37
Everything posted by Miles
Should caliper type/brand/model number be added to the list? I know it made a difference with my Toyota front calipers. The 15" wheels I had at the time I installed the Toyota calipers fit without any clearence problems, but when I installed a set of 15" Ansen slotted mag wheels the mounting surface of the wheel rubbed on the caliper body. A 1/8" spacer fixed the problem.
s12+8 calliper installation problems
Miles replied to miky360's topic in Brakes, Wheels, Suspension and Chassis
Good assumption. My first 240Z had many 280Z parts installed by previous owners. PITA. -
http://www.classiczcars.com/topic/40444-brake-rotor-not-fitting-240z-vs-280z-hub/ -
Do not grind anything. Figure out why it is not fitting: step by step. If you have the correct rotor and calipers they just bolt on. Hundreds of these have been done. Are your hubs installed correctly? Is the inner bearing grease seal seated? Is the hub seated on the axle? Keep searching. This issue has come up before. -
Went with Firefox. Sites that used to hang up with IE load fast and are trouble free. No more IE service pacs etc to deal with. Thanks for the advice.
http://forums.hybridz.org/forum/30-v8-z-forums/
Issue replacing S12W caliper
Miles replied to wigenOut-S30's topic in Brakes, Wheels, Suspension and Chassis
After having bad experiences with several parts store calipers I now only use Nugeon brand parts. Napa carries them. Excellent quality control. http://www.nugeon.com/index.html -
7 Firefox 3 Chrome 1 IE
Trust, but verify. -
Assuming that you have 79 - 85 Toyota 4x4 pickup calipers and the correct rotors and hubs there should be no problem with fitment. Check the links below for more information: http://atlanticz.ca/zclub/techtips/toyotabrakeupgrade/index.html http://www.zhome.com/ZCMnL/tech/Calipers/toyotaCalipers.html http://forums.hybridz.org/topic/88822-70-240z-vs-240z-280z-brake-calipers-and-hubs-4-piston-toyota-caliper-issue/ Note that the Toyota caliper was not designed to accept banjo brake line fittings and may leak. Use a -3AN line and a 10mm x 1.0 to -3AN line adaptor as shown in the attached picture. -
Looks like Chrome is the way I'll go. Any problems with censoring searches or privacy with Chrome? Thank you all for the input.
I am looking for a reliable replacement for Internet Explorer: Firefox or Google Chrome? Other?
has anyone installed Rx7 brakes?
Miles replied to andyhorror's topic in Brakes, Wheels, Suspension and Chassis
Brake bias calculator: http://www.tceperformanceproducts.com/bias-calculator/- 59 replies
Good deal. Let us know how the brakes perform.
Bench bleeding setup. Be sure all fittings are tight and not sucking air. Push the piston in all the way slowly unti there are zero micro bubbles. Plug the outlet ports when transfering the MC to the car.
New Techno Toy Tuning Big Rear Brake Kit!
Miles replied to Turbo6.0's topic in Brakes, Wheels, Suspension and Chassis
Use of the stock E-brake would be a plus. The Miata people already have a full front and rear kit available using this caliper: http://www.habumiata.com/flyin-miata-four-wheel-little-big-brake-kit.html#!prettyPhoto -
Go to the brake section and research: Brake bleeding Soft pedal Bench bleeding master cylinder Missing reaction disk Adjustment of the master cylinder push rod. There are many threads that deal with your exact problem. Take notes and form a plan to diagnose the problem. Make a check list and investigate each component of the brake system starting with the master cylinder e.g., did you bench bleed the master cylinder? Many brake solutions can be found at ClassicZcars. Google 240Z brake problems, 240Z bench bleed master cylinder etc.
Rear Hatch Won't Lock (260z)
Miles replied to SubaruBRZ's topic in Brakes, Wheels, Suspension and Chassis
Wrong key, but if you wiggle it the lock turns. Yes, no? Adjustment Lock is broken -
I looked at the FB page and the website, but didn't see any pictures of the rear kit. -
You may want to research brake balance issues in the brake section before deciding to install rear disk brakes. There are some good threads with balance calculations that quantify balance issues associated with various front and rear disk combinations. You will need to know the piston and rotor diameters for each caliper you plan on using. Match what you are planning to use to the balance calculations HybridZ members have posted or you can calculate based on your planned set up. Many of the so called upgraded front and rear disk combinations result in too much front bias. If you do the rear disk swap be aware that worn bearings and warped stub axle flanges can cause the pads to drag.- 59 replies
Topic has been discussed extensively. Keep searching. You will need pads for a 1979 - 1985 Toyota 4x4 pickup which you should already know if you are going to use the S12-8 calipers. How will your car be used? So state so people don't advise you to buy the wrong type of pads e.g, you do not want to run race pads on a street car. Here is my experience for a daily driver street only V8 240Z: Over the last ten years I have tried KVR, Hawk HPS and Porterfield R4S pads. Low dust, but they did not stop the car very well especially on the first application when cold. That is, they had very poor cold bite which is what you don't want for a street car. You want good cold bite for the street. Performance pads need some heat for optimum performace so do not put them on a street car. I am now using Axxis Ultra pads on my solid Toyota S12-8 front and 240SX rear brakes. They have excellent cold bite and a very linear feel from first application to making hard stops. The set up on my car also includes a 1 inch Wilwood brake MC and 280Z booster. They dust a little, but so what. The idea is to stop the car. Source: http://www.importrp.com/product.php?productid=338850&cat=&page=1 PM me if you require more information about Axxis Ultra brake pads.
