cgsheen
    9
Everything posted by cgsheen
  1. There's an "FAQ" on "turbo alternator upgrade" or just "alternator upgrade". Take a look at that. (swapping an L28ET and using it's alternator in your otherwise stock 280Z, is the same as doing an alternator upgrade on your L28E...) Yup. In the 280ZXT, the ECU controls the fuel pump through the fuel pump relay. You need to understand how your stock fuel pump relay is "switched on" so you can change it to be controlled by your new ECU. As for the coil/ignitor: The Blue wire goes to the Tach through the resistor under the dash. Mine was behind the glove box. The resistor is big and square-ish and sticks out of the harness with 2 wires attached. The Yellow/White goes to the ECU through one of those white connectors near the end of the ECU (ECCS) harness. Important, because that's what tells the ignitor to fire. The Black/White ties to a Black/White on the ignition switch. Also important. In the 280ZXT, Power for the injectors and ECU is supplied from the battery, through that black box with the fusable links, to both a brown and a green wire ("connector #1" in the wiring diagrams). that run accross the firewall and into the ECU harness. I'll try to find the wiring diagrams you need most and post them... It's true this type of post is not meant for this particular Forum - should be just about turbochargers themselves or related to turbochargers... People make mistakes - the Admins will move it or kill it if it needs to be done. We'll start again in a more appropriate place if we have to. If an Admin (or established member) scolds you, simply apologize and be more careful in the future. (Don't know how much experience you have with Forums, sometimes it's best "not to feed the trolls"...)
  2. These are pics of how the coil sits in an '81 280ZXT. The harness runs through the fender back to the left side cabin on the 280ZX. The Stock ECU mounts under the dash beside your left foot. That 3-wire connector in your ign harness picture above is a connector for the Boost Sensor. Here's how I ran the wiring in my 260: You can also kind of see how I mounted the AFM... Yup, it's upside down in my car. We mounted the AFM in my son's '76 280 mostly rightside up - it's harder to fit. We did his 4 years ago, mine 2 years ago. Doesn't seem to make enough difference to care... Here's an early shot of how the coil and AFM went in my 260 swap: Don't let this deter you, I changed a LOT of the wiring in my car while I was doing the swap. My 260 was never set up for EFI, and I knew I'd be using the 280ZXT Alternator. I eliminated my external voltage regulator and the shunt that drives the ammeter guage during the re-wire and installed a volt meter. Plus I eliminated the original coil wiring since I used the harness from the donor... I used a LOT of the wiring from my '81 280ZXT donor car - including the Fusable Link box:
  3. You didn't say what you're swapping this L28ET into - or did I miss that... (doesn't make a lot of difference but it helps a bit if it's a 280 that was already set up for EFI) Do you have the FSM (Factory Service Manual) for your car? Do you have the FSM for a 280ZX? (including the turbo supplement if necessary) If you don't, get them from Xenon's site (search) or from carfiche.com... The coil wiring is fairly simple and the ignitor (transistor ignition) is completely controlled by the ECU. For the coil, there's only a few wires that connect to the ignition circuit and the ECU, plus one wire that drives the Tach. They're pretty clear in the FSM and should also be shown on the famous "turbo swap diagram" that's in the FAQ's section of HybridZ. You're using a stock ECU? What year is your ECU? '81 or '82/'83? I'll post some pics and we can get to "what wire connects to what" in a bit...
  4. It's already well over 100 here in Phoenix... When my stock blower died a few weeks back, I used a blower from a 1999 Kia SUV (I think it was a "Sportage" - I also think they only make one...) It's about the same dimensions as the Honda blower, but the cage is a little wider and it has more fins. It spins the right direction, and the electrical connector is a direct plugin - polarity is correct. The mounting holes are just a wee bit off, but it's mounting plate is plastic so it was easy to "oval out" the holes to make them line up perfectly with the nuts in the blower box. The squirrel cage is slightly too big for the hole in the blower box. You have to pull the blower box out and cut the hole a little bigger. A pair of "right" and "left" cut avaition snips made easy work of it. I wanted to keep the mounting nuts as-is on the blower box, so I put the new squirrel cage close to two of the nuts and drew a circle with a sharpie. That left one of the nuts on the inside of the circle. I just cut a straight line on the inside if that nut and followed the circle I drew around the rest of the box. Then I just had to tilt the blower into the hole and I used all the original mounting nuts to secure it. That also means that I (or someone else) could re-install a stock fan if I ever wanted too. (Actually, I won't - I LOVE my A/C! And I want it to blow as hard as it can...) You have to mount the fan in the box and then reinstall the blower box - won't work to do them seperately... The Kia blower moves quite a bit more air than the factory blower. The ductwork design is pretty terrible though and even a fantastic blower is only going to do so much... Oh, mine's a 260, but my blower box, motor, and fan were exactly the same as my son's '76 280.
  5. Superduner, be sure to tell whoever comes to help that all you have is the L28ET and the ECCS harness and ECU. They're going to need to be able to wire the coil and ignitor (your 240Z coil and transistor ignition stuff won't work and you don't have the 280ZXT coil / headlamp washer harness) They're going to need to wire the main power to the ECCS System, provide fusable links or something equivalent, wire and possibly provide EFI and fuel pump relays. (Do you have an electric fuel pump?) They'll need to figure out the Alternator / Charging system and modify as necessary. Plus they'll either have to know about your #2 and #3 main harness connectors (since the wiring doesn't match the circuit diagram) or they'll have to trace that wiring out to get it connected properly... It may take more than a day. I wouldn't mind leaving Phoenix for San Diego this time of year, but it'd cost you way to much to get me there - sigh...
  6. http://xenons130.com/reference.html Too bad you gave up the 280zx donor. There's a LOT you could have learned about how your engine interfaces with the rest of the car... Understanding that, it would be easier to convert your early Z car to accept the new engine. (I took all the wiring from my donor that had ANY connection to the engine (starting at the battery), it's accessories, the ECU, coil and ignitor, relays... - not just the ECCS harness.) There are so many differences between the 280ZXT and a 240: - Alternator and it's wiring - Voltage regulation (280zx = internal to the alternator, 240 = external (with a shunt to run the ammeter)) - Coil and ignitor (the ZXT ignitor is controlled solely by the ECU) - Electrical power, fusable links, and relays I chose to abandon certain things on my early 260 and substitute the 280ZXT parts and wiring. But, enough of the lecture... I can't help you with the individual wires in your connectors - mine are all exactly as the wiring diagram (and the '83 wiring diagram on xenon's site shows those connectors exactly the same as the '82 wiring diagram) - my son's harness is also exactly the same... You actually only need 4 or 5 or 6 of the wires in those 2 connectors (less than that to actually fire the engine), look at the swap diagram to see which functions you need, trace the wire from it's source to where it ends up in the connector, mark it, and wire it up accordingly. Good luck...
  7. On the stock L28ET the oil feed line comes off a tee installed between the block and the oil pressure sender... Then there's a hard line back toward the firewall, around the back of the engine, to the turbo.
  8. You need to do some additional searching... In the FAQ's (and several other places) there's a diagram of how to wire up those 3 connectors. Plug #1 IS 2 wires (one brown, one green), both connected to the +12V side of the battery THROUGH seperate Fusable Links. A 280ZX is wired through several fusable links. I used my donor cars fusable link box and connected the circuits that applied to the swap. Unfortunately I don't think there are "AMP values" applied to the fusable links. Read the turbo swap guide, maybe someone has used fuses rather than fusable links...
  9. The wiring you're holding is: - AFM plug - AFM Ground wire - The 2 two-wire plugs go to the VCM The wire bundle to the coil and ignitor are completely seperate from the ECCS harness (EFI/ECU harness) on a stock 280zxt. There's a different harness that goes from the cockpit up through the left side fender to the 280zx coil location. Pull the wiring from a 280ZX donor or re-create the wiring - it's a simple bundle...
  10. Don't get it... If you have 2 parts cars, both with factory A/C, why aren't you just removing a complete A/C system from one and installing it in your Z? (or using the best parts from each to equal a complete system...) Stock system converts well to R134a.
  11. Well, the picture you've taken is of a finisher strip that sits atop the weatherstrip and carpet. That's not what you should really be worried about... It's what's under that, under the carpet, under the body... Pull the carpet and padding up and check the floor pans. Check the bottoms of the doors, dogleg, spare tire cavity, frame rails and sheet metal underneath the car.
  12. If you leave it for a year in primer, you'll probably have to take it down again and re-prime before you topcoat (more than just a scuffing)... Primer - even the good stuff can soak up a lot of crud (contaminants, oils, chemicals, all kinds of crap) that may adversely affect how your topcoat goes on and how well it sticks over it's lifespan. Better to be safe than sorry...
  13. I'm also kind of interested since my sons know a designer/fabricator here in Phoenix that has expressed interest in designing a manifold for L28ET's. (He used to work at Full Race as one of their lead designer/fabricators) My youngest son and I (both with turbo swaps running) keep telling my oldest son that there's no reason to have him build us a manifold (which he would probably do for cost of material) because our stock manifold will handle the horsepower we plan to run. He says there are other benefits beyond horsepower and we're NUTS not to let this guy build us a manifold - but I don't really understand them. Are there other benefits like how and when the turbo spools? Are we crazy for not having this guy fab us up a manifold for what is likely to be very cheap? Or will it mostly be "all show - no real go"? We're probably never going to build our Z's past 300 horsepower or so...
