jhm
Super Moderators
    24
Everything posted by jhm
  1. This is a great idea, especially for folks with shaved rear ends! Nobody wants that ’68 Chevy pickup behind you plowing into your rear end because he didn’t see your brake lights. I put a similar system on my car as Cygnus’, but used these LED lights from Harbor Freight vs the PC lights he used. Got the lights at my local store on sale for $7.99 each: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98408 They definitely make the car more visible when braking, and add a little bling at the same time. Enjoy, and happy motoring. Drax- If you use the PC lights, I wouldn’t recommend bending them double…..but it would be easy to mount two strips side-by-side to create a double row (same goes for the Harbor Freight lights I used). John
  2. All- Here’s a great alternative for your interior dome lamp. They’re available from most RV parts suppliers, but I got mine from CarParts.com for $13: http://www.carparts.com/autoparts/Product/Pr-p_Product.CATENTRY_ID:2003343/c-10618/Nty-1/p-2003343/Ntx-mode+matchallpartial/N-10618/tf-Browse/s-10401/Ntk-AllTextSearchGroup?Ntt=aircraft+style+interior+light They come in multiple styles, are available in black or silver brushed aluminum, and the light fixture swivels 360 deg. So if your dome lamp has crapped out, or just gone plain missing over the years (like mine had), and you don’t want to fork out the cash for an original-style replacement unit; you may want consider this nifty alternative. jhm
  3. Glad you got it working, Dave. Next week I'll be putting in a putting in a third brake light like you did -- that was a great idea (and cheap...I always like cheap!)
  4. Well, after owning the car a year, I finally decided to get my clock working (since I was already into the dash chasing dash harness electrical gremlins). From what I've read, these old clocks on the S30's are amazingly robust -- even after 35 years of hard use. They often freeze up if the car has sat for a long time with a dead battery or the battery disconnected. Most can be coaxed into life again, with a little cleaning up and lubricant. Use a small amount of very light-weight oil on the gears and spinning mechanism. Ensure all parts are able to move freely. And, as I found out, there are two screw pins that provide the mounting platform for the spring/counterweight mechanism (which is basically the motor for the clock). These two screw pins may need to be adjusted to get your clock working....they need to be just tight enough to hold the spring/counterweight mechanism securely, but not so tight that they impede free movement of the mechanism. Now my clock is working again and keeping perfect time. It's amazing how much the little things in life mean! jhm
  5. Jake- I'm guessing that your grounds are all good since you hotwired the lights and they worked for you. If not, bad grounds are always a problem with the lights....fortunately bad grounds are easily fixed. WRT the turn signals, could be your flasher's crapped out. It's under the dash on driver's side, just to the left of your left knee. There's two there...one for the hazards and one for the turn signals. I just replaced mine -- $2.99 for a new one from Pep Boys. Headlights could be the combo switch maybe? Have you removed your steering column cover and checked the switch leads and connections? Good luck and be sure to post your results! jhm P.S. I've been watching your build thread for a while now....car looks like it's coming together really nicely. Great job with the engine swap!
  6. Slo Mo- Go for it! I've got a 350 from a '78 C-10 in my 260....runs great and reliable as a brick. Yeah, the stock HP ain't awesome, but it's pretty darn torquey. I've spruced mine up with headers, Edelbrock Performer intake, Holley 600, and Moroso super HEI. May eventually add a cam, but it runs great for now. Good luck and be sure to post your results. jhm
  7. For anyone that's interested, it turned out to be a bad ignition switch. I tested the unit, and determined that the ignition wasn't getting power while the switch was in the "Start" position. The attached schematic was quite helpful -- I believe it applies to all S30s and 130s, since MSA carries the same ignition switch (electrical portion) part number for years 70-83. I was able to get a replacement unit (used) from Z Car Source for $16....only needed the electrical portion of the switch, not the keyed part. Strange that my switch decided to crap out at same time as my fusible links....don't know if there's a connection there somehow.
  8. StealthZ- Thx for the reminder about the locks....I had forgotten about that. (Amazing how our minds blank out the unpleasant things in life!) Yeah.....in addition to the window cranks, armrests, and door-mounting clips; I had to relocate the door locks when I put the 280 door panels on my 260. This meant cutting enough metal inside the metal door frame to provide a new "channel" for the door lock rod to follow. It's all these little details that make our Z's so much fun to work on!!
