Well that's set right. Your RPM readings seem really high. It's like it's either 2k or 0. Even the lower ones that could be cranking RPMs are too high for cranking. Something is wrong in your ignition input settings.
EDIT:
AHHHH!! Just checked your .msq you posted. You're using -66 BTDC, I.E. 66 ATDC. You Trigger Offset numbers should always be positive, unless you're running a wasted spark setup, in which case it should be around -10.