  14. I also highly recommend the FSM. The L28ET (itself) doesn't "need" either of those wires... One (thermotime) helps prevent vaporlock (in a stock 280ZXT) - I think - if the engine is too hot. The other lets you know in the cockpit what the coolant temperature is. The stock EFI system (actually, ECCS system) doesn't use either of them to operate. The wiring to them is in the ECU harness for convienence, not because the ECU uses them...
  15. No, one is for the temperature gauge and the other is for the thermotime switch. The thermotime switch is part of the injector fan assembly that comes on a stock L28ET (that's the "hair dryer" that hangs on the plug side of the engine and has plastic duct that wraps over the valve cover to blow air on the injectors). The system only comes into play when you shut off the engine, and then only if the thermotime switch "senses" water temperature over a certain value... So, If the engine is real hot, the blower runs for a while to cool the injectors (or the fuel in the injectors and piping near them). I don't imagine you'll be using it...
  16. Crap, I'd have to walk all the way out to the garage, open the hatch, lift up the carpet and spare tire cover, go back into the house because I forgot the camera... Give me a few, I'll see if I can get a pic... This is from an early 260, but I think it's exactly the same as a 240. Exciting, huh? The stock hub cap covers pretty much all of that.
  17. My Son just installed a pair of those on his '76 280... Worked perfectly. No wind noise in his car now. I need some for my 260.
  18. That's not a stock A/C system is it? Never-the-less, that's the thermostat. The little capillary tube "senses" the air temperature and the thermostat is a switch that cycles the compressor on and off to maintain a certain temp... SO - following the flow of electricity to the compressor: Your A/C ON switch starts the power supply it is then routed to the thermostat so temperature can be controlled and from there to the compressor or it's relay. BUT, there may be other "safety switches" also in line... Original factory A/C systems also have a "high pressure" switch built into the receiver/dryer that kill power to the compressor if the refrigerant pressure is too high. (Some A/C systems also have a "Low Pressure" switch that will keep the compressor off it there's not enough refrigerant in the system) All of these switches usually run in series along the wiring to the compressor so that any of them can cut power to the compressor.
  19. I recently killed the "squirrel cage" in my 260 and since it's already hot here in Phoenix, I wanted my A/C blowing again PRONTO! I also hoped I would find a newer motor/fan that would move more air than my original! I ran to the local pull-a-part looking for a Honda blower. Our fans spin counter-clockwise as you look at them from the passenger seat (clockwise from the shaft side - which is how all fans are rated - but that's "backwards" to how you're normally looking at a fan under the dash. You're usually looking at it's butt-end and have to turn it around in your mind...). Virtually no one uses a fan that spins clockwise anymore... It's not the motor, you can make the motor spin either direction. It's how the squirrel cage is built. I pulled a Honda blower then spent nearly an hour looking to see if I could find something else. Virtually everyone else but Honda uses a blower that spins the wrong direction - even Nissan... Finally I happened upon a 1999 Kia Sportage: It's blower spun the right direction, 3-bolt pattern, same size as the Honda blower in every respect except the squirrel cage is slightly wider. I took it up to the counter and went out to the lot to get my original blower out of the Z. Confirmed that the bolt pattern looked close, and that the squirrel cage WAS larger in diameter, but about the same width as the 260Z unit. For 10 bucks, I took it... It's NOT a direct bolt-in fit! But modifications were actually slight: - I had to enlarge the hole in my blower housing a little to get the newer squirrel cage in. (but, I've been using aircraft snips for 25+ years so cutting round holes in sheet metal is not a big deal) I was able to leave the original mounting nuts in place. - The mounting holes were off ever so slightly. The "mounting plate" of the Kia blower is plastic so it was easy to elongate each of the holes so the mounting screws would fit properly. Probably about an eighth inch (1/8th in.) per hole... - Like many newer blower motors, it has a "vent" or "cooling" tube built into the housing (to circulate air around the motor?) - I drilled a hole in the blower housing to provide air to this tube... Fitment of the cage in the 260Z blower housing is good - it fills the housing nicely but isn't close enough for anything to rub. The electrical connector is a direct fit into the Kia blower AND polarity is correct! Wiring consisted of pushing the 260Z connector into the side of the Kia motor. It has more vanes on the cage and I feel like it moves quite a bit more air. I don't have anything to actually measure that though... It's nice to have another option (or to know that the Honda blower will also work in 260's/280's with a little massaging, as it's nearly identical to this Kia blower). I also think it's cool that I (or the next owner of this Z) can still revert back to the stock blower...
