Nigel
Everything posted by Nigel
  1. Nigel
    smelly z
    Myself, and two of my friends have added catalytic converters to our Z's and found a noticeable reduction in the exhaust odour. My '73 Z is fuel injected. One of my friends has SU's, and the other has triple Webbers. Nigel
  2. I have a 240mm flywheel. It's been shaved down to around 17lbs. I guess they could have gone lighter, but it's held up for 9 years so far. Nigel '73 240ZT
  3. Sorry to hear about your bad fortunes! I hope things turn around for you. I'm running 17" rims, so I have lots of clearance. Nigel
  4. FYI, Classic Datsun Motorsports has a mold for this hood vent, and is ready to start production. Pricing should be available soon. Contact CDM if you're interested. I'll post any updates I hear about. There's also a thread at www.classiczcars.com. Can't wait! Nigel '73 240Zt
  5. http://www.motortopia.com/album/12964
  6. There are three versions of the Toyota caliper. The 4 cylinder trucks have vented and non-vented rotor versions, but the pads are identical. There is also a larger caliper found on 6 cylinder trucks that is available for a vented rotor only, and the pads are not interchangeable with the 4 cylinder trucks. I believe you only have coolers available for the 6 cylinder truck calipers? I e-mailed you a few years back about making a cooler for the 4 cylinder truck calipers and you said there were no plans to make them. Has this changed? I, of course, have the 4 cylinder truck vented rotor calipers. Nigel '73 240ZT
  7. There have been many, many discussions about this topic over the years, and was just covered again recently. So, you should be able to find plenty of info if you search. To summarize, the stock feed line size is ok, but the return is too small. Either use the gas tank evap. line running to the front of the car, or run a new return. A sump will work pretty well on the bottom of the tank (that's what I have), but the ideal solution would be a surge tank fed by a low pressure feeder pump, with the high pressure pump fed from the surge tank. Nigel '73 240ZT
  8. I have an RT mount in my '73 240Z L28 Turbo. It fit with no problems. I did not use the stock lower mount (complete waste of time IMHO). All I did was to install the bolts from the bottom up, with no washers under the bolt heads, and no washers or spacers between the poly mount brackets and the diff. I did notched the poly bushing for the correct pre-load. My crossmember looks just like the one in the picture above, and I did not have to notch the crossmember. The bolts heads have never hit the crossmember under deceleration. I've had it in the car for several years now. Nigel '73 240ZT
  9. Ignoring all the naysayers, I put a cat in my Z 7 years ago (sorry, I couldn't find any good pictures of the location). I have no regrets doing it. No, I don't have before and after emissions test. However, I also have no complaints about exhaust fumes in the car, and everyone who rides in it comments on how civilized it is. That could just be because my Z is fuel injected, and I've tuned it pretty well, and the previous exhaust system was rather leaky. But, even if it does nothing, for $100 and a couple of horsepower, it's such a tiny investment, that it was worth it to try. And despite road racing, and drag racing, and some tuning mishaps, I've yet to melt it. A friend of mine had a cat put on his Z with triple Webbers, and he swears that it made all the difference in the world in his Z. I'd have to agree that it doesn't smell like a refinery in his car now. Another friend tried a cat in his Z with twin SU's, but I don't think he had as much luck. Theory isn't always everything. Try one out and see if it works for you. Again, it's such a small investment, that you don't have much to loose if it doesn't work, and others have had success with them. Nigel '73 240ZT
  10. I don't think this is correct. Every source that I've read indicates that NOx is formed at high combustion temperatures, and these occur at stoich. Hence, the introduction of the EGR valve, to inject a small amount of inert exhaust gas into the combustion chamber to lower combustion temperatures, and reduce NOx. Unfortunately, this also reduces engine efficiency. Nigel '73 240ZT
  11. Hey Nigel. Know of any solid 240 or early 260 shells kicking around? My 71 is toast and I'm looking to keep the dream going. Let me know.
