37
Everything posted by Miles
The 1988 and newer Camaro 5 speeds are called World Class T5 transmissions. So you are correct, your T5 is not a World Class T5. Note: the T5 for six cylinder cars has a 14 spline input shaft and the T5 for V8 cars has a 26 spline input shaft. The front of the transmission case also has differences for the World Class T5 and the older T5s that you can see by doing a Google search. You could use your T5 as a core and buy a rebuilt 1989 Class T5 which is what I did. I also use a cut down stock Camaro shifter, a Tilton 7/8" master cylinder and a stock Camaro slave cylinder from Napa. You may want to have the flywheel resurfaced and balanced. The clutch kit I used was for an 89 Camaro (http://www.summitracing.com/parts/zzz-hp1675-1a/applications/). It contained the pressure plate, disk, pilot bearing and throwout bearing. So you should be able to find a kit for your application. Suggest that you research Summit for a clutch kit as Summit provides a lot of details about fitment and application. The kits cover several years. You should buy a Haynes Camero manual as it will explain how to work on the Camaro transmisson and clutch. It will show how to install the clutch plate and throwout bearing correctly.
If you might give the Z to a grand kid why not restore it? A V8 Z for a kid is not a good idea.
Do you want others to make a decision for you that you might regret? Only you can make that decision based upon research and weighing the pros and cons. Start with reading every post concerning the swap you want to do. If you can't decide then don't do it.
I made a reaction disk from a rubber stopper of the correct diameter and thickness (approx 6mm). Just take the push rod to the hardware store and match it to a rubber stopper. Cut a 6mm thick section off the end of the stopper and JB Weld it to the push rod. Shape the stopper with sand paper to match the diameter of the push rod. It looks and functions like the original reaction disk.
What year T5? The T5 was made for a V6 and a V8. They are different. Is the T5 a World Class T5 or the older version? What flywheel do you have? Measure the T5 input shaft OD. Use a digital caliper from Harbor Freight Measure the diameter of the hole in the flywheel where the bushing goes. Use the digital caliper. You now have the data to go to the Napa Parts look up. Note: If you buy a new clutch kit they often come with the pilot bushing.
R200 Won't Bolt into 74 260 (11/73)
Miles replied to thomas461's topic in Brakes, Wheels, Suspension and Chassis
brake booster swap/upgrade s30/z31/z32
Miles replied to sid240z's topic in Brakes, Wheels, Suspension and Chassis
http://forums.hybridz.org/topic/29420-brak-booster-and-mc-upgrade/?hl=%2B280zx+%2Bbooster&do=findComment&comment=228628 http://forums.hybridz.org/topic/49295-260z280z-booster-in-a-240z-it-can-be-done/ http://www.zdriver.com/forum/240z-260z-280z-brakes-wheels-suspension-chassis-126/bmc-swapping-27302/ http://forums.hybridz.org/index.php/topic/35455-brake-boostermaster-cylinder-options-on-a-73-240z/ -
A simple method of replacing rear strut cushions
Miles replied to docjim's topic in Brakes, Wheels, Suspension and Chassis
I do mine with a few less steps: Put car on jack stands. Disconnect the brake lines and parking brake cables. Remove the three nuts on the insolater cap holding the strut assembly to the shock tower. There is enough slop in the suspension that you can just put your foot on the hub and push down on it while pulling the strut towards you to clear the fender lip. No need to remove any other parts. Apply spring compressor and remove the nut on the shock. Replace springs/shocks as required. Reverse steps to reassemble. I installed Arizona Z springs on two 240Zzs this way. The Arizona Z springs were shorter than the stock springs so a spring compressor was not required for reinstallation. Seems like it took about twenty minutes per corner. -
Attention: New Tokico Gland Nut Info
Miles replied to camerashy's topic in Brakes, Wheels, Suspension and Chassis
There must be a QC problem at Tokico. Some things never change. I once ordered front and rear Tokicos for a 240Z. All of the gland nuts were wrong. The dealer replaced the gland nuts. Thanks for the update. -
Anybody have trouble installing polyurethane bushings?
