37
Everything posted by Miles
The strap is no longer required. The stock rubber differential mount you replaced would flex and rip apart eventually. Nissan installed the strap to keep the nose of the differential from pitching up under load. For normal daily driving the solid mount works well. But the racers have reported that under hard driving the front cross member can crack and/or pull the center bolt through the cross member. I installed solid mounts in both of my Z cars 20 years ago and have not had a problem. Cars present us with lessons. The lesson is repeated until we get it and then we get another lesson etc etc.
Check out the "Clunk" here:
Welcome to Hybridz. The most efficient way to search Hybridz is to do a Google search using the following format: site: hybridz.org "topic in quotes" For example, site: hybridZ.org "R200" Useful information Download a Factory Service Manual (FSM). http://forums.hybridz.org/topic/48825-factory-manuals-some/?page=2&tab=comments#comment-1208329 Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. Focus on searching Hybridz as 99% of questions have already been addressed. Start bookmarking Z car parts suppliers - there are many! Remember these are 40 year old cars and will need restoration to be safe and drivable. Join ClassicZCars.com website and search there as well. Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. Search the Hybridz forums. Read all of the new member guidelines and FAQs Links: https://www.datsun-240z-upgrades.net/ Recommend the headlight relay harness http://zhome.com/ https://www.zcar.com/ https://www.classiczcars.com/ http://www.zcarparts.com/ http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html http://www.ztherapy.com/ http://www.xenonzcar.com/reference.html
That solid mount you are installing may require longer bolts anyway.
Why not just remove the differential from the car and apply heat to the nuts?
You need more leverage. Use a 2 ft. long pipe as a lever i.e., put the pipe over the wrench handle to extend the length. For example, I couldn't get the nuts on the stub axles to break loose. Tried an air impact wrench. The nuts wouldn't budge. So I got a 4 ft length of pipe and slipped it over the handle of a 1/2 drive ratchet wrench. The nut broke loose instantly.
Did you install the clutch disk backwards?
OIl pressure & water temp electrical
Miles replied to davek's topic in S30 Series - 240z, 260z, 280z
So if you turn the ignition switch to "run", pull the wire that connects to the temperature probe and then ground the wire, the temp gauge should go all the way to full hot. If, while performing this test, the gauge bounces around, then there is an issue with the sensor wire or the gauge. Could be loose or dirty connections. These links may be of some help: https://www.zcar.com/forum/10-70-83-tech-discussion-forum/280481-oil-temp-gauge-not-working.html https://www.zcar.com/forum/10-70-83-tech-discussion-forum/47277-temp-gauge-not-working.html -
Make model and year of the car? Any modifications to the car? Stock gauges? Describe what happens to the temp gauge if you ground the wire connected to the temp sensor. -
Many R200 3.9 differentials used in Z cars. Pick one and you will be miles ahead............................. http://www.zhome.com/ZCMnL/tech/GearRatios.html 240Z 70-73 MT (3.364) (R180) 240Z 70-73 MT 5spd. (3.900) (R180) - non US 240Z 71-73 Auto (3.545) (R180) 260Z 74 MT (3.364) (R180) 260Z 74 Auto (3.545) (R180) 280Z 75-76 (3.545) (R200) 280Z 77-78 MT (3.545) (R200) 280Z 77-78 Auto (3.545) (R180) 280ZX 79 MT,4 Spd,2 Seater (3.364) (R180) 280ZX 79 MT,5 Spd,2 Seater (3.364) (R180) 280ZX 79 All With Automatic(3.545) (R180) 280ZX 79 MT,4 Spd,4 Seater (3.364) (R200) 280ZX 79 MT,5 Spd,4 Seater (3.7) (R200) 280ZX-GL 79 (3.7) (R200) 280ZX 80 MT,2 Seater (3.545) (R180) 280ZX 80 Automatic 2/4Seat (3.545) (R180) 280ZX 80 MT,4 Seater (3.9) (R200) 280ZX-GL 80 (3.9) (R200) 280ZX 81-83 Automatic all (3.545) (R180) 280ZX 81-83 Turbo - all (3.545) (R200) 280ZX 81-83 MT (3.9) (R200) - - - - 300ZX's - - - - - -- - 300ZX 84-86 MT and A/T (3.7) (R200) 300ZX 84-86 Turbo MT and A/T (3.54) (R200) 300ZX 87-89 MT and A/T (3.9 ) (R200) 300ZX 87-89 MT and A/T (3.9 ) (R200) 300ZX 87-89 Turbo MT and A/T (3.7 ) (R200) Note Turbos: #1) after 4/87 only-(3.7 Clutch Type LSD) 2) 88 All White SS used a 3.7 Viscous Coupling LSD) 3) LSD Unites Came With Finned Rear Covers Additional Comments: a) Viscous Coupling LSD requires special splined half shafts - b) 84-87 R200's can be used in earlier cars, but require modifications they are not direct bolt in swapable to 240/260/280Z/280ZX's c) 84-89 R200's used a 12mm bolt in the ring gear - earlier R200 used a 10mm bolt in the ring gear, so you can not swap Gear Sets with the older R200's
How do you use the car? Daily driver? Race car?
alarm?
