Progress!
I didn't get as much done as I wanted to this weekend, but I was feeling pretty crappy. The flu has been going around campus, and I think I had a brief case of it.
We ended up using those bolts I bought to mate the tranny to the engine. We had to cut a little of the end of the threads, but otherwise they seemed to work perfectly. I'll research to see if they're going to be strong enough. If not I'll just replace them with all the bolts I'm eventually going to get from that Z Specialist guy down in Texas.
We played around a little with some sandblasting. It seemed to remove the rust very well. Next time I'm out there I'm first going to try to pick up some primer and maybe even paint, and try to get started on that portion of the project.
Also, I went ahead and drained the mostly full gas tank. I need to get some new fuel lines for it, purge the hard lines, then figure out how to hook up the lines without all that charcoal canister stuff that I'm missing.
I also included a pic of the outside of the shop. It was a nice day, so it seemed like a good time to take one for those of you curious about it.
For the next work weekend:
-Hopefully I'll have all the bolts I need so I can get the engine accessories mounted up
-Lube up and mount the carbs and manifolds, and hope they'll work without a rebuild.
-Get some DOT 5 brake fluid and get the clutch system going
-Get what I need to repack the wheel bearings
-Figure out what I need to refresh/rebuild the brake system
-Start working on hooking back up the electrical system
-If starter gets hooked up, do a compression test
