Mike Rowe
Everything posted by Mike Rowe
  1. Mike are these Performance Supalites? I am just looking at 16x8 Supalites for my 260Z due to fitting the RB26. I currently have 15x7's on both the 240 and the 260 and both are 12p and sit nicely in the guards. I tried a 16x8 4neg on the front and it clears with a bit sticking out the side and a 16x8 4p seems to be the go on the back. If I fit coilovers the 4p will fit front as well. Have you thought of using 16's?
  2. I was in NZ recently and ran this message and met some good guys and their machines. Trying the same here in SA. If any SA guys see this message pls respond and give me your ph contact details. Currently in Cape Town heading to PE then JOberg regards
  3. Hi Paul, I dont have any booster - remember we had a look outside your house and decided it was too big, the last thing I had was the fuel pump bracket which I left on your verandah. Checking out the Z scene here as I can while travelling round, See u when I get back regards Mike
  4. If anyone is a member of HybridZ in Auckland or near by I am here for 5 weeks and would like to catch up. My Aust mobile number is 0417943522 local Auckland home number 5211634 - please give me a call to catch up Mike
  5. The RB30 sump bowl is at the front as said by old300ZX. The RB20 you require is the one with the rear bowl. Even some RB20's have a front bowl as I found out
  6. Thanks very much for the photos. I will see what I can do with my setup
  7. thanks guys for your advice, sounds like I wont be just drilling the bar witjh my hand drill! Will have to find another attachment point regards
  8. Joel, regards fuel lines - my race shop has said to use -6 flex lines to and fro and -8 just from the surge tank to the Bosch pump. You've gone a lot bigger, do you think my lines will be too small?
  9. Open this to look at my seats, they may be Toyota MR2 looking at the seats above http://myweb.westnet.com.au/mikeval/PDF/Part%208%20Seats.pdf
  10. My seats bolted straight into the front and a tab made across the back. They go all the way forward and back. They also have manual height adjustment (good for the wife), lumbar adjust and seat swab adjust to tighten on your back. Unfortunately I dont know what they came out of, but it was a two door as the passenger seat has a knob that automaticvally bends the back down and shoots it forward. It will be out of a jap car either Mazda or Toyota I would think. There is a whole section Part 8 on my website if someone wants to ID them
  11. on my website I show the whole process in Part 3 regards Mike
  12. I have recently purchased one of the above and the booklet is all in Japanese. Has anyone found an English version? I am especially interested in Pages 14-19 which describe where the hose fittings are inserted into the inlet manifold in lieu of the Air Flow meters. I have tried logging onto the Apexi website but it wont come up. Any help would be greatly appreciated
  13. I believe from 2000 on the WRX's had a quick rack & they are much more expensive over here any way
  14. I have exactly the same diff and it came out of a Z31 300Z turbo out of Japan. Has 4.375 and CV's - check out my website regards
  15. I have exactly the same diff and it came out of a Z31 300Z turbo out of Japan. Has 4.375 and CV's - check out my website regards
  16. The bowl at the back of the sump pan is as follows: 140mm deep, 190mm wide and 170mm long regards
  17. I have put a 240Z water temp sensor in that sump as it fits and am using a second 240Z water temp guage as my oil temp guage above my oil pressure guage (adapted original instruments) See my website regards
  18. Hi Fentin, any progress on the photos pls mate? regards
  19. Would you mind still sending me some better photos I am interested how you attached it. Also what size oil cooler and where did you get it from? Also what adaptors did you get for the oil filter housing & did you remotely fit your oil filter? regards
