19
Everything posted by Invincibleextremes
Ford Super 8.8 irs swap thread. Rear brakes too
Invincibleextremes replied to Invincibleextremes's topic in Drivetrain
Here's the thread involving the front end swap using 2014 mustang spindles and the front coilovers off the neon. This allows you to buy a complete set of neon coilovers and use them. Takes a few mods to make it work up front but it's straightforward. To summarize the rear end setup and answer a couple questions I'll post some key points. The bracket in the way is on the left side of the trans tunnel in the back, it's not part of the parking brake assembly so I can only assume it's for the factory exhaust. Factory mustang track width is 64 inches... therefore the axles cannot be used as is. But the shafts needed use factory v8 cv parts so wear items are a non issue. This setup converts to 5 lug, but retains factory track width of 53 inches. Works with 2014 mustang or 2015 mustang brakes. Both readily available and dirt cheap. Dust shields for the rear will need work because the factory 2015 hubs are used but obviously not the spindles. About the custom shafts... to date, there have been no less than 40 shafts purchased and delivered to people. Only thing custom about them is the length, so you don't need to go through me to get custom shafts in the future. Granted your prices may vary but you can send a pair of v8 axles to any reputable axle maker and ask for shafts to fit your needed application. Also, custom high hp axles are available that are advertised to 800hp and 2,000hp. I've contacted them and asked if custom lengths are an option and they are happy to provide them. Most people opt for the DIY version of the kit, they get hardware and cradle and two uprights that are all tacked together but unfinished. They then finish the kit and add whatever custom touches they want. Yes it's designed around an r200 mustache bar but you can just as easily weld on tubing and use bushings to avoid paying for an r200 mustache bar... Noah literally did exactly that.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
David has been driving his for about half a year, I'll ask him for any specs. He may have eyeballed the alignment. I'll ask Andrew as well and see if they can get us numbers. Maybe noah...
- 91 replies
- suspension
- 240z
- (and 5 more)
Raising the diff up can be done, but you're going to have to notch the frame rail above it. Plus you'll run out of room unless you plan on getting rid of the factory parking brake assembly.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Pinion angle was measured and it came out to be a couple degrees. This is why the crossmember needed to be notched, otherwise the pinion angle will be too much. Another option would be to cut the body of the datsun similar to an r230 swap and tuck the diff itself higher on relation to the car. This would require moving the rear plate down on the cradle and tacking up in a new location. Would also require breaking a couple tacks on the front mounts and matching the angle of the diff or at least the location. Most people don't need that since it's a tight fit, but works as is. And most aren't interested in cutting up ththe body of the car itself either.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Shown here is the optional crossmember used to create clearance for the pinion without having to notch the factory one. Both are viable options and I recommend tying in the verticals for maximum strength regardless.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Minor improvements for v3, namely the ability to jump from 2015 to 2014 brakes and back as needed. Also tabbed a few spots to keep it from moving around too much during welding etc. David still rocking v1 in his 800hp car without issues half a year later.- 284 replies
- 1
- disc brakes
- suspension
(and 7 more)
Tagged with:
Heck ya, axles looking good. Btw, 2018 mustang stick v8 cars are using gt350 axles. Gt350 axles are basically the same right axle, but the left has been increased in diameter and cv size. They will not work for this conversion. So you need v8 axles 2015 to 2017 and 2018 must be v8 automatic axles.- 284 replies
- 1
- disc brakes
- suspension
(and 7 more)
Tagged with:
Ah, yeah I didn't know BMW diff was weak.
Are BMW hub bearings bolt on? If they are you could have someone cut something like this, hack it together and use your diff, and all BMW bearings and brakes. I use this as part of a completely different (mustang) IRS diff setup but you may have good results with a similar concept.
Pic of another car with 2014 mustang spindles. It moves the wheel forward by 3/4 btw. So a heads up for anyone planning on larger diameter tires.
