str8pipez
Everything posted by str8pipez
On to the final stages of my build and wondering if anyone has pics of their exhaust with a 4L60E? I plan on using dual 2.5". Welding the v-band and intial 90's tomorrow.
75 280 LS1 Swap Build Thread. I think.
str8pipez replied to str8pipez's topic in Gen III & IV Chevy V8Z Tech Board
Yeah, I will be doing rear discs eventually, probably from Silver Mine. Unfortunately (not really but you know what I'm saying) the engine ain't coming back out for a while. Thanks, it was in pretty good shape to begin with. I'm going to redo the factory harness to clean it up a bit further. -
The camber plates and coilovers are from T3, also just got their TC rods as well. -
str8pipez posted a topic in Gen III & IV Chevy V8Z Tech Board
I've got a small collection of pics so I thought I'd post up a thread on the progress of my swap. I'm not in a hurry and kinda want to do this right, so I'm taking my time. Anywho, the details. I got the engine from my brother who runs a salvage yard. It came out of a 99 TA with a bad transmission. I got the computer, harness and all the accesories, etc. I cleaned the engine like crazy, replaced all the gaskets, water pump, oil pump, timing chain, valley cover (LS6), plugs, wires, etc. I also painted or powder coated everything that came off. My business neighbor is a long time trans shop and they rebuilt me a 4L60E which is what the TA had. Attached are pics of the work thus far, they tell a better story. They should be in some kinda order, from start to where I am. After pulling the engine I welded up some holes (helps that this is me www.johnbecksteel.com, so I've got the tools), removed some brackets and sprayed a tasty coat of paint. -
Hawks third gen motor mounts
str8pipez replied to crapforum's topic in Gen III & IV Chevy V8Z Tech Board
There was confusion. When I bought my Hawk's mounts Bruce wasn't even sure if they would work with the JTR headers. Passenger header side is the problem. While the Hawk's headers ain't cheap (compared to JTR's) they would probably be better in the long run overall. I like the Hawk's mounts WAY more than JCI's. -
Cool, that's how I have it. Thanks!
I know I had this info at one time but can't find it to save my life. Which heater core fitting, top or bottom goes to which fitting at the LS1 waterpump. Does the 3/4" go to top fitting at firewall or bottom? Thanks.
Im putting mine (99 LS1 ECU) in the passenger floor and building a footrest similar to what Singer Porsche does here: http://singervehicledesign.com/gallery/the-machines/brooklyn/#prettyPhoto[gallery]/72/
Champion Radiator Trans Cool Fittings
str8pipez replied to str8pipez's topic in S30 Series - 240z, 260z, 280z
Jackpot. Cheaper than running all braided and new fittings. WHEW, thanks! http://www.jegs.com/i/Earl%27s/361/AT165156/10002/-1?CAWELAID=1710722733&CAGPSPN=pla&catargetid=230006180000848550&cadevice=c&gclid=CL_vxMe4psICFc1i7Aod_1gAjA -
How did you get from the radiator to the -6AN? Going to see if they make this in a female -6AN, I'm planning on welding a male -6AN to the trans. And while I'm at it who uses a damn M12x1.25? -
They do, but they are indeed m12x1.25. I genuine PITA. I think I'll just cut them off and -6AN's welded on. -
So I'm swapping a LS1 into my 75 and using a Champion Radiator. Does anyone know where to find fittings for the trans cooler inlet and outlet fittings? Champion says they are M12x1.25 (male flared) but are impossible to find. Even Champion has no idea where to get them. Thanks!
240z LT1 T56 Comfortable Performance Build
str8pipez replied to Silver Mine Motors's topic in Gen I & II Chevy V8 Tech Board
I've got all the clutch bits if need them (pedal, slave cylinder, lines). They came out of my 75 when I put a 4L60E in. Maybe work a partial trade if the parts will work. -
Johns cars Z Car - Broken Motor mount.
str8pipez replied to datASSun's topic in Gen III & IV Chevy V8Z Tech Board
The "Made in Korea" stamp and super thin material prompted me to replace mine with one from Energy Suspension. -
Hawks 3rd gen mounts/headers
str8pipez replied to bejbis's topic in Gen III & IV Chevy V8Z Tech Board
nope. -
I have one that's on my pulled engine (LS1 swap), 97, XXX miles and I'll send everything that's in it. It's still on the motor. I have video of it running if needed. Here is my CL listing before I decided to part it out. http://stlouis.craigslist.org/pts/4647854938.html
My plan for chassis/subframe fabrication...
str8pipez replied to capriottikidd's topic in Fabrication / Welding
2x2x065 is way common. If you are having trouble finding it try Alro Steel, they are nationwide.- 19 replies
- frame rail
- subframe
(and 2 more)
Tagged with:
Also the shunt has 2 wires that go to the fuel / amp gauge and 2 wires that go to the light switch and volt reg. I no longer have the OEM amp / fuel gauge or voltage regulator and I'm swapping in a LS1. Is there a way to bypass the shunt?
I have a 75 with only 2 fusible links, not four. Can I use one of the attached for each fusible link? Not sure why I need to use the typical four fuse model with seperate power feed. Can I not wire these exactly as the 2 fusible links are currently?
Best Option for Engine Management on LS Swap
str8pipez replied to LS7's topic in Gen III & IV Chevy V8Z Tech Board
have you searched ls1tech?- 13 replies
Roll Call on early LS1 conversions, lets see/share your issues.
str8pipez replied to PLATA's topic in Miscellaneous Tech
Not a maintenance issue, but a issue none the less when burning rubber! -
I have a feeling every list will have tires... -
This guy has had alot of local success. He may be able to shed some light. https://www.facebook.com/DSX.Tuning/info- 13 replies
Anyone weld in the JCI mounts? I know they bolt in but wondering if there are any pros to welding as well as bolting?
