Check out the Brake threads in the FAQ forum and all of the pinned threads in the brake forum. You will see many complaints about degraded rear brake bias after doing the various rear brake "upgrades" using Maxima, 240SX or 280ZX calipers. As you will see after reading about 100 threads they actually are not upgrades at all and people are frequently disappointed after removing their rear drum brakes.
Also, be warned that the stub axles were not designed for disk brakes. The flanges can get bent/warped which will cause the rotor to rub on the pads and overheat. You can have the flanges turned if they are not too bad. Out of six old stub axles, I was able to use one after turning it. New stub axles are NLA. After-market stub axles are available, but run about $600 to $700 (see vendors forum).
Note: I have done all of the so called "brake upgrades" using the above rear calipers, including front caliper, master cylinder and booster variations, and they are not upgrades all.
Go look at Arizona Z Car brakes if you want an upgrade in terms of performance.
Here are my brake bias (torque) calculations I did when playing around with different brake configurations:
Based on using a 1 inch Wilwood master cylinder
Stock front/ 240SX rear: 0.654 front 0.346 rear
Toyota solid front/ 240SX rear: 0.660 front 0.340 rear
Toyota vented front/240SX rear: 0.704 front 0.290 rear
Note: a proportioning valve will not correct the bias problem.
