19
Everything posted by rturbo 930
I just hate to see a Z go to waste for likes on youtube and instagram (or any other reason), which seems to be a theme now. Just to be clear, with regards to engineering ability, I didn't mean just mounting the things on the car, I meant doing it such that they actually work well.
Okay, I didn't see the M5 reveal video. I just subbed to him yesterday. I'm with you on power, with the way I drive, I'd be dead in a week with 500hp. And the Z needs so much work to be able to handle 500hp really well, that I don't think it's really a good candidate for that kind of build. 300hp is probably the sweet spot for a Z. Not slow, but not so powerful that it's out of control. I also left a comment on the video that appears to have gotten some traction, and it looks like I'm not the only one to complain about the wheelbase. We'll see what he says. I don't know if he reads comments or not, and there's a LOT of comments. I've seen a shortened Z by some guy in Malaysia or something that did an AWD RB swap. Looks as stupid as you'd expect. From what I'm reading here and in his comments section, it doesn't sound like he has a clue about engineering anything, and mostly does basic, not terribly well done aesthetic stuff.
Alright, I just saw his second video, describing the plans for this thing. Sounds like it's going to be some frankensteined disaster. He's moving the front wheels back some 5", and swapping a newer, wider, larger interior into it, as well as a suspension that is, from what I gather, about 8" wider, or 4" per side. And a target weight of 3000-3500lbs. So, it's going to be a Goofy looking, short, wide something-or-other, with no visual cohesion (old car+new interior), too fat to be a sports car, but it won't be a luxury car either because it's got a cage, and I'd take a guess it'll drive like crap too.
Yeah, where did you get the idea he's turbocharging it from? I don't think I heard him suggest that. 1000hp would be just silly - a waste IMO.
Yeah, kinda makes sense though. Being a V10, it should fit lengthwise pretty easily, and Datsuns have been V8 swapped enough that I don't think width is too much of an issue. I think even the behemoth twin cam 4.6 Ford motors fit in these cars, although only just. Pretty sure someone did that swap.
B is for Build on YouTube just bought a 240Z to put a BMW V10 into. Should be interesting.
How in the hell did you get a late model 280Z to weigh 2231lbs? Without carbon parts it weighed 2330lbs? That's on the light side even for a 240Z, with a full tank.
http://www.thezstore.com/page/TZS/PROD/classic08i01a/50-2050
Yeah that's definitely too low. Looks like the flare lip is actually lower than the fender lip - a good indication that the flares are too low.
Yeah, I'd look into getting it blasted or dipped.
I believe I saw the ITBs from this build for sale recently, so, I'd say probably not.
Stiffer drop mounts and moustache bar
rturbo 930 replied to EF Ian's topic in Brakes, Wheels, Suspension and Chassis
If you only want to run a finned diff cover, why not just have a new piece made? No need to replace anything but the piece getting in the way. -
Cages - Experiences wanted
No seat belt reel? Doesn't look like it even has a pocket for it. My '76 has dual reels, and so does my '78. Interesting. If I could get my hands on whatever belts the late euro cars had, that would make my life a lot easier. -
For the reasons I stated earlier, you're going to have to re-engineer your seat belts regardless since your main hoop is going where the lower seat belt pockets are, and I don't see how they can both possibly occupy the same space. My plan was to do what you show in the picture above there - mount the bars to the front of the strut tower where the strut bolts in - unless there's something I don't know, I can't imagine that would be much worse than having it on the top of the tower. Interested to see what you do, since I'm facing the same problems. -
I'd put the pad you're gonna use on the frame you're gonna use, and restore it. Less risk of screwing it up after you fix it. I don't know if it has the structural integrity to withstand being repaired off the frame. Here's one guide: https://zcarguide.com/repair-dashboard-datsun-z/ And another: http://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/ There's also this, but I don't know if they have early dash pads available yet. Some guys on CZC were saying in the discussion thread over there that their restored dashes had cracked again. I guess the material that hadn't cracked yet is so brittle that even after you fix it it's still prone to cracking. Food for thought.
