32
Everything posted by Zetsaz
A musician's therapist (The $300 Z)
Zetsaz replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
Having spent more time down there now I think the originals had another piece that covered the whole top. Might potentially look into that. So many of these have been taken apart so many times that oddball non-essential stuff like that just doesn't exist anymore. -
Zetsaz replied to Jboogsthethug's topic in S30 Series - 240z, 260z, 280z
That tdi wagon seems like a great dad-mobile and it makes me want one. If I wasn't such a sucker for marketing and wanting a new Tacoma or the new Frontier after it releases I'd be driving some kind of awd wagon.- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
I am... So sore. Between some of the car work and my workouts recently I've been crashing hard. Basically work, workout, Datsun each day. Some eating and sleeping in between of course. Anyway, got the rock guards in today with some 3M undercoating I have leftover. They were a PAIN to install. Had to get a bolt or two in first then really press on one end to get them close enough to thread. Installing them made me realize just how terrible the reproduction fenders really are. My passenger side up top has a big gap whereas the drive is pretty close. Not blaming Skillard on this one, thankfully the fenders look good from the exterior. -
Thank you all! It's been fun getting to the point where I'm tracking down small stuff. Right now I have new U joints on the way for the driveshaft. I suspect even the one I swapped in isn't perfect. I'm gonna replace it with Spicer joints when I do the top mount. Parts I'm still waiting on include the headliner and A pillar trim, one taillight gasket, strut tower bars, some skillard rock guards to keep the headlight buckets clean (I was noticing some dirt build up I don't want on the hole I cut for the back of the LEDs) and... I think that's it right now. All together will slowly start to quiet it even more and make it more enjoyable. The wind noise I'm still getting and the slight clunk on and off throttle are the only things keeping it from being completely enjoyable. EDIT: I'm actually really enjoying just cruising in it. I'll go out for coffee when it's nice or cruise Chuckanut Drive near me which has great views of the water and the San Juan Islands. I'm pretty happy I focused on the GT element before speed. -
Bumpers. Done. No more unfinished front, no more weird mounting points in the back, no more pilot holes showing up in the rear lower quarters. The alignment on the pilot holes was SUPER close. The 240z has more of an oval than just a bolt hole, but i only have that on the passenger side. Drivers lined up dead dead on. Front was a pain to totally line up from the sides, then I realized the rubber guards on the mounting points had the hole just a biiiit offset from where it needed to be. Bored it out, got a longer bolt so I could start the threading by hand, and it worked. -
Mine just got better, but I can still get a small clunk literally every time I go on and off power and the slack through the drivetrain comes on and off. Only way I can smooth out low speed/low throttle driving to not be jerky is by riding the clutch slightly. I ordered the proper top mount for the RT diff mount instead of the "snubber" I'm currently running. Hopefully that solves it. If not everything is getting retorqued again and I'm paying for the T3 front diff diff mount that uses a better bottom mount poly bushing. -
Hmm.... I'll have to have a shop inspect the driveshaft properly. I'm still getting a bit of clunking I can replicate by literally letting my foot on and off the clutch at a standstill. Might be a combination of the driveshaft and potentially worn front diff mount. I already have an RT diff mount with the poly bushing on top, but I didn't get the top mount. More small things to take care of I guess! Debating if It's really a big enough deal for me to worry about now or if I want to tackle the audio and the interior AC lines next. -
I'm stoked to try them! Today is very nice weather... somehow. I'll let you know how they feel. Between the mildly worn out half shaft U joints, and the noticeably worn driveshaft U joint, I think it's going to feel great. Was lucky enough to have a better driveshaft on hand. The front U joint on mine was clicking and had noticeable movement even when I was just moving it by hand. I'm concerned I'll have to dump some more money on it soon though. Had heard some transmission or clutch noise in specific cases last time I drove it. Will have to check when specifically it's happening and see what needs to be done. It may be a bad pilot bearing but I'll have to confirm if it was only when the clutch was depressed. Might finally upgrade the flywheel and clutch. I'd been holding off since I couldn't commit to a swap, NA, turbo, or just doing more mild upgrades to this. -
Why won't aftermarket 300zx turbo ones work? These are from a 280zx. Another user on this forums makes the adapters. Supposedly working well for him, and the 280zx are shorter than the 300zx so the adapter width is less of an issue with binding. Will have to see once I try them. For less than a quarter the total cost of futofab units, I figured I'd at least give them a shot. I'm doubtful they'll be a weak point with my modest power goals and very conservative use. -Got them installed tonight! (Only took 4 hours longer than expected...) -Also swapped my driveshaft for one my friend had included with the 5spd. Front U joint on mine was fairly bad. I'm sure that was contributing to the clunking as well. -Took the axle opportunity to put lithium grease on my poly bushings. Right control arm was squeaking BAD. Hopefully with everything greased up I'll have a quieter ride as well. -Carpet from Zcardepot arrived yesterday. Fitment is... okay. I'm confused by the thin pieces that go nearest the seatbelt mounts. Will have to check against a friend's original carpet nearby. -My bumpers shipped! Covid has messed with the shipping industry quite badly, I was patient with Datsun Garage since they were very open about the situation from their supplier and offered me a full refund any time I decided I wanted it. Should arrive by Friday Sadly it's been constant rain here, so I won't get a chance to fully test everything, potentially until next week. Excited to see how everything is feeling though. -
There's a chance they are the same mounts. A lot of Frontier guys do a "Titan Swap" to get the VK56 instead of their VQ40, and the swap the suspension (apparently it's nearly bolt in?) to get a cheap-ish wider track and long travel suspension
That is phenomenal! Love the blue and brown. Similar to my Z but mine are both dark shades. Beeeaaautiful work!
