?
  16. The alternative option is to just use the T5 FOR NOW, get the car running, learn its manners, and later on upgrade to either a stouter variant of the T5, or to another transmission altogether. There are not many options in the world of manual transmissions that are both cost-effective and sufficiently strong. Each of the established solutions (T56, Tremec, Doug Nash/Richmond, G-force) have drawbacks, such as high cost, heavy weight, difficult installation, notchy shifts, or poor choice of gear ratios. Don’t let consternation over “will it be strong enough?†set your endeavors back by 6 months.
  17. $400 for that shortblock IS a good deal, plain and simple. Yes, there could be hidden flaws. But a $3000 shortblock could also be suspect, with hairline cranks, mismatched bearing tolerances and all sorts of other ills. Paying top-dollar does not insulate you from potential trouble, but getting a low price definitely eases the pain if and when trouble comes. The tradeoff in quality vs. price is rife with risk at any price level. Nor does building the engine yourself necessarily help, unless you are an experienced mechanic, in which case the entire discussion is moot! Can you really measure bearing clearances down to accuracy of < 0.001â€? I can’t. I couldn’t, even if I had the right tools – and I don’t. I spent $1500 on a mild performance rebuild (stock block, crank and rods), not including the cam and oiling system. Yes, it was a very reputable machine shop that used modern tools and took their time, but in the end it’s still a gamble – I’m taking their word for the precision clearances. I’m taking their word that they really did use a torque-plate for honing the cylinders, and that they really did use the correct bob weights when balancing the crank. And there are still no guarantees that the engine won’t grenade 5 minutes after it’s started. That said, your biggest frustration will be trying to continue the low-price theme for the rest of the engine. I mean, “to do it right†you will end up with at least $500 (maybe $800 or more) for heads with the right machining and valves. Then there’s the oiling system, the intake tract, the exhaust tract, and the various engine externals like cooling and ignition. After spending another $2000 on these various parts, you’ll be wondering: “Maybe I should have spent another $300 on the shortblock – then I wouldn’t have to worry that the shortblock would be a weak linkâ€. But in truth, there is always a weak link! Spend more money on any particular part, and you’ve just transferred the weakness elsewhere.
  18. Nagants are inexpensive, but most are really beaten up and impractical for a first rifle. Standard Red Army (USSR) issue for many years – and before that, used in Czarist Russia. I’ve never seen one with a scope, however. You would probably have to have the receiver casing drilled and tapped. Nagants, unless I’m mistaken, take a 54x7.62 cartridge, which is difficult to find, and is reputed to kick pretty hard. My advice would be to stay away from antiques and military surplus rifles, unless you happen to enjoy gunsmithing. For reasonable deals, check out a generic department store (as opposed to dedicated gun shop). For example, most Walmart gun counters have a photo album with reconditioned or returned rifles. I bought a Weatherby Vanguard for $250 (brand new) from our local Walmart, in 270 caliber. The Weatherby is a decent brand, with good machining quality and a good bolt. Its weak point is the trigger, which in my case required some lapping of the sear to improve trigger feel. The choice of caliber is a debate in its own right. If you have no plans for hunting, consider the 223 – ammo is cheap (for centerfire calibers) and recoil is very light. But in most states 223 is illegal for hunting. And stopping power – for a rifle, that is – is considered to be mediocre. For hunting or other general purposes, common choices are 243, 270 and 30-06. I’d definitely avoid a magnum or an oddball like 220 Swift – ammo is expensive and rare. For pursuit of accuracy, you might find that you’ll have more money in the scope than in the rifle itself. This happened to me ($350 scope). 1†groups at 100 yards are REALLY hard to achieve, by the way; it requires a good gun, a good scope, good sighting-in of the scope, good ammo, and most importantly – a good shooter
  19. If you're a dealer, don't you have space on your lot to store your personal cars indefinitely? And if you are a dealer, most likely you would expect to pay wholesale. The wholesale-retail spread on these cars is huge! I'd say $1500 wholesale for the pair of them, tops.
  20. Well, I'm an aerodynamicist, or at least I play one at work.... Automotive aerodynamics is very much a black art; or rather, it's much more of an art than a science. Airplane aerodynamics is in many regards much simpler. Over the years there have been several pages on the web describing why the S30 Z’s have such a high drag coefficient and so much front-end lift. While the gist of these explanations is generally correct, the technical arguments are at times fallacious. The complexity comes from the role of ground effect, rotating tires, radiator flow, sharp protuberances and flow separation from aft-sloped surfaces. These effects don’t scale well between tunnel models and real life, and are hard to reproduce in the lab. Computations are difficult and unreliable, too. I’ve done some testing in my water tunnel regarding the “smelly exhaust†problem, using a ~1:24 wooden model with a plexiglass ground plate. Dye injection gives sort-of the right picture, but that’s a very crude experiment. The problem gets much more complex in figuring what happens with air dams, radiator flows and underbody flows – so much so, that I’d trust the fingers-and-toes expertise of track testing much more than I would laboratory or computational predictions. That said, it is intuitively true that sealing off the area behind the air dam and underneath the engine compartment will improve downforce and reduce drag (slightly). If these areas are sealed completely, and the air dam extends close enough to the ground, then essentially what happens is that the low-pressure flow behind the car (it must be low pressure, because of overall vehicle drag!) bleeds forward underneath the car, and “piles up†(silly term, but gets the point across) behind the air dam. Hence, downforce. The reduced-drag effect is much smaller, but that’s not our primary concern, anyway. All of this will improve if you do something about rounding-out the sharp front lip of the S30 hood. .
  21. I have Brodix aluminum heads, Hooker block-hugger headers and the standard (low-carbon steel?) bolts that came with the Hooker headers. And Fel-pro (?) copper exhaust gaskets. No loose header trouble yet, but then again the engine hasn't run yet. Slowly I've been drilling the header bolts with a #56 bit to accept safety wire. I use used motor oil as the cutting fluid. With my Harbor Freight drill press and drill bits, it's a slow, laborious process, but so far I haven't broken any bits. Point being, that if you have mild-steel header bolts, consider drilling them yourself, and using safety wire.
  22. I think that it would be spectacular to see a diesel V8 from a full-size pickup (1-ton or larger) in a 240Z, backed up an old-school 4-speed with a granny gear!
