9
Everything posted by Michael
What is the easiest CAD program to learn? (Don't have a clue)
Michael replied to a topic in Non Tech Board
Autocad's principal advantage is that it is the most natural analog of old-school manual drafting. So if you learned drafting on a drafting board, Autocad is a good choice. Also, Autocad is very convenient for 2D drafting. Just be sure that 2D is really what you need, and not merely what you'd like to start out with. Solidworks has become the industry standard in most areas of mechanical engineering. As an Autocad to Solidworks convert, I've also had considerable trouble with the learning curve. The concept of parametric sketch is still counterintuitive to me, but automatic drawing of fasteners, for example, is very convenient. Both Autocad and Solidworks have tremendous support in user literature: "for dummies" manuals, and so forth. Also, the Solidworks user interface can be configured to sort-of emulate Autocad, complete with a command prompt. Niche industries such as aerospace have been using Catia or Unigraphics, because of their "lofting" features - that is, they perform complicated operations on compound curves semi-automatically. This is the one area in which Solidworks is still inferior, but it's growing fast. Pro-Engineer is the original parametric drafting program, but it's fast becoming overtaken by Solidworks. Bottom line - either Autocad or Solidworks. Final choice might come down to price/availability. -
I agree that Roots blowers are not without problems, but the general concept of the car in this thread - tiny chassis, huge engine - is stylistically impressive nonetheless. The builder definitely gets my respect. That said, some relatively "minor" (given the level of effort already invested) modifications would tone down the visual cues, improve drivability and ultimately performance. For 500 hp in a 454, one would think that forced induction is unnecessary. With good heads, a roller cam and "proper component matching" (as the mantra goes), 500 hp with single n/a 4-barrel on a 4000-rpm torque peak and 6000 rpm redline doesn't strike me as at all exotic; at least, that's essentially the goal for my own car.
... for my 460 (454 + 0.030"). It's a "low lash" mechanical roller from Cam Motion. Cam card says: (all duration numbers at 0.050", angles are in crank degrees, unless otherwise specified) Lobe sep 112.2 (cam deg) overlap 21.6 ground +4 advanced Intake: open 12.5 BTDC centerline 108.2 ATDC closed 48 ABDC duration 240.5 lift 0.64178 lobe area 30.19 inches * degrees Exhaust: open 62.3 BBDC centerline 116.2 BTDC closed 9.1 ATDC duration 251.4 lift 0.64553 lobe area 32.29 inches * degrees The open/closed/overlap numbers look a little funny only because these are quoted at 0.050", instead of the more common at 0.006" or 0.020". The large disparity between intake and exhaust duration is because of the heads: Brodix Race-Rite oval port heads, which flow great on the intake side, but e/h ration ain't so hot. And the exhaust tract in general is pretty restrictive (small-tube headers, 2 1/4 pipes). So, the cam goes in next month. Then clearance checks, then pushrod measurement, then.... well, let's not get too carried away here. But I did promise myself to get this car running in 2006!
" If it doesn't fit, force it. If it breaks, it had to be replaced, anyway".
Project BBZ, I would recommend that you mock-up the exhaust tract from the heads back toward the transmission tunnel area, as early as convenient in the car's construction process, to check starter interference, clearance around the bellhousing, etc. Things may turn out to fit perfectly - or they may not. It might be necessary to cut sheet metal, buy a different starter, relocate the steering shaft, and so forth. It might even be necessary to move the engine back or forth slightly.
Project BBZ, any updates on your progress? You cardomain page concludes right at the point where you're about to commence the actual swap.... I'd be especially interested in seeing your solution to the frame rail/exhaust header (Hooker 1.75" block headers, right?) interference problem on the passenger side. Did the air cleaner clear the stock hood?
