Michael
    9
Everything posted by Michael
  1. I think that the point is that whereas the engine itself might be free, solving the various system integration issues (cooling, gearing, reliability, and so forth) would be very un-free - to the extent that it would be cheaper in the long run to avoid the free engine entirely.
  2. One consideration regarding transmission torque-carrying capacity is whether you plan on regularly running the engine at WOT, or if the spirited jaunts will be rare. If the car will see a dozen passes down the quarter mile, every Saturday for six months a year for 10 years, then certainly a strong transmission is required. But if (as for example in my own case) the track would be visited once or twice a year, for a couple of time-trials just to collect a time-slip or two, then it stands to reason that even a gearbox that’s marginal at 300 hp should survive the occasional 500 hp. In that case, torque capacity really shouldn’t be a concern. The higher-rated transmission would be more expensive, heavier, harder to fit, harder to service, and harder to shift. But if you do plan on regular drag racing, then indeed the gearbox strength issue becomes moot, and the slushbox is the way to go.
  3. On the S30, and to some extent on the S130, what accentuates the length of the hood is the pointed hood lip and “forward swept†grill. Rounding out the hood lip/grill/bumper area would reduce drag and front-end lift, besides accomplishing some cosmetic improvements (in the eye of the beholder, of course). If your seat is mounted far aft – either because you’re tall, or the car is otherwise modified to require a further aft seating position (as in my case), then the windshield actually feels too far forward already. However, if you do wish to move its lower lip forward, keep in mind that you’ve effectively shortened the engine bay. For the stock L6 this complicates the installation of the brake vacuum booster and removal of the engine. For a V8 Hybrid these problems become even more severe. An alternative might be to set the windshield upper lip further back, thus sloping the windshield more. This was, if I recall correctly, already done by a member on this site.
  4. Bill, in the final iteration of pushrod length checking, how wide was the area on the valve stem swept by the rocker tip? Any pics?
  5. Garbage in --> garbage out; true enough. But sometimes truth in --> garbage out, nonetheless. I’ve used DD2000 with very marginal success. DD2000 arrives at a higher torque curve at nearly every rpm, whenever a given component is replaced with a bigger one. Got a 650 cfm carb? Great – now replace it with a 850 cfm, and watch the torque curve rise magically. There is no penalty in throttle response and no discernable penalty in quasi steady-state torque. Nor is there a penalty for mismatch of components. The program is very sensitive to intake duration – for some reason, this one parameter has a completely magical effect. Now to change the topic somewhat, and consider for a moment what a good research code (in mechanical engineering, not in “practical†automotive mechanics) should do... A good computational model needs, first of all, the CORRECT GRID – that means full knowledge of the geometry of the air cleaner, carburetor, intake manifold, intake port, combustion chamber and cylinder, exhaust port, header and exhaust tract. It needs the right model for wall surface roughness, including the various bumps and protuberances along the way. Next, a good computational model needs to be solving the “right†set of equations. This is the full 3-D compressible Navier-Stokes, with the right constitutive laws for 2-phase flow, and the right equations for energy and entropy. Next, it needs the right boundary conditions, such as the piston and valve kinematics. And finally – this perhaps the most difficult part – it needs the “right†turbulence model, to “close†the expression for the viscous stress tensor in the momentum equation. This is the sort of computation that would be run in university graduate schools with connections to the OEMs. What I would like to see is a better connection between the research world and the practical applications world.
  6. One specific instance that might call for a custom cam (or a semi-custom cam, as Jakeshoe points out), is when you want to run a mechanical roller, but happen to be interested in a low-rpm application, for which all of the cams in the catalog are too big.
  7. Jon, it sounds like Boise is too much of a small town for some one used to L.A. and Seattle. Granted, small towns have their particular appeal, but I would opine that moving from big city to small town is far more traumatic than the reverse. One experiences a feeling of exile; you offend the authorities, and they send you to a small hamlet in Siberia.
