Invincibleextremes
    19
Everything posted by Invincibleextremes
  1. Yeah, the fronts. I'm not really following you. I can't imagine there being any hub deflection if that's what you're saying may happen. These parts are designed for a car over a thousand pounds heavier.
  2. As in the rear stub axles? The setup I'm designing doesn't use stub axles, but rather bolt on hubs like the newer Nissan stuff. I think that's what the other guy was saying when he was talking about large bore hollow axles too.
  3. It won't move but sure puts a whole lot of constant pressure on the shock rod every time it wants to move... the strut on our cars is behind the axle center line... every sharp bump first tries to twist the strut, then the strut gives way vertically like it's supposed to... The rigid nature of the factory arms keeps the shock piston side loading to a minimum. Adjustable control arms that put a Hein joint on the inside follow the same principles and don't change much from factory in that regard. You can assemble the strut without a shock and it more or less stays in place if you gently lower your car. Assemble your strut without a shock with these arms and the spring will twist and may come off the seat as the strut twists backwards with the wheel pushing it up. That's not to say it doesn't work well, or that there's ever any issues.... That's just my reason for myself not wanting to buy one... I imagine shock life being significantly shorter...
  4. This isnt something thats really marketable btw, just an idea people can use for themselves.... I may have the 1/4 inch strut adapter shims laser cut and sold for $60 for the 4 of them to make it easier for people to do this, but this is honestly something anyone with a welder can do themselves. Monday I'll go grab some 1/4 inch plate steel and bolt it all together, and show you guys what's needed to make the dodge neon coilover bolt to the mustang spindle. Once I have wheels and tires, which I can't afford at the moment, I'll be bolting this up to the front of my datsun and posting pics. And videos. And later down the road I'll have my rear set up designed and built. The rear will require me to design a custom knuckle with neon coilover mounts and be set up for the 2015 mustang irs hubs while using 2014 mustang brakes (so braking stays matched to the 2014 fronts). So for a few months I'll have 5 lug front set up with 4 lug rears untill I have the rear to bolt in.
  5. Mustang spindles. That's what I'm using. Same 5x114.3 wheel pattern. But will need modded 2004 srt4 coilovers and a mustang ball joint and some techno toy tuning outer tie rods to work. Wheel flange is spot on and steering geometry remains factory. Brake options get super cheap too. 13.2 inch brakes for $150, Or 14 inch brembos monsters for $96 per caliper and $45 per rotor.... Can still use 11.5 inch brakes and a 16 inch wheel is that's your thing too.
  6. Parts breakdown. 2004 dodge neon srt4 coilovers. --- I bought mine for $180 2014 mustang spindles ---- $100 a pair, all day. 2014 mustang brakes.--- $100 to $300 a set, easily found. Mine were $150... What's needed to make them all work together is two 1/4 plates with 3 holes each and a welder per spindle. And a hybrid 240z lower control arm that uses a mustang ball joint. In my case I'm just welding a mustang control arm stub to the 240z one.
  7. Been busy. Anyways, did a ton of measuring. First off, steering knuckle to ball joint distance is the same. So geometry remains the same in that regards. Secondly, the tie rod ends have the same taper BUT the mustang ones are bigger and stronger. The solution is to use techno toy tuning 5/8 adjustable outer tie rods. The mustang spindle can be drilled for 5/8 with the provided drill bit. Or do what I'm planning on doing, and fab up the mustang inner tie rod together with the datsun inner, and use mustang outer tie rods, and not drill the spindles. The other all important question is wheel flange to ball joint dimensions, and they are spot on. My original thought was they were kicked out about an inch. I was wrong. You will need to use zero offset wheels with this setup. Or negative if you want to run really wide track. You can use 11.5 inch brakes and run 16 inch wheels. Or be like me, and use 13.2 inch brakes with 17 inch wheels. The strut mounts don't line up, but are 1/2 wider than the mustang spindle. The solution I have come up with is to use 1/4 inch plates to adapter the mounting pattern to the mustang spindle bolt locations. Two plates per strut. All in all my cost for this has been less than the cost of a pair of 5 lug hubs. So yeah, this is a no brainer when it comes to choice for me.
