slownrusty
    12
Everything posted by slownrusty
  1. Excellent originallity! Good for you, sometimes if you stare at something long enough it comes together! Yasin
  2. Here is the spacer you need - 1" can be made at any machine shop very inexpensively. Here is the J-Pipe I modified and I used a regular rubber coupling to mate it to the TB. You have to cut down shaft of the TB only if it had cruise control. You have to use the original arm from your L28 and re-orient it to match the ball and arm linkage of the Z. Its easy once you sit with the parts infront of you. Yasin
  3. I failed miserably my first time at it. I never forgave myself for my shortcomings. I wish you the best of luck, its work granted and you know that "Communication" people always recommend..it will save you. Good luck to the both of you. Yasin
  4. I made that pod from scratch essentially. I started with an Autometer 2pod Miata and added a single Miata pod and cut them up and grafted them onto my A-pillar. Some fiberglass, lots of sanding and voila. I tested the Mustang 5.0L pod and its just wide and would require more work than the Miata pods to make it fit and trust me I have almost 20hours into this stupid pod alone! Can you post pics of your Mustang pod? Yasin
  5. http://cgi.ebay.com/ebaymotors/Other-Makes-SSC-Ult-Aero-TT-07-SSC-Ultimate-Aero-TT-Exotic-Supercar-Ferrari-1180-HP_W0QQitemZ160015765472QQihZ006QQcategoryZ6472QQrdZ1QQcmdZViewItem You can argue with 3 boost setting up to 26psi and almost 1200hp!!! Yasin
  6. Can you imagine with the following: 1) A hot color like a metallic silver 2) A CF hood 3) Loose the rear wing 4) Some siiick HRE wheels 18x11.5 in the back and 17x9.5 up front something like this: 5) Big Wilwoods 6) Coilovers The Kaminari body kit I dig...! Its old skool, period correct and the square arches are just fine with me Yasin
  7. Terry - Those ChoroQ are awesome! Yasin
  8. Actually the camera is a Canon Powershot Pro,,so its pretty decent...must be the operator plus the fact that it was midnight in my garage when I snapped them. I'll take some better pics today - howz that? Yasin
  9. I like the front spoiler...very nice. No door mirrors? Yasin
  10. Either you are going to have to pull that rear glass. And that car has to be completely media blasted. Alot of work ahead of you. Yasin
  11. Gang - A few of you asked me to post some pics of my home made gauge cluster after installation and wiring it up, well here it is just finished tonight...a few minutes past midnight. This thing too way too long to make...18hours...plus it broke when I removed it originally, so I had to repair that and then when the paint was curing it accidently fell and got scraped...so re-sand and paint..UG! and wait yet another day before I could handle it. Working on cars....!! Anyway here is the mock-up, I had to play with colors before I was able to match the car's burgandy interior - and its almost perfectly matched!: Autometer Pro Comp Ultra Lite Engine Temp, EGT and AEM AR gauge all 2": http://pic20.picturetrail.com/VOL86/504386/11903149/177186270.jpg[/img] Installed and wired-up: Not as sexxxy as TimZ's but will work! Regards - Yasin
  12. I think this car is so cool....$4K starting and the build spec is amazing, with different wheels it would be awesome. I would be all over this if I wanted a nice fast ZXT that needed some cosmetics. http://cgi.ebay.com/ebaymotors/Nissan-280ZX-Datsun-280zx-1979-280ZX-5-speed-custom-built-Intercooled-Turbo-Coupe_W0QQcmdZViewItemQQcategoryZ6397QQihZ009QQitemZ190017579286QQrdZ1 Yasin
  13. No worries! Moving and car project(s) = Double triple stress levels, I know as I am there too! For a turbo car, open exhuast is the way they like to breathe.... is the resonator straight through or baffling in the way of the air flow? If you can stand the noise I would recommend the open exhaust or a VERY open chamber 3" muffler (I have a 3" Flowmaster on my L28ET). I do not have a resonator on my car. Yasin
  14. Looks nice and clean. I am interested to hear your feedback on power and throttle response what are the core dimensions on your IC? Yasin
  15. Sparky - Thanks for the info, I did end up finding the same info from the Yahoo Haltech Forums I just joined, also here is the new more modern Haltech Forum, I also discovered, its sponsored by Haltech Distributors and they chime in frequently. Worth bookmarking. I will be ready to wire up my car in a few weeks - x fingers, so you are ahead of me. http://www.oz951.com/halforum/bbs/index.php http://p210.ezboard.com/fhaltechdiscussionforumfrm1 Lets keep in touch! Yasin
  16. I can send you some dimensions of mine, it was designed and fabricated by JamieT and I can run up to a 95mm TB on it if I wanted, but will only run a 70mm! Yasin
  17. Looking great! For all your gaskets you can get them cheaply off eBay or from http://www.roadraceengineering.com - thats where I got mine. I would recommend Jet Coating your manifold, too late now as you have it all painted...but its a better coating that will keep the heat in the pipes and last a VERY long time and good to 2500F Here is what their hottest coating looks like (also avail in black). This is my current project as well: wink! Yasin
  18. Bro...lighten-up! Nothing wrong with having a little cyber fun. Heck I get a good ribbing all the time its all part of the camraderie. Your own friends would do the same to you. To answer your question....stock L28ET healthy 180hp at the crank w your 3" DP and open exhaust (you did not even mention diameter of your "open exhaust", I would say easy 190crank if not more. Come over here and let me give you a hug! Mr.Insane bumped his head just before replying...LOL. Yasin
  19. Wow..very cool site! Bookmarked for the future! Yasin
  20. Castrol GTX 10W30 in the winter and 20W50 in summer. Yasin
  21. Ass draging = dead spring...not shock. The springs support the weight of the car not the shock.
  22. Wow that car is literally 10minutes from my house...I don't care..it could be 10hours... His eBay ad is ignorant and talking about he beat the car-up...would I want to buy or deal with someone like that...nope. He is a dreamer. Run Forest Run! Yasin
  23. Man you live on a dangerous and busy road? I was biting my lower lip watching oncoming traffic. Beautiful car!! Who installed the aftermarket sunroof? Yasin
  24. I am glad you guys dig the S130...I own the other sexxxiest S130...LOL! Yasin
