After doing much searching, I came to the conclusion that to put a T-56 behind a Gen 1 small block I had to buy a Weir conversion, a Mcleod conversion, or use a special adapter plate to mate the T-56 to a standard 4spd bellhousing. It appeared that I would be spending a minimum of 3-400 for the necessary parts.
While following various links I came across a company called Standard Transmission & Gear. I talked to a fellow named Mike who set me up with these parts.
1. a used LS1 bellhousing
2. a new Hydraulic T.O. Brg.
The price delivered to my door was $207 !! Sweet!
After measuring everything looks like it will fit just fine, but possibly require drilling the end of the crank with a 5/8 drill, 1/4in deep, for input shaft clearance. The stock clutch assembly will fit, 153 or 168 flywheel will fit, starter will fit.
Am I missing something or is it going to be this easy. I saw no reference to this setup while doing search.
Obviously it will not be legal for drag racing, but should work fine for street use. I do intend to put a steel shield in the tunnel for my own protection.
To contact Standard Transmission go to http://www.standardtransmission.com/
Input?
