A random search brought this up. I thought it could use a dusting off.
The V12Z.
Engine: Aluminum block and heads Jaguar V12
Weight: 600 lb
Bore: 3.543 Stroke2.756
CID: 326.1 or 5.3L
Valves: intake 1.625 exhaust 1.360
Compression: 11:1
Power: 380 horses.
Cam: Isky XM-2 -.404 lift- 258 duration- set straight up at 0*
Induction: Modified TPI, equal length runners with ram trumpets
Fuel Injection: Programmable Accell DFI
Headers: stainless 3 into 2 into 1. These consist of twelve 1½â€X36†equal length primaries into four 2â€X18†equal length secondary pipes into a pair of 2 ½†exit pipes
Bell housing: Stainless, home engineered, with machining farmed out to people with bigger machines.
Fly Wheel: LT1 type with ballast removed, machined flat on the back side, Jaguar ring gear plate behind
Drivetrain: Aluminum Borg Warner T56
Weight 135 lb
1st 2.66:1
2nd 1.78:1
3rd 1.30:1
4th 1.00:1
5th 0.74:1
6th 0.50:1
Drive shaft: aluminum / shortened Ford Aerostar.
Differential: aluminum ’80 corvette. Ratio 4.11:1
Chassis Modifications:
Glass fiber body. Steel roof
Full 2â€X2†frame
Weight: 3000 lbs.
Front: Stock struts with cut Pinto springs, ’92 Camaro rotors and modified calipers.
Sway bar: ’78 Granada 1â€
Rear: Shortened Corvette, from caliper to caliper
Sway bar: ’69 New Yorker ¾â€