  9. Unfortunately, I believe the door panels between 240/260/280 are all slightly different. I installed 280 panels in my late-'74 260 and the holes for the window cranks and armrests were slightly off (you'd think they'd be the same, given the fact that my car is a LATE-'74 model!). I used 'em anyway....just had to relocate the holes about an inch or so....covered up the gaps with some black adhesive cloth tape. I also had to drill a couple new holes in the backside for the plastic clips. You can see the results in my 'Intro' thread: http://forums.hybridz.org/showthread.php?t=151406 I'm pretty sure the back panels (behind the doors) are pretty much fully interchangeable 70-78. Same goes for the rear hatch pieces. As an alternative, have you considered using any of the spray-on vinyl dyes to dye your brown panels to black? I've used Dupli-Color's Vinyl and Fabric dye with good results -- available at most auto parts stores. Good luck and happy motoring.
  10. Like BRAAP said...."drop the tank!". There's really no way around it. FORTUNATELY....it really isn't that big a deal and you only need to drop the tank a few inches -- no need to completely remove the tank. First, MAKE SURE YOUR TANK IS ESSENTIALLY EMPTY. You will see the wisdom in this once you start getting into it. There's a drain plug at the bottom of your tank. You can usually drop the tank enough by simply removing the two lines in the front of the tank and the big fat filler inlet hose. Remove the two small lines first, lower the tank a couple inches to give you enough room to reach up between the tank and the fender, then remove the filler inlet hose. Lower the tank a couple more inches and you should have sufficient clearance to remove the bumper mount. While you're at it, this is a good time to replace your rubber fuel lines and fuel filter. Good luck and enjoy your new shaved-look rear valence!
  11. Had the same thought when I was wiring up my circuit breakers. I would think that you'd be fine with the soldered wire ends as long as you can sufficiently tighten the terminal nuts. Might help a little if you can put lock washers on (not the single-split kind of lock washer, but the kind with dozens of little splines sticking out). Sorry if I'm not correctly describing the lock washer; it's been a long day...
  12. 570- With respect to your differing hose outlet sizes, there are several places that market hose splicing kits -- JTR has a really nice kit. Or, you could fab your own. Or, you could solve your problem like I did with a radiator hose filler like this one from Summit: "http://www.summitracing.com/parts/MOR-63740/" It has the added advantage of enabling you to easily purge your cooling system of any trapped air. Hope this helps. jhm
  13. You may want to get an independent confirmation that the alternator is overcharging. Places like Autozone and Pep Boys provide free bench-testing for components like alternators, starters, etc. Next, you mentioned that you removed the external regulator.....but are you sure that your new alternator is internally-regulated, and if so, is it working correctly? The bench-testing I mentioned above will include testing the regulator. Finally, are your yellow and white wires large enough to carry high amps? (I think 12-gauge is the norm for the charging wire leaving the alternator.) Also, are all the connections clean and corrosion free? Finally, are you sure that there are no shorts in the system? If you answered no to any of the above, that may be the root cause of your problem. Hope this helps. Be sure to post your results and let us know how it goes. Good luck and happy motoring.
  14. Another plea for help, folks.... Can anyone identify this air dam, and more importantly, a source for such an air dam? I've checked with the owner and he's not sure what brand it is (it came with the car when he bought it). I seem to recall that this style was popular in the '80s....very basic vertical air dam with stiff rubber skirt. If I'm not able to locate one commercially, I will probably attempt to fab one in this style. Thx in advance to anyone that can point me in the right direction! John
  15. cynus- Great looking upgrade! Very nice design and execution. I have to confess that I had been meaning to post a similar thread for a while now -- just never got to it. I recently replace my old (crappy) fusible links....went the circuit breaker route, and chose these: http://www.wiringproducts.com/contents/en-us/p183.html A little pricey, but hopefully will last forever (certainly longer than me or the car!) I chose 80 amp and 50 amp units. They're dustproof, waterproof, and can be manually tripped to act as a master disconnect. I mounted them inside the engine compartment relay bracket -- it's finally good for something since I had already removed the myriad of factory relays in there. Might I suggest that this thread be moved to the "Ignition and Electrical" sub-forum? (Mods, SysAds?)
  16. John Scott- For further clarification, I believe the air plenum is a unit by "Spectre Performance". They've got a pretty good website: http://www.spectreperformance.com/#HOME Several places like Autozone and Pep Boys carry their stuff. Slopoke- It looks like you might be using 3" ducting for your cold air intake? If so, I wonder if 4" tubing would help your motor breather better. Just a thought.... The build looks like it's going really nice -- great job!
  17. Sorry, guys....I should've also mentioned that this problem only recently popped up (after I replaced my cruddy old fusible links with circuit breakers). TR has already given me some helpful info, but I'm still open to any and all suggestions/tips/advice/recommendations!