Guys...should I buy this thing..sitting for 10years!..Pics
Michael replied to slownrusty's topic in Non Tech Board
Sounds like a good swap candidate! Seriously - with a good body, interior and suspension, but a drivetrain of questionable reliability, high complexity and a lot of weight, it makes sense to consider cars of this category as swap candidates. Chances are good that a 350-based SBC (or LS1, if you prefer) would fit - and would actually weigh less than the original engine. -
On a business trip to Germany my rental car was an Opel Vectra GTS. FWD 4-door family car, 2.3L 4-banger. And Opel is just GM. But... that thing was remarkably smooth, tracked fine and steady, reaching 210 kmh (130 mph) on the highway from Braunschweig to Frankfurt. It did feel a little light-footed at the curves, where it was necessary to slow down to around 180 kmh. This is a rather nondescript, lukewarm-sporty family sedan - from GM! On a trip to England I rented a Vauxhall hatchback, with a 1.6L 4-cylinder. If the Opel was striving for upper middle class, the Vauxhall was definitely rental-fleet caliber. And yet, it too had peppy acceleration, responsive handling, logical and useful driver controls, good pedal feel, etc. My point is that there's something about European-market cars that emphasizes taughtness and connectedness with the driver, something that's very difficult to find in American-market cars, even amongst cars of European origin. I don't think that it comes down merely to engine internals.
Frustrated - flames from carb/stalling issue
Michael replied to awd92gsx's topic in Gen I & II Chevy V8 Tech Board
In my case 4 lobes were wiped - one was wiped right down to the base circle! Idle quality was quite good, with the only exception being an occasional popping noise every few minutes. The popping noise increased in frequency and volume with increasing rpm. There was no discernable loss in performance except at the bitter end, when one pushrod actually broke in half and another buckled and was on its way to breakage. However, this was my first V8 and I had no benchmark for comparison of how much power to expect. Another thing to check, if this is a hydraulic cam, is the valve lash. If you adjusted the lash by the usual method (tighen the rocker nut until the respective pushrod no longer spins by hand, then tighten another 3/4 turn) on every valve, and then notice that for some reason one or more valves seem to have picked up some lash, chances are high that the respective lobe is toast. Of course, it's also possible that somehow the rocker adjustment nut isn't holding tightly on the rocker stud - that would be good news, as it were. -
I'm not a turbo guy, but I've done some work here and there on propellers, so Pop n' Wood's analogy is worthy of some further comment... The issue with propeller pitch is with the effective angle of attack [at each spanwise station] of the propeller blade. The angle of attack comes from the relation between the blade geometry (pitch) and the vector sum of blade rotational velocity and the oncoming flow speed - or the speed of the boat or airplane - or the speed of the flow in the nozzle leading to the turbine disk. For a given rpm, low oncoming speed and high blade pitch means that the blade angle of attack (again, angle of attack varies along the blade radial location, but assume that it's a constant for now) is high, so the blade is at or near stall - and maybe even beyond stall. Efficiency will be low. At too high an oncoming speed for a given blade pitch and rpm, the so-called advance ratio is above its critical limit, meaning that the blade angle of attack is effectively below the zero-lift angle - meaning that the propeller isn't making any positive net thrust. Or in the case of the turbine, the turbine isn't extracting net positive work from the oncoming flow. However, these are all issues of steady-state efficiency; what the turbine does once it spools up to a steady-state rpm for a given throttle setting. The original issue, I think, was less about turbine efficiency than about turbo lag, which is mostly concerned with how fast a turbine spools up. And this, I think, has as much to do with turbine wheel moment of inertia as it does with blade design and optimal blade-nozzle matching. Keep in mind that moment of inertia goes as the 5th power of a linear dimension (mass * radius ^2, or density [of the turbine material - steel, ceramic, whatever] * linear dimension ^5); double the size of the turbine wheel, and moment of inertia goes up by a factor of 32!
I'd have to agree with the folks who have mentioned the wiped cam lobes - especially if this is a hydraulic flat-tappet cam from Comp. I had the exact same symptoms on my big-block, after installing a mild hydraulic flat-tappet cam from a Comp "K-kit". Unfortunately this won't be revealed by a cranking compression test - you'll have to pull the cam. -
Might there be a third option - for example Hays or Ram - which give the advantages of an aluminum flywheel, but at a lower price and with the 11" clutch?
Yes, with enough fabbing this could indeed be made to work, but one has to wonder whether the work necessary to fit this to Z body lines is worthwhile - or whether it's easier to just start with a pile of tubes and make your own "kit". When I last looked into this, there was nothing available for the Z; the closest fit was the Vega/Pinto kit.
4link, ladder bars, etc...
