37
Everything posted by Miles
Anyone know what wheels these are?
Miles replied to ThatOneZ's topic in Brakes, Wheels, Suspension and Chassis
Did you look at the links in that thread? -
http://www.zcar.com/forum/10-70-83-tech-discussion-forum/324969-14-wire-wheels.html -
I had the same problem and solved it with a Moroso water flow restrictor: http://www.jegs.com/i/Moroso/710/63440/10002/-1 Try the middle sized restrictor.
There has to be a problem with how the caliper mounts to the strut. Note rotor not centered in attached picture. Also, see hub to strut measurement picture. I am now considering milling about 1mm off the caliper bracket where it bolts to the strut. That would pull the caliper inboard which would center the rotor in the torque member slot.
I found a reference to the dimension between the hub mounting point and the stub axle flange here: http://forums.hybridz.org/topic/4672-rear-disc-bracket-fabrication-some-comments-and-a-question/?hl=%2Bcaliper+%2Brubbing+%2Brotor&do=findComment&comment=35335 See post #2 in link above. The dimension is 45.2374mm or 1 25/32" on a stock 240Z. See attached picture. The dimension matches my hub to stub axle flange distance perfectly. So there is no problem with the stub axle position relative to the hub. This can only mean that the custom MSA mounting bracket was machined 1mm too thick where it bolts to the strut. The rotor is definately not centered in the torque member slot. The rotor is approximately 1mm closer to the inboard edge of the slot of the torque member i.e., the torque member is pushed outboard 1mm by the custom mounting bracket. Looks like I'll be returning the brackets.
Awful squeaking noise from the rear suspension, solutions?
Miles replied to osirus9's topic in S30 Series - 240z, 260z, 280z
Do a search for squeeking. Many hits.- 26 replies
- suspension squeak
- suspension
(and 4 more)
Tagged with:
Make, model and year of car?
How to install door edge seals?
Miles replied to Stresspuppy's topic in S30 Series - 240z, 260z, 280z
All of your answers and more in this book: How to Restore Your Datsun Z Car by Wick Humble At: Amazon, MSA, Black Dragon etc. Also, join ClassicZcars.com where there are many how-to threads -
post pictures -
http://www.datsunstore.com/bias-proportioning-valve-7072-used-p-351.html
Can stock fuel wire handle 2 pumps?
Miles replied to 9rider's topic in S30 Series - 240z, 260z, 280z
Always include details about your car when asking for help: Make, model, year, engine swap and other modifications done to the car. Most electric fuel pumps make noise. How you mount them can reduce noise inside the car. I like the noise as it is a sign my pump is alive. If you start rewiring the fuel pump be sure not to bypass any of the stock fuel pump safety features. You don't want the fuel pump to continue running if you wreck the car. You need to start a collection of Z car factory service manuals and links to Z clubs and parts suppliers. Google and HybridZ searchs will find 95% of them Post some pictures of the fuel pump installation. -
Before "fixing the problem" ask "why is the pump making noise?" And then fix the problem. A Painless Fuel Pump Relay is advisable for any electric fuel pump installation on a Z car. -
Rear brake caliper bolt size
Miles replied to ComicArtist's topic in Brakes, Wheels, Suspension and Chassis
Do you mean the bracket that is part of the caliper assembly or the bracket that bolts the whole caliper to the strut? Are the holes lining up ok" What brand adaptor brackets are you using? -
Only you can plan your project. Educate yourself. Buy the book "How to Restore your Datsun Z car" by Wick Humble. It is a 40 year old car start at the bottom and work up if you want a safe and reliable car. Paint and interior would be last on my list.
What year 300ZX? If you are not a mechanic the 300ZX can be be very expensive to maintain. Call some shops and ask them how much it costs to do various repairs to get a feel for what you might be in for. It is not the best choice as a first car for a teenager. You will probably beat it to death or wreck it. Get a 4runner instead.
Too many people never follow up with a solution. Be sure to post your solution(s) once you are able to get a firm pedal.
- 48 replies
- brake bleeding
- bleed
(and 2 more)
Tagged with:
Bleeding a Z can be very frustrating judging by the number of threads dealing with that subject. If all else fails, fill a swimming pool with brake fluid and immurse your car in it for a few days!
- 48 replies
- brake bleeding
- bleed
(and 2 more)
Tagged with:
With Maxima and 240SX calipers I found that I had to unbolt the caliper from the bracket and bleed it while shaking, tapping and moving the caliper in various orientations to get the air out. Unless you have a pressure bleeder you have to block the piston with something so it doesn't push out. I use a caliper piston tool (Harber Freight $30) turned all the way in to hold the piston while pumping the pedal. Use Earls Solo Speed Bleeders or other brands of bleeders that have a check valve built into them on the calipers and master cylinder.
- 48 replies
- brake bleeding
- bleed
(and 2 more)
Tagged with:
