Miles
    37
Everything posted by Miles
  1. 72 240z with carbed 350 SBC crate engine, Camaro T5, Arizona Z springs Tokico struts, poly bushings. Dyno 240 RWHP so it is still a 240Z. This was my second 240Z V8 build. Car was a very clean stock daily driver for eight years prior to build. 200k miles. Two years planning and gathering parts. Assembled all parts before teardown. One year building including disassembly, paint and interior. Outsourced exhaust installation and door panel covers. The car was old-school pupose built as a daily driver with no computers or modern electronics to allow ease of maintenance. Lots of sound/heat insulation with thick carpets inside. Very nice, clean, quiet inside, daily driver. Sounds good with an attention getting lope at idle. Never get tired of driving it, but, like all things, after four years on the road the initial excitement has faded. I took my time planning the build so there were no disappointing problems. Recently the stock stub axles caused some garage time, but new axles from Chequered Flag fixed that. Now I just modify and try new things to fine tune the performance. Last year I experimented with the so called brake upgrades to see first hand how each "upgrade" performed: 240sx rear, Maxima rear, Toyota vented fronts, Toyota solid fronts etc. Did the math for each configuration. They are all unbalanced and suck. For cheap brakes the solid Toyota fronts with stock rear drums was not bad. So I am very satisfied with the outcome of the project with the exception that parts are becoming harder to get.
  2. Do you mean that you want us to do your searching for you? Here is the link: http://forums.hybridz.org/topic/109702-hybridz-is-not-automotive-101/ Off to the shed!
  3. You might have adjust the length of the booster to master cylinder push rod. Do a search for adjusting the push rod.
  4. Will the clutch master cylinder get in the way?
  5. http://www.zcarparts.com/ http://www.blackdragonauto.com/zZxCatalog.htm http://www.courtesyparts.com/1970-1973-240z-air-conditioning-kit-r134-freon-p-228048.html?cPath=7724_7747& http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Power-Brake-Booster-w-o-Master-Cylinder/_/R-NBB535104_0136011533
  6. Keep searching for a clean and unmodified 240Z with minimum rust and do the conversion yourself. I can't recommend buying a V8 Z unless you know it was done correctly. I purchased my first V8 240Z done by the PO and had to redo the entire installation including all of the wiring that he had chopped up. For my current hybrid 240Z I bought the cleanest Z I could find for $3k. Starting with a clean platform makes the conversion much easier and less costly.
  7. http://www.geocities.com/jasonparuta/diffswap.html http://www.zhome.com/ZCMnL/tech/R200.htm
  8. No, do not use the 240Z driveshaft. You use the Camaro driveshaft and the flange adaptor from JTR: http://www.jagsthatrun.com/Datsun_Order.html The Camaro driveshaft has to be cut down and balanced at your local machine shop.
  9. 1. Do not start this project until you understand what you are doing. 2. Read all of the threads on brake swaps in the FAQ and brake forums. 3. Your bracket is designed such that you will need to pull the stub axles which will be a problem for you if you have never done it before. You will most likely screw up the stub axle if you do not know what you are doing. You should also change the wheel bearings while the stub axle is out. You will need to study how to remove and replace the stub axle and the bearings. BTW the stub axle was designed for drum brakes and runout in the stub axle flange can be a problem when switching to disk brakes. This job requires special tools. 4. The rear disk upgrade is not an upgrade unless you also take time to design and build a balanced brake system which includes the front brakes, master cylinder and booster. 5. If you will take time and study all of the FAQ threads you will know that well maintained stock brakes are fine for daily driving and light track use. 6. It is obvious from your questions that you are not an experienced mechanic. Altering your brake system without knowledge of what you are doing could be dangerous to you and others. 7. Do not modify the bracket. Sell the brackets you bought and use the money to have a brake shop rebuild your 40 year old brake system with fresh parts. 8. There are probably over 50 threads on the above subjects.
  10. Update: The problem was caused by bent stub axle flanges. I couldn't find good used stub axles so I bought new stub axles from Chequered Flag Racing and replaced the bearings. All is well now. http://www.chequeredflagracing.net/Datsun.html
  11. Update: The problem was caused by bent stub axle flanges. I couldn't good used stub axles so I bought new stub axles from Chequered Flag Racing and replaced the bearings. All is well now. http://www.chequeredflagracing.net/Datsun.html
  12. 72 240Z Brake setup: Wilwood 1 inch master cylinder, 280Z booster, Toyota S12+8 front calipers with solid rotor, Modern Motorsports 240SX rear calipers and Axxis ULT pads front and rear. For cold bite and overall brake feel these Axxiis ULT pads are excellent. Unlike the Hawk HPS, Porterfield R4S and KVR pads I have used over the last 10 years these pads do not require three or four stops to get them working in traffic. First stop they bite. Modulation is excellent as well. Good initial bite with good linear feel. Friction code FF They are also sold as PBR ULT. Source: http://www.importrp.com/index.php Check out the Bimmer sites for write ups.
  13. What modifications have been made to your brake system? Did you remove the brake switch under the master cylinder? Sounds like you have air in the system. Did you let the MC run dry? If so you will have to bleed the air out.
  14. This is what I used: http://forums.hybridz.org/topic/32693-spindle-pin-question/ The nut broke as I was removing the second pin, but the pin slid on out.
  15. Here is a link to Axxis pad performance: http://www.zeckhausen.com/axxis_pads.htm#Compare The Axxis ULT pads are also sold as the PBR ULT at some retail outlets such as Napa.
  16. 72 240Z SBC S12+8 solid rotor front brakes and MM 240SX rear brakes I have been looking for brake pads that have good cold bite as I do most of my daily driving in stop and go rush hour traffic. I have tried KVR, Hawk HPS and Poterfield R4S pads and they require a few stops before becoming efficient. I don't care about dust. Research is showing that AXXIS ULT pads have good cold bite and fade resistance. Friction code: FF Do these AXXIS pads make a lot of noise?
  17. Note: JTR also sells a 90 deg. speedo gear adaptor.
  18. If the rear end ratio is 3.36 or 3.54 the drive gear is 7 tooth and is purple. I have a WC T5 with a 3.54 R200 and 7 tooth drive gear. The speedo is spot on. Note: The JTR book has all of this information. Invest $30 and buy the book. You need to tell us what gear ratio the differential is.
  19. Anyone have pictures Outlaw 2800 Calipers on the front of a 240Z? I have seen several old posts that state that the Outlaw 2800 Calipers will bolt up to the 240Z front strut, but not clear which rotor to use and if it requires modification. This may be a good alternative to the Toyota vented swaps.
  20. I am having the exact same problem with left rear wheel bearing free play. I thought replacing the bearings would fix the problem, but the left stub axle still has latteral slop. That is, grabbing the stub axle flnage at 1 o'clock and 7 o'clock I can rock the flange while pushing at 1 o'clock and pulling at 7 o'clock. I measured the "B" spacer and it is within spec per the FSM.
