Miles
    37
Everything posted by Miles
  1. Your stated goal is for a driver and not a project car. So look for a driver that runs and drives reliably. If you want a 280zx try to find a cream puff that someone else has put money into. Otherwise you will be buying a money pit. If you can't do some of the work yourself, the project will become very expensive. Modern mechanics don't know how to work on 38 year old cars. You may have to travel some to find a 280zx that requires minimum repair/replacement. Shipping is an option for out of town cars.
  2. The car is 35 years old. What is your budget for restoration and repair? Do you have the skills to do the repairs?
  3. TYpical car stuff. Post your solution.
  4. Try this blind hole bearing removal tool.
  5. The grease approach only works if you get a good seal around a pilot bushing as with a SBC. On my SBC projects the grease technique worked on the pilot bushing well enough sometimes to move the bushing out enough to get a puller on it. Sometimes I had to chisel a groove in the bushing and then collapse it to get it out. None of this will work with a bearing. Try a different puller. Failing that, you may have to pull the flywheel and take it to a machine shop.
  6. You didn't mention what type of headers you have. But you said that the headers are circular which suggests that you have block hugger style headers such as Hooker etc........................................ I have Hooker block hugger headers on my SBC 350. I have used the oval shaped header gasket for about 16 years. For example: https://www.summitracing.com/parts/mrg-5917 Other examples: https://www.holley.com/products/gaskets/header_gaskets/parts/10891HKR The attached picture is what I am currently using with my round port Hooker headers.
  7. Actually a few members have installed back up switches.
  8. Thanks. I did look at this and other controllers. But I wasn't sure about the reliability so I stuck with the old fashioned relay and thermal switch. I am old school. My first car was a 40 Ford back in the 60s. Grew up on flat heads and small block Chevys. Now there is an idea - a Ford flat head in a 240Z........................
  9. My bad explanation: I have my car wired differently then stock. Also, the Painless 70 amp relay kit is not designed to use a thermal switch ground. The Painless 70 amp kit is simply either turned on/off using a fan switch inside the car or the ignition. I wanted to use a thermal switch to ground and activate the relay so the fan didn't run continuously. I use a solenoid activated electrical master switch (Hotronics) in my 240Z. The master switch kills all power when off. So it acts like an ignition switch powering up the car and all accessories. With stock wiring you could wire it as shown in the picture below. I didn't wire mine that way because I didn't want to run a wire to the ignition since my car has the master power off switch that kills all power. This allowed me to wire the relay trigger (gray/white wire) directly to the relay power source (maxi fuse) that is only energized when the master switch is on (like turning on the ignition). It made running another wire to the ignition unnecessary. The relay is activated when the thermal switch closes and grounds the relay. Painless 70 amp relay kit wiring alternatives: If you want to use the Painless 70 amp relay kit with a thermal switch and use the ignition switch as the trigger you could wire the relay as per the 30 amp Painless relay kit pictured below. If you do not want to use a thermal switch to trigger the 70 amp relay, you can wire the trigger wire (gray/white) to either the ignition switch or a separate fan on/off switch. I preferred using a thermal switch to ground the relay so the fan would only run when needed. Here is a link to the Painless relay kits. Note the manuals with each kit. http://www.painlessperformance.com/webcatalog/fanc
  10. The Painless fan relay comes pre-wired. The power wire is 10ga. So the ground wire for the fan I installed is also 10ga. WIRE SIZE AMPERAGE WIRE GAUGE 2 22 AWG 3 20 AWG 5 18 AWG 10 16 AWG 15 14 AWG 20 12 AWG 30 10 AWG 40 8 AWG For wires over 20 feet go one larger wire size. Note: All of the 30 amp Painless fan relay kits are wired to work with their grounding fan thermal switch. The Painless 70 amp relay kit is not designed to work with a grounding fan thermal switch. The Painless 70 amp relay kit is wired for the ignition switch or a fan switch to trigger the relay. I wired the relay to allow a grounding type Painless fan thermal switch to trigger the relay. When the thermal switch turns on, it grounds the relay which closes the relay and energizes the fan circuit. Not a problem if you are comfortable working with relays. You could do the same thing using a 70 amp Bosch relay and some wire. See atch drawing.
  11. Yep. The Volvo fan amp draw spikes at 60 - 70 amps (momentary) and then settles down to about 30 amps. Even though a relay is rated at 30 amp doesn't mean that it will not overheat/melt at some point under continuous use. The 70 amp relay is insurance for those 110 deg days in the California heat. Other considerations are a quality fan thermal switch and relay, maxi fuse, appropriate wire size, ground and alternator. I upgraded the alternator from 70 amp to 100 amp.