  8. Check to see if for purposes of your application it is required to obey NHRA rules for the intended 1/4 mile time. You only need to remain as legal as the letter of the rules, right? Depending on what’s not necessarily required, it might be feasible to gut everything aft of the crossmember supporting the rear links of the rear A-arms, and everything forward of the radiator. I removed the crash beams from the doors of my 1978 280Z, but retained the glass and window winding mechanism. This required quite a bit of contortion. Using tin snips, I cut as little of the inboard sheet metal as possible. Then, with a dremel, pliers and snips, I cut out the crash beams completely. Then I gathered the scraps of metal and weighed them. The result – for BOTH doors combined: 10 lbs! That was a lot of work for just ten pounds. And comparing, subjectively of course, how the doors feel now, when they’re opened and closed, vs. how they felt before the surgery, the difference in apparent weight is exceedingly minor.
  9. Michael
    Life?
    Business isn’t for everyone. Depending on one’s personality, starting one’s own business could turn into an unmitigated disaster. And it’s especially hard to become a budding capitalist if you’re just 21. My recommendation would be to enroll at the local community college, either in Arts and Sciences (if you wish to transfer to a 4-year college into an academic program, such as Engineering), or in a technical trade. With a suitable degree, the job prospects should hopefully become better. My wife found herself without a career, despite her educational background. So now she’s a part-time student at the local community college, and a part-time waitress at a local chain restaurant. She had to suffer the particular ignominy of transferring credits from her Master’s degree to her community college – and “starting over†in her 30’s. The Midwest in general is declining. Offshoring, globalization, whatever – they’re hurting the Midwest especially acutely, as this region is beholden to traditional manufacturing for its economic mainstay. And if that’s weren’t enough, retiring baby boomers are moving south and west, the tax base is shrinking, and liabilities are rising. So it stands to reason that the job market would be tight.
  10. One would think that faster flow of water through the radiator does NOT reduce cooling efficiency – in fact, quite the reverse. The engine/water pump/radiator/plumbing are a closed system. So, faster flow through the radiator means faster flow everywhere in the system (conservation of mass!) unless part of the coolant flow somehow bypasses the radiator. Water that flows quickly through the radiator will also return quickly; it will spend “more cycles per minute†in the radiator, even if each cycle is shorter. I’m sure that going through the heat transfer equations would confirm that assuming radiator fin surface area is kept constant, that faster water flow increases the heat flux from the coolant overall, into the radiator and into the ambient air.
  11. That does sound intriguing! I have a 280Z which might perhaps be back on the road by the time that your autumn semester starts. Its condition is approximately of the type that you desribe (some rust in rocker panels, covered by POR-15 years ago, but otherwise generally rust-free). Where in Kentucky are you? I'm about 50 miles north of Cincinnati, Ohio.
  12. I removed the reinforcements and related sheet metal from the doors of my 1978 280Z; net weight savings: 10 lbs. Certainly something to consider in the all-out effort for your specific purposes, but not a huge weight savings. Cutting out the front bumper supports and the associated bracing forward of the radiator support should be worth another 10 lbs or so. If you have enough time, consider cutting out the entire radiator support, including the transverse crossmember forming the power portion of the radiator support and connecting the frame rails. Replace with round or square tubes. What about replacing the radiator itself, with an aluminum universal-fit unit, such as Griffin?
  13. While we’re on the subject of deep pockets…. For some one with the resources, the engineering know-how and the gumption to make such an ambitious purchase, wouldn’t it be wonderful to take the additional leap to build a complete car from scratch – to build something truly light-weight and modular, with a chassis designed around the drivetrain, and thus avoid the compromises inherent in any hybrid? If I had the experience and the time, I’d begin quite literally with a clean sheet of paper. Begin with the conceptual design; wheelbase, suspension architecture, rough layout of main components. In aircraft design, once a notional mission is defined, we conduct performance trades, to determine minimal thresholds of things such as thrust to weight ratio, wing loading, fuel fraction, and so forth. Well, apply similar thinking to cars. Then proceed to chassis design and external lines. Some day I’d like to build a car with size and weight comparable to the Anglia or Fiat Topolino, but with better aerodynamics and better chassis design, stuffed with an all-aluminum ~600 cubic inch BBC, with a chromoly frame and fiberglass lift-off body panels. But until then – there’s the Z.