I think you'll be okay with the wiring. There might be a few that you'll need to look up, but I think most of the connectors only go one way, at least from what I remember. Without looking, I'm 99% sure you gotta remove the gauges. Not really a big deal honestly. And yes they are tapered. It sounds like you're trying to save time and effort by cutting corners - the dash is not that hard to take apart, I'd suggest you just do what needs to be done.
His car is a series one, and yours is a non-US '78 260Z, so you should expect a bit more weight, all else equal. I read a post from John C once saying that an early 280Z chassis was 100lbs heavier than a late 240Z, and a late 280Z was 300lbs heavier than an early 240Z. Seems like a big difference for just a chassis (I believe that was the context) but that's the only info I've ever found. I have a '76 chassis and an early 71 chassis, and I'm hoping I can weigh the two while stripped down and compare. I don't know how the non US late models compare to the US models.
I could be wrong here, but I think the idea is to sort of triangulate from the floor, to the roof, to the rear strut towers. Yeah, I'm by no means an expert, but I think your thoughts there are about right. Easy for to say since I don't have to pay for the replacement, but I think I'd toss it and get a proper one welded in by a good shop. -
Yeah, I'm looking at your rear bars, it looks like the mount somewhere in the trunk? I'm also looking at where your main hoop mounts. It's hard to see, but it looks like it could go back a little more, is that right? I'm also thinking it could be leaned back a bit. My plan was to put it pretty tight up to the wheel wells, leaving just enough to get the thing welded, and also put vinyl on the wheel wells - maybe an inch or so out. Though, I'd also consider cutting the wheel wells, and running the bar into them. If I do a bar, I'll likely do it to SCCA rules, so I'll have to double check to make sure this is all in line with their rules. My car is going to be primarily a street car, so it's important that the roll bar doesn't get in the way of that. -
I take it you plan to run 3pt seat belts on the street? And I believe you have a '78, with seat belt reels on both the strut tower and on the floor, yes? If so, this is going to be harder than you think. If you want the roll bar for stiffness, mounting it on the wheel well isn't gonna do anything. Going from memory so I may not have the details right, but John C had the S30 chassis analyzed (I forget the method), and apparently found that the chassis flexes at the front and rear bulkheads "like a hinge." The solution to the front is the 3pt strut tower bar, as well as the bar going from top of rocker to upper chassis rail. Solution for the rear is a 4pt roll bar, and as mentioned, gusseting the bar to the roof helps as well. I'm not 100% sure what he's calling the rear bulkhead, but I think it's like the area about where the tool boxes are. So, the problem here, since you want 3pt seat belts, is that your main hoop needs to go right where your seat belt reel is. I'm planning on doing the same as you, and I think I might have a solution using a slightly modified belt from a newer BMW, but obviously haven't gotten to that point yet. Basically the reel bolts to the stock location on the strut tower, and rather than another reel, the lower belt anchor simply bolts to a location already on the car, like the 240Z seat belts do. Sounds sketchy, but I'm fairly certain it'll be safe. Custom seat belts are also an option. -
Can you post a pic? I was planning on a 4pt roll bar for safety, stiffness, and as a place to mount harnesses, but this is giving me pause. -
The thing with the repaired car is that out of the people doing DIY backyard repairs, there is a wide range of ability to be observed - some of it very impressive, some of it scary. I can't really see the repairs in your pics, but I'd take a good look at the quality of the work that was done there. Also, how well were the parts labeled and organized? Are all the bolts in a big box, or were they put into bags and labeled? Still leaning toward the complete car. Having a running car is a great way of keeping your motivation up, too.
What condition are these cars in? What year are they? Given that you are 15, likely have little money, skills, etc. I'd probably get the first one, get it running and driving well, and focus on fixing all the things that have degraded over the years. Forget about the RB swap until you're older. Dealing with someone's project when you are totally unfamiliar with the platform is a pain.
Depends on the year. For a 240, it's almost nonexistent. 73-76 cars have a door beam added to the door, which is actually pretty beefy, it's about 10lbs worth of steel. 77-78 had the door jamb redesigned for side impact safety, and it's probably safer than you think. Not on the level of a new car, though, obviously.