Thanks for the heads up! First proper drive with the adjusted brakes today and the difference is incredible. I can see brake fade being an issue in racing situations, but for the street I'm already able to lock up the tires with these stock refreshed brakes with good pads and shoes (granted it's a bit chily outside despite the sunshine). -
That is glorious
Nighttime brake update: Brakes used to feel really spongy after starting the engine no matter how well I bled them. Always had to pump once before braking to feel right. Turns out the rear cylinders are notorious for not self adjusting when using the hand brake like they should. Makes sense especially since I rebuilt eeeeverything and there probably didn't adjust them properly the first time. Rear drums were slipping off by hand basically. Manually adjusted them and it feels dramatically better already. -
Small things taken care of the past week: New driver side ball joint. Was told it was a bit worn after alignment. Hard to tell honestly, but even decent Moog parts are dirt cheap on rock auto so swapped it out today. New battery cable terminals. My 12v+ to relay board running megasquirt/fuel pump/spark/injectors was connected only by the original fused connection for the oem ecu with a spade connector... Not ideal. Hopefully slightly more reliable connection now, and better spark at higher rpm. Ordered a variety of parts as well: -Carpet kit. Debated on custom tan/brown. The price of a black kit is just hard to beat. If black carpet with a brown interior is good enough for Mercedes and good enough for the butterscotch 240z's, then it's good enough for me -McMaster Carr weatherstripping. Hate the rear inner hatch seal and the top of the doors have a gap. Hopefully this solves two problems. -T3 Front and rear strut tower bars. No front tribar right now. Bit over what I could justify in the budget. Fortunately it's an add-on and not a completely different part. -Potential 280zx CV stuff... With my U Joints basically being welded to the shafts right now and longer days happening soon, I needed a cheap option. Was about ready to spend on futofab axles, but this allowed me to get CVs and plus a load of other stuff for less than the futofab axles cost. If I hate them down the road and they don't hold up I'll deal with it then. -
Nah, talked to him on Facebook about it. Was referring to baffled/chambered/diffused similar to a Flowmaster. Not a fan of Flowmaster sound, but it's something to consider. I got the super turbo on and finally got the exhaust tip loose from the MSA muffler. Honestly I think the exhaust top made a bigger difference than going from the Ultraflo to the Super Turbo. Maybe it was just a matter of getting the pressure wave to exit farther from the rear valence. At cruise you can hardly hear the exhaust, it's all wind noise now which is nice since it'll help me figure out which seals I need to adjust and finish up. I was noticing a strange sound today that I'm fairly certain is the brake cables brushing up against the half shafts. My hangers are torn so I'll have to buy new ones. Can't tell if I want to get a hoodliner, or not just yet. The hood is a huuuge resonance point. Car is feeling better and better with every tweak, but at this point, as far as being a cruiser I think it's... Hoodliner, finish seals, stereo... And if my bumpers and headliner would arrive already I could finally start to finish up the interior. -
Diffuser muffler? Do you have a link? -
I gotta say.... Tinkering with the IAC and idle advance makes this thing feel almost new. The closed loop idle control made cold start when I checked it during lunch feel satisfying instead of like a chore. IAC opens on start up and I have it tuned close enough right now. No more blipping the throttle to get it to start. Idles a bit high on warm up and comes down smoothly as the coolant temp goes down instead of bogging down and stalling like it did before. VERY satisfying -
Spent maybe a solid 3 hours after work today tinkering around with things. Mounted the IAC Block where the ignition coil normally went. I'm still not sold on the square block, but it's an alright placement for now. Drilled and tapped the holes it already had on the back to be M6x1.0 like most of the bolts holding the car together and bolted it on from the opposite side in the wheel well. Only attached with two bolts for now, that way I'm only drilling one hole right between the original two for the ignition coil bracket. Didn't want to add more holes than necessary to the engine bay if I change my mind on how I'm doing things later. Notice the hose routing is... not ideal in terms of a tidy engine bay I want but it'll do for now. Also finally used the 3D printed TPS bracket to replace the random piece of sheet metal the last owner had it bolted in with. Spent most of the time tinkering