  14. Peak torque and hp figures are very impressive, especially considering the 2.4L displacement. But I can’t help asking… at 2500 rpm, which is already pretty high in my book, this thing isn’t even making 35% of peak torque! Is such a radical torque curve considered to be an acceptable price to pay, to obtain those peak numbers?
  15. I wouldn’t be surprised of that weight figure is optimistic. With aluminum heads, Doug Nash 5-speed, R200, mild-steel roll cage and very liberal slicing of the unibody, I’m hoping to get my 280Z under 2600 lbs. It weighed in at 2725 with cast-iron 236 heads, full-size starter (figure 10 lbs savings), stock hood (new hood weighs 7 lbs). And about 30 lbs have been saved from gutting the doors, hood mounting area, “baggage compartment†behind the seats, etc. Anyway, my original thought was that $24K is pretty cheap for a pro-built car running in the 9’s. But then I realized that even if this car is exactly as advertised, it’s too specialized for my tastes. I’d waste $1000’s undoing what’s been done, just to get it the way I want it. Nevertheless, the next time that I’m in the D.C. area, I’ll pay a visit to see the car. Something tells me that it won’t sell anytime soon. Unfortunately for the seller, the Z community just won’t support a $24,000 car – and the sort of folks willing to drop that kind of money on a dragster would be looking at Chevelles, not Datsuns.
  16. All well and good, but it seems to me that the ultimate arbiter of “what’s the correct valvetrain geometry†– assuming that the various clearances between the various components are within spec, and nothing binds – is how the rocker tip sweeps across the valve stem. Every cam manufacturer’s web site has a drawing akin to “diagram A†in Grumpy’s posting, but I have yet to find any consensus on what is the ideal displacement which is swept by the rocker tip across the valve stem. This is the distance between arrows “1†and “3†in the above diagram. Or to put it another way, if for a given pushrod length the rocker tip goes across the valve stem by, say, 0.070†as the respective valve goes through its lift cycle, is that displacement too much? If so, then the pushrod is too short or too long. If not, then the pushrod length is close enough to optimal, and there’s no point fuddling with pushrod length any further. Use of that plastic “toolâ€, by the way, does not guarantee accurate pushrod length, unless the relation between the base of the rocker studs and the installed-height of the valve springs on your engine happens to be exactly as what the tool’s manufacturer intended. BTW those beehive springs are pretty cool, but unfortunately they’re not (yet) available in spring rates suitable for mechanical roller cams.
  17. The seller's reply was that the car ran mid-low 9's with a 427, and is now "probably" running mid 8's with the 469 - but didn't offer hard numbers. It has Merlin cast-iron rectangular-port heads, a Powerglide and a Dana-60 rear. My personal preferences would be a lighter rear, a stick-shift and oval-port aluminum heads. With the Dana and the cast-iron heads, however, the 2200 lb weight is very impressive!
  18. Awesome! I contacted the seller and asked for time slips.
  19. Short-style valve covers won’t clear the Comp Magnum roller rockers on my BBC, but conventional tall-style valve covers can not be used because their installation or removal would be impeded by the proximity of the “Monte Carlo†bars (diagonals from the front strut towers passing through the firewall and connecting at the dash bar). In other words, those bars pass too closely to the engine, and that makes the choice of valvecovers problematic. Tall valve covers would physically rest in place without interference - they just couldn't be routed over the rockers and under the Monte Carlo bars. Hopefully that wasn’t a too verbose explanation for a pretty simple problem. Anyway, other than custom-machined valve covers, which I am becoming inclined to attempt, the only solution seems to be 2-piece valve covers. These are available for marine engines, for example here: than custom-machined valve covers, which I am becoming inclined to attempt, the only solution seems to be 2-piece valve covers. These are available for marine engines, for example here: http://www.offshoreonly.com/esvon/page-4338.html http://www.hardin-marine.com/detail~ID~818.aspx http://www.zoops.com/newstalgia-products.asp But those cost around $400! Does anyone have leads on “reasonably priced†(< $150) two-piece valve covers for the Mark IV big block Chevy?
