15
Everything posted by Exposed
finished up the passenger side end tank and also finished the upper radiator hose connection. I 3d printed a couple dies for my bead roller and put a bead on a piece of 1.5" dia. tube, tube was cut from 90.
Yes I crossed over while in the trans tunnel, will probably do the same thing when I get to that point. Currently have the entire setup done with soft lines and brackets.
i ran my lines near the top of the trans tunnel then routed them to the "cold" side of the engine. When I redo them again Ill probably build a heat sheild with a bulkhead connector
Looking good 👍
finally found some time to begin working on one of the intercooler end tanks, mocked it up in CAD before starting, then got to work.
Need wiring help - 2JZ GTE direct ignition coil packs on GE
Exposed replied to M_Dragan's topic in Toyota L6 Forum
might be different for the 2jz but on my 1jz I still had my soarer igniter when I swapped coils. Everything worked well while I had the stock ECU. Everything remained the same once I swapped out the ecu for an AEM infinity. Hopefully someone with more knowledge is able to chime in. -
any build pictures? Looks like a good looking car.
@Zetsaz yup, that's awesome
I'm really happy with the way my current build is going, don't think I have a "dream build" though. Everything I've wanted to do I've began or started to brain storm ways to achieve it, the down side to this is the Z is NEVER going to be finished. I guess I just like trying new things and I enjoy seeing a genuine reaction on someones face when they see the car. After this one is "done" i think I'm going to be looking for a Cummins engine out of a dodge ram and possibly tinker with the Idea of AWD. Always thought it would be cool to see a stock looking Z ripping around with a turbo diesel.
@HuD 91gt it felt like a life time. Hoping to find some time this weekend to plug away on the end tanks.
lol I think it took me 4 hours, that includes farting around on some other stuff. Ended up cutting off the end tanks on the intercooler and started my cardboard template.
Ended up making a brace to the block that's able to support the weight of the turbo, fingers crossed it doesn't crack on me. Will also be modifying the water neck outlet to pass below the waste gate.
great looking car, post a break down!
Haven't had to much time to plug away with work being as busy as it is and wrapping up home renovations. On the fence about mounting the turbo and snipping the hood or mounting the turbo lower and leaving the hood as is. I ended up moving the alternator over just incase I want to bring the turbo lower. Next step, modify the lower waterneck outlet and bring it as close to the block as possible. For the guys who upgraded to a single turbo has anyone braced the turbo back to the block or frame of the car?
I used the stock one from a 350z, havent had an issue with it.
I ended up putting the engine in today. Good news is it clears it by half an inch!
@softopz havent tried to put it in the engine bay yet, going to test it this weekend hopefully. Fingers crossed I dont have clearance issues, im not running CX mounts. he's a pic of how the car sits as of monday. Worst case I cut the car apart again and sell it to the scrap yard.....
im everywhere with this project really need to focus on one thing. Back from the powder coater, heres a little teaser!
printed off some of tubes to do my mock up. The plan is to try and shorten up the tubing as much as possible to try to keep all the tubes even. Also welded in the patch panel
@seattlejester I considered just moving it and rewelding it but the shop that did my tuning suggested running a ford iac. After I put the sandwich plate on the oil filter it gave me enough room though so I'll probably just run it like that until it stops working. @Geno750 thanks for the input, great to know its doable. Would you say its worth doing the swap? Looks like it could get costly....then again everything we do to our cars seems to cost an arm and a leg.
and last but not least I made two more patch panels. They didnt turn out the best but it looks good enough for me.
Water pump was swapped out for one of the ones from Driftmotion. One thing that I cannot seem to find an answer to is why is it that the 1jz/ 2jz water pumps are interchangeable but the 1jz/ 2jz waterneck outlet isnt? Am I missing something? I switched out the stock oil cooler for an aftermarket sandwich plate and got that installed. Going to run some -10an lines to the new oil cooler. Fittings on the cooler are -10an x M22 to a 60 degree -10an to hose.
once again thanks to @seattlejester for grabbing me that manifold flange. Shortly after receiving it I started working on 3d printed manifold tubes, similar to whats already being sold. Just need to prints out some 45 and 90 degree pieces. I had purchased an intake plenum about a year back when Otaku Garage first started producing them, assuming they were testing waters at the time because the price of them now is abit higher. With the engine still out of the Z I finally got around to installing it. Fingers crossed that it has good results on the dyno. One thing I dislike right off the bat is the location of the IACV, it comes in contact with the stock oil cool/ filter. From speaking to the guys at Otaku they've since revised its location so its no longer in the way of the stock oil cooler/ filter location. The throttle body the comes with the plenum is a 90mm, I ended up putting a Vibrant HD clamp on the end of it.