with my idle settings. My idle was nice and stable when warm, but I hadn't bothered diving deeper into it. Realized that I didn't have VSS turned on for engine state, so Megasquirt was always assuming I was at cruise and not switching between engine states. Now the IAC is functioning properly. Messed with IAC and Idle Advance to get target RPM and I think I have it in a pretty good spot. Responds within a second when I put the high beams on and crank the fan all the way. Settles into the target rpm within 2-3 seconds. Also finally turned on Idle VE since I hadn't bothered doing that at all. Now my AFR isn't floating around at the lightest change when it's just idling and I leaned it out just slightly. The engine bay is becoming less tidy as I make it closer to the cruiser/touring car I want but that's alright. Tidiness balanced with servicablility and driveability is what I'm aiming for. I'm still having an issue with a sticky throttle at small blade angles. Tends to stick slightly instead of closing all the way. I think if I swap to a 240sx throttle with a spacer, switching to a throttle cable will take care of the problem, and the spacer I would probably have to use could be tapped to be the hose entry point to make my routing on the IAC hose much shorter. If I decide I want turbo power it'll also keep things more serviceable. -
That Dynomax Ultraflo you first linked is exactly what I have now. I'm gonna try it with the muffler tip that came with the MSA unit (45 deg cut aims it slightly down once it's out... if I could just get it out of the MSA muffler right now. It's a bit stuck haha). If that's not enough I'll stick with the Dynomax Super Turbo which is supposed to be much quieter. Fortunately they're quite cheap. Both new are less than a Borla XS and I can still return since Dynomax has a pretty straight forward 90 day return policy. For now, thermostat is going in tonight and I'll finally be able to check some things at proper operating temp. IAC pigtail should arrive by tomorrow afternoon and I'll be able to fool around with that. -
This exactly is part of the struggle with quieting our exhausts compared to bigger American cars. Length of the muffler makes a big impact. Unless I start cutting at the piping, longest I can fit is about a 14" housing -
Interesting... I'll have to look more into it. My understanding from other members is the "super turbo" is quieter than the straight through and isn't a chambered design, but sound cancellation and harmonic resonance is a such a fickle science. Will look more into it later in the day, currently on lunch. -
Dynamax straight through? I have a Dynomax Ultraflo I've tried and the sound was worse. This is a Dynomax brand I ordered as well. I think there are some nomenclature weirdnesses when talking mufflers. The one I ordered isn't a big straight through or cherry bomb looking one, it looks almost like an oem and has the redirected airflow with holes in the channels as well as matting on the inside. The straight through Dynomax Ultraflo doesn't sound bad outside, but it's just so loud when casually driving around. -
Small parts updates: Exhaust: Have been upset at how loud the MSA muffler is considering how... not... aggressive my engine is. I ordered a Dynomax Super Turbo since I've heard they're decent quality and not too loud. Here's hoping it's a bit less obnoxious because right now even with the resonator it's still annoyingly loud (for my taste) until you're cruising steady at 3k rpm. Bumpers: I finally got an update that my bumpers are are arriving at the reseller and will ship out as soon as they inspect them. They've been stuck at port for a while now. Shipping industry in general has been very slow, so I'm not blaming it at all on Datsun Garage who have done an excellent job maintaining communication. AC Hoses: Decided to ahead and order the Vintage air hoses and drier. Shipped yesterday. Opted for the extended length. Most of the brackets/tie downs from the factory AC were all on the rubber parts, so I'm hoping it's actually reasonably tidy if I route them the same way. The extended length will allow me to relocate the drier up front or wherever it looks tidiest, since my fuse block that replaced the fusible links is mounted where the original drier was. IAC: Ordered the pigtail I need to wire the Jeep IAC. I've seen some people use a Bosch unit that's round, but I think my block will work for now and I'll still be able to mount it where the original ignition coil was. Thermostat: I've been meaning to do this for ages, but just never got around to it. When I was cleaning up the gaskets and replacing the water pump a few years ago I replaced the thermostat, but the parts store gave me a 160 deg unit. Finally purchased a proper 180 deg unit which will let the engine run better and actually give me heat on cool days.