  20. Pete, good observation! I was also surprised to find that passage in Hot Rod, considering that they spent the past half dozen issues lashing themselves for their "imports might not be so bad, after all" phase a couple of years ago. The Toyota Carina build-up in the previous month's issue was also an interesting exception. But the same article went on to mention that the post-swap weight of the Solistice would likely be over 3000 lbs - perhaps well over 3000 lbs. Most our HybridZ's are under 3000 lbs, even with all-cast-iron engines and full amenities.
  21. Just an observation on the meaning of “high cost of livingâ€â€¦. High taxes – sure, that’s a high cost of living. But high housing prices? Bubbles aside, if you move to a place where houses are inexpensive, that’s probably because they have not been appreciating in recent years – and they probably won’t be appreciating in the near future. So the net difference between what you get out of the house when you sell it, vs. what you paid for the house when you moved in, would be lower in areas where the housing costs are lower. If you can afford larger monthly payments, the true cost of living is actually LOWER where the housing is more expensive! Example: my house in semi-rural Southwest Ohio now costs a little over $200K. That’s what it cost about 5 years ago, when I bought it. The net appreciation is zero. The same house in a “working class†neighborhood in Los Angeles would have cost around $500K in 2001. And today it would be worth - $1M? Also keep in mind that wealthier areas have a better tax base. If you earn $100K/yr in Ohio, you’re the local aristocrat, and will be taxed accordingly. If you earn $100K in Northern Virginia, you’re just an average Joe – and again, will be taxed accordingly. If there are lots of affluent people in a given area, then the burden of funding the schools, the firehouse, the police department, and so forth, is spread collectively. So, my point is, that if you’re going to settle in a new place for quite some time, it might make more financial sense to seek a more “expensive†area.
  22. Back to the original question.... Early 1990's Camry/Accord are good choices, but would be tough to find in decent shape at under $2000. A Corolla or its GM twin, the Prism, might be a better price/condition compromise. I found a $1200 1990 Honda Accord last year, but it was in really rough condition. And the fuel mileage isn't that great - around 25 mpg in mixed city/highway driving. My 1991 Corolla (bought for $1800 in 2001) would get around 32 mpg. V8 Mustangs, on the other hand, command quote a premium. Finding one below $2000 from any year, in any condition, would be quite a challenge!
  23. So that’s how that BMW mpg gauge works! That explains why it swings wildly between full-throttle blips going uphill, and shifting into neutral. It’s so annoying on my 1992 325 that seriously considering masking it with tape.
  24. First I sawed through the spindle pin to remove the control arm. Then I used a 75-ton press – and bent the fixture that I used to apply loading to the spindle pin, but didn’t budge the spindle pin! Then I drilled through the spindle pin with a 3/8†drill bit from both ends, and tried again with the hydraulic press – no luck. Finally I took the strut casting to a machine shop, which used a mill and boring-bar to remove the remnants of the spindle pin. $200 later the job was done. Next time I do this, I’ll take the whole strut/control arm assembly to a machine shop.
  25. Refreshing messed-up threads with a die can be problematic. I tried this on a particularly bad example (did not grind off the stakes on the retaining nut; unscrewed it with brute force, consequently destroying all threads at the stake location and further outboard), but could not get the die to cut into the same helix as the remaining, good threads. The "solution" was to first grid off the half dozen or so of the most outboard threads, then resume rethreading with the die. I ended up installing the 280ZX-style nuts, torqued to 240 ft-lbs. Car hasn't hit the road yet, so durability has not been verified.