    Sean
  12. Not sure if you realize that that is a rare Datsun Competition Hood Scoop he has on his car, not just a stock hood with a vent cut in the side: http://zhome.com/History/ComHood.htm I wish somebody would reproduce them! I'd buy one in an instant. Hey J. Soileau... look up two posts from yours. I don't think Drax is going to be happy with you Nigel '73 240ZT
  13. Have you seen this... http://forums.hybridz.org/index.php/topic/31011-my-240sx-rear-irs-swap-into-my-240z/ Only covers the rear suspension though. BTW, the picture links on the first 3 pages are dead. Nigel '73 240ZT
  14. Actually, it is closed loop, with a temperature compensated pressure sensor. That's pretty good for an EBC that's less than half the cost of an AEM Tru Boost EBC, which isn't closed loop. Nigel
  15. Hey! So somebody else is finally using one of these EBC's! I'm glad to hear my suggested mods worked out for you. I never got around to trying them. My EBC is still working great. Every now and then it will switch boost levels when I start the car, but I haven't had any other issues. I'm just seeing your e-mail now. I'm still not getting e-mail updates for this thread, but I do for all the others I'm subscribed to. Haven't figured out why yet. You're right, the HDI instructions don't clearly show that the bottom port of an external wastegate needs to be connected to a boost source (your picture #2). But otherwise, it's correct. You can also use the other external wastegate hookup you have shown (pic #3), but the exhaust pressure could potentially force the wastegate open I guess. Nigel
  16. Where and what were you searching for? There have been countless discussions on fuel system mods needed to run FI in 240Z's. That being said, at the very least, you will need a larger return line of at least 5/16", and if you ever plan on tracking the car, I wouldn't waste my time on the 280Z tank. With a high flow pump, it'll be sucking air on hard corners with less than half a tank. There are lots of discussions on better alternatives (sumps, surge tanks, in-tank pumps, custom tanks, fuel cells). If you're just looking for something temporary to get the car driveable, use a 90deg fitting off of the drain on the bottom of the tank as the supply, and use the original feed as the return with a new, bigger feed line. Nigel '73 240ZT
  17. FYI, the 9.5†width that these rims are available in is less than the recommended minimum width for a 295 tire. Nigel '73 240ZT
  18. From Chilton Manual '84 - '86 300ZX Front Rotors Base Model - 9.84" (250mm) dia. GL, GL-L - 10.79" (274) dia. Nigel
  19. Those are probably base model Z31 rotors. IIRC, you need the GL/GLL rotors. You definitely should not use them like that! Nigel '73 240ZT
  20. I'm not aware of any North American distributors. They do ship internationally though. I bought one of their DIY kits (I'm an electronics tech) about 5 years ago and it's been working fine. A lot of other wideband products have come on the market since then. There may be better options now, but I'm happy with the Tech Edge product. Nigel
  21. I have the datalogging chip. It's pretty limited. It only records the AFR (providing you have an AFR meter - preferably wideband) on the RPM map. But it can be handy for doing some quick tuning without a laptop. Keep in mind that because it only records on the RPM map, if you have a turbocharged engine, you won't know if the RPM or Manifold pressure map needs to be changed while building boost. Once you're at a steady boost level, you will know if it's the RPM map that needs adjusting. For more detailed datalogging, I got a Techedge Wideband 02 meter which can log up to six channels. I just tapped into the SDS signals I wanted to monitor (RPM, manifold pressure, throttle position, and air temp so far). This made all the difference in the wold. http://wbo2.com/3a1/default.htm Nigel '73 240ZT
  22. They're locking tabs to keep the nuts from coming loose. You bend the tabs over against the nuts once the nuts are tight. Nigel '73 240ZT
  23. I have these in the rear of my Z right now, and I'm not happy with them. The hole that the strut rod goes though in the center of the large bushing has deformed, and the bushing will no longer hold it's position. This happened very quickly after installation. I think it maintains maybe a 1/2 degree. Nigel '73 240ZT
  24. I think the drivetrain forum would have been more appropriate for this topic, but regardless... I looked up the bore diameter for a 240SX slave, and it doesn't appear to be any different from any other Z slave cylinder at 3/4". Are you sure there's a difference? I did a S14 transmission conversion for my L28, and the clutch hardware for the S14 didn't look any different than what I was using for the L28. The arm, throwout bearing and sleeve were all identical. S14 transmission didn't come with a slave though, so I couldn't do a direct comparison. But I'd really be surprised if there's any difference. How do you know that your clutch master cylinder is not shot, or maybe there's just air in the line? Nigel