Steering rack parts have been NLA for many years. So called "rebuilt steering racks" also need those same NLA parts. Always ask the dealer if the rebuilt/new rack actually has new parts in it. If you search HybridZ you will see this topic was beat to death years ago. If you find the parts you need post the supplier here for us.
No (Low) Rear Brake Pressure
Miles replied to Twisted46's topic in Brakes, Wheels, Suspension and Chassis
What you have here is known as a Kluge: a collection of ill fitting parts forming a disgusting whole. Looks like the PO used hard lines that were too long. To get the lines to fit he took up the extra length by coiling the hard lines. The lines are not anchored correctly. Get rid of the yellow zip ties and do it right. Replace the hard lines with stock lines or make your own. If you are not up to making your own hard lines find a shop or web site that can make the lines at the correct length. Note: the fittings on Z cars are all 10 x 1.0mm double inverted flare. -
Coils? -
With the one inch MC you will notice that it takes more pedal force to stop the car. If you are going to larger calipers on the front then you will be all set. Even with the one inch MC you may still notice longer pedal travel before the brakes engage after you install larger front calipers. It is kind of a domino effect when modifying brake systems. -
Some after market master cylinders do not have the large reservoir in front. As long as the master cylinder is correct in all other aspects then it doesn't matter. You can always swap the front reservoir from the old master cylinder onto the new one for a "stock" appearance.
Join and search ClassicZcars. https://www.classiczcars.com/ ClassicZcars specializes in stock restoration. Also buy the book How to Restore Your Datsun Z Car by Wick Humble.
Welcome Useful information · Download a Factory Service Manual (FSM). http://forums.hybridz.org/topic/48825-factory-manuals-some/?page=2&tab=comments#comment-1208329 · Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. · Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. · Focus on searching Hybridz as 99% of questions have already been addressed. · Start bookmarking Z car parts suppliers - there are many! · Buy the Datsun V8 Conversion Manual from Jags That Run (JTR). · Remember these are 40 year old cars and will need restoration to be safe and drivable. · Join ClassicZCars.com website and search there as well. · Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. · Search the Hybridz forums. · Read all of the new member guidelines and FAQs Links: https://www.datsun-240z-upgrades.net/ Recommend the headlight relay harness http://zhome.com/ https://www.zcar.com/ http://www.classiczc...com/index.html/ http://www.zcarparts.com/ http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html http://www.ztherapy.com/ http://www.xenonzcar.com/reference.html
New to the Forum, 240Z with most dealer options
Miles replied to SpectreZ's topic in New Members Forum
Welcome Useful information · Download a Factory Service Manual (FSM). http://forums.hybridz.org/topic/48825-factory-manuals-some/?page=2&tab=comments#comment-1208329 · Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. · Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. · Focus on searching Hybridz as 99% of questions have already been addressed. · Start bookmarking Z car parts suppliers - there are many! · For SU carbs, parts and instructions go to Ztherapy. Buy the "Just SUs" video. · Remember these are 40 year old cars and will need restoration to be safe and drivable. · Join ClassicZCars.com website and search there as well. · Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. · Search the Hybridz forums. · Read all of the new member guidelines and FAQs Links: https://www.datsun-240z-upgrades.net/ Recommend the headlight relay harness http://zhome.com/ https://www.zcar.com/ http://www.classiczc...com/index.html/ http://www.zcarparts.com/ http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html http://www.ztherapy.com/ http://www.xenonzcar.com/reference.html -
Welcome Useful information · Download a Factory Service Manual (FSM). http://forums.hybridz.org/topic/48825-factory-manuals-some/?page=2&tab=comments#comment-1208329 · Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. · Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. · Focus on searching Hybridz as 99% of questions have already been addressed. · Start bookmarking Z car parts suppliers - there are many! · For SU carbs, parts and instructions go to Ztherapy. Buy the "Just SUs" video. · Remember these are 40 year old cars and will need restoration to be safe and drivable. · Join ClassicZCars.com website and search there as well. · Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. · Search the Hybridz forums. · Read all of the new member guidelines and FAQs Links: https://www.datsun-240z-upgrades.net/ Recommend the headlight relay harness http://zhome.com/ https://www.zcar.com/ https://www.classiczcars.com/ http://www.zcarparts.com/ http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html http://www.ztherapy.com/ http://www.xenonzcar.com/reference.html
You sure that the top wire goes into the engine? May have originally connected to the fluid level sensors in the MC tanks.
Power issue after fuse box upgrade
Miles replied to ~KnuckleDuster~'s topic in Ignition and Electrical
Please let us know what MSA says.