Michael replied to boostedz31's topic in Brakes, Wheels, Suspension and Chassis
The guy who built the frame for my 280Z had a strip-only 280Z with a custom tube chassis and a 4-link. Road handling was awful, but the car ran low 10’s. This was in the 1980’s – so, the technology is dated by 20 years. It’s true that there isn’t enough room in a Z for leaf springs or ladder bars, but a 4-link will fit – with enough surgery to the sheet metal. There’s a member on this site (his handle is Japtin, or something like that) with a semi-kit tube chassis. Jegs or Chris Alston might sell a “Vega/Pinto†kit that with considerable customization would fit a Z. Another option is to retain the IRS but beef up the halfshafts, stub axles, etc. – and go with a R230. Weight and balance issues with a big block can be offset by moving the firewall aft, for more engine setback. This is the approach that I took. Of course, there’s no guarantee of launch consistency. If you’re going to go with a big block Chevy, don’t settle for a 396; the weight penalty of a big block deserves at least a 454, if not larger. If I were to do my swap all over again, I’d begin with a Dart Big-M block (4.600 bore) with at least 4.25†stroke. -
According To Mas280, I'm Heavy Z!!!
Michael replied to LS1 Z's topic in Gen III & IV Chevy V8Z Tech Board
My 1978 280Z with a semi-tube frame (much of it 1.75†0.134â€-thick mild-steel DOM tubes) and an all-cast-iron big block Chevy engine weighed in at 2725 lbs. This was a completely stripped car, with a lot of the unibody cut out and most stock bolt-ons removed, but with essentially stock suspension and a pretty heavy drivetrain. Weight as measured on four scales, one under each tire. With aluminum heads, fiberglass hood, gutted doors and a few other mods, I’m hoping that the new weight will hit 2600 or better. I’ve driven Pete’s car, and it really was surprising that the weight came out as high as it did. However, when you close a door in his car, you’re rewarded with a throaty, reassuring “clickâ€, like in a modern luxury car. When you close a door in my car, it sounds like kicking a garbage can. So, the moral of the story is, an all-around solidly-built car WILL have a weight penalty, whereas there’s considerable weight savings in a tin-can stripper. It all depends on your objective…. -
Comparing a relatively stock American V8 with a moderately-built L28T or other small-displacement turbo engine, the main difference comes down to how much you value low-end torque. If low-rpm torque is not important, go with the turbo – it’s an easier swap. If the low-end torque is important (and for me it’s the meaning of life, existence and the universe) then it would be difficult to beat a traditional large-displacement V8. Weight, reliability and ease of maintenance are comparable, assuming a “clean†installation in both cases. Just about every claim of XYZ swap being a nose-heavy, overweight, temperamental pig will have a counter-example. And in either case it’s definitely true that you’d be money-ahead and time-ahead by purchasing some one else’s conversion, instead of starting from scratch.
The principal appeal of the 70-78 S30 series is their kinship to 50’s-60’s sports cars; styling, simplicity, emphasis on performance vs. comfort, and other aspects associated with such sports cars. Never mind that newer members of the Z family in many cases had superior performance out of the box; it’s more a question of association, of flavor, and of aesthetics. It’s the change in flavor that causes many S30 fans to thumb their noses at the newer Z’s. The 280ZX suffers from a particular trough of prestige because it’s a transitional car; not quite old enough or pure enough or simple enough to be a “classicâ€, yet not quite hi-po or high-tech enough to be a modern car.
If you follow the editorials in the Detroit-iron mainstay magazines, such as Hot Rod and Car Craft, you’ll notice that the editorials praise muscle cars not only for large engine with lots of torque (always a good thing in my book) but their “manly sizeâ€. In other words, many American car buyers prefer the large dimensions and don’t mind the weight. True, as posted above, many consumers are simply ignorant about weight. But even among those that appreciate the importance of power to weight, many simply prefer the larger car and the more imposing bulk. This has been true in the American market for many decades. What disappoints me is that over the past 25 years Japanese and European cars have grown in size and weight, coming more and more to emulate American cars. So that while technology has given us ever more powerful and fuel efficient engines, today’s cars fail to meet both their acceleration and efficiency potential. Then there’s the retro styling craze… I shudder to think how much extra aerodynamic drag the new Mustang is saddled with, on account of the forward-swept fishmouth grill. But hey, that style is popular with consumers, and form the viewpoint of profit Ford made a brilliant decision with those outer mold lines. Of all the alternatives, probably the best rendition of a muscle car in today’s market is probably the Pontiac GTO. It’s “only†3750 lbs, and the styling is at least somewhat restrained. Personally for daily driver I insist on RWD and a manual transmission, in a compact package – even if the horsepower isn’t exactly impressive. “Compact†to me means under 3000 lbs. And convertibles are excluded. In todays’ market, there are essentially no cars that fit those criteria. So I’d either buy an Infiniti G35, which misses the weight numbers, or a Mazda 3, which is FWD.