  18. OK, gents.....I've searched high and low; and while other folks have had similar-sounding problems, I haven't found any info on my specific dilemma. For example, TrumpetRhapsody was having identical symptoms with his car, but that turned out to be the ballast resistor -- N/A to me because I've got a SBC w/ GM HEI (and obviously, no ballast resistor). In short, my engine will crank just fine when the key is turned to the "Start" position, but it won't fire up. However, when the key is released to the "On" position, the motor will usually fire (and run fine from then on). For some crazy reason, I'm getting good spark in the "On" position but not in the "Start" position! I have a 1974 260Z w/ a late '70's SBC equipped with a GM HEI distributor. I recently upgraded the HEI with Proform ignition module and high output coil. I had previously removed all of the engine compartment relays, so my problem shouldn't be related to a bad relay (at least any of the relays under the hood). So any ideas??? Even though I don't think it would be a bad ignition switch (since it cranks the engine just fine), I've dismantled and cleaned the switch -- it didn't help. Again....good battery, supposedly good distributor, and good spark in the "On" position, but no fire in the "Start" position. Help!! Thanks in advance to all. r/John
  19. RSKDSK- Don't know if you ever got all the info you were looking for, but I've got a late '74 260Z as well (produced Sep 1974). It came with the large bumpers (see attached pix), which I have since removed. Not only do I prefer the cleaner look w/o the bumpers, I reduced the cars weight by over 100 lbs. As Rolling Parts suggested, if you're really intent on going with the original (large) bumpers, you should look hard at refurbing your current bumpers. It's amazing what a difference you can make with some sandpaper, paint, and universal rubber bumper trim. Good luck and be sure to post your final results! r/jhm
  20. JSM- In my (limited) experience shipping large, bulky, heavy items, Greyhound has been the cheapest route by far. Two years ago, I had a rollbar shipped from AZ to VA -- it cost approx $45 via Greyhound. Additionally, since Greyhound is a point-to-point delivery, you usually don't have to worry about packaging the item as carefully (i.e. "bullet-proof") as you would if using a standard shipper like UPS or FedEx. Good luck! r/JHM
  21. LHD- +1 on what jt1 said about the 4 speed at highway speeds! If it's the car I'm thinking of (purple car up in Penn or MD -- can't remember where exactly), I think you're probably getting a very good deal. I seriously considered buying that car about a year ago, and talked with the owner quite extensively. He seemed very knowledgeable and honest about the car's history and condition. Besides all the engine work done to the car, it has some other nice/unusual features....pantera hatch, g-nose, Recaros, roll bar, and some kind of fiberglass/cowl induction hood if I recall correctly. I seem to recall the car originally came from CA or CO, so there's a good chance that it's relatively rust free -- give a good inspection to the floor pans, frame rails, and fender inner tubs to confirm. The main reason I didn't buy the car is that it already had alot of work done. I was in the market for more of a project car, to allow me to restore/upgrade as I went along. Again, if we're talking about the same car, I think you're getting a heck of a deal. Good luck and be sure to keep us posted, and welcome to HybridZ! jhm
  22. I'm assuming you checked the obvious (e.g. bulbs, fuses, etc)? If not, do this first. You say your tail lights work, but the brake lights don't? Many times the problem is a bad ground in the vicinity of the affected area. There's a ground wire for the rear lights inside the hatch, right behind the spare tire well. Even though your tail lights are working, I'd check this ground wire to ensure it's got a good connection. Also, check your harness connections (to the tail light assemblies) and bulb sockets while you're back there. Unplugging your brake light switch will NOT ensure that brake lights stay on all the time.....rather, that ensures that they will stay off all the time. Plug it back in and check the operation and adjustment of the switch. The switch can be adjusted closer or further from the brake pedal. It should provide a solid connection across the two leads when the brake pedal is depressed. Sometimes a simple cleaning, lubing, and adjusting of the brake light switch is all it takes to get the lights working again. Good luck and be sure to post your results!
  23. If I recall correctly, the 280Z voltage regulator is mounted on the engine bay relay bracket, just forward of the battery. It should have a 6-prong plug connecting it to the wiring harness. You can take your alternator into many auto parts stores (e.g. Autozone, Pep Boys, etc) for FREE bench testing. I'd try this first if you think you're having alternator problems.
  24. Check your flasher relay. There are two mounted next to each other on the side panel underneath the dash (on the driver's side, just to the left of your left knee). One flasher is for your turn signal; the other's for your hazard lights. Very cheap to replace -- I just got a new flasher for my turn signal at Pep Boys for $2.99. Also check your bulbs. As Zedman mentioned, a burned-out bulb may sometimes cause system problems. Finally, check your connections under the dash. The two connection points that come to mind are: 1) the turn signal connection on your steering column (3-prong plug) and 2) the harness connections under the dash on the passenger-side. Ensure all connection plugs are firmly plugged in. Good luck and happy motoring.
