37
Everything posted by Miles
1972 240Z New Goodwrench crate SBC 350 Holley Carb Hooker block hugger exhaust headers Build date: 2009 Approximately 6,000 miles on build Holley carb, MSD HEI distributor and timing not touched since dyno tune 2009 Car ran fine for nine years , but developed a recent exhaust header leak. Replaced header and flange gaskets and, while I was at it, also replaced the plugs - Accel shorty Plugs gapped at 0.035 At start up, the exhaust makes popping sounds at idle after five minute warm up. No popping when cold. Gets worse the longer the engine idles. Popping gets louder with warm up and is punctuated by a very loud POW at random times. No other changes were made. Checked: Plug wires not mixed up. No arcing around plugs or wires Plug wires tight on plugs and distributor cap Re-tightened header and flange bolts.
Sensitive Brake Pedal
Miles replied to compression's topic in Brakes, Wheels, Suspension and Chassis
Edit: Perhaps he didn't lengthen the push rod as required for the 280ZX MC swap which would act like a missing reaction disk. He should check that the measurement first and if that doesn't fix the problem go looking for the reaction disk. When I lost my reaction disk I made a new one from a rubber stopper and used JB Weld to fix it to the push rod base permanently. Push rod length per the picture below is 0.53 inch or 13.462 mm from the flange. Note: you do not have to remove the brake pipes to adjust the push rod. Just pull the MC back and push it aside. Push rod adjustment -
Yep reaction disk. Typically falls out while adjusting the push rod length to work with the 280zx master cylinder. -
Quarter window lower rubber glass to door seal
Miles replied to 72zzcar's topic in S30 Series - 240z, 260z, 280z
Use a strong adhesive. -
No picture. Pick up a copy of: How to Restore Your Datsun Z Car by Wick Humble. Details how to disassemble, repair and reassemble the 240Z with detailed pictures not available in the FSM. I used this book in restoring my 72 240Z. It saved hours of researching. Can you post a picture of which seal you mean? I can look at my Z or look it up. -
Again, what happens when the lock button is pulled up? Does the button stay up in the unlocked position? There is a small torsion spring that keeps the lock button up. If that spring fails the door will always be locked. https://www.zcar.com/forum/10-70-83-tech-discussion-forum/108890-door-lock-knob-not-staying-up.html
Lift the door lock button up. When you let go of the button does it just drop down and lock the door when you release it?
Google searched "vq35de 280zx" See: Z-Fever VQ35DE swapped 280ZX post below Includes videos! Z-Fever has a website which includes tech write ups on VQ35 swaps: www.zfever.com Looks complex and expensive. SBC or LS engine swaps into 280Zx cars have been done and install kits are available.
Search this site for "vq35de". Lots of data!
Keep searching and form a plan. Members will be more likely to help once you can lay out a plan.
It has been done. Search HybridZ for member projects.
From the album: Miles