  8. For example... the cheapest coilover setup is 900 bucks and requires welding... or you can use bolt struts from a different platform... I'm trying to use the super 8.8 off a 2015 mustang... bolt on factory brakes on the rear, hubs etc... 40 bucks for a hub sure beats 800 for stub axles and then another 600 for companion flanges. The s30 platform market is saturated, very true. But it's saturated with severely overpriced junk.
  9. True, I'm just trying to offer the same thing, but for the guys with big hp who don't want to spend the current market prices for it...
  10. I'm not messing with stub axles. Gets too expensive fast... I can build a setup with 14 inch brembos up front and 800 hp axles for WAY less than what it currently costs to do the rear conversion kit from any number of places... The Nissan stuff is severely overpriced.
  11. Oh. Yeah, I don't think a spindle and ball joint designed for a 3,500 lb car is going to be the weak link in a 2,500 lb v8 datsun...
  12. Yeah, that's exactly what I'm thinking. A small adapter with 5 holes... 4 for the control arm, and one for the 2014 mustang ball joint. Not looking to push the ball joint out ... that would create camber. I plan on bolting a 2014 mustang spindle on with a 2004 Subaru coil over strut in the exact 240z factory locations. I just have a feeling that the wheel mounting surface on a 2014 mustang is out farther from the ball joint pivot point than it is on a 240z. I know this because mustangs use a 35mm or 42mm positive offset wheel... Factory steering on any car always places the center of steering directly in the middle of a tire... ALWAYS. Either with a positive offset wheel or by being very shallow on the spindle like the 240z is. I have one question. Why the Chrysler ball joint? What suspension bolts up to it?
  13. After looking everything over and doing some digging I came to the conclusion that using 65 mustang hubs on 240z spindles is not a cost effective solution for big brakes. I am now looking into a ball joint adapter that bolts to the control arm of the 204z and uses press in 2014 mustang ball joints. I intend to use this in conjunction with 2004 Subaru wrx coil over struts to allow the use of 5 lug 2014 mustang hubs and brakes. Which are 5x114.3 The intent is to have the outer wheel mount flange be pushed out roughly 35mm.... effectively converting our cars from a "zero offset" wheel to a "plus 35mm" wheel... aka just like the 300z and the 240sx, Toyota supra etc... It's a front steer, rear caliper spindle just like the stock 240z, once I know what the bump steer geometry will be I will have a clearer picture of things. Someone could use a widebody or flared setup if they chose to run a zero offset wheel, or use cheap and readily available 350z wheels and have stock track width. Let me know if anyone has any input on this. Good idea, bad, etc...
  14. Used a cj7 master cylinder to complete the 4 speed swap with a $99 hydraulic throwout bearing. Worked well actually and bolts right in to our 240z cars. Had to extend the shift linkages and make a custom shift plate to locate the shifter farther back but it all works great now. The phantom grip limited slip actually works pretty decent. Not the best but it beats having an open diff. The open diff really sucked on the few days I drove it.
  15. Completed the 4 speed conversion and took it out for a spin. Absolutely love it. Wishing I had more traction, but I can't risk breaking the stock stub axles.
  16. Yeah, except I'm not a fan of q45 or z32 parts, their strength or their pricing... I like the pricing of their backing plates front mount and mustache bar, in theory someone could just order those and the axle conversion they sell and get away with it on the cheap... except they'd be stuck building a strut. So more or less you're stuck paying the full asking price of the kit, which btw isn't cheap. And still need to source the short nose r200, and axles and brakes. I don't know know man, it just doesn't sit well with me. I like the idea that someone could buy some backing plates, a diff mount, and custom length axles and some cheap $250 coilover struts and be on the road with a setup that can handle 800hp...
  17. Yeah, turbo skyline and Silvia guys abuse those r200 diffs all day, should be ok, just don't get greedy with the power.