  20. No, most of the oil accumulates in the compressor itself and the accumulator (receiver/dryer). The oil in the rest of the system generally isn't enough to be concerned about. Get as much oil out of the compressor as you can and replace it with a like amount of R-134a compatible oil. They always suggest that you replace the accumulator with a new one - I didn't on my Z, but it's a very good idea. That's the main filter (and "dryer") for the system, so it protects everything else. They make a conversion product that has a small amount of oil, acid neutralizers, conditioners, plus a small charge of R-134a to carry all that stuff into the system. It's a good idea to use it on a older system that you're converting. You use slightly less R-134a than the system specified charge of R-12. I never charge by specific amounts though, I go by pressures and performance. If you have leaks, find and fix them. Vacuum down the system, -30psi for 30 minutes, to remove as many condensables as can be removed. I'm overly careful about NOT introducing any "air" back into the system when I'm charging, so I bleed my gauge set and hoses before (while) attaching them. Just let a whisper of refrigerant escape through the hose(s) while you're connecting them. You'll get better results the first time out if you charge when everything is nice and WARM... If it's 90-100 here (remember, no humidity here... It's a DRY heat!) I shoot for center vent temps in the mid-to-low 20's with a suction side pressure in the low 20's psi. Suction side pressure will start out much higher, and fall into place when the refrigerant level / performance gets near the "sweet spot"...
  21. I used the 280ZX radiator from my donor car in my "early" 260... It works alright for being free. If I were to spend money on a radiator, I'd get one built for the 240/early 260 frame. The ZX radiator is "taller". When it's mounted properly for hood clearance, it hangs down below the radiator frame support exposing the lower tank to rocks and debris and puts the bottom 3 (or more) inches of fins behind sheet metal. Still, it's worked fine with my turbo swap and I've never had a cooling problem (Phoenix, AZ so that says something). My son's '76 280 has a different lower cross member for the radiator support than our early model Z's. They "bowed" the lower member down on the 280's. His Z takes a ZX radiator without it hanging down below the radiator support...
  22. 40 degree air??? I converted my stock system to R-134a when I completed the turbo swap. I'd be dying if it only blew 40 here in Phoenix! I get temps in the low 20's (F)... (I've actually measured it as low as 9 degrees - my son's '76 280 blew 5 degrees after we converted it from R-12 to 134a...) It's hotter than 90 here but we don't have any humidity. I have no problem with using R-12 if that floats your boat (best refrigerant they ever made for these things), but you can make R-134a work just fine. 2 cans cost me about 20 bucks - no reason for me to fuss with R-12... Condenser runs hotter, but we close up the gaps around it and the radiator to get the best air-flow through them that we can. Nissan has always used a good sized condenser - I've never had any problems converting Z's, 240SX's, and etc... Mine has never overheated the cooling system, even when it's 115+ here in Arizona.
  23. I got my harness and ECU from an '81 Turbo car I bought in San Diego and limped home to Phoenix... Must be kind of a common leak point - right above the ECU. My harness connectors and the pins of the ECU were badly oxidized. It took me a LONG time and multiple cleanings to get rid of the electrical problems caused by poor connections at the ECU. BTW - I did much the same thing, except I could reach the wires and connectors to my ECU. When my car would start running like crap, I'd reach down and wiggle the wires around until it straightened up... Finally got SO sick of doing it that I finally: 1 - pulled the ECU cleaned all of it's connector pins to a stupid degree 2 - pulled every wire OUT of each of the 3 connectors one-by-one a. cleaned and adjusted the connector on the end of the wire b. soldered the crimp connection between wire and metal connector I haven't had any problems since I did that...
  24. Don't know much of anything about MS, but I can say that the only major difference between the '81 L28ET and the later year engines is the crank angle sensor. On the '81 it's external - there's a trigger wheel bolted to the crank pulleys and a sensor near the A/C compressor - as I'm sure you've seen. On the '82-'83 it's built into the distributor. If MS doesn't use the stock CAS, shouldn't matter a bit... (even if it does, the CAS signal must be the same from either unit... I use a stock '81 harness and ECU on my '83 engine) (The '81 also uses a "package" of dropping resistors for the injectors that is external to the ECU, but that too doesn't matter a bit if you're not using a stock harness and/or ECU...) Otherwise, all the L28ET's pretty much "same same" as far as the electronics go.
