proxlamus©
Everything posted by proxlamus©
  1. shadytrixta1's setup is nice for low boost applications.. problem comes with high boost, that wastegate outlet from the turbo is so so small, it would require some porting to open up and prevent creep.
  2. Reasoning... "you were accelerating at a very high rate to the speed limit which was dangerous for the conditions." It was 11:10am on a saturday morning.. on a 70 degree day down a 3 lane road with a 55mph speed limit. Supposedly I can be pulled over for accelerating too quickly. Um.. I didnt know there was a law or limit to the linear acceleration to the speed limit on a licensed and legal vehicle. He gave me a warning because I would loose my license for it. Thank you Officer
  3. the fitting in the valve cover is the oil return
  4. first off go to http://www.ststurbo.com These are pictures from 280z nick from Zcar.com one main addition to a standard turbo setup. you will need an external oil pump.
  5. Nissan T3's !! whoo whoo! Hey Moby.. I still owe you a butt load of wiring for your help with the MS install like 2 years ago lol. Now that I have my license when can I fly down there and help ya out with the build?! I can land out at Calhan airport if ya wanna pick me up =)
  6. Matt, why didnt you just weld up the internal wastegate and build an external setup? 280zwitha383 keep in mind feedback is placed typically immediatly after the package is recieved or FIRST bolted on.. yeh itll be fine for a little bit, but try actually running it hard then the housings will seperate or the bearings will be shot. every part ive ever left feedback for was after I opened it and it was "as described"
  7. OHH btw .. run Moby's setup.. he has very similar specs to your setup. see if it works than fine tune
  8. what version of Megasquirt? is this Megasquirt n Spark?! more info please
  9. very hard to see because the pic is so damn small Possible over-run fuel cut? or acceleration enrichments are a bit off
  10. if that hot chick in the picture is my teacher for all 4 years.. count me in
  11. Yes sir! I have my 4 pin HEI unit mounted on a heat sync from a computer.. you can find them at radio shack. I have some heat sync compound between the HEI unit and the heatsync.
  12. simply amazing. excellent work Mark!! truely beautiful
  13. yeh I made sure to go to the config and ACTIVATE the new firmwire with MegaTune. I wonder what settings are way diff from 021u reguarding spark
  14. Alright guys I am running 021u .. and old old version now that I have a laptop I have been trying to upgrade to 024, 029q 029v and the HiRes 09c code.. and the car runs like crap I printed up all screen shots of the 021u code and settings.. and spent like 20 min typing the settings in the new version. I have tried upgrading the firmwire, opened up Megatune and configured it for the new code .. and began pecking away matching the settings exactly. and still the car runs terrible. today alone I tried 029q and the HiRes code. the HiRes code ran better than any of them, but was cutting out and was crap. any ideas?!
  15. looks awsome Austin.. very nice work.. as usual
  16. Exhuast ports should be polished and smooth Intake ports should be coarse
  17. yeh if you need help in colorado.. holler at me or bobby.. fabbin stuff is fun
  18. Gate (pin1) has a small wire soldered onto it, and it leads to the X4 output on the PCB2.0 board. It is soldered to only X4 and I made sure there was no other contact. The wire has a 100ohm resistor inline from the FET to the X4 output. The wire leading from the GATE on the FET also has a 10k resistor to the Source (ground) wire Basically identical to this
  19. alright guys.. I will be testing the FET on saturday morning before I head off to work.. i appologize for the rediculously long wait!! School and work and snow storms combined = slow car progress Datman.. when you say "lamp" do you mean hook up a small LED or a light?! maybe it's the UK terminology lol
  20. increased pressure = increased heat increase heat = increase wear and tear my guess
  21. Datman what do you mean?! Ya mean I should apply a 12v source on the "gate" terminal which Megasquirt would normally apply out of the X4 output correct?!
