SHANE
Everything posted by SHANE
Hey Cody, glad to see the JWT system is doing good for ya. i actually really regret selling that unit. it worked so flawlessly for me. after doing both the SDS and JWT i'll go back to JWT next time. My new project is an 82 280zxt and i am shootinf for 11's on the stock turbo As far as my T5 experience goes, the only time i ever had a grinding problem was if i lift throttle shift. I never let off the throttle when i shift at the track, and i think that is the secret. on the other hand i always had trouble with clutches
cool, then it looks like i will be able to pick up a T5 pretty cheap then. you guys must be making 500+ horsepower if you have T5 troubles. i cant find anything it wont handle. hundreds of drag launches never a problem. now my 1990 twin turbo on the other hand lasted only 5 passess before i lost second gear. must have been the weight of the 300zx. what clutch do you guys run?
hmmm, anyone know of a conversion chart to convert 1/8 to 1/4. my best run at this little 1/8 mile hick track is 7.41@96mph. i am wondering what that would get me at a real track
There is nothing NOTHING wrong with Felpro. Simply the best gasket you can use (save for the metal one). now if you had a Nissan gasket i would say that would be your problem. If you used a Victor, well you would not have made it out of the driveway
What are the pros/cons of building a turbo stroker motor?
SHANE replied to mrcheeze36's topic in Turbo / Supercharger
Well i have not seen one pro to building a stroker. All that extra work and they just are not making any more power than what a bone stock block can handle. I put down 436 FT LB of torque to the wheels completely UNTUNED. Stock head, stock block, stock intake manifold, stock exhaust manifold. That was pushing 18psi. Now granted i am smart enough to through that Nissan headgasket in the trash and use a Felpro, but other than that we are talking stock. This motor has 145,000 miles on it too. That was a few years back, now i run 25psi completely untuned. Nothing more than seat of the pants tuning with the SDS. My solution for tuning? Nitrous!!! Now i run 25 psi (big hybrid turbo) and a 75hp shot of nitrous. All on a bone stock motor. Now tell me, if a stock motor can handle all this abuse. Why in the HELL would you change it????? Oh and guess what, i have yet to have a dampner problem since i shift at 6500 rpm -
Who sells the turbo spacer to install Hybrid turbo?
SHANE replied to a topic in Turbo / Supercharger
Turbo Engineering Corp in Denver Colorado http://www.turboengineering.com/ -
Have To Upgrade The Fuel Pump On My L28ET - Recommendations?
SHANE replied to slownrusty's topic in Turbo / Supercharger
Shop around, the MSD pump is $75.00 from Summitt racing. Great pump too, i run 2 of them. -
I did not mean the same brand but same size, my core is 24x12x3. Hi nathan, congrats on your 12 Your car is more than capable of a show!! hey at least your are man enough to stay with the 5speed. Mycar is still running pig rich, i came down 3000+ ft in elevation and the car still has too much fuel. guess i was running real rich in denver.
Trash can.
Anyone here ever try water/alcohol/methanol injection?
I had the Spearco system on my car and saw NO gain from it. All i got was rust!! Rust in the i/c piping (the little bit that was exposed) was very bad. It did not allow for more boost or timing. i do hear that the more expesive computer controlled kits are very nice. The cheaper kits 300.00 and under use a washer fluid pump and rely on boost to pressure the tank. the nicer kits run an actuall high pressure pump for a nice mist. -
here is how it looks installed http://www.geocities.com/shaneszt/index.html?1032746695529
diesel's do not have a throttle plate, there is no reason at all for a BOV on a diesel since there is no throttle to close and back feed to the turbo.
I can't get the search function to work re: turbo oil feed
SHANE replied to SleeperZ's topic in Turbo / Supercharger
yeah i just run a -6 line, no probs here -
Anyone Here Build/Repair Auto trannis For A Living?
SHANE replied to Scottie-GNZ's topic in Drivetrain
Does your trans have a vacuum modulator? when i switched to an auto the guy that built the tranny had me put some check valves and vents in the line to the modulator. this would keep the line form seeing boost and keep it from trapping vacuum in the line and sucking the fluid out. anyway maybe your somehow leaking boost into the tranny -
i can honestly say that the driveshaft loop is very good to have
I started on my roll cage install!!!!
SHANE replied to stony's topic in Brakes, Wheels, Suspension and Chassis
is that cage going to be NHRA legal? from what i remember the bars coming off the hoop to the back had to mount to the floor not the strut tower. there was a certain angle they had to be. -
Uhh after the turbo and before the TB are one in the same. i think you mean before or after the intercooler.
yes i have heard it and it has a stupid high piched girlish whistle. not ricey huh? then why was it used for the sound clips in the fast and the furious.
TIAL!! Stay very far away from the HKS SSBOV unless you like the sound of rice.
I got my JE pistons from Top End. 850 for pistons with total seal rings.
WHAT??? Never ever in a turbo car. just good old BPR7ES or in my case BPR8ES.
how about just shifting at 6000rpm? there is NO need to spin the engine higher than that. run more boost, toss the cam in the trash and go with a stocker. add nitrous and problem is solved. if you are trying to be fast unboosted than buy a V8 (250 RWHP fast does not make). its not a damn honda, there is no sense in trying to spin a SOHC 2V motor to 9 grand. an inline 6 is torquey by design, use that.
I guess there can always be an exception to every rule Shane, but the overwhelming number of people that I have talked to including myself have had very bad experiences with the Fel Pro gasket, while having positive experiences with the Nissan gasket. Possibly you got a bad Nissan gasket or something went wrong at installation which caused it's failure, but if you compare the two head gaskets side by side ,the quality of construction with the Nissan is way better than the Fel Pro. well you could be right i could have had a bad gasket from nissan. strange though that i have never seen the problems that you guys describe i dont know but i will definately stick with felpro since i have such good luck with them
really this post long overdue. stupid questions should be marked as such and discarded. yes a 280zx turbo motor can be put in a 240/260/280z get your hands dirty and find out for yourself. i did my swap without the internet and i am a dumbass. if i can figure it out then anyone can. heres another one of my favorites. if you dropped your timming chain then YES you have to take the front of the motor apart and yes it is alot of work. next time pull your head out of your ass and make sure it doesn't happen. and if your feelings get hurt over something that is said on a message board (even if it was said by James, who happens to be a very nice guy) then you need some serious help. remember the only thing that matters is how fast your car is, everything else is BORING!!!
