Miles
    37
Everything posted by Miles
  1. Refer them here: http://forums.hybridz.org/topic/109702-hybridz-is-not-automotive-101/
  2. No. Do it right. Go search spacers in the vendors forum. You will find one.
  3. You just have to methodically keep eliminating circuits until the problem circuit is identified. Also, for H4 headlights you should install the headlight relay harness sold by a HybridZ member and at Motor Sports Auto (MSA). The H4 lights pull more amps. It will take the load off of the headlight switch/wiring and provide brighter headlights. Do a search for the headlight relay harness for more info. Get a schematic and study it until you understand the affected lighing circuits and can trace them in the car. Have you identified every light that is on the problem circuit? There may be other lights such as a glove compartment light, dome light etc. that may have been miswired or become shorted. Don't open the harness unless you have eliminated all other possibilities and testing shows a problem. Most likely the paint shop grounded a wire. Keep looking.
  4. When I had my first 240Z painted, the painters removed the side marker lights. When they reassembled the side marker lights they plugged in the wires to the socket backwards so that the power wire went directly to ground. Each time the lights were turned on the fuse blew and took out all the lights on that circuit. What did you do the car that could cause the lights to fail?
  5. DOT brake pad edge codes. Codes are based on SAE Standard J 866. See picture. If you know your pad edge code it could be added to this thread.
  6. KTM No problem. I have been experimenting with different rear brake and master cylinder combinations.
  7. Stop. Don't modify anything. Get a schematic and study the wiring and internal connections of the switch until you understand how it is supposed to work. Then use a volt meter to figure out what is happening. Only then will you solve the problem. If the PO screwed up the wiring - fix it. Look at your fuse box for signs of burning/melting. There may be a clue there.
  8. Add your car info to your signature line so it is always available. See mine above. I keep several repaired TS and head light combo switches on hand for trouble shooting and quick repairs.
  9. 1. Read and study FAQs and old posts for at least 40 hours since all of these issues have been discussed in detail over the last 10 years. If the search function doesn't work, do a Google search. Type: site: hybridz.org key words 2. Save your money. Stock brakes are fine. 3. Since the car is close to 40 years old rebuild/refresh the stock brakes and add some good street pads e.g., Hawk blues etc. Add SS braided brake lines. 4. So called brake upgrades don't always improve performance - they can actually reduce performance. 5. Always consider that installing "big brakes" can result in an unbalanced system. The stock brakes were engineered and balanced. Most "hobby" brake upgrades are not. Make haste slowly.
  10. year? 240Z or 280Z? Most likely the it is the TS switch since it controls the lights that are not working. On a 240Z the brake light circuit is cut in and out by the TS switch in turn mode. There is also a common power wire. Take the TS switch apart and examine the copper contacts as for: Carbon build up. Clean with fine file. Bent or slightly out of alignment contacts. Especially the copper rocker which has four contacts. Broken or unsoldered wires There are several "how to" threads here, ClassicZcars.com and on the web for repairing the TS switch. Note there are small parts and a very small ball bearing that can go bouncing out of the switch when you open it. Do a search.
  11. Also, check Dorman products for longer studs. Installation: Front: Put hub in vise. Knock out the stud with a hammer. Insert stud in hole and pull it through using an open lug nut and washers to take up the slack as the stud pulls through the hub. I used an impact wrench, but a ratchet would work as well. Rear: There is just enough room to replace stock studs with stock drum brakes with the rear hubs on the car. Knock out the stud with a hammer and pull the new stud through using a lug nut. You might be able to get a longer stud in the same way. No problem at all If you have disk brakes. From my notes: http://forums.hybridz.org/index.php/topic/52907-wheel-studsreplacements/?&p=473102&hl=%2Bwheel+%2Bstuds&fromsearch=1
  12. Check for leaks around the throttle shafts. Check if the needle valve in the fuel bowel is sticking.
  13. Here is an on-line brake bias calculator that reduces the hassle of running calculations over and over each time a parameter is changed e.g, master cylinder diameter, rotor size, caliper piston area etc. Go here: http://www.tceperformanceproducts.com/bias-calculator/
  14. Make and model of car plus mods would help. How many turns out for each carb on the mixture adjusters? Not what you want to hear, but you may not find resolution in any forum/blog. Without understanding how the SU carbs work and how to tune them it is unlikley that you will solve the problem. Go to Z Therapy and buy the $25 DVD or tape "Just SUs" at http://www.ztherapy.com/
  15. After missing several deliveries while at work and driving 30 miles to the nearest FedEx I got a UPS box five minutes from home. Not expensive.
  16. On my 72 240z I installed the SPAL switches in the flip up fuse cover.
  17. Also, if you are using metal flake beware of making tiger stripes in the base coat like I did. My spray technique was off somehow.
  18. Down load a FSM from the Links forum on HybridZ and also get a Haynes maual for your car. The Haynes manual has an electrical schematic. Trace the affected circuits on the schematic and check for broken wires and loose connectors. Fusible link: http://www.zcarparts.com/ or try Black Dragon, Napa etc.
  19. I just got over 300 hits on 280ZX V8 swaps here: Gen I & II Chevy V8 Tech Board You will see that there are other companies that provide swap kits in addition to JTR.
  20. At minimum you should get a Haynes repair manual and a FSM to help diagnose/repair SU carbs etc. go here: http://forums.hybridz.org/topic/48825-factory-manuals-some/
  21. Do a Google search as there are several "How to rebuild/tune SU carbs" threads on several Z car websites. "This morning I swapped the carbs onto the 77'. It did fire up, but not very well. It was popping and back firing thru the carbs so I didnt get any further with it." This indicates a too lean condition. Do a search for SU mixture adjustments.
  22. See my reply to your original post. Buy up several combo switches and repair them. As a Z owner you are going to need them.