If this is mandrel-bent custom 2 1/2†or larger dual exhaust with X-pipe and high-quality dual mufflers, $600 isn’t a bad deal. They have to do multiple trial-fits, possibly introduce multiple flanges to clear the transmission mount, the rear suspension links, etc. – and possibly even hammer the spare tire housing to fit those mufflers – all while avoiding fuel lines and fitting the pipes inside the transmission tunnel. We just fixed the exhaust on my wife’s 1990 Honda Accord. Bone stock, downstream of the catalytic convertor, single pipe with the cheapo crinkle-bends was something like $220 parts + labor. This was ZERO fabrication work and maybe 1/2-hour in the shop total. I think that a lot of guys are so used to getting “deals†– getting lucky with clueless sellers who don’t know what they have, or bartering with down-and-out mechanics who’d do 40 hours of custom work for a six pack and a large pizza – that any sort of retail price comes across as sticker shock! I mean, there’s a reason why a plain-Jane muscle car restoration costs $100,000 these days!
how much power will these motors produce?
Michael replied to jnewby's topic in Gen I & II Chevy V8 Tech Board
Facetiousness aside, you’re going to find that both of your engine options will be relatively disappointing in horsepower. What’s the casting number on those big-block oval port heads? If the engine is from a 70’s truck, they are most likely 236-heads – which means about 220 hp at the crank. With that engine you still have a decent foundation for performance – but it will require considerable modification. BTW, please post more details about your BBC swap. Mine is “mostly†complete (after 6+ years, plus professional help), but if I were to do it all over again, the logical choice would have been a 350-based SBC. -
Good question! The last time that I checked, which was around 1999, the NHRA rules stated something like 10.99 as the no-IRS cutoff point. However, there was (or is now, if there wasn't back then) a loophole that somehow accommodated Vipers and Corvettes. Also I vaguely recall that NHRA distinguishes between IRS where the halfshafts are used as suspension links (such as the Jaguar and most aftermarket hot-rod IRS retrofits), and Chapman struts (such as the Z) where the halfshafts are telescoping and not used for the suspension proper. The difference is that in the former, if a halfshaft breaks, the corresponding wheel comes off.
7.5 L GM V8 Many guys on this board can beat the hp, but can anyone surpass the displacement?
I don’t mean to hijack this thread, but how do these turbo 4-cylinders perform in the off-the-line torque department? I don’t mean rev-it-and-dump-the-clutch, but leave the line lazily at 1200 rpm, then punch the gas. How would they compare to, say, an early 1990’s 5.0L Mustang or a LT1 Z28 Camaro? In all cases assume a manual transmission.
You guys are great! Indeed, the transmission was stuck in two gears simultaneously. Evidently what happened was that one of the shifter arms got bumped when the engine/transmission were reinstalled. Working the shifter (Hurst) didn’t help, but wiggling the 3/4-gear lever arm popped it back into neutral. And then both aforementioned transmission problems magically went away! BTW the shifter rods were custom-resized/bent when the car “ran†the first time, in August 2000.
I finally reinstalled my engine back into the engine bay. It’s a Mark IV BBC, now displacing 461 cu in, with a Doug Nash 5-speed (similar to Richmond 5-speed) transmission into a ’78 280Z, Centerforce clutch, Ram aluminum flywheel, McLeod hydraulic throwout bearing. The transmission has been sitting for 5 years. Two problems... 1. The shifter appears to be in neutral, but I can’t shift any gears; the shifter simply won’t budge! The clutch is hooked up but not bled yet, so it’s not functional. 2. The input shaft is spinning OK (I checked before connecting the transmission and engine) but the output shaft is not! Torque to turn over the crankshaft (spark plugs not installed) is about 30 ft-lbs – same as it was without the transmission installed. Connecting the driveshaft makes the car immobile. Turning over the crankshaft will not turn over the driveshaft. This is an externally-shifted transmission. I checked that there’s no interference between the trans tunnel and the shift rods (trans tunnel has some mods). By my estimation, the transmission is nearly (but not completely) empty of gear oil; most spilled out through the tailshaft when the engine/trans were pulled in October 2000. So, given the above – any hunches as to why would a transmission “lock up†this way?