  18. Yes, it will all revolve around a custom knuckle. Just like the intrepid based setup, and just like the r230 z32 knuckle from Arizona Z car and so on. The key difference is the hub, brakes, and struts will all be off the shelf, keeping costs down for everyone, including me. No boring out a wilwood rotor hat or anything like that. Just off the shelf bolt on and go brakes, crack a rotor? Go buy one and be driving the same day, don't like your spring rates? Go order a different wrx strut and bolt on and go...
  19. That's amazing how rust free your car is. Mine is literally about to fold in half, but it's on the road and I'm having fun. Any reason you went with the short nose r200 instead of a longnose or a ford 8.8?
  20. The story of how it all began, including pictures of ugly prototypes and crude early versions... What it all amounted to is a simple, strong bolt in swap that utilizes factory control arms and r200 mustache bar and allows the use of 2015 mustang brakes, hubs, cv axle ends and differential. The pinion yoke is a 1350 u joint one off a 1993 f250, it can be found at Denny's drivetrain. The struts that work with this setup are modified 2004 srt4 neon struts with their tops changed to the datsun 3 bolt camber plates. Most people simply contact bc racing and have them supply the 280z coilovers and exchange the bottom sleaves with the 2004 srt4 neons ones. Other people just use the coilovers they have and weld on the coilover tabs I also developed, so struts that work are basically anything you want. The brakes are either 13 inch rear brakes off a 2015 mustang or 11.8 inch brakes off a 2014 mustang. Both are dirt cheap, and both have a built in parking brake. I'm constantly updating the design with every batch, but here is what one of the components for a tacked cradle looks like. Pictured here is version 6, and the cradle bolted to the differential is version 4 I believe. *** Here's a picture of what it all ended up being in the end.
  21. Did some digging around, and I'm going to get an adapter set made to adapt the 240z spindles to s550 disc brake mounting points. This are massive brakes that sell for pennies on the dollar. Good for the guys with 800 hp ls v8s and 2jz setups. Going to use 65 mustang hubs which have the same A2 and A6 inner and outer bearings as the 240z spindles. Still got some fitting to do, more to come later. We are talking 4 piston 14 inch brakes for under $200 sometimes. Or 15 inch monster 6 piston brembos setup if your heart desires. Anyways, let me know if anyone would be interested, I'll be building the setup for my own 240z, but if 5 or 6 people want some, I will make extras. I did something similar for 1968 dodge chargers and people love them. Made an adapter that allowed use of 2014 mustang brakes on drum hubs and people have been buying and using them with great results, so I'm not new to designing something that works and offering it to people. I'll post pictures as I make progress. Currently dealing with a child who has a fatal heart defect so this may take a few months, but this is something I'm seriously designing right now to go along with the super 8.8 rear irs conversion I'm developing... The idea is to have a balanced braking system off a 2015 mustang complete, front and rear, no mismatch.
  22. Video of the sloppy flare install and me driving it on some back country roads and getting after it. Some donuts and mild drifting. Almost done with the 4 speed install and I installed a cheesy phantom grip lsd. Hoping it works better than the open diff did. Very excited about my stacked dual exhaust. It's 2.5 inch dual with x pipe the whole way, but routed to exit at the same spot. Looking forward to fixing all the rust, but priority is getting it on the road and earning it's own keep. BTW I will be putting together an end all, be all ultimate 8.8 irs set in this. I'm just tired of just a 930 cv conversion being close to 2,500.... What I'm trying to do is keep it under 2k with 800 hp axles and disc brakes and 8.8 and everything. Seems like people expect us Z owners to just bend over when it comes to parts. I mean 800 just for stub axles? And then another 600 just for the companion flanges? Sorry guys, not for me.
  23. Well. It's registered, and actually runs and drives and so on. Still a rotten pile of junk, but I'm hoping to race it in January in Arizona at the ziptie drags. Gotta buy acres of sheetmetal so it doesn't fold in half.