- 91 replies
- suspension
- 240z
- (and 5 more)
Shafts themselves are rated to 800tq, 8 ball v8 mustang cv ratings are unknown but whole assembly has been kicking butt on an 800hp car with zero issues since install. As per forum rules prices cannot be discussed in the technical threads, so PM me and I'll gladly let you know everything. To put it in perspective though... complete pair including low mileage v8 cv usually ends up costing less than the discontinued oem Nissan turbo z32 axle PER SHAFT... IF you can get them. We're talking about 34 spline inner stubs, 8 ball cv, heat treated custom shafts and 32 spline outer using a bolt on hub with a SUBSTANTIAL bearing size to boot.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Pic of the summers brothers racing shafts on mustang v8 cv cores. The left and right factory shafts are shown next to the completed assembly.- 284 replies
- 1
- disc brakes
- suspension
(and 7 more)
Tagged with:
Obviously I can't stop to take pictures of everything going out the door, but here's a couple more uprights set up for 2015 brakes and hubs tacked up for someone. Oh and shout out to summers brothers racing. They make a kickass set of axles for this conversion. Roughly a dozen pairs so far and the fitment is amazing.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Test fitting kits on my spare 3.31 lsd diff. That crossmember is optional and is for people not wanting to notch their own factory front LCA mounts like we did on David's car.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Yes I'm tacking everything together today and tomorrow.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
V 2.0 of the uprights. Same design, even more camber adjustment and shed a little weight while still keeping most of its strength. And let's face it, "most" of it's strength is still head and shoulders over what else is out there.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
I'm not a hard guy to find. PM me for my number or just contact me on Instagram, Facebook under my youtube channel name of Invincible Extremes- 284 replies
- 1
- disc brakes
- suspension
(and 7 more)
Tagged with:
This one going out in the morning, itll still need to be tied into the notched crossmember, and fully welded up. Jig for the cradle is built so it's going very smoothly so far.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Entire rear subframe can be had for anything from 500 to 1200 plus freight. Just the bare diff itself ranges from $100 to $900 and is available in 3.15, 3.31 all the way up to 4.09 factory. Aftermarket 4.56 gears are also available. The most common ones are 3.15 from a v6 rental and 3.31 off an ecoboost. Ebay is full of them, ALL have lsd but some even come with torsen.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Yup.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
3.15 has it's own lsd, and 3.31 to 4.56 share the same carrier and can be interchanged. The strength of aluminum ears is only in question because of the design of the factory mustang mounts, my setup doesnt use bushings on the 4 corners but ties everything together with a solid cradle. But for maximum strength, the iron case is definitely the way to go. The auto and manual input yoke are different, but swapping to the f250 slip yoke makes this a non issue. There are several different axles from the factory, ALL of them use 34 spline inner stubs, and 32 spline outer, but have different cv size and intermediate shafts... I provided the part numbers for the v8 shafts, which work work with the racing shafts from summers brothers racing. Those shafts, like in David's car, are designed around the bigger v8 cv and won't work with the smaller v6 cv... something to keep in mind when hunting for cores to build. Noah has an aluminum 3.15 diff off a v6 rental car and is using the same 34 spline v8 shafts as david and me.- 284 replies
- 1
- disc brakes
- suspension
(and 7 more)
Tagged with:
Video of our adventures during the race event. We had a lot of fun despite shredding the blower belt and not reaching out target speed. Brief summary of the entire concept of the swap as follows. - Bushings. That's right, the diff is SOLID mounted to the cradle, which is a two part assembly that uses bushings up front and ties into the r200 mustache bar to use the bushings there. They really only absorb sharp impacts and harmful vibrations to prevent cracks from forming. But even so, we didn't hear the diff at all. That worn out t56 is another story... The diff is huge... it's literally a cut down 10.25 inch... 34 spline axles and all. Speaking of axles... options on end. The cheapest being a couple race shafts on cheap v8 cv assemblies... and nicest being 2,000 hp axles from DSS. Admittedly they quoted me at 100 bucks over selling price for custom length 800hp axles, so I still need to get with them about the 2,000 hp axles... I'll post when I know. Gear choices. 3.15 has it's own lsd, but 3.31 to 4.56 can be rebuilt as whatever ratio you want on the same LSD... and all use the same 34 spline axles. Speaking of LSD, they all come with it, but some even come with a torsen, at a higher price of course. Or it can ordered separate. Yokes for 1330 or 1350 u joints are readily available. Thanks to Ford using the same tooling for years on end. Its 31 spline for future reference. Bolt on hubs for dirt cheap, as of this writing timken hubs are 69 dollars and they're 14mm on the studs. Brakes... you will need longer parking brake cables, but the parking brake is built into the caliper on both the 2014 and the 2015 brakes. Using 2014 brakes allows some 15 inch wheels to fit but requires cleaning up a shoulder on the hub bore... or the rotor itself. Obviously 2015 brakes won't require this, but will require 16 inch wheels for the smallest brake... the big 13 inch rear brakes require a 17 inch wheel. You can do what you like of course, but the whole setup is designed to utilize all 8 bolts on an integrated front mount. And the bushings are placed as close in line with the bolts as possible to eliminate torque load on the bolts. Oh yeah, almost forgot... at the hub camber adjustment. No need for camber plates, although some choose to use them.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
