Now I'm confused. Terminology, perhaps? To clarify, I'm calling a trigger anything that provides positional (or RPM) information to the EMS. Be it a sync pulse, multi-tooth wheel, or even just a negative coil pick-up.
Matadem, the way I'm using the Z32 CAS is functionally identical to the way I'm using a 280zxt CAS. In my case, both can be used with no disc modifications. Or, with a simple modification (adding an additional 'slot' adjacent one of the existing slots). In the first example, the EMS knows engine position, but it doesn't know specifically where cyl 1 is. With the modification, the EMS can establish where cyl. one is. Note: I'm only implementing the 'low res' row, ignoring the 360 slot row.
As Tim suggested, it could also be used as a 'sync', working in conjunction with a crank sensor. In that case, a disc with only one slot would do the trick. It adds some complexity (requiring the use of two triggers), but it can add accuracy.
