37
Everything posted by Miles
Early 1971 240z Master Brake Cylinder Question
Miles replied to nusevad's topic in Brakes, Wheels, Suspension and Chassis
Why do you need a 15/16 MBC? If you have stock brakes the 15/16 MBC will increase the brake pedal force required to stop the car. That is, your car will not stop well. Recommend that you research the 15/16 MBC swap and the brake line issue before doing anything. There has been a lot written about this subject in the brake section. -
Useful links to bookmark: http://zhome.com/ http://www.atlanticz.ca/index.php/tech-tips.html http://www.classiczcars.com/index http://www.zcarparts.com/ http://www.blackdragonauto.com/zZxCatalog.htm http://www.arizonazcar.com/
Suggestions: If doing a V8 swap buy the JTR book and read it at least 5 times. Buy a FSM and Haynes repair manuals for your specific car. Download electrical schematics for your car. PDFs are easier to read than those found in books. Buy the book How to Restore Your Dasun Z Car by Wick Humble. It will save you hours of searching. Focus on searching Hybridz for at least 40 hours as 99% of your questions have already been addressed. Make a detailed plan with parts list including cost. Start bookmarking Z car parts suppliers - there are many! Remember these are 40 year old cars and will need restoration to be safe and drivable. Join Classic Z Cars website and search there as well. Become well informed about modifications before asking questions. People will be more inclined to answer informed questions as apposed to the I am too lazy to read/study questions. Have some money. I stopped counting after $12k. Read all of the new member FAQs. Read, study, plan, execute the plan.
Brake conversion datsun 260z(early)
Miles replied to 260zeto's topic in Brakes, Wheels, Suspension and Chassis
done -
240z clutch master and slave question
Miles replied to the240z's topic in Gen I & II Chevy V8 Tech Board
Please state what engine, clutch and trans setup you have. -
S130 Interchangeable springs?
Miles replied to ProjectDatsun916's topic in Brakes, Wheels, Suspension and Chassis
Hybridz may not have the exact answer you need. Try this: copy and paste into Google search: site: classiczcars.com s130 spring swaps or site: classiczcars.com 280zx spring swaps etc Google s130 spring swaps etc use above search format to search other Nissan and other Z car websites. There are many. -
I have the 1 inch Wilwood MC with Toyota solid calipers on the front and 240sx calipers on the the rear with all adjustments, including the push rod, verified and no air in the lines. I have a long slightly squishy pedal which becomes firm after about one inch of travel. Many other people have made this same complaint. The long pedal is a pain, so I researched the 240SX caliper design. The 240SX caliper has a low drag design (look it up) which means that the seals are designed to pull the piston away from the rotor which means that moving the piston takes a bit more fluid volume to bring the pads in contact with the rotor. I verified this by looking at 240SX master cylinders and sure enough they are of the "fast fill" step bore design as indicated by the bulge on the side. The"fast fill" MC provides an initial additional volume of fluid to push the piston out of the caliper to reduce time for the pads make contact with the rotor. I now believe that this may explain why there are many complaints about a long pedal or squishy pedal by people who have done the 240SX rear caliper swap. I have been researching the pros and cons of installing a 2psi residual pressure valve on the rear brake line coming out of the MC to offset the lag time (volume) required to bring the piston out of the bore. Some hot rod blogs make this recommendation to fix the long pedal issue common to drum to caliper swaps: http://www.hotrodders.com/forum/low-drag-caliper-replacement-110823.html I am still researching the viability of installing the 2psi residual pressure valves. Note: The first two Wilwood MCs I bought both leaked internally out of the box. So far the third MC has held up for three years.
I got the self locking ZX nut from my local Nissan dealer.
The book contains detailed instructions on how to make the 280Z tach work. Most people will be unwilling to type a page of instructions from the JTR book. Done
http://www.jagsthatrun.com/OrderingBooks.html
http://www.classiczcars.com/topic/13726-hood-alignment-primer/
I just noticed that your latching plate is mounted the reverse of mine. My latch is on the top of the bracket that is bolted to the fire wall. Look at my picture of the latch. The way you have the latch mounted on the bracket shouldn't effect alignment, but it could allow the peg on the hood to strike the distributor cap when closing the hood. The legnth of the peg is adjustable.
The question is: is the problem caused by hinge alignment or the latching mechanism? If you remove the latch from the hood so you can close the hood, would the hood line up with the fenders and fire wall? What do the gaps between the hood and the fenders look like ? What does the gap between the hood and the fire wall look like? Note there are some excellent threads on classiczcars.com web site that explain how to install and fine tune the hood alignment. There is a tutorial thread there by a member named escanlon that explains hood alignment. Paste this into Google: site: classiczcars.com "escanlon hood" etc etc
Need to show us photos of the hinges.
Chapter 10-1 7th edition of the JTR Datsun V8 conversion manual explains, in detail, how to do the required modifications and calibration to make the stock tach work with a V8. The manual costs around $30. Well worth the investment.
http://forums.hybridz.org/forum/28-links/
New Techno Toy Tuning Big Rear Brake Kit!
Miles replied to Turbo6.0's topic in Brakes, Wheels, Suspension and Chassis
Thanks for this info. Any possibility that the stock parking brake cable will work with TTT caliper. -
Please include which year Z you are asking about and what mods have been done. For a 71 240Z see post #8 for picture: http://www.classiczcars.com/topic/45901-early-1971-240z-and-rheostat/
When I was searching for a 78 280Z booster for my 240Z I discovered that there was a company in my hometown that rebuilds boosters and master cylinders for a variety of companies. I bought a booster from a local Nissan only wrecking yard and had the booster repair company rebuild it for $125. Check your surrounding communities for companies that rebuild boosters.
Google: "280zx eibach springs" etc etc etc -
Post some pictures of the hinges,and torsion bars, hood release and hood in the open and closed position (side and front angles). In the meantime don't grind or force anything.
Have you tried MSA yet? http://www.thezstore.com/page/TZS/CTGY/classic21a15
http://www.napaonline.com/Catalog/Result.aspx/Datsun-240Z-1973/_/Ntt-/Ntk-Keyword/Nty-1/N-599001%20101973%2050018%202018010%2026401/Ne-25000
For the Maxima calipers you should be able to find SS lines with a 10mm banjo on one end and a 10mm x 1.0 inverted flare end that connects to the hard line on the body. MSA sells a Maxima kit that uses SS lines with banjo fittings. Call MSA and ask if they sell the lines for the Maxima kit. Or you can use -3 adaptors on both ends. For the front you will need a -3 to 10mm x 1.0 inverted flare adaptor on the caliper and a SS line that has a 10mm x 1.0 inverted flare end to connect to the hard line on the body or you can use a -3 to 10mm x 1.0 inverted flare adaptor for the hard line connection. Recommend that you research this brake swap before ripping your brake system apart. This brake combination is not balanced and you will need to install either a 15/16 or 1 inch master cylinder for adequate fluid volume. The Maxima calipers are not well mached to the Toyota calipers resulting in too much front bias (search). Many people regret this swap. This has been documented extensively in the brake section and FAQs. Suggest that you rebuild the stock brakes, install SS lines and keep the brakes maintained.
