Leon
    24
Everything posted by Leon
  1. Thanks, I'm in San Bruno. This was actually down the street from my house. I got a call from my dad who told me that there was a huge explosion by the house, while I was walking the dogs at a nearby beach. It scared the crap out of me, but luckily I found out that it's not a threat to us. Unfortunately, that whole neighborhood is obliterated and I know some people that lost their homes. If anyone needs help, let me know. Leon
  2. Great info John. I'd like to add that more positive caster will also increase steering effort and it would decrease feedback to the driver since the mechanical trail would make up a larger fraction of total trail. It's the self-centering characteristic of pneumatic trail that gives feedback through the steering wheel. Just a few more things to keep in mind about changing steering axis inclination. Please correct me if I'm wrong with any of this since this comes from memory and not actual hands-on experience.
  3. Thanks for the heads up, just picked one up in SSF today! I managed to find one in orange, had to dig for it. The period correct license plate and VIN on the dash is a nice touch. Speaking of the VIN, it's only 68 cars ahead of one of my '71s! Anybody have HLS30-25008?
  4. I think it will sound glorious, make sure you get some sound clips! Great job so far, I'm loving the fab work.
  5. No problem, I always thought it was a cool setup. I never thought of applying it elsewhere though, that would be great to see! That van was an awesome sleeper.
  6. http://partners.academic.ru/dic.nsf/enwiki/621088
  7. The S/C Toyota Previa had an electromagnetic clutch that engaged the supercharger depending on load. Too bad the head or head-gasket cracked when ours approached 200k!
  8. Rockauto has pretty much always been great about getting the parts out quickly. Usually I get my stuff from them two or three days after ordering, with regular cheap shipping! Just got some con rod bearings, and as usual they came in three days. The prices are usually great as well.
  9. Hidden answer, I'll take the M91/30! Apple or cherry pie?
  10. And that's why I loved Cal Poly SLO! Tons of hands on work that really lets you dig into the stuff you're studying. I'm still trying to find work but I feel confident that I can take on whatever task is at hand whether hands-on or not. I've been waitlisted for all my classes and gotten then all. Gotta be persistant! It is definitely going to be weird not having classes anymore...
  11. I actually called the guy, and then saw the joke! Guy said he's selling it for $6000, way too much.
  12. That's awesome, I love MST3k!!! Haven't seen an episode in ages...
  13. Acrylic sounds interesting, and it can be cut with a router or most any decent rotary tool. I wonder how well paint would stick to it. Acrylic can be bought from places like McMaster for some DIY fun!
  14. I don't think it should be a huge deal, that's where my other tapped hole is I believe. The hole would be close to the balance tube anyway, so I don't think the effect will be detrimental to performance, and likely to the contrary, be beneficial. It's what I'm planning to do with my triples, so hopefully it works fine that way. You can use a Coke can as a catch can if you want to. No big deal there.
  15. I have triples as well that I will be installing and I was thinking of using the hole in the intake that's provisioned for the vacuum advance for the PCV instead. I don't know how many vacuum provisions you have in your intake, but I have one for the brake booster and one for vacuum advance. I won't be using the vac advance (I'm using the ZX dizzy for my 240Z as well) so I figured that tap is good for something. I'll have to check the threading of the PCV valve and see if I can screw it into the manifold. If not, it can probably be connected in between two lines with one routed to the block and the other to the intake manifold. Like I said, the catch can is your other solution.
  16. That hose looks like the one for the positive crankcase ventilation (PCV) system. It should be plugged into the PCV valve. I see that your running triples and don't have a PCV valve so you can route the hose into a catch-can. Not the best solution but it should work.
  17. Oh man, I can't wait to see this thing running and driving. Great work! :2thumbs:
  18. Exactly! Jasper, how would the radiator cap sense pressure inside the block? It can't, it gets its readings from the radiator since that's where it is installed. The pressure between the pump and thermostat inherently has to be higher than pressure at the cap because of the restriction. Please read the thread that was linked here earlier before making more replies.
  19. NJ-5 is OK. I prefer the BL-7 (Boltzmann-Liebnitz) fluid. It lasts much longer.
  20. Love the 918! The 110 Red isn't bad either, sort of a persimmon color. Dark Blue also looks great but the stock blue isn't dark enough, IMO.
  21. First of all, hot adjustment specs are 0.25mm and 0.30mm not .025mm and .030mm! Secondly, your Z club fellow probably meant .011 inches not millimeters... You need to get the units straight. Also make sure that you are using the correct set of feeler gauges, standard or metric. I'd pull off your valve cover and take a look at your valve train carefully at this point. 0.25mm and 0.30mm translates to about .010" and .012" FWIW. *I got the specs from the 240Z FSM, assuming that valve lash between 240Z and 280Z is the same.
  22. Good work, way to bring that Z back to life!
  23. Hilarious! Thanks for the clip!
  24. That's a very good possibility! Honestly, I was going to copy-paste your post, but I really wanted him to put up the pics of the L6 claiming that it was a Ferrari V12. What a moron. That clip gave me a bad feeling when I first saw it anyway, guy seemed like a typical poseur pretending to be a "car guy". Not gonna be watching that crap again...
  25. That's funny, I just saw a Genesis Coupe on the street today. It looked really good, I've been wanting to test drive one.
