Exposed
    10
Everything posted by Exposed
  1. Yup I've definitely learned a lot with all the input from the community. Hopefully with all the mistakes I make and post no one will make the same ones.
  2. one option depending on the application is to use white lithum grease for any two different metals touching.
  3. fingers crossed I don't get a bad solenoid or I havent hooked it up incorrectly. I have my wide band, and oil pressure gauges hooked up just need to tidy up the set up and mount them properly. I was thinking of redoing my electrical panel and building a cover just to tidy everything up and make it look better. Anyone ever use or see someone use MDF for this? Bouncing back and forth between aluminum and mdf at the moment.
  4. Started it up today! cant wait for the snow to disappear.
  5. I ended up switching the gasket on the mishimoto thermostat and its fixed my leaking issue for the time being. For anyone thinking of using a mishimoto thermostat check your gasket height. I bought a different gasket from the local parts source, its a "Fel-Pro" gasket and the part number is "16325-62010". Mishimoto thermostat with Mishimoto gasket Mishimoto thermostat with Fel-Pro gasket
  6. Thanks! I do abit of CAD sketchs for a couple firms occasionally so I get a bit of practice. Noticed I forgot to toss up a picture of the catch can mod a couple posts ago. Doesn't look to great but does the job.
  7. Ya was thinking of swapping out the bolt, measured it out and its an M8 x 1.25. Assuming it has a bit of lock tight on it. heres a rough idea of the height differences in the gasket.
  8. Thanks, thats good to know, I'll need to verify the part number for the thermostat I used. Hopefully that's what the problem is.
  9. I'll be sure to take you up on that offer, any specific file type it should be converted too?
  10. is your printer able to handle ABS material? I would be interested in seeing how an ABS performs in the field. Been jumping between the idea of getting a 3d printer just havent found the one yet.
  11. I figured this was the weekend I'd start up the Z but had a bit of a hiccup when filling my fluids. The issue right now is the water neck outlet is leaking where it mates to the waterpump? When I took the water neck outlet off of the engine there wasn't any gaskets so I didn't add any when I put it back together the first time. I filled it up with rad fluid and saw nothing dripping, so I bolted the manifold back up. I went for a quick bite to eat and when I got back I noticed there was a slow drip so I drained the system and unbolted everything, I took the water neck outlet off and put some gasket marker on it thinking it would fix the issue. It cured overnight and I filled everything back up once again...no leaks. I then bolted the manifold on and noticed another slow leak after about a half hour. Having almost no patience left I jacked the car up and the only thing I'm seeing that might be an issue is the manifold touching a bolt. Does anything think when the manifold is tightened its pushing against the bolt causing the water neck outlet to not sit flush with the mating surface? Not sure if this might cause an issue but I also switched the stock thermostat for a mishimoto thermostat. The mishimoto thermostat seems to sit low inside of the aluminum housing, will post a rough sketch to better explain myself.
  12. great job on the hand brake. Did you end up out sourcing the 3d printing? What type of plastic was used? I'll be honest I'm a bit jealous of the no snow on the ground...
  13. I typically only have time to work on the car after work on weekends so progress is extremely slow. I managed to weld in some -10an bungs onto the valve covers, modified the catch can and switched out the stock oil level sender for an aem oil pressure sensor. For anyone looking to do that the thread is 1/8" bspt, and the aem sensor comes as a 1/8" npt. A part number for an adapter is "EAR-968698ERL" and thats off of summit racing. Managed to finish my headlights, extremely happy with how they came out, I'll be able to see at night!
  14. @seattlejester just tried a 1/8"NPT, it started to strip the thread, will take a picture and post it. Called a BW dealer to see what the thread pitch is just waiting on a call back. I put a 1/8" npt fitting incase I needed to widen the hole. I ended up putting a 1" dia. tube inside the catch can to help draw air from the inside, also put course stainless steel wool inside. The plug at the bottom will be replaced with a hose so I can drain it easily from under the car. Thanks @Greeko I'm still a rookie though, I see it as worst case scenario I have scrap aluminum and wasted some cash. The best thing is I practice tig welding.
  15. appreciate all the info guys, ended up just getting an air filter this weekend and tossed something together to get it on. Also finished my intercooler piping and catch can. Can't wait to get this on the road. Been reading up trying to find out what size fitting going on the front on the turbo, had read it was 1/8"npt, some say M10x1.0, anyone happen to know?
  16. some great info above, thanks Geno I haven't seen anything like that before. It's definitely something worth looking into.
  17. Thanks for the info guys. Saw a couple of the pictures above but was planning on running a turbo guard filter. I might just drill the existing hole in the turbo housing and use that for the catch can, waste gate and boost controller. Will read up on it a bit more.
  18. silly question but would either of these work? I've normally see it run to where the air filter would go but I was thinking of running a turbo-guard filter.
  19. @seattlejester I was thinking about leaving it like that but I think I'm going to do a custom oil catch can and just run some -8an lines. Was thinking of fabbing up a catch can in the space between the battery and the passenger strut tower. I'll put that filter on the catch after. Already made my cardboard template. Whats your opinion on leaving just the filter? @Greeko lol 10 months of winter, sadly its true. and yes the TTT strut does clear the engine.
  20. started the down pipe this weekend and tacked everything together for the time being. First time using pie cuts, dont think it came out to bad. A lot of welding to do though.
  21. glad I'm not the only one who stopped at a home hardware store.
  22. Little update, received the manifold after welding was finished and also received some misc. things. Used a vibrant fitting from the engine to the oil inlet on the turbo, part No. listed incase anyone is curious bolt size that buttons up to the engine is M12x 1.25. oil drain flange looks to be well made and comes with an O-ring. Have a couple options for the oil inlet on the turbo, was thinking of using the flange. What does everyone recommend left or right? Oil drain is installed and looks to be about 1/2" away from the manifold. Should I be concerned about heat? Vibrant says there hoses there hoses are "capable of handling operating temperatures ranging from -40 deg F to 300 deg F and elevated operating pressure of 500psi."
  23. setup looks amazing. what type of flares are you using?
