19
Everything posted by Invincibleextremes
Ford Super 8.8 irs swap thread. Rear brakes too
Invincibleextremes replied to Invincibleextremes's topic in Drivetrain
As in? Diff went in, stayed in and gave us no issues. It's a tight fit but works great. Only issue I can forsee is someone not welding it to the crossmember correctly, or warping the crossmember while notching it.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Video of us installing the dif in David's 800hp datsun.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Swap kit for s30 datsuns to swap the super 8.8 off a 2015 and up mustang into the 240z, 260z, 280z Comes with uprights that bolt up to off the shelf 2004 neon srt4 coilovers and a cradle kit for the super 8.8 diff. Brakes, bolt on hub, donor cv axle parts and diff all off a 2015 mustang. 5x114.3 bolt pattern. 2014 brakes will work for some 15 inch wheels and will bolt up with 5/16 caliper spacers that can be ordered extra or can make your own. Kit is currently in many many cars. If you have questions i would be happy to answer them. Fully welded kit is all I'm currently selling. 1600 plus shipping. Complete assembled axles are 1100 plus shipping. Feel free to ask questions, also can accommodate special requests within reason.
- 91 replies
- suspension
- 240z
- (and 5 more)
David's 800hp datsun is now equipped with the super 8.8 differential swap. 1/2 mile racing it on Saturday.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Giant 14 inch brembos on David's car. If he used the 15 inch brembos he'd need even bigger wheels. Barely fit as is.
- 91 replies
- suspension
- 240z
- (and 5 more)
- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Dcr.david on Instagram got ahold of the 14 inch brembos at 77 bucks a caliper and is using them with 18 inch wheels on his crazy 800hp blue machine. Looking forward to seeing how well they do.
- 91 replies
- suspension
- 240z
- (and 5 more)
- 284 replies
- 1
- disc brakes
- suspension
(and 7 more)
Tagged with:
Noah dropkin making progress on his datsun using a tacked kit I shipped him. He didn't have an r200 mustache bar so he made ears to add to the back plate.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
You would need a hybrid axle... 240sx on one end and 2015 mustang on the other end... the weak link being the 240sx parts. Or just drill the mustang hubs for 4 lug... that would be strongest. Here's another customer setup I tacked together. He'll need to notch his crossmember and tie in with the two halves up front... or I can provide a laser cut crossmember already tied in... working on getting a batch of those in once I design that. I changed the angle of the diff which works better with an rb25 or an LS. Carbed motors sit at an angle and it worked with the older version but a more inline approach is what most will need.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Built a mock up kit in foam board which allowed me to take it with me and draft up a bunch of the parts and I then took out some weight in areas that didn't need the extra material. Paid for a batch of different parts to get laser cut, which definitely speeds up my efforts vs having to hand cut all the parts. Working on a few customer orders at the moment and I'll post pictures before I ship them out. Also having a small batch of 800tq axle shafts made for this conversion. Last batch we got fit perfect so we're getting more. $65 per decent cv axle plus the $300 each shaft makes for some relay cheap, really strong cv axles. Maybe one day I'll go with some of the aftermarket 800hp, 1400hp or 2000 hp axle assemblies being offered for the 2015 mustang but in a car as light as a datsun I dont see the need just yet. And as someone pointed out... LESS has done 8's in the 1/4 mile.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
thank you, edited best I could and I will stick to the rules and post in the vender forum when i have kits available.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
In short. Kit is bolt in instead of an r200. One bracket on the drivers side in the trans tunnel is in the way but the parking brake cables are left untouched. Uses 2015 mustang brakes, hubs, cv axle parts and diff. Requires custom length axle shafts if using factory cv. Or 800hp and 1400hp race axles. The kit bolts up to 2004 neon coilovers with swapped tops. Also has the option to run smaller 2014 mustang brakes and use 15 inch wheels as a result. New 34 spline super 8.8 is 30% stronger than the older 31 spline 8.8 diff and shares NO parts with them. Thats a quote direct from ford. Some Older 8.8 swaps have easily held 800hp on a datsun and NONE have ever been this strong or used a cradle. The custom shafts are 800 ft lbs capable but use factory cv so 500hp is what i would trust them at. 800hp has been used on much weaker parts... but I'm not going to make those promises. The 800hp axles sold by DSS are for a 4,000 lb car so you make you own guesses as to what they're good to on a datsun... ***contact for pricing if interested, on an individual basis*** Today for example i ordered some half inch cut pieces at an amazing deal so price will reflect that in the future.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Cutting them by hand takes forever and theres no way i'm working for free.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Bolted everything up and then welded the front part to the crossmember on the customers car. Definitely the strongest way to do it.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Built jig for the uprights and making progress. Still a few more things to finish and I'm dropping it off for the customer. Both sides will be gusseted btw... Oh and had a chance to snap a pic of whats needed from a 2015 mustang (brakes can be 2014 for smaller wheels) Brakes, hubs, cv axles with custom length shaft, and the diff itself comes from one donor car.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
A part that can easily be replaced once i get to the hp goals. What's your point? Test fitting a customers cradle in my rusty pile of a datsun before final weld. Now that everything checks out I'm building jigs so i don't have to take my car apart every time someone wants a cradle and uprights.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Mismatch would be if i stayed with a small motor and toploader... plans are for insane level hp.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Got a 1,000 hp nascar driveshaft... 4.5 inches in diameter. Compared to the current aluminum corvette driveshaft I've been using so far. Btw nascar driveshafts are $90 to $150 all over ebay. Too long for this, but cut and balance isn't too bad cost wise, and the driveshafts usually come with billet yokes which are worth the purchase price by themselves. Spicer 1350 u joint flange and factory five super 8.8 driveshaft adapter for the cast iron diff. Automatic cars that used an aluminum diff get a different adapter because they used a different driveshaft from ford. Not sure if i mentioned this, but my goals for this car are to use a 532 cubic big block ford stroker with aluminum heads and a toploader 4 speed... and later a nascar trans if the toploader lets go.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
I'm in portland. You're welcome to stop by at the end of the week and look it all over.- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Thats close enough i guess. Should i make you a set from this batch? The guy I'm working with who's helping with the axles is in California as well- 284 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