  12. You are using the stock Chevy rams horn manifolds? Depending on the engine mounts used, the stock manifold may not clear the steering shaft. Do you have a picture of the engine mounts?
  13. This was my third failed 1 inch Wilwood MC. I bought a 15/16 replacement from Arizona Z Cars. The fan/shroud/radiator combination is working perfectly. The temp gauge stays between 170deg and 185 - 190deg in traffic on hot days.
  14. Go here and download the FSM for your 73 240Z: http://www.xenonzcar.com/s30/reference.html
  15. You are way ahead of the game. Hope you can post pictures of the trans install. The only other thing that comes to mind is to check the balance of the new flywheel. My flywheel was off right out of the box. Also, I had a bad experience with the shop that shortened and balanced my driveshaft. After cutting the driveshaft, they welded the shaft back together off axis which caused a high speed vibration. Had to pull the driveshaft and take it to another shop to correct the problem.
  16. Do all of the exterior lights come on? If not, which lights are out?
  17. Do you know that you have to dent the body to allow clearance for the clutch arm? Do you know about drive line phasing? There are a lot of details about the 240Z V8 conversion you need to know before you start the project. Purchase and read the JTR V8 conversion manual. You can buy it here: https://jagsthatrun.com/collections/jtr-v8-conversion-manuals/products/copy-of-v-8-conversion-manual-for-volvo-200-series JTR also sells many of the conversion parts you will need e.g., mounting brackets, hood bracket, speedometer drive gear (goes in the trans), etc.
  18. Note: you should purchase the JTR Z V8 conversion manual. And research HybridZ before doing the swap. The parts listed below are what I used. 1. T5 transmission: The WC T5 transmission is tilted 15 degrees towards the driver. The 15 deg tilt is absolutely no problem, I have done two. Unless you want to make a special transmission mount, you will need an 89 Camaro T5 bell housing, driveshaft, flywheel, clutch pressure plate/disk, throw out arm, throw out bearing, clutch slave and a 7/8" clutch MC. Note that there is a V8 and a V6 version of the T5 transmission. They have different spline counts. You will need the V8 version. 2. Bell Housing: 1989 -90 bell housing for V8. Verify that the pivot ball is in place as that part is NLA. 3. Flywheel: 158 tooth flywheel: https://www.summitracing.com/parts/zzz-50-6516 4. Clutch Kit: Zoom High Performance Clutch Kits HP1675-1A https://www.summitracing.com/parts/zzz-hp1675-1a/applications/ 5. Clutch Hydraulic Components: Camaro Clutch Slave: Napa sells the Camaro clutch slave. https://www.napaonline.com/p/NCF73110 Clutch Master Cylinder: Both Tilton and Wilwood make 7/8in. clutch master cylinders. The Wilwood unit is more compact allowing use of a larger brake booster. Tilton 74-875U: https://www.summitracing.com/parts/til-74-875u Wilwood 260-10374: https://www.summitracing.com/parts/wil-260-10374 6. Clutch Hose and Fittings: Hose: -3 A/N SS hose. Length TBD Roll pin to A/N SS line adaptor Russell 640281 (connects -3 A/N SS line to the Camaro slave): https://www.summitracing.com/parts/rus-640281 MC A/N SS -3 A/N line to 1/8in NPT adaptor Earls 961603ERL (connects -3 line to the MC): https://www.summitracing.com/parts/ear-961603erl 6. Starter: Hitachi gear reduction starter or similar unit.
  19. Her asking a dog question is a testimony to the high regard people have for the HybridZ community. I've seen a look in dogs' eyes, a quickly vanishing look of amazed contempt, and I am convinced that basically dogs think humans are nuts. - John Steinbeck
  20. Dogs didn't evolve to live in apartments. They need to be outside where they can be dogs and get exercise - a lot of exercise. They are also social (pack) animals, and become anxious when left alone. The shock collar is not the solution. If you keep your dog in the apartment and don't do the right things to help him thrive he will become fat and neurotic i.e. you will have a fat dog that is depressed/anxious and barks a lot. Your choices are: Take a class on dog behavior and Move to a place suitable for dogs If you are not prepared to learn about dog behavior, exercise him every day and provide your dog with a proper environment then give him to someone who does.