Miles replied to jparker893's topic in S30 Series - 240z, 260z, 280z
No. Just my club which consists of me and my son and two hybrid 240Zs. -
Just use stock rubber bushings for the TC rod and poly for the rest of the suspension. -
Check out Wilwood clutch MCs. They may be more compact.
'72 240Z Backfiring Through Carbs at Low RPM.
Miles replied to Connor280ZX's topic in Nissan L6 Forum
Go to Z Therapy and buy the video "just SUs". It will explain how to maintain SU carbs. http://www.ztherapy.com/ Note: backfiring through the carb can be timing or the carb set too lean. The video will expalin it all. Also there are over a hundred posts here, at ClassicZcars.com and listed in Google searches dealing with SU carbs. Many many how-to posts are on-line. All of those vacuum lines have a purpose. See the FSM. Download a copy of the factory service manual (FSM) from elsewhere on this site or Google a FSM download, and buy a Haines manual. Watch the video until you understand SU carbs. You will then be able to tune a set of SU carbs in about 15 minutes. -
Found a switch under center console (1978 280z)
Miles replied to cbakes004's topic in Miscellaneous Tech
Look here: http://www.classiczcars.com/forums/electrical-s30/18532-power-antenna-electrics.html- 8 replies
- switches
- blue wires
(and 2 more)
Tagged with:
gland nut welded to strut tube
Miles replied to grillhands's topic in Brakes, Wheels, Suspension and Chassis
You need to download a copy of the factory service manual (FSM) before you start working on the suspension. Some of the FSMs are available in one of the forums. Or do a google search. Also a Haynes manual. You are aware that you will need a spring compressor if you have to remove the strut (shock absorber). -
77 280z master cylinder check valve
Miles replied to voltron_boi's topic in Brakes, Wheels, Suspension and Chassis
Go to the brake section and enter "push rod" into the search window. There are many many posts, with pictures and methods for measuring the push rod. Or just take it to a brake mechanic and have the MC installed -
Yes the 7/8 240Z has a check valve in the rear port because the 240Z had drums on the rear. Note I have found check valves in the front port on some rebuilt MCs. So I always check the front and rear MC ports before installing the MC. Do you mean the cone shaped seat for the pipe flange? If so, the cone shaped part just sits in the MC and can become stuck in-place. Carefully use a small screw driver and pry around the cone's base. Or use a rod or small screw driver that fits in the hole of the cone and gently move the cone from side to side. Do not scratch or dent the cone where the flange seats or it will leak. The cone usually just falls out after some light prying. The check valve and spring should just fall out or use some needlenose pliers to pull the valve out. There is a torque spec for the port fittitings. Look it up in the Haynes manual or in your factory service manual. -
Brake Master Cylinder Replacement
Miles replied to Shakey's topic in Brakes, Wheels, Suspension and Chassis
Are you running those pads on the street or track only? -
My solution: http://forums.hybridz.org/topic/5361-stuck-240z-brake-drum/?hl=%26quot%3Bstuck+drum%26quot%3B&do=findComment&comment=40349
Brake Line fittings question
Miles replied to Chaparral2f's topic in Brakes, Wheels, Suspension and Chassis
Go to either Earls Performance Plumbing or to Russell Performance Plumbing websites. They make a variety of AN adaptors. Everything you need to know is on Google. Research the difference between Japanese and metric brake fittings. -
I replaced the original dome light with an aircraft eyeball style map light. Had to do some minor grinding in the recess where the original dome light was in.
Works now. Thanks
When clicking on a topic I get this: There appears to be an error with the database. If you are seeing this page, it means there was a problem communicating with our database. Sometimes this error is temporary and will go away when you refresh the page. Sometimes the error will need to be fixed by an administrator before the site will become accessible again. You can try to refresh the page by clicking here
